  3. Off Topic
  4. ! gelöst ! NUC Proxmox Bluetooth onboard
    6.1k
33 Beiträge 4 Kommentatoren 5.5k Aufrufe 4 Beobachtet
  • W woupi
    @dp20eic sagte in NUC Proxmox Bluetooth onboard:
    @woupi sagte in NUC Proxmox Bluetooth onboard:
    # lsusb
    # lspci
    Ist denn da Bluetooth zu finden, hast Du mal im Bios geschaut ob das angeschaltet ist?
    Bernd
    root@server:~# lsusb
    Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics CH340 serial converter
    root@server:~#
    root@server:~# lspci
    00:00.0 Host bridge: Intel Corporation Device 9b71 (rev 0c)
    00:02.0 VGA compatible controller: Intel Corporation CometLake-U GT2 [UHD Graphi        cs] (rev 02)
    00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6        th/7th/8th Gen Core Processor Gaussian Mixture Model
    00:12.0 Signal processing controller: Intel Corporation Comet Lake Thermal Subsy        tem
    00:14.0 USB controller: Intel Corporation Comet Lake PCH-LP USB 3.1 xHCI Host Co        ntroller
    00:14.2 RAM memory: Intel Corporation Comet Lake PCH-LP Shared SRAM
    00:15.0 Serial bus controller: Intel Corporation Serial IO I2C Host Controller
    00:15.2 Serial bus controller: Intel Corporation Comet Lake PCH-LP LPSS: I2C Con        troller #2
    00:16.0 Communication controller: Intel Corporation Comet Lake Management Engine        Interface
    00:17.0 SATA controller: Intel Corporation Comet Lake SATA AHCI Controller
    00:1c.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #5 (rev f        0)
    00:1d.0 PCI bridge: Intel Corporation Device 02b5 (rev f0)
    00:1f.0 ISA bridge: Intel Corporation Comet Lake PCH-LP LPC Premium Controller/e        SPI Controller
    00:1f.4 SMBus: Intel Corporation Comet Lake PCH-LP SMBus Host Controller
    00:1f.5 Serial bus controller: Intel Corporation Comet Lake SPI (flash) Controll        er
    00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (10) I219-V
    01:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
    02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
    02:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
    02:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge        2C 2018] (rev 06)
    03:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ri        dge 2C 2018] (rev 06)
    39:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [        Titan Ridge 2C 2018] (rev 06)
    3a:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller
    root@server:~#
    @woupi
    Moin,
    sorry, das ich mich erst jetzt einschalte, aber im Gegensatz zu meiner Frau und CPU, bin ich nur Single Task fähig :)
    Freut mich, dass Du, mit kompetenter Hilfe, weitergekommen bist.
    Du solltest alle Schritte und Erkenntnisse mal kurz zusammenschreiben, kann sicherlich für das iobroker Wiki interessant sein, als Ergänzung zum iobroker auf Proxmox installieren.
    Als Tip ob das jetzt schon unter der VM funktioniert, kannst Du mal versuchen irgend ein Bluetooth Gerät zu pairen.
    Als Anhalt kann ich dir da bluetoothctl nennen, must Du evtl. in der VM noch nachinstallieren.
     16:46:35  dp20eic@ryzen-5  ~ 
    $ bluetoothctl
    Agent registered
    [bluetooth]# ?
    Invalid command in menu main: ?
    Use "help" for a list of available commands in a menu.
    Use "menu <submenu>" if you want to enter any submenu.
    Use "back" if you want to return to menu main.
