  4. [gelöst] Nach Upgrade/Update kein Webserver nicht mehr
    5.5k
61 Beiträge 4 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • jmeister79J jmeister79
    @thomas-braun jetzt gehen die updates dauern aber extreeeem lange
    @jmeister79
    Geh 'nen Kaffee trinken während das läuft.
    jmeister79J 2 Antworten Letzte Antwort
      @jmeister79
      jmeister79J Offline
      jmeister79J Offline
      jmeister79
      @thomas-braun :-D
        @jmeister79
        jmeister79J Offline
        jmeister79J Offline
        jmeister79
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated crypto@1.0.1: This package is no longer supported. It's now a built-in Node module. If you've depended on crypto, you should switch to the one that's built-in.
        npm WARN deprecated @types/bl@5.1.0: This is a stub types definition. bl provides its own type definitions, so you do not need this installed.
        npm WARN deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated uuid@3.3.2: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated xmldom@0.1.16: Deprecated due to CVE-2021-21366 resolved in 0.5.0
        was sind das alles für warnungen?
          @jmeister79 sagte in Nach Upgrade/Update kein Webserver nicht mehr:
          Das sind keine 'Warnungen' sondern 'Hinweise'. Kannst du ignorieren, ist für die Modul-Maintainer interessant.
          jmeister79J 1 Antwort Letzte Antwort
            jmeister79J Offline
            jmeister79J Offline
            jmeister79
            @thomas-braun yo danke. fahre das normalerweise ohne debugmode. gut ich verschließe die Augen!
              @jmeister79
              In deinem Skript hast du die nie gesehen, weil du da ja alles blind abnickst.
              Und genau deswegen würde ich das nie so machen.
                @jmeister79
                jmeister79J Offline
                jmeister79J Offline
                jmeister79
                @thomas-braun Danke für deine Hilfe, ich konnte jetzt alle Updates fahren, allerdigns hat jedes einzelne Update bis zu 45 min gedauert.
                Nach dem jeweiligen Systemcall passierte immer ne Ewigkeit nichts und dann kamen die ganzen Nachrichten mit depricated usw.
                Im Top hat man gesehen, dass mein RAM bis auf 200/300 MB ausgelastet war (4GB Raspi 4).
                Habt Ihr da Erfahrung wo die Ursache dafür liegen kann? Hat der Updater Probleme mit meinen Ordner Rechten?
                Bisher lief das nie so lange
                Gibt es da evtl. eine Möglichkeit die Installation nachhaltig zu fixen?
                Ich würde ungerne alles neu aufsetzen, da bei dem Image noch so n paar kleine Helferlein neben her laufen, die ich mit Hängen und Würgen in gang bekommen hab und bei denen ich froh bin, dass sie laufen wegduck
                Beste Grüße
                Nils
                Thomas BraunT CodierknechtC 3 Antworten Letzte Antwort
                  Beste Grüße
                  Nils
                  @jmeister79
                  iob diag
                  sagt in der Langfassung?
                    Beste Grüße
                    Nils
                    @jmeister79
                    Und was soll
                    besagen? Das hört sich nach planlosem Herumgewürge an.
                      Beste Grüße
                      Nils
                      CodierknechtC Online
                      Codierknecht
                      Im Zusammenhang mit
                      ... da führt wohl eins zum anderen.
                      Meine Glaskugel sagt mir, dass da z.B. noch Influx und what auch ever auf dem Raspi laufen.
                      Da wird's dann mit 4 GB schon mal eng.
                      HmIP|ZigBee|Tasmota|Unifi
                      Zabbix Certified Specialist
                      • CodierknechtC Codierknecht
                        Im Zusammenhang mit
                        jmeister79J Offline
                        jmeister79J Offline
                        jmeister79
                        @codierknecht Es läuft ein SFTP auf den 3 Kameras ihre Snapshots ablegen, LCD Ansteuerung und ein Sender für 433 MHz.
                        Bis auf den FTP finde ich das unkritisch. Ich hatte es vorher über die Surveillance Station laufen, aber das ist ein Stromfresser wenn der Server nicht in den Standby geht.
                        Ich nutze den lokalen FTP, da er sonst ständig auf einen anderen Server schauen muss ob neue Bilder da sind und mit den Mounts und der Bootreihenfolge war das immer eine Qual.
                        Ich bin sehr dankbar für die Software (Adapter, ioBroker usw) und dass dieses Setup seit vier Jahren seinen Dienst tut.
