  3. Einsteigerfragen
  4. Absturzursache Raspi und iO Broker finden
    5.5k
148 Beiträge 11 Kommentatoren 18.3k Aufrufe 9 Beobachtet
  • L Laser
    bin da gerade drin: (läßt sich ja Alles rückgängig machen)
    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
    #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
    #neu:
    ### official Debian mirrors might be more up-to-date...
    deb http://ftp.debian.org/debian stable main contrib non-free
    deb http://security.debian.org/debian-security stable/updates main contrib non-free
    deb http://ftp.debian.org/debian stable-updates main contrib non-free
    #deb http://ftp.debian.org/debian stable-proposed-updates main contrib non-free
    #90
    @laser
    Und danach
    sudo apt update
    L 1 Antwort Letzte Antwort
      @laser
      Und danach
      sudo apt update
      Laser
      #91
      pi@Heizung:~ $ sudo apt upgrade
      Reading package lists... Done
      Calculating upgrade... Done
      The following package was automatically installed and is no longer required:
        raspinfo
      Use 'sudo apt autoremove' to remove it.
      The following packages will be upgraded:
        curl libcurl3-gnutls libcurl4 libtiff5
      4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      Need to get 1,144 kB of archives.
      After this operation, 0 B of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf curl armhf 7.                       74.0-1.3+deb11u7 [258 kB]
      Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl4 armh                       f 7.74.0-1.3+deb11u7 [310 kB]
      Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl3-gnut                       ls armhf 7.74.0-1.3+deb11u7 [306 kB]
      Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libtiff5 armh                       f 4.2.0-1+deb11u4 [270 kB]
      Fetched 1,144 kB in 1s (1,171 kB/s)
      Reading changelogs... Done
      (Reading database ... 54016 files and directories currently installed.)
      Preparing to unpack .../curl_7.74.0-1.3+deb11u7_armhf.deb ...
      Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u7_armhf.deb ...
      Unpacking libcurl4:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
      Preparing to unpack .../libcurl3-gnutls_7.74.0-1.3+deb11u7_armhf.deb ...
      Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) .                       ..
      Preparing to unpack .../libtiff5_4.2.0-1+deb11u4_armhf.deb ...
      Unpacking libtiff5:armhf (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
      Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) ...
      Setting up libcurl4:armhf (7.74.0-1.3+deb11u7) ...
      Setting up libtiff5:armhf (4.2.0-1+deb11u4) ...
      Setting up curl (7.74.0-1.3+deb11u7) ...
      Processing triggers for man-db (2.9.4-2) ...
      Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
      pi@Heizung:~ $ nano /etc/apt/sources.list
      pi@Heizung:~ $ sudo nano/etc/apt/sources.list
      sudo: nano/etc/apt/sources.list: command not found
      pi@Heizung:~ $ sudo nano /etc/apt/sources.list
      pi@Heizung:~ $
      pi@Heizung:~ $ sudo apt update
      Get:1 http://security.debian.org/debian-security stable-security InRelease [48.4 kB]
      Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Get:3 http://deb.debian.org/debian stable InRelease [116 kB]
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 http://deb.debian.org/debian stable-updates InRelease [44.1 kB]
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      0% [Working]gpgv: Signature made Wed Mar  1 05:32:51 2023 CET
      gpgv:                using RSA key A0DA38D0D76E8B5D638872819165938D90FDDD2E
      gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>"
      /usr/bin/apt-key: 57: cannot create /dev/null: Permission denied
      0% [Working]gpgv: Signature made Sat Dec 17 11:15:20 2022 CET
      gpgv:                using RSA key 0146DC6D4A0B2914BDED34DB648ACFD622F3D138
      gpgv: Can't check signature: No public key
      gpgv: Signature made Sat Dec 17 11:15:21 2022 CET
      gpgv:                using RSA key A7236886F3CCCAAD148A27F80E98404D386FA1D9
      gpgv: Signature made Sat Dec 17 11:20:04 2022 CET
      gpgv:                using RSA key A4285295FC7B1A81600062A9605C66F00D6C9793
      gpgv:                issuer "debian-release@lists.debian.org"
      Err:3 http://deb.debian.org/debian stable InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      0% [Working]gpgv: Signature made Wed Mar  1 06:32:42 2023 CET
      gpgv:                using RSA key 5237CEEEF212F3D51C74ABE0112695A0E562B32A
      gpgv: Signature made Wed Mar  1 06:32:43 2023 CET
      gpgv:                using RSA key ED541312A33F1128F10B1C6C54404762BBB6E853
