  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.8k Aufrufe 52 Beobachtet
  • wendy2702W Online
    wendy2702W Online
    #388
    Habe gerade mal die aktuelle Version installiert.
    Bei mir fehlen unter consumables die Angaben in Pozent wie lange die Verschleißteile noch halten.
    Habe Instanz schon gestoppt, Objekte gelöscht und Instanz neu gestartet.
    Adapter start sieht so aus:
    2023-03-02 18:55:17.195  - info: host.iobroker "system.adapter.roborock.0" enabled
    2023-03-02 18:55:17.572  - info: host.iobroker instance system.adapter.roborock.0 started with pid 297607
    2023-03-02 18:55:19.029  - debug: roborock.0 (297607) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-03-02 18:55:19.070  - debug: roborock.0 (297607) Objects client ready ... initialize now
    2023-03-02 18:55:19.112  - debug: roborock.0 (297607) Objects create System PubSub Client
    2023-03-02 18:55:19.112  - debug: roborock.0 (297607) Objects create User PubSub Client
    2023-03-02 18:55:19.195  - debug: roborock.0 (297607) Objects client initialize lua scripts
    2023-03-02 18:55:19.203  - debug: roborock.0 (297607) Objects connected to redis: 0.0.0.0:9001
    2023-03-02 18:55:19.242  - debug: roborock.0 (297607) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-03-02 18:55:19.278  - debug: roborock.0 (297607) States create System PubSub Client
    2023-03-02 18:55:19.279  - debug: roborock.0 (297607) States create User PubSub Client
    2023-03-02 18:55:19.365  - debug: roborock.0 (297607) States connected to redis: 0.0.0.0:9000
    2023-03-02 18:55:19.672  - info: roborock.0 (297607) starting. Version 0.0.10-alpha.0 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.14.2, js-controller: 4.0.24
    2023-03-02 18:55:20.141  - debug: roborock.0 (297607) Init debug: undefined
    2023-03-02 18:55:20.251  - debug: roborock.0 (297607) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
    2023-03-02 18:55:20.277  - info: roborock.0 (297607) MQTT initialized
    2023-03-02 18:55:20.285  - debug: roborock.0 (297607) Robot key: roborock.vacuum.a15
    2023-03-02 18:55:20.647  - debug: roborock.0 (297607) dps debug: {"id":1,"result":["ok"]}
    2023-03-02 18:55:20.991  - debug: roborock.0 (297607) socket connection status: null
    2023-03-02 18:55:20.994  - warn: roborock.0 (297607) State "roborock.0.Devices.52xxxxxxxxDmr.map.mapData" has no existing object, this might lead to an error in future versions
    2023-03-02 18:55:20.994  - warn: roborock.0 (297607) State "roborock.0.Devices.52xxxxxxxxDmr.map.mapBase64" has no existing object, this might lead to an error in future versions
    2023-03-02 18:55:21.006  - warn: roborock.0 (297607) State "roborock.0.Devices.52mxxxxxxxDmr.map.mapBase64Truncated" has no existing object, this might lead to an error in future versions
    2023-03-02 18:55:22.911  - debug: roborock.0 (297607) getParameter: get_fw_features
    2023-03-02 18:55:22.911  - debug: roborock.0 (297607) Firmware features request
    2023-03-02 18:55:22.911  - debug: roborock.0 (297607) getParameter: get_multi_maps_list
    2023-03-02 18:55:22.912  - debug: roborock.0 (297607) getParameter: get_room_mapping
    2023-03-02 18:55:22.912  - debug: roborock.0 (297607) get_room_mapping
    2023-03-02 18:55:23.005  - debug: roborock.0 (297607) dps debug: {"id":2,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
    2023-03-02 18:55:23.006  - debug: roborock.0 (297607) dps debug: {"id":3,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1677678491,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
    2023-03-02 18:55:23.028  - debug: roborock.0 (297607) dps debug: {"id":4,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
    2023-03-02 18:55:23.028  - debug: roborock.0 (297607) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
    2023-03-02 18:55:23.073  - debug: roborock.0 (297607) onStateChange: load_multi_map with value: 0
    2023-03-02 18:55:23.230  - debug: roborock.0 (297607) dps debug: {"id":5,"result":["retry"]}
    2023-03-02 18:55:23.231  - error: roborock.0 (297607) Failed to create canvas: retry
    2023-03-02 18:55:23.766  - debug: roborock.0 (297607) dps debug: {"id":6,"result":["ok"]}
    2023-03-02 18:55:23.767  - debug: roborock.0 (297607) Map okloaded.
    2023-03-02 18:55:23.859  - debug: roborock.0 (297607) dps debug: {"id":8,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) get_room_mapping via load_multi_map: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397445 with name: Flur
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397450 with name: Schlafzimmer
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397453 with name: Bad
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397457 with name: Arbeitszimmer
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397459 with name: Wohnzimmer
    2023-03-02 18:55:23.860  - debug: roborock.0 (297607) Mapped room matched: 10397463 with name: Küche
    2023-03-02 18:55:23.966  - debug: roborock.0 (297607) dps debug: {"id":7,"result":["ok"]}
    2023-03-02 18:55:24.285  - debug: roborock.0 (297607) socket connection status: null
    2023-03-02 18:55:52.929  - debug: roborock.0 (297607) Latest data requested
    2023-03-02 18:55:52.936  - debug: roborock.0 (297607) getParameter: get_status
    2023-03-02 18:55:52.962  - debug: roborock.0 (297607) getParameter: get_consumable
    2023-03-02 18:55:52.963  - debug: roborock.0 (297607) getParameter: get_network_info
    2023-03-02 18:55:52.964  - debug: roborock.0 (297607) Update map
    2023-03-02 18:55:52.969  - debug: roborock.0 (297607) getParameter: get_carpet_mode
    2023-03-02 18:55:52.969  - debug: roborock.0 (297607) getParameter: get_carpet_clean_mode
    2023-03-02 18:55:52.969  - debug: roborock.0 (297607) getParameter: get_water_box_custom_mode
    2023-03-02 18:55:53.034  - debug: roborock.0 (297607) dps debug: {"id":9,"result":[{"msg_ver":2,"msg_seq":1914,"state":8,"battery":100,"clean_time":2550,"clean_area":40712500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
    2023-03-02 18:55:53.035  - debug: roborock.0 (297607) get_status: {"msg_ver":2,"msg_seq":1914,"state":8,"battery":100,"clean_time":2550,"clean_area":40712500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}
    2023-03-02 18:55:53.113  - debug: roborock.0 (297607) dps debug: {"id":10,"result":[{"main_brush_work_time":643840,"side_brush_work_time":643840,"filter_work_time":98748,"filter_element_work_time":0,"sensor_dirty_time":112058,"dust_collection_work_times":60}]}
    2023-03-02 18:55:53.116  - debug: roborock.0 (297607) dps debug: {"id":11,"result":{"ssid":"WANOSOHO","ip":"192.168.178.73","mac":"b0:4a:39:38:3e:72","bssid":"76:83:c2:9a:11:5d","rssi":-65}}
    2023-03-02 18:55:53.118  - debug: roborock.0 (297607) dps debug: {"id":13,"result":{"clean_time":643820,"clean_area":9494165000,"clean_count":391,"dust_collection_count":326,"records":[1677675855,1677499871,1677422225,1677230274,1677226995,1677136060,1677066719,1676982752,1676965395,1676714863,1676714836,1676553466,1676549100,1676462483,1676312526,1676308476,1676302620,1676302509,1676292110,1676203358]}}
    2023-03-02 18:55:53.129  - debug: roborock.0 (297607) dps debug: {"id":15,"result":[{"carpet_clean_mode":1}]}
    2023-03-02 18:55:53.130  - debug: roborock.0 (297607) dps debug: {"id":14,"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    2023-03-02 18:55:53.138  - debug: roborock.0 (297607) dps debug: {"id":16,"result":[203]}
    2023-03-02 18:55:53.172  - debug: roborock.0 (297607) dps debug: {"id":17,"result":[{"begin":1677675855,"end":1677678405,"duration":2550,"area":40712500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.173  - debug: roborock.0 (297607) Cleaning record: {"begin":1677675855,"end":1677678405,"duration":2550,"area":40712500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.198  - debug: roborock.0 (297607) dps debug: {"id":19,"result":[{"begin":1677422225,"end":1677425056,"duration":2831,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.198  - debug: roborock.0 (297607) Cleaning record: {"begin":1677422225,"end":1677425056,"duration":2831,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.200  - debug: roborock.0 (297607) dps debug: {"id":25,"result":[{"begin":1676965395,"end":1676965624,"duration":229,"area":5177500,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":1}]}