                          @jmeister79
                          iob diag
                          • jmeister79J Offline
                            jmeister79J Offline
                            jmeister79
                            Wäre es denn besser evtl. mehrere Raspi zu verwenden mit mehreren ioBroker Instanzen?
                            zb einer der sich nur um Kameras und Datenerfassung kümmert und einer der das reine Schicki Micki Smarthome macht (Licht, Automation usw).
                            Zu meiner Verteidigung möchte ich noch sagen, dass das ganze mit 4 Fritzsteckern angefangen hat mit denen ich überwachen wollte wie oft meine Tauchpumpen im Keller laufen. Ich hab das ja alles nicht gewollt. 🚪
                            Und über die Jahre wurde es immer mehr und hat mich total in den Bann gezogen.
                            Von vonre angefangen würde ich einiges sicherlich anders aufziehen. Nur fehlt dazu leider grad die Zeit :-(
                            @Thomas-Braun : ich schau nachher mal, bin gerade im VPN am Arbeitsrechner.
                              @jmeister79
                              iob diag
                              jmeister79J Offline
                              jmeister79J Offline
                              jmeister79
                              npm ERR! code ELSPROBLEMS
                              npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                              npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                              npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                              npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                              npm ERR! invalid: iobroker.icons-open-icon-library-png@0.1.3 /opt/iobroker/node_modules/iobroker.icons-open-icon-library-png
                              npm ERR! invalid: iobroker.km200@2.0.3 /opt/iobroker/node_modules/iobroker.km200
                              npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
                              npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
                              npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                              npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                              npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                              npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
                              npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                              npm ERR!     /home/pi/.npm/_logs/2023-03-21T07_46_23_247Z-debug-0.log
                              Adapters from github:   2
                              npm und nodejs wollte ich ja eigentlich updaten, soweit bin ich noch nicht gekommen seit gestern.
                              Liegt da evtl das Problem?
                              Skript v.2023-01-02
                              *** BASE SYSTEM ***
                              Model           : Raspberry Pi 4 Model B Rev 1.2
                              Architecture:   aarch64
                              Docker:         false
                              Virtualization: none
                              Distributor ID: Raspbian
                              Description:    Raspbian GNU/Linux 11 (bullseye)
                              Release:        11
                              Codename:       bullseye
                              PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                              NAME="Raspbian GNU/Linux"
                              VERSION_ID="11"
                              VERSION="11 (bullseye)"
                              VERSION_CODENAME=bullseye
                              ID=raspbian
                              ID_LIKE=debian
                              HOME_URL="http://www.raspbian.org/"
                              SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                              BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                              Systemuptime and Load:
                               08:46:02 up 15:00,  1 user,  load average: 0.60, 0.73, 0.69
                              CPU threads: 4
                              *** Time and Time Zones ***
                              Tue Mar 21 07:46:02 UTC 2023
                              Tue Mar 21 08:46:02 CET 2023
                              CET +0100
                              Europe/Berlin
                              *** User and Groups ***
                              pi
                              /home/pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                              *** X-Server-Setup ***
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              Boot Target:    multi-user.target
                              *** MEMORY ***
                              Mem:            3.8G        1.8G        316M        0.0K        1.7G        2.1G
                              Swap:            99M          0B         99M
                              Total:          3.9G        1.8G        416M
                                       3794 M total memory
                                       1777 M used memory
                                       1840 M active memory
                                       1126 M inactive memory
                                        316 M free memory
                                        540 M buffer memory
                                       1159 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              *** FILESYSTEM ***
                              /dev/root      ext4       59G   16G   41G  29% /
                              devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
                              tmpfs          tmpfs     759M  872K  759M   1% /run
                              /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
                              tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                              Messages in dmesg:
                              [Mon Mar 20 17:45:32 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:59:34:6E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                              [Mon Mar 20 17:45:33 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
                              [Mon Mar 20 17:45:33 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                              [Mon Mar 20 17:45:36 2023] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
                              TARGET  SOURCE         FSTYPE OPTIONS
                              /       /dev/mmcblk0p2 ext4   rw,noatime
                              `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                              /var:
                              2.7G    /var/
                              2.0G    /var/log/journal/d894d73ccc4e4e4ea197a2ff3874f9bf
                              2.0G    /var/log
                              453M    /var/cache
