  4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
    6.5k
3.8k Beiträge 462 Kommentatoren 2.3m Aufrufe 410 Beobachtet
  • J juggi1962
    @tombox
    Hallo Zusammen.
    Der Adapter bringt wieder mal einen Login Fehler.
    Hat VW wieder mal was geändert oder ist das nur vorübergehend.
    Danke im Voraus, Gruß Jürgen
    vw-connect.0
    2023-02-27 15:40:38.525	error	Login Failed
    vw-connect.0
    2023-02-27 15:40:38.522	error	"404 Not Found: Requested route ('login.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:40:38.522	error	404
    vw-connect.0
    2023-02-27 15:40:38.521	error	Failed in first login step
    vw-connect.0
    2023-02-27 15:40:38.333	error	"404 Not Found: Requested route ('login.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:40:38.331	error	404
    vw-connect.0
    2023-02-27 15:40:38.329	error	Failed in receive login url
    vw-connect.0
    2023-02-27 15:39:40.103	error	Failed refresh token. Relogin
    vw-connect.0
    2023-02-27 15:39:40.103	error	"404 Not Found: Requested route ('login.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:39:40.101	error	404
    vw-connect.0
    2023-02-27 15:39:39.943	error	get id status Failed
    vw-connect.0
    2023-02-27 15:39:39.943	error	"404 Not Found: Requested route ('mobileapi.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:39:39.942	error	AxiosError: Request failed with status code 404
    vw-connect.0
    2023-02-27 15:38:40.212	error	Failed refresh token. Relogin
    vw-connect.0
    2023-02-27 15:38:40.212	error	"404 Not Found: Requested route ('login.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:38:40.211	error	404
    vw-connect.0
    2023-02-27 15:38:40.027	error	get id status Failed
    vw-connect.0
    2023-02-27 15:38:40.027	error	"404 Not Found: Requested route ('mobileapi.apps.emea.vwapps.io') does not exist.\n"
    vw-connect.0
    2023-02-27 15:38:40.026	error	AxiosError: Request failed with status code 404
    Luxi
    #1670
    @juggi1962 me2 als ich den Adaper neu startete, vorher gings noch.
    (ID.3)
    • L Luxi
      (ID.3)
      juggi1962
      #1671
      @luxi sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
      (ID.3)
      Neustart hilft leider nicht.
      Gruß Jürgen
      L 1 Antwort Letzte Antwort
      • J juggi1962
        (ID.3)
        Gruß Jürgen
        L Online
        L Online
        lesiflo
        #1672
        Muss mich leider anschließen, gleiches Problem wie die letzten 3 Einträge hier, ID.4
        • JB_SullivanJ Offline
          JB_Sullivan
          #1673
          Rollt mal auf die 0.58 zurück - mit der 0.60 habe ich auch alles voller Fehlermeldungen, mit 0.58 nicht eine einzige und es funktioniert soweit ich das sehen auch noch alles - Allerdings Skoda Enyaq
          J M 2 Antworten Letzte Antwort
          • JB_SullivanJ JB_Sullivan
            juggi1962
            #1674
            @jb_sullivan sagte in Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda:
            Hmmm wo findest du die Version 0.58
            Unter den Adaptern gibt es nur die 0.56
            • J juggi1962
              @tombox
              Hallo Zusammen.
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              vw-connect.0
              tombox
              #1675
              @juggi1962 Bitte mal die github version testen ob alles wieder geht
              B S 2 Antworten Letzte Antwort
              • T tombox
                bommel_030
                schrieb am zuletzt editiert von bommel_030
                #1676
                @tombox
                Danke, die github-Version (0.61) holt wieder Daten.
                • T tombox
                  schmuh
                  #1677
                  @tombox
                  Ja, läuft wieder. Vielen Dank
                  • B bommel_030
                    @tombox
                    Luxi
                    #1678
                    @bommel_030
                    Na, 6:22 Uhr gabs noch Fehler, nach Adapter Neustart 6:52 ist alles o.k..
                    Zwischenzeitlich kein Upgrade gemacht.
                    • J Offline
                      juggi1962
                      #1679
                      @tombox Ja funktioniert wieder 👍
                      Vielen Dank für deine Arbeit
                      • J juggi1962
                        JB_Sullivan
                        #1680
                        @juggi1962 Sorry - war mein Fehler - ich meinte natürlich die 0.56 - aber das scheint mit der 0.61 eh Geschichte zu sein.
                          Anderl73
                          #1681
                          wie finde ich den die 0.61?
                          er lädt bei mir nur eine 0.60...
                          • A Anderl73
                            #1682
                            @anderl73
                            Liegt im Beta-Repo:
                            vw-connect
                            github:	0.0.60
                            latest:	0.0.61 for 0 days
                            stable:	0.0.56 for 84 days
                              @anderl73
                              Liegt im Beta-Repo:
                              vw-connect
                              github:	0.0.60
                              Anderl73
                              #1683
                              @thomas-braun DANKE!
                                Anderl73
                                schrieb am zuletzt editiert von Anderl73
                                #1684
                                @Thomas-Braun
                                die 0.61 habe ich jetzt installiert, der loging klappt trotzdem nicht.... (Audi Q4)
                                Thomas BraunT M 2 Antworten Letzte Antwort
                                • A Anderl73
                                  @Thomas-Braun
                                  #1685
                                  @anderl73
                                  Systemzeit richtig?
                                  iob diag
                                  sagt dir das unteranderem.
                                    @anderl73
                                    Systemzeit richtig?
                                    iob diag
                                    Anderl73
                                    #1686
                                    ich würde sagen ja (iobroker läuft bei mir auf einer Synology NAS im Docker), zumindest wird mir die aktuelle Zeit angezeigt...
                                    • A Anderl73
                                      jschwettmann
                                      #1687
                                      @anderl73 Bei mir läuft es wieder mit der 0.61. DANKE!
                                        Anderl73
                                        #1688
                                        @Thomas-Braun
                                        wenn ich das Fahrzeug auf "Audi" ändere, dann verbindet er sich wieder, findet aber kein Fahrzeug.
                                        Stelle ich das Fahrzeug wieder zurück auf "Audi Etron" ist keine Verbindung möglich.....
                                        • L Luxi
                                          @bommel_030
                                          bommel_030
                                          #1689
                                          @luxi
                                          5:36 Adapter Neustart mit Fehler, seit 5:42 nach Update auf 0.61 ohne Fehler...