      Err:1 http://security.debian.org/debian-security stable-security InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      0% [Working]gpgv: Signature made Tue Feb 28 15:00:50 2023 CET
      gpgv:                using RSA key CF8A1AF502A2AA2D763BAE7E82B129927FA3303E
      gpgv: Good signature from "Raspberry Pi Archive Signing Key"
      0% [Working]gpgv: Signature made Wed Mar  1 09:14:56 2023 CET
      gpgv: Signature made Wed Mar  1 09:15:35 2023 CET
      Err:5 http://deb.debian.org/debian stable-updates InRelease
      0% [Working]gpgv: Signature made Fri Feb 17 01:55:45 2023 CET
      gpgv:                using RSA key 9FD3B784BC1C6FC31A8A0A1C1655A0AB68576280
      gpgv: Good signature from "NodeSource <gpg@nodesource.com>"
      W: GPG error: http://deb.debian.org/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
      E: The repository 'http://deb.debian.org/debian stable InRelease' is not signed.
      N: Updating from such a repository can't be done securely, and is therefore disabled by default.
      N: See apt-secure(8) manpage for repository creation and user configuration details.
      W: GPG error: http://security.debian.org/debian-security stable-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
      E: The repository 'http://security.debian.org/debian-security stable-security InRelease' is not signed.
      W: GPG error: http://deb.debian.org/debian stable-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
      E: The repository 'http://deb.debian.org/debian stable-updates InRelease' is not signed.
        raspinfo
      0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
      • L Laser
          raspinfo
        pi@Heizung:~ $
          raspinfo
        #92
        @laser
        Ersetz mal 'stable' durch den Releasename das du da fährst. 'bullseye'?
          @laser
          Laser
          schrieb am zuletzt editiert von Laser
          #93
          @thomas-braun so?
          deb http://deb.debian.org/debian bullseye main contrib non-free
          deb http://security.debian.org/debian-security bullseye-security main contrib non-free
          deb http://deb.debian.org/debian bullseye-updates main contrib non-free
          pi@Heizung:/etc/apt$ sudo apt update
          Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
          Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48                     .4 kB]
          Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Get:5 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
          gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <                     mpthompson@gmail.com>"
          Err:2 http://security.debian.org/debian-security bullseye-security InRelease
            The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
          Err:1 http://deb.debian.org/debian bullseye InRelease
            The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F                     00D6C9793
          Err:5 http://deb.debian.org/debian bullseye-updates InRelease
          W: GPG error: http://security.debian.org/debian-security bullseye-security InRel                     ease: The following signatures couldn't be verified because the public key is no                     t available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
          E: The repository 'http://security.debian.org/debian-security bullseye-security                      InRelease' is not signed.
          N: Updating from such a repository can't be done securely, and is therefore disa                     bled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration deta                     ils.
          W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following sig                     natures couldn't be verified because the public key is not available: NO_PUBKEY                      648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
          E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signe                     d.
          W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The follo                     wing signatures couldn't be verified because the public key is not available: NO                     _PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
          E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is n                     ot signed.
          pi@Heizung:/etc/apt$ sudo apt upgrade
            raspinfo
          • L Laser
            @thomas-braun so?
              raspinfo
            #94
            @laser
            Irgendwas stimmt mit den signaturen noch nicht.
            Ich kann aber im Moment nicht nachschauen, weil ich hier ein ganz anderes System fahre.
              @laser
              Laser
              #95
              Kein Problem!
              Ich suche mal nach einem anderen Pi zur Testinstallation. Ich muß jetzt auch erst mal weg.
