  3. Einsteigerfragen
  4. Absturzursache Raspi und iO Broker finden
    5.5k
148 Beiträge 11 Kommentatoren 18.3k Aufrufe 9 Beobachtet
    @laser
    cat /etc/apt/sources.list
    Laser
    schrieb am zuletzt editiert von Laser
    #88
    bin da gerade drin: (läßt sich ja Alles rückgängig machen)
    # Uncomment line below then 'apt-get update' to enable 'apt-get source'
    #deb-src http://raspbian.raspberrypi.org/raspbian/ bullseye main contrib non-free rpi
    #neu:
    ### official Debian mirrors might be more up-to-date...
    deb http://ftp.debian.org/debian stable main contrib non-free
    deb http://security.debian.org/debian-security stable/updates main contrib non-free
    deb http://ftp.debian.org/debian stable-updates main contrib non-free
    #deb http://ftp.debian.org/debian stable-proposed-updates main contrib non-free
    • L Laser
      #neu:
      #89
      @laser sagte in Absturzursache Raspi und iO Broker finden:
      Trag das mal so ein:
      deb http://deb.debian.org/debian stable main contrib non-free
      deb http://security.debian.org/debian-security stable-security main contrib non-free
      deb http://deb.debian.org/debian stable-updates main contrib non-free
      • L Laser
        #neu:
        #90
        @laser
        Und danach
        sudo apt update
        L 1 Antwort Letzte Antwort
          @laser
          Und danach
          sudo apt update
          Laser
          #91
          pi@Heizung:~ $ sudo apt upgrade
          Reading package lists... Done
          Calculating upgrade... Done
          The following package was automatically installed and is no longer required:
            raspinfo
          Use 'sudo apt autoremove' to remove it.
          The following packages will be upgraded:
            curl libcurl3-gnutls libcurl4 libtiff5
          4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Need to get 1,144 kB of archives.
          After this operation, 0 B of additional disk space will be used.
          Do you want to continue? [Y/n] y
          Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf curl armhf 7.                       74.0-1.3+deb11u7 [258 kB]
          Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl4 armh                       f 7.74.0-1.3+deb11u7 [310 kB]
          Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl3-gnut                       ls armhf 7.74.0-1.3+deb11u7 [306 kB]
          Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libtiff5 armh                       f 4.2.0-1+deb11u4 [270 kB]
          Fetched 1,144 kB in 1s (1,171 kB/s)
          Reading changelogs... Done
          (Reading database ... 54016 files and directories currently installed.)
          Preparing to unpack .../curl_7.74.0-1.3+deb11u7_armhf.deb ...
          Unpacking curl (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
          Preparing to unpack .../libcurl4_7.74.0-1.3+deb11u7_armhf.deb ...
          Unpacking libcurl4:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) ...
          Preparing to unpack .../libcurl3-gnutls_7.74.0-1.3+deb11u7_armhf.deb ...
          Unpacking libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) over (7.74.0-1.3+deb11u5) .                       ..
          Preparing to unpack .../libtiff5_4.2.0-1+deb11u4_armhf.deb ...
          Unpacking libtiff5:armhf (4.2.0-1+deb11u4) over (4.2.0-1+deb11u3) ...
          Setting up libcurl3-gnutls:armhf (7.74.0-1.3+deb11u7) ...
          Setting up libcurl4:armhf (7.74.0-1.3+deb11u7) ...
          Setting up libtiff5:armhf (4.2.0-1+deb11u4) ...
          Setting up curl (7.74.0-1.3+deb11u7) ...
          Processing triggers for man-db (2.9.4-2) ...
          Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
          pi@Heizung:~ $ nano /etc/apt/sources.list
          pi@Heizung:~ $ sudo nano/etc/apt/sources.list
          sudo: nano/etc/apt/sources.list: command not found
          pi@Heizung:~ $ sudo nano /etc/apt/sources.list
          pi@Heizung:~ $
          pi@Heizung:~ $ sudo apt update
          Get:1 http://security.debian.org/debian-security stable-security InRelease [48.4 kB]
          Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
          Get:3 http://deb.debian.org/debian stable InRelease [116 kB]
          Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
          Get:5 http://deb.debian.org/debian stable-updates InRelease [44.1 kB]
          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
          0% [Working]gpgv: Signature made Wed Mar  1 05:32:51 2023 CET
          gpgv:                using RSA key A0DA38D0D76E8B5D638872819165938D90FDDD2E
          gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>"
          /usr/bin/apt-key: 57: cannot create /dev/null: Permission denied
          0% [Working]gpgv: Signature made Sat Dec 17 11:15:20 2022 CET
          gpgv:                using RSA key 0146DC6D4A0B2914BDED34DB648ACFD622F3D138
          gpgv: Can't check signature: No public key
          gpgv: Signature made Sat Dec 17 11:15:21 2022 CET
          gpgv:                using RSA key A7236886F3CCCAAD148A27F80E98404D386FA1D9
          gpgv: Signature made Sat Dec 17 11:20:04 2022 CET
          gpgv:                using RSA key A4285295FC7B1A81600062A9605C66F00D6C9793
          gpgv:                issuer "debian-release@lists.debian.org"
          Err:3 http://deb.debian.org/debian stable InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
          0% [Working]gpgv: Signature made Wed Mar  1 06:32:42 2023 CET
          gpgv:                using RSA key 5237CEEEF212F3D51C74ABE0112695A0E562B32A
          gpgv: Signature made Wed Mar  1 06:32:43 2023 CET
          gpgv:                using RSA key ED541312A33F1128F10B1C6C54404762BBB6E853
          Err:1 http://security.debian.org/debian-security stable-security InRelease
            The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
          0% [Working]gpgv: Signature made Tue Feb 28 15:00:50 2023 CET
          gpgv:                using RSA key CF8A1AF502A2AA2D763BAE7E82B129927FA3303E
          gpgv: Good signature from "Raspberry Pi Archive Signing Key"
          0% [Working]gpgv: Signature made Wed Mar  1 09:14:56 2023 CET
          gpgv: Signature made Wed Mar  1 09:15:35 2023 CET
          Err:5 http://deb.debian.org/debian stable-updates InRelease
          0% [Working]gpgv: Signature made Fri Feb 17 01:55:45 2023 CET
          gpgv:                using RSA key 9FD3B784BC1C6FC31A8A0A1C1655A0AB68576280
          gpgv: Good signature from "NodeSource <gpg@nodesource.com>"
          W: GPG error: http://deb.debian.org/debian stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
          E: The repository 'http://deb.debian.org/debian stable InRelease' is not signed.
          N: Updating from such a repository can't be done securely, and is therefore disabled by default.
          N: See apt-secure(8) manpage for repository creation and user configuration details.
          W: GPG error: http://security.debian.org/debian-security stable-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
          E: The repository 'http://security.debian.org/debian-security stable-security InRelease' is not signed.
          W: GPG error: http://deb.debian.org/debian stable-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
          E: The repository 'http://deb.debian.org/debian stable-updates InRelease' is not signed.
            raspinfo
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          • L Laser
              raspinfo
            pi@Heizung:~ $
              raspinfo
            #92
            @laser
            Ersetz mal 'stable' durch den Releasename das du da fährst. 'bullseye'?
              @laser
              Laser
              #93
              @thomas-braun so?
              deb http://deb.debian.org/debian bullseye main contrib non-free
              deb http://security.debian.org/debian-security bullseye-security main contrib non-free
              deb http://deb.debian.org/debian bullseye-updates main contrib non-free
              pi@Heizung:/etc/apt$ sudo apt update
              Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
              Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48                     .4 kB]
              Hit:3 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Get:5 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
              gpgv: Good signature from "Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <                     mpthompson@gmail.com>"
              Err:2 http://security.debian.org/debian-security bullseye-security InRelease
                The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
              Err:1 http://deb.debian.org/debian bullseye InRelease
                The following signatures couldn't be verified because the public key is not av                     ailable: NO_PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F                     00D6C9793
              Err:5 http://deb.debian.org/debian bullseye-updates InRelease
              W: GPG error: http://security.debian.org/debian-security bullseye-security InRel                     ease: The following signatures couldn't be verified because the public key is no                     t available: NO_PUBKEY 112695A0E562B32A NO_PUBKEY 54404762BBB6E853
              E: The repository 'http://security.debian.org/debian-security bullseye-security                      InRelease' is not signed.
