  4. Adapter taucht immer wieder auf
    5.5k
adapter löschenmiele
31 Beiträge 3 Kommentatoren 1.0k Aufrufe 2 Beobachtet
  • H husneck
    @thomas-braun Danke für den Hinweis.
    pi@iobroker:/opt/iobroker $ iob del miele
    Delete adapter "miele"
    host.iobroker Counted 1 instances of miele
    host.iobroker Counted 1 meta of miele
    host.iobroker Adapter miele cannot be deleted completely, because it is marked non-deletable.
    host.iobroker Counted 1 states of miele
    host.iobroker Counted 14 states of system.adapter.miele
    host.iobroker Counted 14 states (system.adapter.miele.*) from states
    host.iobroker file miele.admin deleted
    host.iobroker object miele deleted
    host.iobroker object miele.admin deleted
    host.iobroker Deleting 17 object(s).
    host.iobroker Deleting 14 state(s).
    Ist als non-deletable markiert. Welcher Weg ist der beste, um die Datei als deletable zu markieren?
    @husneck
    Und die Ausgabe zum anderen Befehl?
    H 1 Antwort Letzte Antwort
      @husneck
      husneck
      pi@iobroker:/opt/iobroker $ iob add miele
      NPM version: 8.19.3
      Installing iobroker.miele@0.1.5... (System call)
      added 2 packages in 7s
      82 packages are looking for funding
        run `npm fund` for details
      host.iobroker install adapter miele
      upload [2] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/index.html index.html text/html
      upload [1] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/miele.png miele.png image/png
      upload [0] miele.admin /opt/iobroker/node_modules/iobroker.miele/admin/xmiele.png xmiele.png image/png
      host.iobroker object system.adapter.miele created/updated
      host.iobroker create instance miele
      host.iobroker object system.adapter.miele.0.alive created
      host.iobroker object system.adapter.miele.0.connected created
      host.iobroker object system.adapter.miele.0.compactMode created
      host.iobroker object system.adapter.miele.0.cpu created
      host.iobroker object system.adapter.miele.0.cputime created
      host.iobroker object system.adapter.miele.0.memHeapUsed created
      host.iobroker object system.adapter.miele.0.memHeapTotal created
      host.iobroker object system.adapter.miele.0.memRss created
      host.iobroker object system.adapter.miele.0.uptime created
      host.iobroker object system.adapter.miele.0.inputCount created
      host.iobroker object system.adapter.miele.0.outputCount created
      host.iobroker object system.adapter.miele.0.eventLoopLag created
      host.iobroker object system.adapter.miele.0.sigKill created
      host.iobroker object system.adapter.miele.0.logLevel created
      host.iobroker object miele.0.IPs created
      host.iobroker object system.adapter.miele.0 created
      • H husneck
        NPM version: 8.19.3
        @husneck
        Schau mal ob das Objekt system.adapter.miele (ohne .0!) im Reiter "Allgemein" eine Checkbox mit Text "nondeletable" oder so ähnlich hat. Wenn ja, mach den Haken weg und versuch den Adapter nochmal zu löschen.
        H 2 Antworten Letzte Antwort
          @husneck
          husneck
          Habe das schon mal gelesen, aber ich finde bei mir keinen Reiter "Allgemein" Das ist der Eintrag unter system/adapter, welchen ich bearbeiten könnte, wenn ich auf den Stift klicke. Kann ich auch dort unter Objektdaten, "nondeletable":false setzen?
            @husneck
            husneck
            Das ändern der Objektdaten bringt leider nichts. Der adapter taucht immer noch auf, wenn ich npm ls aufrufe.
            • H husneck
              @husneck sagte in Adapter taucht immer wieder auf:
              der kommt erst wenn du auf den Bleistift klickst
              hast du denn zwischenzeitlich nochmal versucht zu löschen?
                husneck
                Ja, leider ohne Erfolg. Wenn ich auf den Bleistift klicke, kommt folgendes:
                • H husneck
                  und links ist allgemein
                  rechts ist non deletable ja immer noch true.
                  bist du im Expertenmodus?
                  dann iobroker add miele
                  non deletable deaktivieren
                  danach iob del miele
                  ich hoffe durch deine Manipulation über das Dateisystem beim Versuch zu löschen ist nix verbogen worden
                    husneck
                    schrieb am zuletzt editiert von husneck
                    Habe ich schon versucht, leider ohne Erfolg.
                    host.iobroker Counted 1 adapter for miele
                    host.iobroker Counted 15 states (system.adapter.miele.*) from states
                    host.iobroker Deleting 18 object(s).
                    host.iobroker Deleting 15 state(s).
                    das scheint zu funktionieren, jedoch ist der Adapter immer noch da.