              Unabhängig von den falschen Quellen hat meine FritzBox ein Problem. Muß ich auch immer mal neu starten. Evtl. hat der Hersteller ein "Gute Nacht- kauf mal was Neues" - Update installiert?
              • L Laser
                Kein Problem!
                #96
                @laser sagte in Absturzursache Raspi und iO Broker finden:
                Das siehst du ja in entsprechenden Logs.
                Wenn du die nicht ausknipsen würdest jedenfalls...
                  Laser
                  #97
                  ich werde die logs wieder einschalten. Aber gefunden habe ich darin bisher nichts Brauchbares...
                  • L Laser
                    Ich "treibe " überhaupt nichts! Das System ist eingerichte, wie es die Anleitung gezeigt hat. Das einzige, was ch "getrieben" habe, sind regelmäßige "Updates" apt-get Update und apt-get upgrade
                    #98
                    welche?
                      welche?
                      Laser
                      #99
                      Da müßte ich jetzt suchen. Ist schon eine Weile her. Aber es war die, welche mir hier einige Beiträge vorher hier im Forum empfohlen wurde.
                      IO-Broker so mit dem Script:
                      sudo apt install curl
                      sudo curl -sL https://iobroker.net/install.sh | bash -
                      Zu Beginn hatte ich noch Debmatic mit drauf. Habe ich jetzt auf einem extra Pi.
                      • L Laser
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        #100
                        @laser hör bitte auf wie "früher" deine Beiträge nachträglich zu editieren... und:
                        macht man nicht --- ohne sudo ist da angesagt auf einem gescheiten System !
                        Lehrling seit 1975 !!!
                        • DJMarc75D DJMarc75
                          Laser
                          #101
                          @djmarc75
                          Das habe ich jetzt nur aus einer alten Textdatei kopiert. Jetzt sehe ich es auch. Habe zum Schluß aber ohne sudo installiert. Muß die abgelegte Hilfedatei korrigieren.
                          • L Laser
                            @djmarc75
                            Laser
                            #102
                            @laser und vorher Debian mit dem Rasberry Imager.
                            Wenn ich nicht eine offline Vis Lizenz hätte, würde ich Alles neu auf einem anderen Pi installieren...
                            • L Laser
                              Laser
                              #103
                              @laser lassen sie die Rechte nachträglich mit sinnvollem Aufwand anpassen?
                              • L Laser
                                wendy2702W Offline
                                wendy2702W Offline
                                #104
                                @laser welche Rechte willst du anpassen?
                                • wendy2702W wendy2702
                                  Laser
                                  #105
                                  @wendy2702
                                  Falls ich, wie hier vermutet wurde, etwas mit Sudo Rechten installiert hätte.
                                  L DJMarc75D 2 Antworten Letzte Antwort
                                  • L Laser
                                    @wendy2702
                                    Laser
                                    #106
                                    @laser
                                    Brauche das System heute noch. Habe gerade ein Backup gemacht. Wie lange wird eine komplette Neuinstallation etwa dauern?
                                    • L Laser
                                      @laser
                                      Laser
                                      #107
                                      @laser
                                      Beschreibe gerade eine neue SD Card. Ziehe ein Image und schreibe das auf die SSD. Dann habe ich immer noch meine alte SSD, wenn es nicht so klappt.
                                      • L Laser
                                        @wendy2702
                                        DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        #108
                                        Wenn man mal Deine vielen Probleme aus Deinen Beiträgen so liest, dann hast Du definitiv da mit irgendwelchem Murks gearbeitet... kein Vorwurf sondern eine Feststellung !
                                        Dann:
                                        wie machs Du das ?
                                        Was sollte das nicht klappen wenn man es richtig macht ?
                                          Dann:
                                          wie machs Du das ?
                                          Laser
                                          #109
                                          @djmarc75
                                          -Installieren mit Raspberry Pi Imager. Image mit Win32 Diskmanager. Beschreiben der SSD mit Balena.
                                          -OW Server installiern
                                          -IOBroker: installieren mit Script.
                                          Ist da was falsch dran?