    2023-03-02 18:55:53.200  - debug: roborock.0 (297607) Cleaning record: {"begin":1676965395,"end":1676965624,"duration":229,"area":5177500,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":1}
    2023-03-02 18:55:53.202  - debug: roborock.0 (297607) dps debug: {"id":24,"result":[{"begin":1676982752,"end":1676986375,"duration":3517,"area":40877500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.202  - debug: roborock.0 (297607) Cleaning record: {"begin":1676982752,"end":1676986375,"duration":3517,"area":40877500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.203  - debug: roborock.0 (297607) dps debug: {"id":26,"result":[{"begin":1676714863,"end":1676717480,"duration":2617,"area":40660000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.203  - debug: roborock.0 (297607) Cleaning record: {"begin":1676714863,"end":1676717480,"duration":2617,"area":40660000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.203  - debug: roborock.0 (297607) dps debug: {"id":31,"result":[{"begin":1676312526,"end":1676313224,"duration":698,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.203  - debug: roborock.0 (297607) Cleaning record: {"begin":1676312526,"end":1676313224,"duration":698,"area":11827500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.204  - debug: roborock.0 (297607) dps debug: {"id":20,"result":[{"begin":1677230274,"end":1677238596,"duration":2656,"area":37345000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.204  - debug: roborock.0 (297607) Cleaning record: {"begin":1677230274,"end":1677238596,"duration":2656,"area":37345000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.204  - debug: roborock.0 (297607) dps debug: {"id":18,"result":[{"begin":1677499871,"end":1677502529,"duration":2657,"area":40902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.204  - debug: roborock.0 (297607) Cleaning record: {"begin":1677499871,"end":1677502529,"duration":2657,"area":40902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.205  - debug: roborock.0 (297607) dps debug: {"id":32,"result":[{"begin":1676308476,"end":1676309969,"duration":1493,"area":22955000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.205  - debug: roborock.0 (297607) Cleaning record: {"begin":1676308476,"end":1676309969,"duration":1493,"area":22955000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.205  - debug: roborock.0 (297607) dps debug: {"id":22,"result":[{"begin":1677136060,"end":1677136166,"duration":106,"area":2767500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
    2023-03-02 18:55:53.206  - debug: roborock.0 (297607) Cleaning record: {"begin":1677136060,"end":1677136166,"duration":106,"area":2767500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}
    2023-03-02 18:55:53.206  - debug: roborock.0 (297607) dps debug: {"id":27,"result":[{"begin":1676714836,"end":1676714840,"duration":4,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":37,"dust_collection_status":0}]}
    2023-03-02 18:55:53.206  - debug: roborock.0 (297607) Cleaning record: {"begin":1676714836,"end":1676714840,"duration":4,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":37,"dust_collection_status":0}
    2023-03-02 18:55:53.208  - debug: roborock.0 (297607) dps debug: {"id":28,"result":[{"begin":1676553466,"end":1676553468,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
    2023-03-02 18:55:53.208  - debug: roborock.0 (297607) Cleaning record: {"begin":1676553466,"end":1676553468,"duration":1,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}
    2023-03-02 18:55:53.209  - debug: roborock.0 (297607) dps debug: {"id":30,"result":[{"begin":1676462483,"end":1676465190,"duration":2707,"area":40237500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.209  - debug: roborock.0 (297607) Cleaning record: {"begin":1676462483,"end":1676465190,"duration":2707,"area":40237500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.210  - debug: roborock.0 (297607) dps debug: {"id":33,"result":[{"begin":1676302620,"end":1676308304,"duration":1060,"area":19920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
    2023-03-02 18:55:53.210  - debug: roborock.0 (297607) Cleaning record: {"begin":1676302620,"end":1676308304,"duration":1060,"area":19920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}
    2023-03-02 18:55:53.210  - debug: roborock.0 (297607) dps debug: {"id":36,"result":[{"begin":1676203358,"end":1676206131,"duration":2773,"area":41585000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.210  - debug: roborock.0 (297607) Cleaning record: {"begin":1676203358,"end":1676206131,"duration":2773,"area":41585000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.211  - debug: roborock.0 (297607) dps debug: {"id":35,"result":[{"begin":1676292110,"end":1676293918,"duration":1808,"area":29330000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.211  - debug: roborock.0 (297607) Cleaning record: {"begin":1676292110,"end":1676293918,"duration":1808,"area":29330000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.211  - debug: roborock.0 (297607) dps debug: {"id":21,"result":[{"begin":1677226995,"end":1677229239,"duration":2244,"area":37375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.211  - debug: roborock.0 (297607) dps debug: {"id":23,"result":[{"begin":1677066719,"end":1677069130,"duration":2411,"area":36420000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:53.211  - debug: roborock.0 (297607) Cleaning record: {"begin":1677226995,"end":1677229239,"duration":2244,"area":37375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:53.212  - debug: roborock.0 (297607) Cleaning record: {"begin":1677066719,"end":1677069130,"duration":2411,"area":36420000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:54.447  - debug: roborock.0 (297607) dps debug: {"id":29,"result":[{"begin":1676549100,"end":1676551700,"duration":2600,"area":40600000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-03-02 18:55:54.447  - debug: roborock.0 (297607) Cleaning record: {"begin":1676549100,"end":1676551700,"duration":2600,"area":40600000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}
    2023-03-02 18:55:54.448  - debug: roborock.0 (297607) dps debug: {"id":34,"result":[{"begin":1676302509,"end":1676302540,"duration":31,"area":367500,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
    2023-03-02 18:55:54.448  - debug: roborock.0 (297607) Cleaning record: {"begin":1676302509,"end":1676302540,"duration":31,"area":367500,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}
    2023-03-02 18:55:54.449  - debug: roborock.0 (297607) dps debug: {"id":12,"result":["ok"]}
    2023-03-02 18:55:54.907  - debug: roborock.0 (297607) socket connection status: null
    2023-03-02 18:56:22.911  - debug: roborock.0 (297607) Latest data requested
    2023-03-02 18:56:22.912  - debug: roborock.0 (297607) getParameter: get_status
    2023-03-02 18:56:22.912  - debug: roborock.0 (297607) getParameter: get_consumable
    2023-03-02 18:56:22.912  - debug: roborock.0 (297607) getParameter: get_network_info
    2023-03-02 18:56:22.913  - debug: roborock.0 (297607) Update map
    2023-03-02 18:56:22.913  - debug: roborock.0 (297607) getParameter: get_carpet_mode
    2023-03-02 18:56:22.913  - debug: roborock.0 (297607) getParameter: get_carpet_clean_mode
    2023-03-02 18:56:22.913  - debug: roborock.0 (297607) getParameter: get_water_box_custom_mode
    2023-03-02 18:56:23.002  - debug: roborock.0 (297607) dps debug: {"id":39,"result":{"ssid":"WXXXXXXXO","ip":"192.168.178.73","mac":"b0:XXXXXX72","bssid":"76:83:c2:9a:11:5d","rssi":-65}}
    Und da fällt mir das auf:
    roborock.0
    2023-03-02 19:08:34.608	info	starting. Version 0.0.10-alpha.0 (non-npm: copystring/ioBroker.roborock#dev) in /opt/iobroker/node_modules/iobroker.roborock, node: v18.14.2, js-controller: 4.0.24
    Obwohl laut Admin neueste installiert:
    copystringC 2 Antworten Letzte Antwort
    • wendy2702W wendy2702
      roborock.0
      copystringC Offline
      copystringC Offline
      copystring
      schrieb am zuletzt editiert von copystring
      #389
      @wendy2702 cool. Wie kommt das denn darein? 😂
      Das wird automatisch verwaltet...