                    • H husneck
                      leider ohne Erfolg.
                      solange non deletable nicht vorher auf false steht, hat es auch keinen Sinn!
                      was war hier mit?
                      @homoran sagte in Adapter taucht immer wieder auf:
                      beim Adapter steht UNMET DEPENDENCY.
                      seh ich nicht.
                      • H husneck
                        @husneck nichts editieren!
                        Da liest niemand mehr!
                        Browsercache löschen?
                          leider ohne Erfolg.
                          was war hier mit?
                          seh ich nicht.
                          husneck
                          "non-deletable" habe ich auf false gesetzt. Trotzdem scheint nicht alles gelöscht zu werden.
                          ├── UNMET DEPENDENCY iobroker.miele@0.1.5
                          das war der Eintrag von npm ls am Anfang, ist aber durch das erneute installieren behoben worden.
                          • H husneck
                            wirklich?
                              wirklich?
                              husneck
                              ja wirklich.
                              • H husneck
                                ja wirklich.
                                @husneck hmm 🤔
                                und in der Konsole steht nichts anderes?
                                ich sehe zum Abschluss den prompt nicht
                                  @husneck hmm 🤔
                                  husneck
                                  @homoran leider nicht.
                                  • H husneck
                                    da ist aber abrupt abgeschnitten
                                      husneck
                                      @homoran kommt kein prompt
                                      pi@iobroker:/opt/iobroker $ iobroker del miele
                                      • H husneck
                                        kommt kein prompt
                                        jetzt ja!
                                        bitte immer alles im Kontext zeigen, keine Schnipsel!
                                        gib mal den output von iob diag
                                          kommt kein prompt
                                          jetzt ja!
                                          husneck
                                          Skript v.2023-01-02
                                          *** BASE SYSTEM ***
                                          Model           : Raspberry Pi 4 Model B Rev 1.2
                                          Architecture:   armv7l
                                          Docker:         false
                                          Virtualization: none
                                          Distributor ID: Raspbian
                                          Description:    Raspbian GNU/Linux 11 (bullseye)
                                          Release:        11
                                          Codename:       bullseye
                                          PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                                          NAME="Raspbian GNU/Linux"
                                          VERSION_ID="11"
                                          VERSION="11 (bullseye)"
                                          VERSION_CODENAME=bullseye
                                          ID=raspbian
                                          ID_LIKE=debian
                                          HOME_URL="http://www.raspbian.org/"
                                          SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
                                          BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
                                          Systemuptime and Load:
                                           11:53:46 up  1:26,  1 user,  load average: 0.18, 0.36, 0.37
                                          CPU threads: 4
                                          *** Time and Time Zones ***
                                          Wed Mar  8 10:53:46 UTC 2023
                                          Wed Mar  8 11:53:46 CET 2023
                                          CET +0100
                                          Europe/Berlin
                                          *** User and Groups ***
                                          pi
                                          /home/pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          *** X-Server-Setup ***
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Mem:            3.8G        1.3G        2.2G        0.0K        307M        2.8G
                                          Swap:            99M          0B         99M
                                          Total:          3.9G        1.3G        2.3G
                                                   3838 M total memory
                                                   1305 M used memory
                                                    141 M active memory
                                                   1364 M inactive memory
                                                   2226 M free memory
                                                     53 M buffer memory
                                                    253 M swap cache
                                                     99 M total swap
                                                      0 M used swap
                                                     99 M free swap
                                          *** FILESYSTEM ***
                                          /dev/root      ext4       14G  6.3G  7.2G  47% /
                                          devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
                                          tmpfs          tmpfs     768M  808K  767M   1% /run
                                          /dev/mmcblk0p1 vfat      253M   50M  203M  20% /boot
                                          tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
                                          Messages in dmesg:
                                          [Wed Mar  8 10:27:30 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:80:12:08 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=9f23093d-02 rootfstype=ext4 fsck.repair=yes rootwait
                                          [Wed Mar  8 10:27:31 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                          [Wed Mar  8 10:27:31 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
                                          [Wed Mar  8 10:27:33 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
                                          TARGET  SOURCE         FSTYPE OPTIONS
                                          /       /dev/mmcblk0p2 ext4   rw,noatime
                                          `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                                          /var:
                                          2.0G    /var/
                                          1.2G    /var/log/journal/925da4241a0e4a8ab78a2506ba1ed48a
                                          1.2G    /var/log
                                          713M    /var/cache
                                          /opt/iobroker/backups:
                                          67M     /opt/iobroker/backups/
                                          /opt/iobroker/iobroker-data:
