  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Node red
Node red
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
74 Beiträge 8 Kommentatoren 27.6k Aufrufe
  • E
    E
    electric69
    Однако через WEB-интерфейс драйвер устанавливается, но не работает, в логе видно как циклически падает с предупреждениями.
    Лог:
    ! node-red.0 2016-05-10 10:59:57 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:57 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:57 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:57 warn node-red.0 node-red.0 2016-05-10 10:59:57 warn node-red.0 ^ node-red.0 2016-05-10 10:59:57 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:57 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:57 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:52 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:52 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:52 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:52 warn node-red.0 node-red.0 2016-05-10 10:59:52 warn node-red.0 ^ node-red.0 2016-05-10 10:59:52 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:52 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:52 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:47 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:47 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:47 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:47 warn node-red.0 node-red.0 2016-05-10 10:59:47 warn node-red.0 ^ node-red.0 2016-05-10 10:59:47 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:47 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:46 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:41 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:41 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:41 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:41 warn node-red.0 node-red.0 2016-05-10 10:59:41 warn node-red.0 ^ node-red.0 2016-05-10 10:59:41 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:41 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:41 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:36 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:36 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:36 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:36 warn node-red.0 node-red.0 2016-05-10 10:59:36 warn node-red.0 ^ node-red.0 2016-05-10 10:59:36 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:36 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:36 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:31 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:31 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:31 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:31 warn node-red.0 node-red.0 2016-05-10 10:59:31 warn node-red.0 ^ node-red.0 2016-05-10 10:59:31 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:31 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:31 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:26 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:26 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:26 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:26 warn node-red.0 node-red.0 2016-05-10 10:59:26 warn node-red.0 ^ node-red.0 2016-05-10 10:59:26 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:26 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:26 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:21 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:21 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:21 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:21 warn node-red.0 node-red.0 2016-05-10 10:59:21 warn node-red.0 ^ node-red.0 2016-05-10 10:59:21 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:21 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:20 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:15 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:15 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:15 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:15 warn node-red.0 node-red.0 2016-05-10 10:59:15 warn node-red.0 ^ node-red.0 2016-05-10 10:59:15 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:15 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:15 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:10 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:10 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:10 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:10 warn node-red.0 node-red.0 2016-05-10 10:59:10 warn node-red.0 ^ node-red.0 2016-05-10 10:59:10 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:10 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:10 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:05 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:05 warn node-red.0 ^ Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.j node-red.0 2016-05-10 10:59:05 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:05 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:59:05 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:59:00 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:59:00 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:59:00 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:59:00 warn node-red.0 node-red.0 2016-05-10 10:59:00 warn node-red.0 ^ node-red.0 2016-05-10 10:59:00 warn node-red.0 throw err; node-red.0 2016-05-10 10:59:00 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:59 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:54 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:54 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:54 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:54 warn node-red.0 node-red.0 2016-05-10 10:58:54 warn node-red.0 ^ node-red.0 2016-05-10 10:58:54 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:54 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:54 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red.0 2016-05-10 10:58:49 info node-red.0 node-red exited with 1 node-red.0 2016-05-10 10:58:49 warn node-red.0 at require (internal/module.js:12:17) node-red.0 2016-05-10 10:58:49 warn node-red.0 