      Edit: Merkwürdig, aber in dev ist das bereits behoben.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
        roborock.0
        copystringC Offline
        copystringC Offline
        copystring
        #390
        @wendy2702 Probiere bitte dev Version aus. Dort sind bereits einige Fehler behoben.
        Hast du vielleicht einen Roboter älter als S7? Dann würde das wahrscheinlich passen.
        • copystringC Offline
          copystringC Offline
          copystring
          #391
          Ich versuche gerade herauszufinden, wie in der Roborock App die Räume eingefärbt werden.
          Kann es sein, dass die Räume nach der Raumgröße eingefärbt werden? Die Reihenfolge der Raumfarbe von klein nach groß scheint so zu sein: Türkis → Rot → Orange → Blau
          Bei meinen Karten sind die Räume in Rot und Orange ziemlich gleich groß. Daher könnte es sein, dass Rot und Orange doch umgekehrt sind. Könnt ihr das mit euren Karten in der Roborock App vergleichen?
          David G.D N 2 Antworten Letzte Antwort
          • copystringC copystring
            David G.D Online
            David G.D Online
            David G.
            #392
            @copystring
            Kann mir deine Karten ja leider nicht anschauen.
            So sehen die Farben bei mir in der App aus.
              N Offline
              N Offline
              nathan1312
              #393
              @copystring sagte in Roborock Adapter tester gesucht:
              ich bin mir ziemlich sicher, dass die Farbe nicht (alleine) von der Raumgröße abhängt. Auf der Karte werden zwei nebeneinander liegende Räume ja nie in derselben Farbe angezeigt. Das hat auf jeden Fall Priorität bei der Farbvergabe.
              • N nathan1312
                David G.D Online
                David G.D Online
                David G.
                #394
                @nathan1312 sagte in Roborock Adapter tester gesucht:
                Das erste Bild von mir bestaidas auch. Die Räume sind ja alle ca gleich groß.
                  @tschoeplis said in Roborock Adapter tester gesucht:
                  @david-g ich habe nur eine Etage, da steht (0) drin
                  Hast du der Etage in der App keinen Namen gegeben?
                  tschoeplis
                  #395
                  @copystring Etagenname, dass war das Problem. Danke
                  Ich habe einen Etagennamen vergeben und alles neu installiert. Nun funktioniert auch bei mir die Zimmerreinigung ;-)
                    Dimi
                    #396
                    @copystring
                    Also bei mir sind zwar die Datenpunkte unter Consumables jetzt da aber die werden nicht gefüllt. Ich habe die alte Adapterversion deinstalliert und die Version 0.1.3 installiert. Ich habe den S6 MaxV
                    Unter HomeData sind die Werte jedoch da.
                    "deviceStatus":{"120":0,"121":18,"122":93,"123":106,"124":204,"125":99,"126":98,"127":97}
                    copystringC 1 Antwort Letzte Antwort
                    • D Dimi
                      @copystring
                      copystringC Offline
                      copystringC Offline
                      copystring
                      #397
                      @dimi said in Roborock Adapter tester gesucht:
                      @copystring
                      OK. Dann funktioniert der s6 maxv wie ein s7. Das kann ich später noch anpassen. Dann werden die Werte als 125, 126 und 127 erscheinen.
                        @copystring
                        Dimi
                        #398
                        @copystring
                        Mit der neuen Version stürtzt der Adapter ab. Das habe ich jetzt erst gemerkt. Da ich ioBroker unter Raspberry pi 4 betreibe habe ich die Kartendarstellung deaktiviert. Also hat es nichts mit der Map zu tun. In den letzten Versionen hat der Adapter ohne die Kartendrstellung auch gut funktioniert. Anbei der debug Log.
                        Fallls ich eine Issue aufmachen soll, dann gib Bescheid.
                        2023-03-04 22:11:22.961 - info: host.ioBroker-RasPi "system.adapter.roborock.0" enabled
                        2023-03-04 22:11:23.230 - info: host.ioBroker-RasPi instance system.adapter.roborock.0 started with pid 19384
                        2023-03-04 22:11:25.103 - debug: roborock.0 (19384) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-03-04 22:11:25.154 - debug: roborock.0 (19384) Objects client ready ... initialize now
                        2023-03-04 22:11:25.157 - debug: roborock.0 (19384) Objects create System PubSub Client
                        2023-03-04 22:11:25.158 - debug: roborock.0 (19384) Objects create User PubSub Client
                        2023-03-04 22:11:25.214 - debug: roborock.0 (19384) Objects client initialize lua scripts
                        2023-03-04 22:11:25.223 - debug: roborock.0 (19384) Objects connected to redis: 127.0.0.1:9001
                        2023-03-04 22:11:25.262 - debug: roborock.0 (19384) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-03-04 22:11:25.281 - debug: roborock.0 (19384) States create System PubSub Client
                        2023-03-04 22:11:25.283 - debug: roborock.0 (19384) States create User PubSub Client
                        2023-03-04 22:11:25.362 - debug: roborock.0 (19384) States connected to redis: 127.0.0.1:9000
                        2023-03-04 22:11:25.466 - debug: roborock.0 (19384) Plugin sentry Initialize Plugin (enabled=true)
                        2023-03-04 22:11:25.473 - info: roborock.0 (19384) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-03-04 22:11:25.621 - info: roborock.0 (19384) starting. Version 0.1.3 (non-npm: copystring/ioBroker.roborock#ac791acf50e71d92720a4a536285fbfaffcaef9c) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
                        2023-03-04 22:11:26.103 - info: roborock.0 (19384) MQTT initialized
                        2023-03-04 22:11:26.105 - debug: roborock.0 (19384) RoomIDs debug: {"4517900":"Küche","4524358":"Kinderzimmer","4524368":"Schlafzimmer","4524483":"Bad","4524523":"Flur","4526290":"Gäste WC","4526403":"Wohnzimmer","4527411":"Heizraum"}
                        2023-03-04 22:11:26.110 - debug: roborock.0 (19384) Robot key: roborock.vacuum.a10
                        2023-03-04 22:11:26.469 - debug: roborock.0 (19384) getParameter: get_fw_features
                        2023-03-04 22:11:26.470 - debug: roborock.0 (19384) Firmware features request
                        2023-03-04 22:11:26.474 - debug: roborock.0 (19384) getParameter: get_multi_maps_list
                        2023-03-04 22:11:26.476 - debug: roborock.0 (19384) Latest data requested
                        2023-03-04 22:11:26.477 - debug: roborock.0 (19384) getParameter: get_status
                        2023-03-04 22:11:26.478 - debug: roborock.0 (19384) getParameter: get_consumable
                        2023-03-04 22:11:26.480 - debug: roborock.0 (19384) getParameter: get_network_info
                        2023-03-04 22:11:26.552 - debug: roborock.0 (19384) dps debug: {"id":6,"result":[25529,284035000,28,[1677948252,1677947496,1677946124,1677945412,1677943775,1677943347,1677941836,1677940521,1677938198,1677935777,1677874339,1677873334,1676921862,1676906243,1676903837,1676059068,1676051600,1676051536,1676036591,1676034772]]}
                        2023-03-04 22:11:26.569 - debug: roborock.0 (19384) dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1676023062,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1675975972,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