                                          257M    /opt/iobroker/iobroker-data/
                                          161M    /opt/iobroker/iobroker-data/files
                                          60M     /opt/iobroker/iobroker-data/backup-objects
                                          51M     /opt/iobroker/iobroker-data/files/javascript.admin
                                          33M     /opt/iobroker/iobroker-data/files/javascript.admin/static
                                          25M     /opt/iobroker/iobroker-data/objects.jsonl
                                          19M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js.map
                                          19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js.map
                                          8.2M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.2975a411.js
                                          7.9M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.a5972028.js
                                          *** NodeJS-Installation ***
                                          /usr/bin/nodejs         v16.19.1
                                          /usr/bin/node           v16.19.1
                                          /usr/bin/npm            8.19.3
                                          /usr/bin/npx            8.19.3
                                          nodejs:
                                            Installed: 16.19.1-deb-1nodesource1
                                            Candidate: 16.19.1-deb-1nodesource1
                                            Version table:
                                           *** 16.19.1-deb-1nodesource1 500
                                                  500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                                               12.22.12~dfsg-1~deb11u3 500
                                          *** ioBroker-Installation ***
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          Core adapters versions
                                          js-controller:  4.0.24
                                          admin:          6.3.6
                                          javascript:     7.0.1
                                          Adapters from github:   0
                                          Adapter State
                                          + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                          + system.adapter.bosesoundtouch.0         : bosesoundtouch        : iobroker                                 -  enabled
                                          + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
                                          + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                                          + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                          + system.adapter.history.0                : history               : iobroker                                 -  enabled
                                          + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                                          + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
                                          + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
                                          + system.adapter.jarvis.0                 : jarvis                : iobroker                                 -  enabled
                                          + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                          + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
                                          + system.adapter.mielecloudservice.0      : mielecloudservice     : iobroker                                 -  enabled
                                          + system.adapter.net-tools.0              : net-tools             : iobroker                                 -  enabled
                                          + system.adapter.netatmo.0                : netatmo               : iobroker                                 -  enabled
                                          + system.adapter.ping.0                   : ping                  : iobroker                                 -  enabled
                                          + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                                          + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
                                          + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                                          + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                            system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                          + system.adapter.xiaomi-gateway3.0        : xiaomi-gateway3       : iobroker                                 -  enabled
                                          + instance is alive
                                          ioBroker-Repositories
                                          Active repo(s): beta
                                          Installed ioBroker-Instances
                                          Used repository: beta
                                          Adapter    "admin"        : 6.3.6    , installed 6.3.6
                                          Adapter    "backitup"     : 2.6.8    , installed 2.6.8
                                          Adapter    "bosesoundtouch": 0.10.3  , installed 0.10.3
                                          Adapter    "cloud"        : 4.3.1    , installed 4.3.1
                                          Adapter    "fritzdect"    : 2.3.1    , installed 2.3.1
                                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                                          Adapter    "hue"          : 3.7.1    , installed 3.7.1
                                          Adapter    "iot"          : 1.14.5   , installed 1.14.5
                                          Adapter    "jarvis"       : 3.1.3    , installed 3.1.3
                                          Adapter    "javascript"   : 7.0.1    , installed 7.0.1
                                          Adapter    "meross"       : 1.15.0   , installed 1.15.0
                                          Adapter    "miele"        : 0.1.5    , installed 0.1.5
                                          Adapter    "mielecloudservice": 6.4.0, installed 6.4.0
                                          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                                          Adapter    "netatmo"      : 3.1.0    , installed 3.1.0
                                          Adapter    "shelly"       : 6.4.0    , installed 6.4.0
                                          Adapter    "socketio"     : 6.3.4    , installed 6.3.4
                                          Adapter    "tado"         : 0.4.4    , installed 0.4.4
                                          Adapter    "web"          : 5.5.2    , installed 5.5.2
                                          Adapter    "ws"           : 2.3.6    , installed 2.3.6
                                          Adapter    "xiaomi-gateway3": 0.3.6  , installed 0.3.6
                                          Objects and States
                                          Objects:        3671
                                          States:         3187
                                          Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                          Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          Reading package lists...