Error: Cannot find module 'brace-expansion' at Function.Module._resolveFilename (module.js:325:15) at Function.Module._load (module.js:276:25) at Module.require (module.js:353:1 node-red.0 2016-05-10 10:58:49 warn node-red.0 node-red.0 2016-05-10 10:58:49 warn node-red.0 ^ node-red.0 2016-05-10 10:58:49 warn node-red.0 throw err; node-red.0 2016-05-10 10:58:49 warn node-red.0 module.js:327 node-red.0 2016-05-10 10:58:49 info node-red.0 Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:44 info node-red exited with 1 node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:44 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:44 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:44 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:44 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:44 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:44 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:44 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:44 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:44 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:44 warn node-red-0 2016-05-10 10:58:44 warn ^ node-red-0 2016-05-10 10:58:44 warn throw err; node-red-0 2016-05-10 10:58:44 warn module.js:327 node-red-0 2016-05-10 10:58:44 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js admin-0 2016-05-10 10:58:42 info successful connection to socket.io from ::ffff:109.194.66.17 node-red-0 2016-05-10 10:58:39 info node-red exited with 1 node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:300:12) node-red-0 2016-05-10 10:58:39 warn at Module.load (module.js:343:32) node-red-0 2016-05-10 10:58:39 warn at Object.Module._extensions..js (module.js:416:10) node-red-0 2016-05-10 10:58:39 warn at Module._compile (module.js:409:26) node-red-0 2016-05-10 10:58:39 warn at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/fs-extra/node_modules/rimraf/node_modules/glob/node_modules/minimatch/minimatch.js:10:14) node-red-0 2016-05-10 10:58:39 warn at require (internal/module.js:12:17) node-red-0 2016-05-10 10:58:39 warn at Module.require (module.js:353:17) node-red-0 2016-05-10 10:58:39 warn at Function.Module._load (module.js:276:25) node-red-0 2016-05-10 10:58:39 warn at Function.Module._resolveFilename (module.js:325:15) node-red-0 2016-05-10 10:58:39 warn Error: Cannot find module 'brace-expansion' node-red-0 2016-05-10 10:58:39 warn node-red-0 2016-05-10 10:58:39 warn ^ node-red-0 2016-05-10 10:58:39 warn throw err; node-red-0 2016-05-10 10:58:39 warn module.js:327 node-red-0 2016-05-10 10:58:38 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js node-red-0 2016-05-10 10:58:38 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.node-red iobroker 2016-05-10 10:58:38 info exit 0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0 created host-vm32test 2016-05-10 10:58:38 info instance system.adapter.node-red.0 started with pid 3965 host-vm32test 2016-05-10 10:58:38 info object change system.adapter.node-red.0 iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.alive created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.connected created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapUsed created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memHeapTotal created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.memRss created iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red.0.uptime created iobroker 2016-05-10 10:58:38 info host.vm32test object node-red.0 created iobroker 2016-05-10 10:58:38 info host.vm32test create instance node-red iobroker 2016-05-10 10:58:38 info host.vm32test object system.adapter.node-red created iobroker 2016-05-10 10:58:38 info upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html iobroker 2016-05-10 10:58:38 info upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png iobroker 2016-05-10 10:58:38 info got /opt/iobroker/node_modules/iobroker.node-red/admin iobroker 2016-05-10 10:58:38 info host.vm32test install adapter node-red iobroker 2016-05-10 10:58:37 info add node-red !
    • V
      V
      VictorS
      Добрый вечер,
      столкнулся с загадочной проблемой. nodered падает если добавить вот такую ноду:
      "id": "b63c97fe.3efc08",
      "type": "mqtt in",
      "z": "c608cffb.e48a7",
      "name": "Ver1 Light",
      "topic": "/sh-esp-ver1/output14",
      "qos": "2",
      "broker": "15a9d586.42d9ba",
      "x": 130,
      "y": 248,
      "wires": [
      "id": "15a9d586.42d9ba",
      "type": "mqtt-broker",
      "z": "",
      "broker": "localhost",
      "port": "1883",
      "clientid": "nodered.0",
      "usetls": false,
      "compatmode": true,
      "keepalive": "60",
      "cleansession": true,
      "willTopic": "",
      "willQos": "0",
      "willPayload": "",
      "birthTopic": "",
      "birthQos": "0",
      "birthPayload": ""
      т.е. input от mqtt завязанную на gpio от esp. при изменения состояния с "0" -> "1" или "1" -> "0" nodered отваливается от mqtt в логе:
      warn Client error [nodered.0]: Error: Invalid message id
      потом соединение восстанавливается, значение из mqtt в ноду получено.
      где я что сделал не так?
      • I
        I
        instalator
        @VictorS:
        Добрый вечер,
        "type": "mqtt in",
        "qos": "2",
        "x": 130,
        "y": 248,
        "wires": [
        "z": "",
        "port": "1883",
        "usetls": false,
        "compatmode": true,
        "keepalive": "60",
        "willTopic": "",
        "willQos": "0",
        "willPayload": "",
        "birthTopic": "",
        "birthQos": "0",
        "birthPayload": ""
        где я что сделал не так? `
        Попробуй использовать не mqtt, а объект из иоб
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
        • V
          V
          VictorS
          @instalator:
          Попробуй использовать не mqtt, а объект из иоб `
          Спасибо, помогло :)
          Еще вопросы:
          1. В настройках nodered есть "Convert ioBroker values to string" - какой в этом смысл? Удобнее наверное принимать значения в том виде в котором они в IOB?
          2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница?