                        2023-03-04 22:11:26.574 - debug: roborock.0 (19384) dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                        2023-03-04 22:11:26.577 - debug: roborock.0 (19384) dps debug: {"id":4,"result":[{"main_brush_work_time":25584,"side_brush_work_time":25584,"filter_work_time":25584,"filter_element_work_time":3502,"sensor_dirty_time":25529}]}
                        2023-03-04 22:11:26.579 - debug: roborock.0 (19384) dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":4878,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}]}
                        2023-03-04 22:11:26.581 - debug: roborock.0 (19384) get_status: {"msg_ver":2,"msg_seq":4878,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}
                        2023-03-04 22:11:26.637 - debug: roborock.0 (19384) dps debug: {"id":5,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-49}}
                        2023-03-04 22:11:26.643 - debug: roborock.0 (19384) dps debug: {"id":7,"result":[[1677948252,1677948686,434,4127500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.645 - debug: roborock.0 (19384) Cleaning record: [1677948252,1677948686,434,4127500,0,1,2,3,56]
                        2023-03-04 22:11:26.677 - debug: roborock.0 (19384) dps debug: {"id":15,"result":[[1677938198,1677939258,1060,19120000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.678 - debug: roborock.0 (19384) Cleaning record: [1677938198,1677939258,1060,19120000,0,1,2,3,56]
                        2023-03-04 22:11:26.680 - debug: roborock.0 (19384) dps debug: {"id":9,"result":[[1677946124,1677946790,666,11780000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.681 - debug: roborock.0 (19384) Cleaning record: [1677946124,1677946790,666,11780000,0,1,2,3,56]
                        2023-03-04 22:11:26.687 - debug: roborock.0 (19384) dps debug: {"id":8,"result":[[1677947496,1677947948,452,7805000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.688 - debug: roborock.0 (19384) Cleaning record: [1677947496,1677947948,452,7805000,0,1,2,3,56]
                        2023-03-04 22:11:26.690 - debug: roborock.0 (19384) dps debug: {"id":12,"result":[[1677943347,1677943668,321,3607500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.692 - debug: roborock.0 (19384) Cleaning record: [1677943347,1677943668,321,3607500,0,1,2,3,56]
                        2023-03-04 22:11:26.694 - debug: roborock.0 (19384) dps debug: {"id":10,"result":[[1677945412,1677946080,668,11695000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.695 - debug: roborock.0 (19384) Cleaning record: [1677945412,1677946080,668,11695000,0,1,2,3,56]
                        2023-03-04 22:11:26.699 - debug: roborock.0 (19384) dps debug: {"id":11,"result":[[1677943775,1677944130,355,3640000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.700 - debug: roborock.0 (19384) Cleaning record: [1677943775,1677944130,355,3640000,0,1,2,3,56]
                        2023-03-04 22:11:26.702 - debug: roborock.0 (19384) dps debug: {"id":16,"result":[[1677935777,1677938021,2244,19407500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.703 - debug: roborock.0 (19384) Cleaning record: [1677935777,1677938021,2244,19407500,0,1,2,3,56]
                        2023-03-04 22:11:26.705 - debug: roborock.0 (19384) dps debug: {"id":25,"result":[[1676036591,1676036948,357,3572500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.706 - debug: roborock.0 (19384) Cleaning record: [1676036591,1676036948,357,3572500,0,1,2,3,56]
                        2023-03-04 22:11:26.708 - debug: roborock.0 (19384) dps debug: {"id":24,"result":[[1676051536,1676051568,22,0,0,0,2,3,60]]}
                        2023-03-04 22:11:26.709 - debug: roborock.0 (19384) dps debug: {"id":18,"result":[[1677873334,1677874242,908,7950000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.709 - debug: roborock.0 (19384) Cleaning record: [1676051536,1676051568,22,0,0,0,2,3,60]
                        2023-03-04 22:11:26.710 - debug: roborock.0 (19384) Cleaning record: [1677873334,1677874242,908,7950000,0,1,2,3,56]
                        2023-03-04 22:11:26.712 - debug: roborock.0 (19384) dps debug: {"id":14,"result":[[1677940521,1677941615,1094,8802500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.713 - debug: roborock.0 (19384) dps debug: {"id":13,"result":[[1677941836,1677942370,534,8825000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.714 - debug: roborock.0 (19384) Cleaning record: [1677940521,1677941615,1094,8802500,0,1,2,3,56]
                        2023-03-04 22:11:26.714 - debug: roborock.0 (19384) Cleaning record: [1677941836,1677942370,534,8825000,0,1,2,3,56]
                        2023-03-04 22:11:26.716 - debug: roborock.0 (19384) dps debug: {"id":20,"result":[[1676906243,1676907146,903,7945000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.717 - debug: roborock.0 (19384) Cleaning record: [1676906243,1676907146,903,7945000,0,1,2,3,56]
                        2023-03-04 22:11:26.718 - debug: roborock.0 (19384) dps debug: {"id":21,"result":[[1676903837,1676905210,1373,11760000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.719 - debug: roborock.0 (19384) Cleaning record: [1676903837,1676905210,1373,11760000,0,1,2,3,56]
                        2023-03-04 22:11:26.811 - debug: roborock.0 (19384) dps debug: {"id":17,"result":[[1677874339,1677875649,1310,11890000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.813 - debug: roborock.0 (19384) Cleaning record: [1677874339,1677875649,1310,11890000,0,1,2,3,56]
                        2023-03-04 22:11:26.815 - debug: roborock.0 (19384) dps debug: {"id":22,"result":[[1676059068,1676060385,1317,11925000,0,1,2,3,56]]}
                        2023-03-04 22:11:26.815 - debug: roborock.0 (19384) Cleaning record: [1676059068,1676060385,1317,11925000,0,1,2,3,56]
                        2023-03-04 22:11:26.817 - debug: roborock.0 (19384) dps debug: {"id":26,"result":[[1676034772,1676036070,1089,8902500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.818 - debug: roborock.0 (19384) dps debug: {"id":23,"result":[[1676051600,1676052498,898,7932500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.818 - debug: roborock.0 (19384) Cleaning record: [1676034772,1676036070,1089,8902500,0,1,2,3,56]
                        2023-03-04 22:11:26.819 - debug: roborock.0 (19384) Cleaning record: [1676051600,1676052498,898,7932500,0,1,2,3,56]
                        2023-03-04 22:11:26.821 - debug: roborock.0 (19384) dps debug: {"id":19,"result":[[1676921862,1676922313,451,4172500,0,1,2,3,56]]}
                        2023-03-04 22:11:26.821 - debug: roborock.0 (19384) Cleaning record: [1676921862,1676922313,451,4172500,0,1,2,3,56]
                        2023-03-04 22:11:32.525 - debug: roborock.0 (19384) Websocket client connected
                        2023-03-04 22:11:32.567 - error: roborock.0 (19384) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-03-04 22:11:32.568 - error: roborock.0 (19384) unhandled promise rejection: Unexpected end of JSON input
                        2023-03-04 22:11:32.569 - error: roborock.0 (19384) SyntaxError: Unexpected end of JSON input
                        at JSON.parse ()
                        at /opt/iobroker/node_modules/iobroker.roborock/main.js:376:30
                        at async WebSocket. (/opt/iobroker/node_modules/iobroker.roborock/main.js:374:7)
                        2023-03-04 22:11:32.569 - error: roborock.0 (19384) Unexpected end of JSON input
                        2023-03-04 22:11:32.575 - info: roborock.0 (19384) terminating
                        2023-03-04 22:11:32.577 - debug: roborock.0 (19384) Plugin sentry destroyed