                              /opt/iobroker/backups:
                              4.0K    /opt/iobroker/backups/
                              /opt/iobroker/iobroker-data:
                              1.8G    /opt/iobroker/iobroker-data/
                              959M    /opt/iobroker/iobroker-data/history
                              575M    /opt/iobroker/iobroker-data/files
                              166M    /opt/iobroker/iobroker-data/backup-objects
                              78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                              41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                              33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                              23M     /opt/iobroker/iobroker-data/objects.jsonl
                              20M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.becd2d7c.js.map
                              19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                              *** NodeJS-Installation ***
                              /usr/bin/nodejs         v16.19.1
                              /usr/bin/node           v16.19.1
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
                              nodejs:
                                Installed: 16.19.1-deb-1nodesource1
                                Candidate: 16.19.1-deb-1nodesource1
                                Version table:
                               *** 16.19.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                   12.22.12~dfsg-1~deb11u3 500
                              *** ioBroker-Installation ***
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              Core adapters versions
                              js-controller:  4.0.24
                              admin:          6.3.7
                              javascript:     6.1.4
                              Adapter State
                              + system.adapter.admin.0                  : admin                 : iobrokerpi                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              + system.adapter.backitup.0               : backitup              : iobrokerpi                               -  enabled
                              + system.adapter.bestway.0                : bestway               : iobrokerpi                               -  enabled
                              + system.adapter.ble.0                    : ble                   : iobrokerpi                               -  enabled
                              + system.adapter.chromecast.0             : chromecast            : iobrokerpi                               -  enabled
                                system.adapter.devices.0                : devices               : iobrokerpi                               - disabled
                              + system.adapter.discovery.0              : discovery             : iobrokerpi                               -  enabled
                              + system.adapter.ems-esp.0                : ems-esp               : iobrokerpi                               -  enabled
                                system.adapter.flot.0                   : flot                  : iobrokerpi                               - disabled
                              + system.adapter.fritzdect.0              : fritzdect             : iobrokerpi                               -  enabled
                                system.adapter.habpanel.0               : habpanel              : iobrokerpi                               - disabled
                              + system.adapter.history.0                : history               : iobrokerpi                               -  enabled
                                system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobrokerpi                               - disabled
                                system.adapter.icons-icons8.0           : icons-icons8          : iobrokerpi                               - disabled
                                system.adapter.icons-material-png.0     : icons-material-png    : iobrokerpi                               - disabled
                                system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobrokerpi                               - disabled
                              + system.adapter.info.0                   : info                  : iobrokerpi                               -  enabled
                              + system.adapter.iot.0                    : iot                   : iobrokerpi                               -  enabled
                              + system.adapter.javascript.0             : javascript            : iobrokerpi                               -  enabled
                                system.adapter.material.0               : material              : iobrokerpi                               - disabled
                              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobrokerpi                               -  enabled, port: 54321
                                system.adapter.mobile.0                 : mobile                : iobrokerpi                               - disabled
                              + system.adapter.mqtt.0                   : mqtt                  : iobrokerpi                               -  enabled, port: 1883, bind: 0.0.0.0
                              + system.adapter.net-tools.0              : net-tools             : iobrokerpi                               -  enabled
                              + system.adapter.philips-tv.0             : philips-tv            : iobrokerpi                               -  enabled
                              + system.adapter.ping.0                   : ping                  : iobrokerpi                               -  enabled
                              + system.adapter.rpi2.0                   : rpi2                  : iobrokerpi                               -  enabled
                                system.adapter.sayit.0                  : sayit                 : iobrokerpi                               - disabled, port: 0
                                system.adapter.sayit.1                  : sayit                 : iobrokerpi                               - disabled, port: 0
                              + system.adapter.shelly.0                 : shelly                : iobrokerpi                               -  enabled, port: 1882, bind: 0.0.0.0
                                system.adapter.sql.0                    : sql                   : iobrokerpi                               - disabled
                                system.adapter.synology.0               : synology              : iobrokerpi                               - disabled, port: 5001
                              + system.adapter.telegram.0               : telegram              : iobrokerpi                               -  enabled, port: 8443, bind: 0.0.0.0