          • BluefoxB
            @VictorS:
            @instalator:
            Спасибо, помогло :)
            Еще вопросы:
            2. По настройкам выходов с IOB с nodered. Type ("command", "value"). А в чем разница? `
            Первую настройку я что то не могу найти. :lol:
            А вот вторую я попытался объяснить тут: https://github.com/ioBroker/ioBroker/wi … d-statuses
            • V
              V
              VictorS
              @Bluefox:
              @VictorS:
              Еще вопросы:
              А вот вторую я попытался объяснить тут: https://github.com/ioBroker/ioBroker/wi … d-statuses `
              первая - это настройки адаптера nodered, вот тут;
              • BluefoxB
                @VictorS:
                @Bluefox:
                @VictorS:
                Еще вопросы:
                ! nodered-settings.jpg `
                Ну node-red раньше обрабатывал все значения, как строки. Сейчас вроде бы можно любые использовать настройка больше не актуальна.
                • M
                  M
                  maxmen
                  #66
                  Сначала поставил Nodered, настроил что мне было нужно, потом ставил iobroker.
                  Потом из iobroker поставил драйвер nodered в надежде что при установке просто в nodered Добавятся модули iobroker.
                  Драйвер после установки не запускается, т.к. на порту 1880 уже висит nodered изначально установленный.
                  Модули IObroker в Nodered естественно, не появились.
                  Сейчас 3 варианта:
                  1. менять порты (смысла нет держать пару запущенных nodered)
                  2. сносить тот что был изначально и ставить драйвер
                  3. как-то пытаться добавить модуль iobroker в стандартную установку Nodered.
                  Отличаются ли версии nodered в драйвере iobroker и если ставить Nodered обычным способом?
                  Если отличаются, то насколько быстро обновления nodered появляются в драйвере?
                  Существует ли отдельно устанавливаемый модуль Npm iobroker для nodered?
                  • I
                    I
                    instalator
                    #67
                    @maxmen:
                    Сейчас 3 варианта:
                    Существует ли отдельно устанавливаемый модуль Npm iobroker для nodered? `
                    снеси сторонний нодред, а лучше использовать javasript
                    • M
                      M
                      maxmen
                      #68
                      @instalator:
                      снеси сторонний нодред, а лучше использовать javasript `
                      Javascript круто, но nodered для меня нагляднее и понятнее.
                      Вот в том-то и вопрос - кто из этих nodered сторонний и насколько быстро доходят обновления с оригинального до стороннего.
                      • I
                        I
                        instalator
                        #69
                        @maxmen:
                        @instalator:
                        Вот в том-то и вопрос - кто из этих nodered сторонний и насколько быстро доходят обновления с оригинального до стороннего. ` что за обновления? у тебя два независимых нодрнда сейчас работают они никак не пересекаются кроме используемых портов. в итоге потом все равно придётся все переписывать на javascript
                        • M
                          M
                          maxmen
                          #70
                          Если просто ставить Nodered, то ставится версия 0.17.5, если ставить драйвер nodered для iobroker - ставится версия 0.16.2
                          В драйвере ставится дополнительно несколько полезных модулей кроме iobroker, которых я не нашел в стандартных доступных для установки NPMов. Можно ли их поставить отдельно или когда планируется обновление драйвера?
                          node-red-dashboard и node-red-contrib-os в npm нашлись. Не нашел только iobroker модлуь.
                          • I
                            I
                            instalator
                            #71
                            @maxmen:
                            node-red-dashboard и node-red-contrib-os в npm нашлись. Не нашел только iobroker модлуь. ` драйвер на то и драйвер что работает только из иоброкера
                            • BluefoxB
                              #72
                              @maxmen:
                              Ну вообще то можно и не ждать манны небесной, а самому поправить и протестировать драйвер. Это не очень сложно.
                              А так я новую версию подготовил уже месяц назад и сегодня положил в latest.
                              Пожалуйста протестируйте и отпишитесь, что бы я мог передвинуть версию в stable.
                              • M
                                M
                                maxmen
                                #73
                                Bluefox, если бы я знал как это делать, то скорее всего сам бы и сделал.
                                Как я могу выбрать для установки более свежую версию, чем предлагается в списке драйверов (например, ту что уже лежит в latest)?
                                пробовал npm install iobroker.node-red - вроде устанавливается, но в списке драйверов не появляется и сам nodered не запускается. Пробую запустить вручную - node-red-start, запускается, но версия 1.7 и без модуля iobroker. Т.е то что и было изначально установлено.
                                В системе стоят nodejs v6.11.3 и npm 5.4.1
                                Переключил репозиторий в настройках, теперь в списке драйверов пишет что версия 1.4…..
                                • M
                                  M
                                  MSapogov
                                  #74
                                  У меня тоже node-red сам не обновлялся, была версия 1.1.6
                                  Пришлось жать кнопку "Установить их собственного источника" (третья кнопочка в левом верхнем углу) и выбирать с GitHub "node-red".
                                  После этого версия стала установлена 1.4.1
                                  Может такой вариант обновления Вам поможет.
                                  84.2k
