  4. (gelöst) Backup nur nach Raspi Neustart, danach nicht mehr!
    5.5k
34 Beiträge 5 Kommentatoren 3.2k Aufrufe 4 Beobachtet
  • E edition
    Hier das ganze:
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   aarch64
    Docker:         false
    Virtualization: none
    Distributor ID: Debian
    Description:    Debian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
    NAME="Debian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=debian
    HOME_URL="https://www.debian.org/"
    SUPPORT_URL="https://www.debian.org/support"
    BUG_REPORT_URL="https://bugs.debian.org/"
    Systemuptime and Load:
     21:21:27 up 3 days, 10:15,  1 user,  load average: 0.39, 0.15, 0.14
    CPU threads: 4
    *** Time and Time Zones ***
    Wed Mar  8 20:21:27 UTC 2023
    Wed Mar  8 21:21:27 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            909M        528M        102M        0.0K        278M        325M
    Swap:            99M         99M          0B
    Total:          1.0G        628M        102M
              909 M total memory
              529 M used memory
              369 M active memory
              355 M inactive memory
              101 M free memory
               16 M buffer memory
              262 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G  3.3G   25G  12% /
    devtmpfs       devtmpfs  325M     0  325M   0% /dev
    tmpfs          tmpfs     455M     0  455M   0% /dev/shm
    tmpfs          tmpfs     182M  712K  182M   1% /run
    /dev/mmcblk0p1 vfat      253M   31M  222M  13% /boot
    tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
    Messages in dmesg:
    TARGET  SOURCE         FSTYPE OPTIONS
    /       /dev/mmcblk0p2 ext4   rw,noatime
    `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    /var:
    1.3G    /var/
    813M    /var/log
    809M    /var/log/journal/2ac2779a3e264b89af8a628ac67e13bd
    256M    /var/cache
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    118M    /opt/iobroker/iobroker-data/
    53M     /opt/iobroker/iobroker-data/backup-objects
    23M     /opt/iobroker/iobroker-data/files
    13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/states.jsonl
    6.6M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.8083c40d.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.1
    /usr/bin/node           v16.19.1
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.1-deb-1nodesource1
      Candidate: 16.19.1-deb-1nodesource1
      Version table:
     *** 16.19.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
         12.22.12~dfsg-1~deb11u3 500
            500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
         12.22.5~dfsg-2~11u1 500
            500 http://deb.debian.org/debian bullseye/main arm64 Packages
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     "javascript" not found
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : ioBroker                                 -  enabled
    + system.adapter.discovery.0              : discovery             : ioBroker                                 -  enabled
    + system.adapter.fhem.0                   : fhem                  : ioBroker                                 -  enabled, port: 7072
      system.adapter.modbus.0                 : modbus                : ioBroker                                 - disabled
    + system.adapter.smartmeter.0             : smartmeter            : ioBroker                                 -  enabled
      system.adapter.sonoff.0                 : sonoff                : ioBroker                                 - disabled, port: 1883, bind: 0.0.0.0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "fhem"         : 1.6.3    , installed 1.6.3
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "smartmeter"   : 3.3.4    , installed 3.3.4
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Objects and States
    Objects:        17571
    States:         16775
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 3
    *** Listening Ports ***
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14086      457/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10696      457/iobroker.js-con
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13072      477/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       14277      708/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          13074      477/sshd: /usr/sbin
    udp        0      0 0.0.0.0:54939           0.0.0.0:*                           108        14003      365/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14001      365/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14082      664/dhcpcd
    udp6       0      0 :::56008                :::*                                108        14004      365/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        14002      365/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          10676      664/dhcpcd
    2023-03-08 21:02:25.586  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:03:26.586  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:04:27.568  - info: smartmeter.0 (762) Error: Error while parsing SML message: Error: Unknown TL-Field 0x49b for OctetString [Offset: 221]!: Message: 1b1b1b1b010101017605f1dcd405620062007263010176010102310b0a01445a4700039e0e3d7262016501f1a5c0620263dd26007605f2dcd405620062007263070177010b0a01445a4700039e0e3d070100620affff7262016501f1a5c07477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eec680177070100100700ff017262016200621b52fe54009e58010101631377007605f3dcd405620062007263020163c90b001b1b1b1b1a0038bd
    2023-03-08 21:04:27.569  - warn: smartmeter.0 (762) Error while parsing SML message: Error: Unknown TL-Field 0x49b for OctetString [Offset: 221]!: Message: 1b1b1b1b010101017605f1dcd405620062007263010176010102310b0a01445a4700039e0e3d7262016501f1a5c0620263dd26007605f2dcd405620062007263070177010b0a01445a4700039e0e3d070100620affff7262016501f1a5c07477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eec680177070100100700ff017262016200621b52fe54009e58010101631377007605f3dcd405620062007263020163c90b001b1b1b1b1a0038bd
    2023-03-08 21:05:28.633  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:06:29.564  - info: smartmeter.0 (762) Error: Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 1b1b1b1b0101010176055fded40562007263010176010102310b0a01445a4700039e0e3d7262016501f1a63a620263053100760560ded405620062007263070177010b0a01445a4700039e0e3d070100620affff7262016501f1a63a7477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eecf20177070100100700ff017262016200621b52fe54009ded010101633aee00760561ded40562006200726302017101634ead001b1b1b1b1a00978e
    2023-03-08 21:06:29.565  - warn: smartmeter.0 (762) Error while parsing SML message: Error: Wrong TL-Field (7) for Unsigned!: Message: 1b1b1b1b0101010176055fded40562007263010176010102310b0a01445a4700039e0e3d7262016501f1a63a620263053100760560ded405620062007263070177010b0a01445a4700039e0e3d070100620affff7262016501f1a63a7477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eecf20177070100100700ff017262016200621b52fe54009ded010101633aee00760561ded40562006200726302017101634ead001b1b1b1b1a00978e
    2023-03-08 21:07:49.846  - info: smartmeter.0 (762) Error: No or too long answer from Serial Device after last request.