                              + system.adapter.text2command.0           : text2command          : iobrokerpi                               -  enabled
                              + system.adapter.tr-064.0                 : tr-064                : iobrokerpi                               -  enabled
                                system.adapter.vis-colorpicker.0        : vis-colorpicker       : iobrokerpi                               - disabled
                              + system.adapter.vis-inventwo.0           : vis-inventwo          : iobrokerpi                               -  enabled
                                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobrokerpi                               - disabled
                                system.adapter.vis-lcars.0              : vis-lcars             : iobrokerpi                               - disabled
                                system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobrokerpi                               - disabled
                                system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobrokerpi                               - disabled
                                system.adapter.vis.0                    : vis                   : iobrokerpi                               -  enabled
                              + system.adapter.web.0                    : web                   : iobrokerpi                               -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                              + system.adapter.ws.0                     : ws                    : iobrokerpi                               -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                              + system.adapter.zigbee.0                 : zigbee                : iobrokerpi                               -  enabled, port: /dev/ttyUSB0
                              + instance is alive
                              ioBroker-Repositories
                              online        : https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/sources-dist.json
                              sources       : conf/sources-dist.json
                              latest        : http://iobroker.live/repo/sources-dist-latest.json
                              km            : https://github.com/frankjoke/ioBroker.km200
                              Active repo(s): latest
                              Installed ioBroker-Instances
                              Used repository: latest
                              Adapter    "admin"        : 6.3.7    , installed 6.3.7
                              Adapter    "backitup"     : 2.6.12   , installed 2.6.12
                              Adapter    "bestway"      : 0.0.3    , installed 0.0.3
                              Adapter    "ble"          : 0.13.3   , installed 0.13.2 [Updatable]
                              Adapter    "chromecast"   : 3.0.3    , installed 3.0.3
                              Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                              Adapter    "devices"      : 1.1.2    , installed 1.1.2
                              Adapter    "ems-esp"      : 1.29.0   , installed 1.29.0
                              Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                              Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                              Adapter    "history"      : 2.2.4    , installed 2.2.4
                              Adapter    "iot"          : 1.14.5   , installed 1.14.5
                              Adapter    "javascript"   : 7.0.3    , installed 6.1.4  [Updatable]
                              Adapter    "km200"        : 2.0.3    , installed 2.0.3
                              Adapter    "material"     : 1.3.1    , installed 1.3.1
                              Adapter    "mihome-vacuum": 3.9.5    , installed 3.9.5
                              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                              Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                              Adapter    "philips-tv"   : 0.5.3    , installed 0.5.3
                              Adapter    "sayit"        : 1.12.6   , installed 1.12.6
                              Adapter    "shelly"       : 6.4.0    , installed 6.4.0
                              Adapter    "socketio"     : 6.3.5    , installed 6.3.5
                              Adapter    "synology"     : 2.1.13   , installed 2.1.13
                              Adapter    "telegram"     : 1.15.6   , installed 1.15.6
                              Adapter    "text2command" : 3.0.2    , installed 3.0.2
                              Adapter    "vis-hqwidgets": 1.3.1    , installed 1.3.1
                              Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                              Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                              Adapter    "web"          : 5.5.3    , installed 5.5.3
                              Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                              Adapter    "ws"           : 2.3.6    , installed 2.3.6
                              Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                              Objects and States
                              Objects:        6639
                              States:         5120
                              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                              Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                              Reading package lists...
                              Pending Updates: 0
                              *** Listening Ports ***
                              tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       146707     7921/io.mqtt.0
                              tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       146708     7921/io.mqtt.0
                              tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       146452     7790/iobroker.js-co
                              tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       146445     7790/iobroker.js-co
                              tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13989      544/sshd: /usr/sbin
                              tcp6       0      0 :::8081                 :::*                    LISTEN      1001       143242     7808/io.admin.0
                              tcp6       0      0 :::8082                 :::*                    LISTEN      1001       155126     9024/io.web.0
                              tcp6       0      0 :::8084                 :::*                    LISTEN      1001       157854     9017/io.ws.0
                              tcp6       0      0 :::21                   :::*                    LISTEN      110        15776      813/proftpd: (accep
                              tcp6       0      0 :::22                   :::*                    LISTEN      0          13991      544/sshd: /usr/sbin
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       143291     7876/io.chromecast.