              N: Updating from such a repository can't be done securely, and is therefore disa                     bled by default.
              N: See apt-secure(8) manpage for repository creation and user configuration deta                     ils.
              W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following sig                     natures couldn't be verified because the public key is not available: NO_PUBKEY                      648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 605C66F00D6C9793
              E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signe                     d.
              W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The follo                     wing signatures couldn't be verified because the public key is not available: NO                     _PUBKEY 648ACFD622F3D138 NO_PUBKEY 0E98404D386FA1D9
              E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is n                     ot signed.
              pi@Heizung:/etc/apt$ sudo apt upgrade
                raspinfo
              • L Laser
                @thomas-braun so?
                  raspinfo
                #94
                @laser
                Irgendwas stimmt mit den signaturen noch nicht.
                Ich kann aber im Moment nicht nachschauen, weil ich hier ein ganz anderes System fahre.
                  @laser
                  Laser
                  #95
                  Kein Problem!
                  Ich suche mal nach einem anderen Pi zur Testinstallation. Ich muß jetzt auch erst mal weg.
                  Unabhängig von den falschen Quellen hat meine FritzBox ein Problem. Muß ich auch immer mal neu starten. Evtl. hat der Hersteller ein "Gute Nacht- kauf mal was Neues" - Update installiert?
                  • L Laser
                    Kein Problem!
                    #96
                    Das siehst du ja in entsprechenden Logs.
                    Wenn du die nicht ausknipsen würdest jedenfalls...
                      Laser
                      #97
                      ich werde die logs wieder einschalten. Aber gefunden habe ich darin bisher nichts Brauchbares...
                      • L Laser
                        Ich "treibe " überhaupt nichts! Das System ist eingerichte, wie es die Anleitung gezeigt hat. Das einzige, was ch "getrieben" habe, sind regelmäßige "Updates" apt-get Update und apt-get upgrade
                        #98
                        welche?
                          welche?
                          Laser
                          #99
                          Da müßte ich jetzt suchen. Ist schon eine Weile her. Aber es war die, welche mir hier einige Beiträge vorher hier im Forum empfohlen wurde.
                          IO-Broker so mit dem Script:
                          sudo apt install curl
                          sudo curl -sL https://iobroker.net/install.sh | bash -
                          Zu Beginn hatte ich noch Debmatic mit drauf. Habe ich jetzt auf einem extra Pi.
                          • L Laser
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            #100
                            @laser hör bitte auf wie "früher" deine Beiträge nachträglich zu editieren... und:
                            macht man nicht --- ohne sudo ist da angesagt auf einem gescheiten System !
                            Lehrling seit 1975 !!!
                            • DJMarc75D DJMarc75
                              Laser
                              #101
                              @djmarc75
                              Das habe ich jetzt nur aus einer alten Textdatei kopiert. Jetzt sehe ich es auch. Habe zum Schluß aber ohne sudo installiert. Muß die abgelegte Hilfedatei korrigieren.
                              • L Laser
                                @djmarc75
                                Laser
                                #102
                                @laser und vorher Debian mit dem Rasberry Imager.
                                Wenn ich nicht eine offline Vis Lizenz hätte, würde ich Alles neu auf einem anderen Pi installieren...
                                • L Laser
                                  Laser
                                  #103
                                  @laser lassen sie die Rechte nachträglich mit sinnvollem Aufwand anpassen?
                                  • L Laser
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #104
                                    @laser welche Rechte willst du anpassen?
                                    • wendy2702W wendy2702
                                      Laser
                                      #105
                                      @wendy2702
                                      Falls ich, wie hier vermutet wurde, etwas mit Sudo Rechten installiert hätte.
                                      L DJMarc75D 2 Antworten Letzte Antwort
                                      • L Laser
                                        @wendy2702
                                        Laser
                                        #106
                                        @laser
                                        Brauche das System heute noch. Habe gerade ein Backup gemacht. Wie lange wird eine komplette Neuinstallation etwa dauern?
                                        • L Laser
                                          @laser
                                          Laser
                                          #107
                                          @laser
                                          Beschreibe gerade eine neue SD Card. Ziehe ein Image und schreibe das auf die SSD. Dann habe ich immer noch meine alte SSD, wenn es nicht so klappt.