                                          Pending Updates: 4
                                          *** Listening Ports ***
                                          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       16417      1003/io.shelly.0
                                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       12957      489/iobroker.js-con
                                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       12142      489/iobroker.js-con
                                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12866      527/sshd: /usr/sbin
                                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       19325      1659/io.jarvis.0
                                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       14171      1116/io.web.0
                                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13128      638/io.admin.0
                                          tcp6       0      0 :::22                   :::*                    LISTEN      0          12868      527/sshd: /usr/sbin
                                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12791      388/avahi-daemon: r
                                          udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          10211      849/dhcpcd
                                          udp        0      0 0.0.0.0:53378           0.0.0.0:*                           108        12793      388/avahi-daemon: r
                                          udp6       0      0 :::5353                 :::*                                108        12792      388/avahi-daemon: r
                                          udp6       0      0 :::35590                :::*                                108        12794      388/avahi-daemon: r
                                          udp6       0      0 :::546                  :::*                                0          10220      849/dhcpcd
                                          2023-03-08 11:38:41.749  - info: host.iobroker object deleted system.adapter.miele.0
                                          2023-03-08 11:38:41.751  - info: host.iobroker stopInstance system.adapter.miele.0 (force=false, process=true)
                                          2023-03-08 11:38:41.761  - info: miele.0 (5096) Got terminate signal TERMINATE_YOURSELF
                                          2023-03-08 11:38:41.763  - info: miele.0 (5096) terminating
                                          2023-03-08 11:38:41.765  - info: miele.0 (5096) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2023-03-08 11:38:41.801  - info: host.iobroker stopInstance system.adapter.miele.0 send kill signal
                                          2023-03-08 11:38:42.329  - error: host.iobroker instance system.adapter.miele.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                          2023-03-08 11:38:42.329  - info: host.iobroker Do not restart adapter system.adapter.miele.0 because desired by instance
                                          2023-03-08 11:41:13.888  - error: xiaomi-gateway3.0 (1524) Unknown BLE device did = blt.4.15s8nds54gk00
                                          2023-03-08 11:42:14.594  - error: xiaomi-gateway3.0 (1524) Unknown BLE device did = blt.4.15s8nds54gk00
                                          2023-03-08 11:45:07.994  - info: admin.0 (638) <== Disconnect system.user.admin from ::ffff:192.168.178.41 admin
                                          2023-03-08 11:45:13.427  - info: admin.0 (638) ==> Connected system.user.admin from ::ffff:192.168.178.41
                                          2023-03-08 11:46:14.226  - error: xiaomi-gateway3.0 (1524) Unknown BLE device did = blt.4.15s8nds54gk00
                                          2023-03-08 11:46:52.869  - info: host.iobroker instance system.adapter.miele.0 started with pid 6424
                                          2023-03-08 11:46:54.662  - info: miele.0 (6424) starting. Version 0.1.5 in /opt/iobroker/node_modules/iobroker.miele, node: v16.19.1, js-controller: 4.0.24
                                          2023-03-08 11:50:45.139  - info: host.iobroker object deleted system.adapter.miele.0
                                          2023-03-08 11:50:45.142  - info: host.iobroker stopInstance system.adapter.miele.0 (force=false, process=true)
                                          2023-03-08 11:50:45.153  - info: miele.0 (6424) Got terminate signal TERMINATE_YOURSELF
                                          2023-03-08 11:50:45.159  - info: miele.0 (6424) terminating
                                          2023-03-08 11:50:45.164  - info: miele.0 (6424) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          2023-03-08 11:50:45.191  - info: host.iobroker stopInstance system.adapter.miele.0 send kill signal
                                          2023-03-08 11:50:45.748  - error: host.iobroker instance system.adapter.miele.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
                                          2023-03-08 11:50:45.748  - info: host.iobroker Do not restart adapter system.adapter.miele.0 because desired by instance
                                          2023-03-08 11:52:14.276  - error: xiaomi-gateway3.0 (1524) Unknown BLE device did = blt.4.15s8nds54gk00
                                          2023-03-08 11:53:14.641  - error: xiaomi-gateway3.0 (1524) Unknown BLE device did = blt.4.15s8nds54gk00
                                          iob diag has finished.