                        2023-03-04 22:11:32.578 - warn: roborock.0 (19384) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-03-04 22:11:33.237 - error: host.ioBroker-RasPi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-03-04 22:11:33.238 - info: host.ioBroker-RasPi Restart adapter system.adapter.roborock.0 because enabled
                        2023-03-04 22:12:03.388 - info: host.ioBroker-RasPi instance system.adapter.roborock.0 started with pid 19459
                        2023-03-04 22:12:05.267 - debug: roborock.0 (19459) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-03-04 22:12:05.318 - debug: roborock.0 (19459) Objects client ready ... initialize now
                        2023-03-04 22:12:05.321 - debug: roborock.0 (19459) Objects create System PubSub Client
                        2023-03-04 22:12:05.323 - debug: roborock.0 (19459) Objects create User PubSub Client
                        2023-03-04 22:12:05.383 - debug: roborock.0 (19459) Objects client initialize lua scripts
                        2023-03-04 22:12:05.392 - debug: roborock.0 (19459) Objects connected to redis: 127.0.0.1:9001
                        2023-03-04 22:12:05.431 - debug: roborock.0 (19459) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-03-04 22:12:05.511 - debug: roborock.0 (19459) States create System PubSub Client
                        2023-03-04 22:12:05.513 - debug: roborock.0 (19459) States create User PubSub Client
                        2023-03-04 22:12:05.592 - debug: roborock.0 (19459) States connected to redis: 127.0.0.1:9000
                        2023-03-04 22:12:05.706 - debug: roborock.0 (19459) Plugin sentry Initialize Plugin (enabled=true)
                        2023-03-04 22:12:05.712 - info: roborock.0 (19459) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-03-04 22:12:05.890 - info: roborock.0 (19459) starting. Version 0.1.3 (non-npm: copystring/ioBroker.roborock#ac791acf50e71d92720a4a536285fbfaffcaef9c) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
                        2023-03-04 22:12:06.374 - info: roborock.0 (19459) MQTT initialized
                        2023-03-04 22:12:06.375 - debug: roborock.0 (19459) RoomIDs debug: {"4517900":"Küche","4524358":"Kinderzimmer","4524368":"Schlafzimmer","4524483":"Bad","4524523":"Flur","4526290":"Gäste WC","4526403":"Wohnzimmer","4527411":"Heizraum"}
                        2023-03-04 22:12:06.383 - debug: roborock.0 (19459) Robot key: roborock.vacuum.a10
                        2023-03-04 22:12:06.754 - debug: roborock.0 (19459) getParameter: get_fw_features
                        2023-03-04 22:12:06.755 - debug: roborock.0 (19459) Firmware features request
                        2023-03-04 22:12:06.760 - debug: roborock.0 (19459) getParameter: get_multi_maps_list
                        2023-03-04 22:12:06.762 - debug: roborock.0 (19459) Latest data requested
                        2023-03-04 22:12:06.763 - debug: roborock.0 (19459) getParameter: get_status
                        2023-03-04 22:12:06.764 - debug: roborock.0 (19459) getParameter: get_consumable
                        2023-03-04 22:12:06.765 - debug: roborock.0 (19459) getParameter: get_network_info
                        2023-03-04 22:12:06.819 - debug: roborock.0 (19459) dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                        2023-03-04 22:12:06.822 - debug: roborock.0 (19459) dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1676023062,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1675975972,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
                        2023-03-04 22:12:06.853 - debug: roborock.0 (19459) dps debug: {"id":4,"result":[{"main_brush_work_time":25584,"side_brush_work_time":25584,"filter_work_time":25584,"filter_element_work_time":3502,"sensor_dirty_time":25529}]}
                        2023-03-04 22:12:06.866 - debug: roborock.0 (19459) dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":4879,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}]}
                        2023-03-04 22:12:06.867 - debug: roborock.0 (19459) get_status: {"msg_ver":2,"msg_seq":4879,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}
                        2023-03-04 22:12:06.915 - debug: roborock.0 (19459) dps debug: {"id":5,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-49}}
                        2023-03-04 22:12:06.930 - debug: roborock.0 (19459) dps debug: {"id":6,"result":[25529,284035000,28,[1677948252,1677947496,1677946124,1677945412,1677943775,1677943347,1677941836,1677940521,1677938198,1677935777,1677874339,1677873334,1676921862,1676906243,1676903837,1676059068,1676051600,1676051536,1676036591,1676034772]]}
                        2023-03-04 22:12:06.988 - debug: roborock.0 (19459) dps debug: {"id":7,"result":[[1677948252,1677948686,434,4127500,0,1,2,3,56]]}
                        2023-03-04 22:12:06.990 - debug: roborock.0 (19459) Cleaning record: [1677948252,1677948686,434,4127500,0,1,2,3,56]
                        2023-03-04 22:12:06.995 - debug: roborock.0 (19459) dps debug: {"id":10,"result":[[1677945412,1677946080,668,11695000,0,1,2,3,56]]}
                        2023-03-04 22:12:06.996 - debug: roborock.0 (19459) Cleaning record: [1677945412,1677946080,668,11695000,0,1,2,3,56]
                        2023-03-04 22:12:06.999 - debug: roborock.0 (19459) dps debug: {"id":8,"result":[[1677947496,1677947948,452,7805000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.000 - debug: roborock.0 (19459) Cleaning record: [1677947496,1677947948,452,7805000,0,1,2,3,56]
                        2023-03-04 22:12:07.003 - debug: roborock.0 (19459) dps debug: {"id":11,"result":[[1677943775,1677944130,355,3640000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.004 - debug: roborock.0 (19459) Cleaning record: [1677943775,1677944130,355,3640000,0,1,2,3,56]
                        2023-03-04 22:12:07.006 - debug: roborock.0 (19459) dps debug: {"id":12,"result":[[1677943347,1677943668,321,3607500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.007 - debug: roborock.0 (19459) Cleaning record: [1677943347,1677943668,321,3607500,0,1,2,3,56]
                        2023-03-04 22:12:07.009 - debug: roborock.0 (19459) dps debug: {"id":9,"result":[[1677946124,1677946790,666,11780000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.010 - debug: roborock.0 (19459) Cleaning record: [1677946124,1677946790,666,11780000,0,1,2,3,56]
                        2023-03-04 22:12:07.025 - debug: roborock.0 (19459) dps debug: {"id":13,"result":[[1677941836,1677942370,534,8825000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.026 - debug: roborock.0 (19459) Cleaning record: [1677941836,1677942370,534,8825000,0,1,2,3,56]
                        2023-03-04 22:12:07.028 - debug: roborock.0 (19459) dps debug: {"id":17,"result":[[1677874339,1677875649,1310,11890000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.029 - debug: roborock.0 (19459) Cleaning record: [1677874339,1677875649,1310,11890000,0,1,2,3,56]
                        2023-03-04 22:12:07.031 - debug: roborock.0 (19459) dps debug: {"id":23,"result":[[1676051600,1676052498,898,7932500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.032 - debug: roborock.0 (19459) Cleaning record: [1676051600,1676052498,898,7932500,0,1,2,3,56]
                        2023-03-04 22:12:07.034 - debug: roborock.0 (19459) dps debug: {"id":20,"result":[[1676906243,1676907146,903,7945000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.034 - debug: roborock.0 (19459) Cleaning record: [1676906243,1676907146,903,7945000,0,1,2,3,56]