    [bluetooth]# help
    Menu main:
    Available commands:
    advertise                                         Advertise Options Submenu
    monitor                                           Advertisement Monitor Options Submenu
    scan                                              Scan Options Submenu
    gatt                                              Generic Attribute Submenu
    admin                                             Admin Policy Submenu
    player                                            Media Player Submenu
    endpoint                                          Media Endpoint Submenu
    transport                                         Media Transport Submenu
    list                                              List available controllers
    show [ctrl]                                       Controller information
    select <ctrl>                                     Select default controller
    devices [Paired/Bonded/Trusted/Connected]         List available devices, with an optional property as the filter
    system-alias <name>                               Set controller alias
    reset-alias                                       Reset controller alias
    power <on/off>                                    Set controller power
    pairable <on/off>                                 Set controller pairable mode
    discoverable <on/off>                             Set controller discoverable mode
    discoverable-timeout [value]                      Set discoverable timeout
    agent <on/off/capability>                         Enable/disable agent with given capability
    default-agent                                     Set agent as the default one
    advertise <on/off/type>                           Enable/disable advertising with given type
    set-alias <alias>                                 Set device alias
    scan <on/off/bredr/le>                            Scan for devices
    info [dev]                                        Device information
    pair [dev]                                        Pair with device
    cancel-pairing [dev]                              Cancel pairing with device
    trust [dev]                                       Trust device
    untrust [dev]                                     Untrust device
    block [dev]                                       Block device
    unblock [dev]                                     Unblock device
    remove <dev>                                      Remove device
    connect <dev>                                     Connect device
    disconnect [dev]                                  Disconnect device
    menu <name>                                       Select submenu
    version                                           Display version
    quit                                              Quit program
    exit                                              Quit program
    help                                              Display help about this program
    export                                            Print environment variables
    [bluetooth]# devices
    Device D4:6D:6D:E6:29:BC VWAGWOLOM0ZO
    Device 14:3F:A6:67:91:B5 WH-1000XM4
    Device F0:41:C8:31:46:6B BT HIFI AUDIO
    Device DF:BB:70:6C:AC:F2 Nuimo_silbern
    Device B8:27:EB:A3:AA:24 Moode Bluetooth
    Device E8:0A:C0:3A:6B:FA Nuimo
    [bluetooth]#
    [bluetooth]# pairable
    Missing on/off argument
    [bluetooth]# pairable on
    Changing pairable on succeeded
    [bluetooth]# scan
    Missing on/off/bredr/le argument
    [bluetooth]# scan on
    Discovery started
    [CHG] Controller FC:77:74:87:56:44 Discovering: yes
    [NEW] Device 5C:3F:61:A1:54:BC 5C-3F-61-A1-54-CC
    [NEW] Device 54:D2:72:DB:B4:B9 Nuki_13DBB4AAAAA9
    [DEL] Device 5C:3F:61:A1:54:BC 5C-3F-61-A1-54-CC
    [DEL] Device 54:D2:72:DB:B4:B9 Nuki_13DBB4AAAAA9
    Bernd
    W 1 Antwort Letzte Antwort
      @woupi
      Moin,
      $ bluetoothctl
      Agent registered
      [bluetooth]# ?
      [bluetooth]# help
      Menu main:
      Available commands:
      quit                                              Quit program
      exit                                              Quit program
      [bluetooth]#
      [bluetooth]# scan
      Discovery started
      Bernd
      W Offline
      W Offline
      woupi
      schrieb am zuletzt editiert von woupi
      @woupi
      Moin,
      Vielen Dank, dass du dich meldest und auch ich bin nicht Multitasking fähig. Normalerweise bin ich auch von 6 bis 18:00 nicht zu Hause, bin bis einschließlich heute aber Arbeitsunfähig. Darum hatte ich überhaupt die Zeit so früh was zu machen.
      mich auch.
      Das werde ich gerne versuchen.
      Habe ich gemacht und siehe da, es kommen reichlich Geräte 😀
      Discovery started
      [CHG] Controller 08:71:90:56:38:C0 Discovering: yes
      [NEW] Device 71:9C:11:D5:DF:26 71-9C-11-D5-DF-26
      [NEW] Device 40:D5:E8:8E:EF:95 40-D5-E8-8E-EF-95
      [NEW] Device CC:33:31:B5:A2:42 CC-33-31-B5-A2-42
      [NEW] Device 74:38:B7:D2:1F:71 74-38-B7-D2-1F-71
      [CHG] Device CC:33:31:B5:A2:42 TxPower: 0
      [CHG] Device CC:33:31:B5:A2:42 Name: Geberit AC PRO
      [CHG] Device CC:33:31:B5:A2:42 Alias: Geberit AC PRO
      [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Key: 0x0100
      [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Value:
        00 31 34 36 32 30                                .14620
      [CHG] Device CC:33:31:B5:A2:42 ManufacturerData Key: 0x3200
        34                                               4
      [CHG] Device 71:9C:11:D5:DF:26 RSSI: -87
      [CHG] Device 40:D5:E8:8E:EF:95 RSSI: -95
      [CHG] Device 74:38:B7:D2:1F:71 TxPower: 6
      [CHG] Device 74:38:B7:D2:1F:71 Appearance: 0x0200
      [CHG] Device 74:38:B7:D2:1F:71 Name: EOS850D_CBC374
      [CHG] Device 74:38:B7:D2:1F:71 Alias: EOS850D_CBC374
      [CHG] Device 71:9C:11:D5:DF:26 RSSI: -95
      [bluetooth]#
      Damit würde ich sagen, funktioniert.