    2023-03-08 21:07:49.846  - warn: smartmeter.0 (762) No or too long answer from Serial Device after last request.
    2023-03-08 21:08:51.577  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:09:52.580  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:10:53.552  - info: smartmeter.0 (762) Error: Error while parsing SML message: Error: Unknown TL-Field for SmlList!: Message: 1b1b1b1b01010101760577e1d405620062007263010176010102310b0a01445a4700039e0e3d7262016501f1a7426202633b2f00760578e1d405620062007263070177010b0a01445a4700039e0e3d070100620affff7262620001f1a7427477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eee150177070100100700ff017262016200621b52fe54009820010101633b7d00760579e1d4056200620072630201710163a14e001b1b1b1b1a000130
    2023-03-08 21:10:53.553  - warn: smartmeter.0 (762) Error while parsing SML message: Error: Unknown TL-Field for SmlList!: Message: 1b1b1b1b01010101760577e1d405620062007263010176010102310b0a01445a4700039e0e3d7262016501f1a7426202633b2f00760578e1d405620062007263070177010b0a01445a4700039e0e3d070100620affff7262620001f1a7427477070100603201010172620162006200520004445a470177070100600100ff017262016200620052000b0a01445a4700039e0e3d0177070100010800ff641c01047262016200621e52ff65031eee150177070100100700ff017262016200621b52fe54009820010101633b7d00760579e1d4056200620072630201710163a14e001b1b1b1b1a000130
    2023-03-08 21:11:54.607  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:12:55.559  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:13:56.560  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:14:57.555  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:15:59.552  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:17:00.550  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:18:01.545  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:19:02.542  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:20:03.540  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:21:04.539  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:22:05.539  - info: smartmeter.0 (762) Received 4 values, 2 updated
    2023-03-08 21:23:06.542  - info: smartmeter.0 (762) Received 4 values, 2 updated
    @edition sagte in Backup nur nach Raspi Neustart, danach nicht mehr!:
    ? Kein javascript aktiv?
    • E Offline
      edition
      Stimmt! Meinst du das spielt mit da rein?
      • E edition
        Ich war eigentlich der Meinung das der so essentiell sei, der ist immer installiert.
        • E edition
          Hier das ganze:
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=debian
          CPU threads: 4
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         99M          0B
                    909 M total memory
                    529 M used memory
                    369 M active memory
                    101 M free memory
                     16 M buffer memory
                    262 M swap cache
                     99 M total swap
                     99 M used swap
                      0 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          1.3G    /var/
          813M    /var/log
          256M    /var/cache
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          Adapter State
          + instance is alive
          Objects and States
          Objects:        17571
          States:         16775
          Pending Updates: 3
          Swap: 99M 99M 0B
          nee der ist trockengelaufen!
          1GB reicht nicht mehr
          • E Offline
            edition
            Also auf PI4 umsteigen?
            HomoranH CodierknechtC 2 Antworten Letzte Antwort
            • E edition
              oder was anderes, je nach Gusto
              E 1 Antwort Letzte Antwort
                edition
                @homoran sagte in Backup nur nach Raspi Neustart, danach nicht mehr!:
                Gusto???????????
                CodierknechtC HomoranH 2 Antworten Letzte Antwort
                • E edition
                  CodierknechtC Offline
                  Codierknecht
                  Wird schwierig ... wenn Du überhaupt einen bekommst, ist der aktuell unverschämt teuer.
                  HmIP|ZigBee|Tasmota|Unifi
                  Zabbix Certified Specialist
                  • E Offline
                    edition
                    Hab noch ein 8GB Modell. Der hat gerade keine Aufgabe!
                    • E edition
                      @edition ja dann 😁 gib ihm was zu tun
                      • E edition
                        Gusto???????????
                        Codierknecht
                        Gusto???????????
                        NUC, MiniPC, Docker auf'm NAS ... gibt verschiedene Möglichkeiten.
                        Evtl. geht auch OrangePi oder BananaPi?
                        • E Offline
                          edition
                          Dann ist das Wochenende ja gerettet!
                          • E edition
                            Gusto???????????
                            Gusto???????????
                            Geschmack, deiner
                              Gusto???????????
                              Geschmack, deiner
                              edition
                              Geschmack, deiner
                              Aaaahhh!
                              • CodierknechtC Codierknecht
                                Gusto???????????
                                @codierknecht sagte in Backup nur nach Raspi Neustart, danach nicht mehr!:
                                Gusto???????????
                                odroid c4 bei Reichelt
                                • E Offline
                                  edition
                                  Ok, ich vertage mich aufs Wochenende und mache den PI4 mit 8GB startklar. Ich berichte dann.
                                  Habt schönen Dank für die Hilfe
                                  edition
                                  • E Offline
                                    edition
                                    Guten Abend!
                                    Erste Rückmeldung: Rpi4 mit 8GB läuft! Restore war einfacher als gedacht. Aktuelle Ram Auslastung:
                                                  gesamt       benutzt     frei      gemns.  Puffer/Cache verfügbar
                                    Speicher:       7812         544        7037           0         230        7156
                                    Swap:             99           0          99
                                    Gesamt:         7912         544        7137
                                    Bin gespannt, was nach dem ersten Backup passiert.
                                    edition