                        2023-03-04 22:12:07.036 - debug: roborock.0 (19459) dps debug: {"id":15,"result":[[1677938198,1677939258,1060,19120000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.036 - debug: roborock.0 (19459) Cleaning record: [1677938198,1677939258,1060,19120000,0,1,2,3,56]
                        2023-03-04 22:12:07.038 - debug: roborock.0 (19459) dps debug: {"id":22,"result":[[1676059068,1676060385,1317,11925000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.040 - debug: roborock.0 (19459) dps debug: {"id":24,"result":[[1676051536,1676051568,22,0,0,0,2,3,60]]}
                        2023-03-04 22:12:07.040 - debug: roborock.0 (19459) Cleaning record: [1676059068,1676060385,1317,11925000,0,1,2,3,56]
                        2023-03-04 22:12:07.041 - debug: roborock.0 (19459) Cleaning record: [1676051536,1676051568,22,0,0,0,2,3,60]
                        2023-03-04 22:12:07.043 - debug: roborock.0 (19459) dps debug: {"id":14,"result":[[1677940521,1677941615,1094,8802500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.043 - debug: roborock.0 (19459) Cleaning record: [1677940521,1677941615,1094,8802500,0,1,2,3,56]
                        2023-03-04 22:12:07.045 - debug: roborock.0 (19459) dps debug: {"id":21,"result":[[1676903837,1676905210,1373,11760000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.046 - debug: roborock.0 (19459) Cleaning record: [1676903837,1676905210,1373,11760000,0,1,2,3,56]
                        2023-03-04 22:12:07.086 - debug: roborock.0 (19459) dps debug: {"id":16,"result":[[1677935777,1677938021,2244,19407500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.088 - debug: roborock.0 (19459) dps debug: {"id":18,"result":[[1677873334,1677874242,908,7950000,0,1,2,3,56]]}
                        2023-03-04 22:12:07.089 - debug: roborock.0 (19459) Cleaning record: [1677935777,1677938021,2244,19407500,0,1,2,3,56]
                        2023-03-04 22:12:07.090 - debug: roborock.0 (19459) Cleaning record: [1677873334,1677874242,908,7950000,0,1,2,3,56]
                        2023-03-04 22:12:07.093 - debug: roborock.0 (19459) dps debug: {"id":19,"result":[[1676921862,1676922313,451,4172500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.094 - debug: roborock.0 (19459) Cleaning record: [1676921862,1676922313,451,4172500,0,1,2,3,56]
                        2023-03-04 22:12:07.096 - debug: roborock.0 (19459) dps debug: {"id":25,"result":[[1676036591,1676036948,357,3572500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.097 - debug: roborock.0 (19459) Cleaning record: [1676036591,1676036948,357,3572500,0,1,2,3,56]
                        2023-03-04 22:12:07.100 - debug: roborock.0 (19459) dps debug: {"id":26,"result":[[1676034772,1676036070,1089,8902500,0,1,2,3,56]]}
                        2023-03-04 22:12:07.101 - debug: roborock.0 (19459) Cleaning record: [1676034772,1676036070,1089,8902500,0,1,2,3,56]
                        2023-03-04 22:12:07.663 - debug: roborock.0 (19459) Websocket client connected
                        2023-03-04 22:12:07.688 - error: roborock.0 (19459) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-03-04 22:12:07.688 - error: roborock.0 (19459) unhandled promise rejection: Unexpected end of JSON input
                        2023-03-04 22:12:07.689 - error: roborock.0 (19459) SyntaxError: Unexpected end of JSON input
                        at JSON.parse ()
                        2023-03-04 22:12:07.689 - error: roborock.0 (19459) Unexpected end of JSON input
                        2023-03-04 22:12:07.693 - info: roborock.0 (19459) terminating
                        2023-03-04 22:12:07.695 - debug: roborock.0 (19459) Plugin sentry destroyed
                        2023-03-04 22:12:07.695 - warn: roborock.0 (19459) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-03-04 22:12:08.278 - error: host.ioBroker-RasPi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-03-04 22:12:08.279 - info: host.ioBroker-RasPi Restart adapter system.adapter.roborock.0 because enabled
                        2023-03-04 22:12:38.437 - info: host.ioBroker-RasPi instance system.adapter.roborock.0 started with pid 19495
                        2023-03-04 22:12:40.276 - debug: roborock.0 (19495) Redis Objects: Use Redis connection: 127.0.0.1:9001
                        2023-03-04 22:12:40.328 - debug: roborock.0 (19495) Objects client ready ... initialize now
                        2023-03-04 22:12:40.331 - debug: roborock.0 (19495) Objects create System PubSub Client
                        2023-03-04 22:12:40.332 - debug: roborock.0 (19495) Objects create User PubSub Client
                        2023-03-04 22:12:40.396 - debug: roborock.0 (19495) Objects client initialize lua scripts
                        2023-03-04 22:12:40.404 - debug: roborock.0 (19495) Objects connected to redis: 127.0.0.1:9001
                        2023-03-04 22:12:40.443 - debug: roborock.0 (19495) Redis States: Use Redis connection: 127.0.0.1:9000
                        2023-03-04 22:12:40.464 - debug: roborock.0 (19495) States create System PubSub Client
                        2023-03-04 22:12:40.466 - debug: roborock.0 (19495) States create User PubSub Client
                        2023-03-04 22:12:40.542 - debug: roborock.0 (19495) States connected to redis: 127.0.0.1:9000
                        2023-03-04 22:12:40.645 - debug: roborock.0 (19495) Plugin sentry Initialize Plugin (enabled=true)
                        2023-03-04 22:12:40.651 - info: roborock.0 (19495) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
                        2023-03-04 22:12:40.785 - info: roborock.0 (19495) starting. Version 0.1.3 (non-npm: copystring/ioBroker.roborock#ac791acf50e71d92720a4a536285fbfaffcaef9c) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.1, js-controller: 4.0.24
                        2023-03-04 22:12:41.451 - info: roborock.0 (19495) MQTT initialized
                        2023-03-04 22:12:41.452 - debug: roborock.0 (19495) RoomIDs debug: {"4517900":"Küche","4524358":"Kinderzimmer","4524368":"Schlafzimmer","4524483":"Bad","4524523":"Flur","4526290":"Gäste WC","4526403":"Wohnzimmer","4527411":"Heizraum"}
                        2023-03-04 22:12:41.476 - debug: roborock.0 (19495) Robot key: roborock.vacuum.a10
                        2023-03-04 22:12:41.864 - debug: roborock.0 (19495) getParameter: get_fw_features
                        2023-03-04 22:12:41.865 - debug: roborock.0 (19495) Firmware features request
                        2023-03-04 22:12:41.869 - debug: roborock.0 (19495) getParameter: get_multi_maps_list
                        2023-03-04 22:12:41.871 - debug: roborock.0 (19495) Latest data requested
                        2023-03-04 22:12:41.872 - debug: roborock.0 (19495) getParameter: get_status
                        2023-03-04 22:12:41.873 - debug: roborock.0 (19495) getParameter: get_consumable
                        2023-03-04 22:12:41.875 - debug: roborock.0 (19495) getParameter: get_network_info
                        2023-03-04 22:12:41.976 - debug: roborock.0 (19495) dps debug: {"id":4,"result":[{"main_brush_work_time":25584,"side_brush_work_time":25584,"filter_work_time":25584,"filter_element_work_time":3502,"sensor_dirty_time":25529}]}
                        2023-03-04 22:12:41.981 - debug: roborock.0 (19495) dps debug: {"id":3,"result":[{"msg_ver":2,"msg_seq":4880,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}]}
                        2023-03-04 22:12:41.983 - debug: roborock.0 (19495) get_status: {"msg_ver":2,"msg_seq":4880,"state":2,"battery":28,"clean_time":434,"clean_area":4127500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":3,"water_box_status":0,"fan_power":106,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":204,"distance_off":0,"water_box_carriage_status":0,"mop_forbidden_enable":0,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0]}