      Vielen Dank für eure Hilfe.
      Ich werde am WE alles zusammenschreiben.
      Viel Falsch machen kann ich ja auch nicht, denn es steht ja alle hier drin, nur halt durcheinander und das ist für einen suchenden nicht gut, das musste ich die letzten Monate leider auch wieder feststellen.
      Wenn ich das habe, werde ich dann mal sehen was Du genau mit dem Wiki meinst, habe ich noch nicht gesehen, muss zu meiner Schade gestehen, habe ich auch noch nicht nach gesucht.
      Ich wünsche euch einen schönen Abend, ich bin dann ab morgen auch wieder arbeiten, dann ist es vorbei mit der Zeit für so schöne Dinge. 😖
      Sascha
      NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
      • W woupi
        @woupi
        Moin,
        mich auch.
        Discovery started
          34                                               4
        [bluetooth]#
        Sascha
        W Offline
        W Offline
        woupi
        Ich habe mich jetzt auf die suche nach dem wiki gemacht.
        Ich habe dich bestimmt auch falsch verstanden, denn da gibt es keinen Punkt iobroker auf Proxmox.
        wendy2702W ? 2 Antworten Letzte Antwort
        • W woupi
          wendy2702W Offline
          wendy2702W Offline
          @woupi nimm einfach dass:
          https://www.iobroker.net/#de/documentation/install/proxmox.md
          • wendy2702W wendy2702
            W Offline
            W Offline
            woupi
            @wendy2702 sagte in NUC Proxmox Bluetooth onboard:
            Es ging darum, dass ich
            das, für ein Wiki zusammentragen sollte. Gut wenn jetzt mit wiki eine Dokumentation gemeint ist, komme ich damit, wenn ich es weiß, parat. Aber eintragen kann ich da doch nichts, oder?
            Irgendwie stehe ich auf dem Schlauch.
            • W woupi
              wendy2702W Offline
              wendy2702W Offline
              @woupi schreibe es doch mal runter und poste es hier. Dann bekommen wir das auch in die Doku.
              • W woupi
                @woupi
                Moin,
                ja ich meinte das, was @wendy2702 dir gezeigt hat, Danke dafür.
                Ja Du darfst da nichts eintragen, aber man kann einen Post machen und der Wiki Beauftragte, kann das dann sicherlich dort einfügen, den richtigen werden wir schon finden :)
                Bernd
                • W Offline
                  W Offline
                  woupi
                  Dank euch beiden,
                  ok, dann werde ich das machen, heute allerdings nicht mehr, ich habe mich schon einer anderen Baustelle gewidmet und bin jetzt durch (kann nicht mehr).
                  Sascha
                  • W woupi
                    Dank euch beiden,
                    Sascha
                    wendy2702W Offline
                    wendy2702W Offline
                    @woupi Kein Stress.
                    • W Offline
                      W Offline
                      woupi
                      Ich habe versucht es so knapp wie möglich zusammen zu schreiben.
                      NUC-Proxmox-VM-iobroker onBoard Bluetooth durchreichen:
                      1. onBoard Bluetooth im Bios aktivieren, falls deaktiviert
                      2. über z.B. Putty, oder direkt in Proxmox in der VM "iobroker", an der Konsole anmelden
                      3. mit
                      lsusb
                      überprüfen ob der onBoard Adapter vorhanden ist (Beispiel)
                      Bus 001 Device 003: ID 8087:0026 Intel Corp
                      1. Wenn der Bluetooth Adapter vorhanden ist, in Proxmox in der VM "iobroker", Hardware --> Hinzufügen --> USB -Gerät-->Hersteller/Geräte ID verwenden --> Gerät Wählen --> das mit lsusb gefundene Gerät auswählen (hier 8087:0026)
                      2. Hinzufügen
                      3. Wieder auf die Konsole der VM "iobroker" wechseln
                      Bluetoothctl
                      Scan -on
                      Jetzt sollten Bluetooth Geräte gefunden werden, sofern es aktive Geräte in der Nähe gibt
                      xxxxxxxx@iobroker:~$ sudo bluetoothctl
                      [sudo] password for xxxxxxxx:
                      Agent registered
                      [CHG] Controller 08:71:90:56:38:C0 Pairable: yes
                      Discovery started
                      [NEW] Device 4C:BA:D7:80:3C:59 [LG] webOS TV OLED55G29LA
                      [bluetooth]#
                      mit exit wieder beenden.
                      Nun könnt Ihr in iobroker Bluetooth Geräte einbinden