                              udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14583      429/avahi-daemon: r
                              udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       146724     7980/io.shelly.0
                              udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14650      734/dhcpcd
                              udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       147481     7887/io.mihome-vacu
                              udp        0      0 0.0.0.0:51820           0.0.0.0:*                           0          14808      -
                              udp        0      0 0.0.0.0:50393           0.0.0.0:*                           108        14585      429/avahi-daemon: r
                              udp6       0      0 :::5353                 :::*                                108        14584      429/avahi-daemon: r
                              udp6       0      0 :::41417                :::*                                108        14586      429/avahi-daemon: r
                              udp6       0      0 :::546                  :::*                                0          12861      734/dhcpcd
                              udp6       0      0 :::51820                :::*                                0          14809      -
                              2023-03-21 08:45:29.284  - warn: chromecast.0 (7876) Google Homes - Client error: Error: connect ECONNREFUSED 192.168.178.49:32156
                                  at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1278:16)
                              2023-03-21 08:45:32.266  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:45:33.294  - warn: chromecast.0 (7876) Google Homes - Client error: Error: connect ECONNREFUSED 192.168.178.49:32156
                              2023-03-21 08:45:37.272  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:45:42.325  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:45:47.379  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:45:52.431  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:45:57.522  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:02.573  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:07.621  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:12.629  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:17.677  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:22.733  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:27.782  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:32.831  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:37.882  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:42.933  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:47.986  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:53.240  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:46:58.292  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:47:03.320  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              2023-03-21 08:47:06.721  - warn: fritzdect.0 (8123) State value to set for "fritzdect.0.DECT_087610265658.celsius" has value "7.5" less than min "8"
                              2023-03-21 08:47:08.370  - debug: philips-tv.0 (9231) The TV seems to be turned off
                              CodierknechtC Thomas BraunT 3 Antworten Letzte Antwort
                                Skript v.2023-01-02
                                *** BASE SYSTEM ***
                                Docker:         false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=raspbian
                                ID_LIKE=debian
                                CPU threads: 4
                                CET +0100
                                Europe/Berlin
                                pi
                                /home/pi
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Swap:            99M          0B         99M
                                         3794 M total memory
                                         1777 M used memory
                                          316 M free memory
                                          540 M buffer memory
                                         1159 M swap cache
                                           99 M total swap
                                            0 M used swap
                                           99 M free swap
                                *** FILESYSTEM ***
                                Messages in dmesg:
                                /var:
                                2.7G    /var/
                                2.0G    /var/log
                                453M    /var/cache
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.7
                                javascript:     6.1.4
                                Adapter State
                                + instance is alive
                                Objects and States
                                Objects:        6639
                                States:         5120
                                Pending Updates: 0
                                Codierknecht
                                Node 16.19.1 und NPM 8.19.3 sind die aktuell empfohlenen Versionen.
                                Da muss nix aktualisiert werden!
                                  Skript v.2023-01-02
                                  *** BASE SYSTEM ***
                                  Docker:         false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=raspbian
                                  ID_LIKE=debian
                                  CPU threads: 4
                                  CET +0100
                                  Europe/Berlin
                                  pi
                                  /home/pi
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M          0B         99M
                                           3794 M total memory
                                           1777 M used memory
                                            316 M free memory
                                            540 M buffer memory
                                           1159 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  Messages in dmesg:
                                  /var:
                                  2.7G    /var/
                                  2.0G    /var/log
                                  453M    /var/cache
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.7
                                  javascript:     6.1.4
                                  Adapter State
                                  + instance is alive
                                  Objects and States
                                  Objects:        6639
                                  States:         5120
                                  Pending Updates: 0
                                  Codierknecht
                                  @jmeister79
                                  Gibt es einen bestimmten Grund, warum Du da mit dem Beta-Repo unterwegs bist?
                                    jmeister79J Offline
                                    jmeister79
                                    @codierknecht Ich hatte seinerzeit Probleme mit dem Zigbee Adapter und deren Fix war nur in der Beta und ich brauchte schnell ne Lösung.
                                    Könnte ich mal wieder zurückstellen
                                      Codierknecht
                                      Mach das. Beta ist halt Beta und sollte nur aus gutem Grund und nur für bestimmte Dinge verwendet werden.
                                      Dir werden sonst alle möglichen Updates angeboten, die Du für ein Produktivsystem mit ziemlicher Sicherheit gar nicht willst und auch nicht unbedingt gebrauchen kannst.
                                        jmeister79J Offline
                                        jmeister79J Offline
                                        jmeister79
                                        schrieb am zuletzt editiert von jmeister79
                                        @codierknecht Danke Dir. Sehr guter Hinweis!
                                        http://download.iobroker.net/sources-dist.json als stable ist richtig?
                                          @jmeister79
                                          Und stell den debug-Modus bei Adaptern ab, wenn da nix mehr debuggt wird.