                        2023-03-04 22:12:41.987 - debug: roborock.0 (19495) dps debug: {"id":1,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
                        2023-03-04 22:12:41.997 - debug: roborock.0 (19495) dps debug: {"id":6,"result":[25529,284035000,28,[1677948252,1677947496,1677946124,1677945412,1677943775,1677943347,1677941836,1677940521,1677938198,1677935777,1677874339,1677873334,1676921862,1676906243,1676903837,1676059068,1676051600,1676051536,1676036591,1676034772]]}
                        2023-03-04 22:12:42.012 - debug: roborock.0 (19495) dps debug: {"id":2,"result":[{"max_multi_map":4,"max_bak_map":0,"multi_map_count":2,"map_info":[{"mapFlag":0,"add_time":1676023062,"length":11,"name":"Erdgeschoss","bak_maps":[]},{"mapFlag":1,"add_time":1675975972,"length":12,"name":"Obergeschoss","bak_maps":[]}]}]}
                        2023-03-04 22:12:42.057 - debug: roborock.0 (19495) dps debug: {"id":5,"result":{"ssid":"xxx","ip":"xxx","mac":"xxx","bssid":"xxx","rssi":-49}}
                        2023-03-04 22:12:42.062 - debug: roborock.0 (19495) dps debug: {"id":8,"result":[[1677947496,1677947948,452,7805000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.064 - debug: roborock.0 (19495) Cleaning record: [1677947496,1677947948,452,7805000,0,1,2,3,56]
                        2023-03-04 22:12:42.067 - debug: roborock.0 (19495) dps debug: {"id":9,"result":[[1677946124,1677946790,666,11780000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.068 - debug: roborock.0 (19495) Cleaning record: [1677946124,1677946790,666,11780000,0,1,2,3,56]
                        2023-03-04 22:12:42.076 - debug: roborock.0 (19495) dps debug: {"id":12,"result":[[1677943347,1677943668,321,3607500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.077 - debug: roborock.0 (19495) Cleaning record: [1677943347,1677943668,321,3607500,0,1,2,3,56]
                        2023-03-04 22:12:42.079 - debug: roborock.0 (19495) dps debug: {"id":16,"result":[[1677935777,1677938021,2244,19407500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.080 - debug: roborock.0 (19495) Cleaning record: [1677935777,1677938021,2244,19407500,0,1,2,3,56]
                        2023-03-04 22:12:42.082 - debug: roborock.0 (19495) dps debug: {"id":15,"result":[[1677938198,1677939258,1060,19120000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.083 - debug: roborock.0 (19495) Cleaning record: [1677938198,1677939258,1060,19120000,0,1,2,3,56]
                        2023-03-04 22:12:42.084 - debug: roborock.0 (19495) dps debug: {"id":13,"result":[[1677941836,1677942370,534,8825000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.085 - debug: roborock.0 (19495) Cleaning record: [1677941836,1677942370,534,8825000,0,1,2,3,56]
                        2023-03-04 22:12:42.087 - debug: roborock.0 (19495) dps debug: {"id":10,"result":[[1677945412,1677946080,668,11695000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.088 - debug: roborock.0 (19495) Cleaning record: [1677945412,1677946080,668,11695000,0,1,2,3,56]
                        2023-03-04 22:12:42.090 - debug: roborock.0 (19495) dps debug: {"id":7,"result":[[1677948252,1677948686,434,4127500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.091 - debug: roborock.0 (19495) Cleaning record: [1677948252,1677948686,434,4127500,0,1,2,3,56]
                        2023-03-04 22:12:42.092 - debug: roborock.0 (19495) dps debug: {"id":18,"result":[[1677873334,1677874242,908,7950000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.093 - debug: roborock.0 (19495) Cleaning record: [1677873334,1677874242,908,7950000,0,1,2,3,56]
                        2023-03-04 22:12:42.118 - debug: roborock.0 (19495) dps debug: {"id":24,"result":[[1676051536,1676051568,22,0,0,0,2,3,60]]}
                        2023-03-04 22:12:42.119 - debug: roborock.0 (19495) Cleaning record: [1676051536,1676051568,22,0,0,0,2,3,60]
                        2023-03-04 22:12:42.121 - debug: roborock.0 (19495) dps debug: {"id":20,"result":[[1676906243,1676907146,903,7945000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.121 - debug: roborock.0 (19495) Cleaning record: [1676906243,1676907146,903,7945000,0,1,2,3,56]
                        2023-03-04 22:12:42.123 - debug: roborock.0 (19495) dps debug: {"id":14,"result":[[1677940521,1677941615,1094,8802500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.124 - debug: roborock.0 (19495) Cleaning record: [1677940521,1677941615,1094,8802500,0,1,2,3,56]
                        2023-03-04 22:12:42.126 - debug: roborock.0 (19495) dps debug: {"id":17,"result":[[1677874339,1677875649,1310,11890000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.127 - debug: roborock.0 (19495) Cleaning record: [1677874339,1677875649,1310,11890000,0,1,2,3,56]
                        2023-03-04 22:12:42.128 - debug: roborock.0 (19495) dps debug: {"id":11,"result":[[1677943775,1677944130,355,3640000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.129 - debug: roborock.0 (19495) Cleaning record: [1677943775,1677944130,355,3640000,0,1,2,3,56]
                        2023-03-04 22:12:42.130 - debug: roborock.0 (19495) dps debug: {"id":25,"result":[[1676036591,1676036948,357,3572500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.131 - debug: roborock.0 (19495) Cleaning record: [1676036591,1676036948,357,3572500,0,1,2,3,56]
                        2023-03-04 22:12:42.133 - debug: roborock.0 (19495) dps debug: {"id":19,"result":[[1676921862,1676922313,451,4172500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.134 - debug: roborock.0 (19495) Cleaning record: [1676921862,1676922313,451,4172500,0,1,2,3,56]
                        2023-03-04 22:12:42.168 - debug: roborock.0 (19495) dps debug: {"id":23,"result":[[1676051600,1676052498,898,7932500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.169 - debug: roborock.0 (19495) Cleaning record: [1676051600,1676052498,898,7932500,0,1,2,3,56]
                        2023-03-04 22:12:42.183 - debug: roborock.0 (19495) dps debug: {"id":22,"result":[[1676059068,1676060385,1317,11925000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.183 - debug: roborock.0 (19495) Cleaning record: [1676059068,1676060385,1317,11925000,0,1,2,3,56]
                        2023-03-04 22:12:42.185 - debug: roborock.0 (19495) dps debug: {"id":21,"result":[[1676903837,1676905210,1373,11760000,0,1,2,3,56]]}
                        2023-03-04 22:12:42.190 - debug: roborock.0 (19495) Cleaning record: [1676903837,1676905210,1373,11760000,0,1,2,3,56]
                        2023-03-04 22:12:42.192 - debug: roborock.0 (19495) dps debug: {"id":26,"result":[[1676034772,1676036070,1089,8902500,0,1,2,3,56]]}
                        2023-03-04 22:12:42.193 - debug: roborock.0 (19495) Cleaning record: [1676034772,1676036070,1089,8902500,0,1,2,3,56]
                        2023-03-04 22:12:44.806 - debug: roborock.0 (19495) Websocket client connected
                        2023-03-04 22:12:44.850 - error: roborock.0 (19495) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                        2023-03-04 22:12:44.851 - error: roborock.0 (19495) unhandled promise rejection: Unexpected end of JSON input
                        2023-03-04 22:12:44.852 - error: roborock.0 (19495) SyntaxError: Unexpected end of JSON input
                        at JSON.parse ()
                        2023-03-04 22:12:44.853 - error: roborock.0 (19495) Unexpected end of JSON input
                        2023-03-04 22:12:44.859 - info: roborock.0 (19495) terminating
