  3. Einsteigerfragen
  4. Javaskript Fehler Ausgabe Was bedeutet Sie?
    1.9k
    2.4k
7 Beiträge 4 Kommentatoren 668 Aufrufe 4 Beobachtet
  • L Offline
    Langer
    schrieb am zuletzt editiert von Langer
    Nach Umzug auf einen anderen Rechner:
    AMD Phenom(tm) II X6 1090T Processor mit 24GB RAM
    Node.js = 16.19.1
    NPM: 8.19.3
    js-controller: 4.0.24
    bekam ich nach Start eines Skriptes folgende Fehlermeldung im Protokoll:
     javascript.0
    2023-03-01 09:00:54.044	error	Exception-Code: EPIPE: write EPIPE
    javascript.0
    2023-03-01 09:00:54.044	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.043	error	uncaught exception: write EPIPE
    javascript.0
    2023-03-01 09:00:54.041	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.041	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    2023-03-01 09:00:54.040	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    javascript.0
    javascript.0
    2023-03-01 09:00:54.039	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.039	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    2023-03-01 09:00:54.038	error	Exception-Code: EPIPE: write EPIPE
    javascript.0
    javascript.0
    javascript.0
    2023-03-01 09:00:54.038	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.037	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.037	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    2023-03-01 09:00:54.036	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    javascript.0
    2023-03-01 09:00:54.037	error	uncaught exception: write EPIPE
    javascript.0
    javascript.0
    2023-03-01 09:00:54.035	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.035	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    2023-03-01 09:00:54.034	error	Exception-Code: EPIPE: write EPIPE
    javascript.0
    javascript.0
    javascript.0
    2023-03-01 09:00:54.034	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at Log.error (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/log.ts:45:21) at Object.error (/opt/iobroker/node_modules/iobroker.javascript/main.js:823:33) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9341:44) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.033	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at console.value (node:internal/console/constructor:299:16) at console.warn (node:internal/console/constructor:381:26) at console.error (/opt/iobroker/node_modules/@sentry/src/integrations/console.ts:51:29) at Object.logAndExitProcess (/opt/iobroker/node_modules/@sentry/src/integrations/utils/errorhandling.ts:14:11) at OnUncaughtException.handler (/opt/iobroker/node_modules/@sentry/src/integrations/onuncaughtexception.ts:101:9) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    2023-03-01 09:00:54.033	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    javascript.0
    2023-03-01 09:00:54.032	error	Error: write EPIPE at afterWriteDispatched (node:internal/stream_base_commons:160:15) at writeGeneric (node:internal/stream_base_commons:151:3) at Socket._writeGeneric (node:net:905:11) at Socket._write (node:net:917:8) at writeOrBuffer (node:internal/streams/writable:391:12) at _write (node:internal/streams/writable:332:10) at Socket.Writable.write (node:internal/streams/writable:336:10) at Console.log (/opt/iobroker/node_modules/winston/lib/winston/transports/console.js:79:23) at Console._write (/opt/iobroker/node_modules/winston-transport/index.js:103:17) at doWrite (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:380:5) at Console.Writable.write (/opt/iobroker/node_modules/winston-transport/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.ondata (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:629:20) at DerivedLogger.emit (node:events:525:35) at DerivedLogger.emit (node:domain:489:12) at addChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:279:12) at readableAddChunk (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:262:11) at DerivedLogger.Readable.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_readable.js:228:10) at DerivedLogger.Transform.push (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:131:32) at DerivedLogger._transform (/opt/iobroker/node_modules/winston/lib/winston/logger.js:313:12) at DerivedLogger.Transform._read (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:165:10) at DerivedLogger.Transform._write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_transform.js:154:83) at doWrite (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:389:139) at writeOrBuffer (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:380:5) at DerivedLogger.Writable.write (/opt/iobroker/node_modules/winston/node_modules/readable-stream/lib/_stream_writable.js:301:11) at DerivedLogger.<computed> [as error] (/opt/iobroker/node_modules/winston/lib/winston/create-logger.js:81:14) at exceptionHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9371:16) at process.<anonymous> (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.js:9403:44) at process.emit (node:events:525:35) at processEmit (/opt/iobroker/node_modules/signal-exit/index.js:199:34) at process.emit (/opt/iobroker/node_modules/source-map-support/source-map-support.js:516:21) at process._fatalException (node:internal/process/execution:149:25)
    javascript.0
    javascript.0
    2023-03-01 09:00:54.033	error	uncaught exception: write EPIPE
    javascript.0
    javascript.0
    2023-03-01 09:00:54.031	error	An error happened which is most likely from one of your scripts, but the originating script could not be detected.
    Es wird im Skript auch kein log ausgegeben.
    Frage 1: was stimmt da nicht?
    Frage 2: Es sind 24 GB RAM installiert, im Host wird folgende ausgegeben:
    CPU 7.07% RAM: 92.3%, heißt das jetzt,
    obwohl noch keine VIS läuft, nur ein kleines Script gelaufen ist, das bis auf 7.7% der gesamte Speicher in
    Benutzung ist?
    MfG
    Wastl
    Thomas BraunT crunchipC CodierknechtC 3 Antworten Letzte Antwort
    • L Langer
      Node.js = 16.19.1
      NPM: 8.19.3
       javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      Benutzung ist?
      MfG
      Wastl
      @langer
      Schau mit
      iob diag
      nach. Das wertet u.a. auch den Speicher aus.
      • L Langer
        Node.js = 16.19.1
        NPM: 8.19.3
         javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        Benutzung ist?
        MfG
        Wastl
        crunchipC Abwesend
        crunchipC Abwesend
        @langer sagte in Bin wieder mal mit meinem Latein am Ende:
        Benutzung ist?
        nein, das 92.3% frei sind
        • L Langer
          Node.js = 16.19.1
          NPM: 8.19.3
           javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          javascript.0
          Benutzung ist?
          MfG
          Wastl
          CodierknechtC Online
          Codierknecht
          @langer
          1.) Ändere bitte den Titel in etwas sinnvolleres. Unter dem aktuellen Titel kann sich wohl kaum jemand etwas vorstellen.
          2.) Packe die Logausgabe bitte in Code-Tags </> - auch hinter einem Spoiler. Das kann man so wie es ist kaum entziffern.
          HmIP|ZigBee|Tasmota|Unifi
          Zabbix Certified Specialist
          L 1 Antwort Letzte Antwort
          • CodierknechtC Codierknecht
            @langer
            Langer
            @codierknecht
            Danke für die Anregung, wurde geändert.
            @crunchip
            @Thomas-Braun
            Dank für die Info's.
            Aber was sagt die Fehlermeldung aus?
            MfG
            Wastl
            • L Langer
              @codierknecht
              @crunchip
              @Thomas-Braun
              MfG
              Wastl
              @langer
              Das hier ein Prozess nicht richtig mit einem anderen Prozess kommunizieren kann. Dazu werden 'Pipes' benutzt. Bei dir ist offenbar aber die Pfeiffe verstopft.
              • L Langer
                @codierknecht
                @crunchip
                @Thomas-Braun
                MfG
                Wastl
                crunchipC Abwesend
                crunchipC Abwesend
                @langer schwer zu sagen ohne das man das script kennt
                83.2k