                        2023-03-04 22:12:44.861 - debug: roborock.0 (19495) Plugin sentry destroyed
                        2023-03-04 22:12:44.862 - warn: roborock.0 (19495) Terminated (UNCAUGHT_EXCEPTION): Without reason
                        2023-03-04 22:12:45.512 - error: host.ioBroker-RasPi instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                        2023-03-04 22:12:45.513 - info: host.ioBroker-RasPi Restart adapter system.adapter.roborock.0 because enabled
                        2023-03-04 22:12:45.513 - warn: host.ioBroker-RasPi Do not restart adapter system.adapter.roborock.0 because restart loop detected
                        2023-03-04 22:13:21.124 - info: host.ioBroker-RasPi "system.adapter.roborock.0" disabled
                        • D Dimi
                          @copystring
                          at JSON.parse ()
                          at JSON.parse ()
                          at JSON.parse ()
                          copystringC Offline
                          copystringC Offline
                          copystring
                          #399
                          @copystring
                          at JSON.parse ()
                          at JSON.parse ()
                          at JSON.parse ()
                          Jupp. Du hast auf die Weboberfläche zugegriffen während das Erstellen der Karte deaktiviert ist. Das führt zu einem Fehler da die Kartendaten nicht existieren. Ist in der dev Version behoben. Dort werden die Server nicht mehr gestartet wenn das Erstellen der Karte deaktiviert ist.
                          • David G.D Online
                            David G.D Online
                            David G.
                            #400
                            @copystring
                            Hast du schon was zum Verhalten von zum fortsetzen der Pause festgestellt?
                            • David G.D David G.
                              @copystring
                              copystringC Offline
                              copystringC Offline
                              copystring
                              #401
                              @david-g said in Roborock Adapter tester gesucht:
                              @copystring
                              Nein. Aktuell mangelt es an Zeit. Mein Saugroboter ging heute dazu noch kaputt und musste den erstmal reparieren.
                              Ein paar Gedanken darüber wie das zu implementieren ist habe ich mir bereits gemacht, aber hatte noch keine Zeit mich aktiv darum zu kümmern.
                                @copystring
                                David G.D Online
                                David G.D Online
                                David G.
                                #402
                                @copystring
                                Wir haben ja alle keine Not.
                                Wir sind dankbar für den Adapter wie er jetzt ist und für jede so kleine langsame entwicklung dankbar.
                                Dann Kummer dich erstmal um deinen kleinen ^^.
                                  @copystring
                                  copystringC Offline
                                  copystringC Offline
                                  copystring
                                  #403
                                  @copystring
                                  OK. Das war dann doch weniger Arbeit als ich dachte. Es hat gereicht, zwei neue Befehle hinzuzufügen: resume_segment_clean und resume_zoned_clean.
                                  Zum Verständnis: Wenn app_pause ausgeführt wird und dann app_start wird die Reinigung fortgesetzt, wenn diese mit app_start gestartet wurde.
                                  Für die Raumreinigung und Zonenreinigung funktioniert app_pause ebenfalls. Nur das Fortsetzen klappt dann entsprechend nur mit resume_segment_clean oder resume_zoned_clean.
                                  Wenn du magst, dann kannst du das hier testen https://github.com/copystring/ioBroker.roborock/tree/dev oder auf den nächsten release warten.
                                    @copystring
                                    David G.D Online
                                    David G.D Online
                                    David G.
                                    #404
                                    @copystring
                                    Hab es grad getestet.
                                    Klappt wunderbar bei mir.
                                    So ein Saugrobotor ist schon was komplexer als eine Glühbirne.
                                    Man hat für alles schöne Datenpunkte, jedoch alles sauber umzusetzen in der Visu ist schon eine Herausforderung.
                                    Man möchte ja keine 3 Buttons zum starten/pausieren/fortsetzen haben.
                                    Wobei mir grad beim schreiben eine Idee kommt. Mal sehen ob ich es so mache oder eine Anregung für euch ist.
                                    Man könnte den "Start- oder Pauseknoof" doppelt belegen. Ein Skript müsste dann prüfen, ob zuletzt der Datenpunkt zum Starten oder Pausieren getätigt wurde und dann das Gegenteil ausführen.
                                    Oder man fragt den Status ab, da kann es eben was dauern bin man diesen aktuell hat nach dem Pausieren.
                                    EDIT
                                    @copystring
                                    Denkst du, dass es (nicht nur für mich ^^) interessant ist, den Adapter sofort (500ms oder so) nach einem command nochmal die Daten einlesen zu lassen?
                                    Alternativ einen DP zum aktualisieren. Den könnte man sich dann bei Bedarf selber Triggern über einen selector etc.
                                    So hat man nach einer Aktion direkt den entsprechenden Status. So könnte man dann auch den intervall zum abrufen ggf was runterstellen.
                                      @copystring
                                      EDIT
                                      @copystring
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #405
                                      Ja. Ich habe bereits darüber nachgedacht. Das Problem mit Timern wie z. B. 500ms ist, dass ein Fehlverhalten entstehen würde, wenn der Adapter nach 500ms noch keine Antwort vom vorherigen Befehl erhalten hat.
                                      Also habe ich mir das mal angeschaut und versucht es so umzusetzen, dass der Befehl des Datenabrufens erst dann durchgeführt wird, wenn der erste Befehl fertig ist. Das reicht aber leider nicht aus.
                                      Aktuell habe ich keine passende Idee, dies sauber umzusetzen, ohne Timer einzusetzen.
                                        copystringC Offline
                                        copystring
                                        #406
                                        Wer mag, kann die 0.1.4-beta.0 testen. Wenn dort keine gravierenden Bugs auftreten, wird das der nächste Release.
                                        M-A HuebM 1 Antwort Letzte Antwort
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          #407
                                          @copystring
                                          Könnte man ggf mit einer Sperrvariable oder so arbeiten? Über einen timestamp könnte man das ohne Timer machen.
                                          Neuer Abruf nur, wenn Sperrvariable älter s x sek. Wenn Aufruf erfolgt Sperrvariable auf false.
