  3. Off Topic
  4. InfluxDB
  5. (gelöst) influxdb mir unbekannte Probleme
    6.7k
Geplant Angeheftet Gesperrt Verschoben InfluxDB
80 Beiträge 3 Kommentatoren 11.2k Aufrufe 4 Beobachtet
  • W woupi
    @thomas-braun sagte in (gelöst) influxdb mir unbekannte Probleme:
    @woupi
    Das Grafana-Repo fehlt.
     sudo apt update
    Hit:1 http://archive.ubuntu.com/ubuntu jammy InRelease
    Hit:2 https://repos.influxdata.com/debian stable InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
    Get:4 https://apt.grafana.com stable InRelease [5984 B]
    Hit:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease
    Get:6 https://apt.grafana.com stable/main amd64 Packages [108 kB]
    Fetched 114 kB in 0s (230 kB/s)
    Reading package lists... Done
    3 packages can be upgraded. Run 'apt list --upgradable' to see them.
    Jetzt, sollte es aber passen, hoffen lasse ich jetzt mal weg
    #66
    @woupi
    date && date -u
    cat /etc/timezone
    sudo apt full-upgrade
    W 1 Antwort Letzte Antwort
      @woupi
      date && date -u
      cat /etc/timezone
      W Offline
      W Offline
      woupi
      #67
      @woupi
      date && date -u
      cat /etc/timezone
      date && date -u
      Sun Feb 19 16:39:49 UTC 2023
      bernhard@influxdb:~$ cat /etc/timezone
      Etc/UTC
      bernhard@influxdb:~$ sudo apt full-upgrade
      Calculating upgrade... Done
      The following packages have been kept back:
        python3-software-properties software-properties-common
      The following packages will be upgraded:
        grafana
      1 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
      Need to get 89.3 MB of archives.
      After this operation, 258 kB of additional disk space will be used.
      Do you want to continue? [Y/n] y
      Get:1 https://apt.grafana.com stable/main amd64 grafana amd64 9.3.6 [89.3 MB]
      Fetched 89.3 MB in 8s (10.8 MB/s)
      (Reading database ... 30024 files and directories currently installed.)
      Preparing to unpack .../grafana_9.3.6_amd64.deb ...
      Unpacking grafana (9.3.6) over (9.3.2) ...
      Setting up grafana (9.3.6) ...
      Restarting grafana-server service... OK
      NUC10i3, Proxmox, VM Ubuntu iobroker, lxc ubuntu influxdb, grafana, lxc ubuntu SAE, lxc ubuntu MotionEye, WP Panasonic Jeisha 5kW mit Heishamon, Shelly 2.5 und 2pm Rolladensteuerung, OpenWB Wallbox
      • W woupi
        @woupi
        date && date -u
        cat /etc/timezone
        date && date -u
        Etc/UTC
          grafana
        #68
        @woupi Zeitzone setzen, das ist wichtig und keine Kosmetik.
        • W woupi
          @woupi
          date && date -u
          cat /etc/timezone
          date && date -u
          Etc/UTC
            grafana
          #69
          @woupi sagte in (gelöst) influxdb mir unbekannte Probleme:
          Und was klemmt da?
          apt install --dry-run python3-software-properties software-properties-common
            W Offline
            W Offline
            woupi
            #70
            Jetzt habe ich erstmal das gemacht
            bernhard@influxdb:~$ sudo timedatectl set-timezone Europe/Berlin
            bernhard@influxdb:~$ timedatectl
                           Local time: Sun 2023-02-19 17:47:43 CET
                       Universal time: Sun 2023-02-19 16:47:43 UTC
                             RTC time: n/a
                          NTP service: inactive
                      RTC in local TZ: no
              Und was klemmt da?
              W Offline
              W Offline
              woupi
              #71
              bernhard@influxdb:~$ sudo apt install --dry-run python3-software-properties software-properties-common
              2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
              Inst software-properties-common [0.99.22.3] (0.99.22.5 Ubuntu:22.04/jammy-updates [all]) []
              Inst python3-software-properties [0.99.22.3] (0.99.22.5 Ubuntu:22.04/jammy-updates [all])
              Conf software-properties-common (0.99.22.5 Ubuntu:22.04/jammy-updates [all])
              Conf python3-software-properties (0.99.22.5 Ubuntu:22.04/jammy-updates [all])
              und jetzt das
              • W woupi
                und jetzt das
                W Offline
                W Offline
                woupi
                #72
                Sieht das gut aus?
                • W woupi
                  Sieht das gut aus?
                  #73
                  Sieht das gut aus?
                  Von sudo hatte ich zwar nichts geschrieben, aber sei's drum...
                  sudo apt update
                    Sieht das gut aus?
                    sudo apt update
                    W Offline
                    W Offline
                    woupi
                    #74
                    Ich bin davon ausgegangen, dass da immer sudo vor muss, sorry. Offensichtlich aber wohl nicht.
                    Gibt es irgendwo eine Erklärung dafür, wann sudo und wann nicht davor muss?
                    Aber egal, ich werde mich dran halten und ggf mal danach suchen, kommt mit auf die Liste.
                    sudo apt update
                    Hit:1 https://repos.influxdata.com/debian stable InRelease
                    Hit:2 https://apt.grafana.com stable InRelease
                    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                    Hit:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                    2 packages can be upgraded. Run 'apt list --upgradable' to see them.
                    0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
                    • W woupi
                      sudo apt update
                      #75
                      sudo kommt nur dann vor Standardbefehle, wenn die mit root-Rechten ausgeführt werden sollen. Zum nur herumschauen braucht man das aber nicht mit schweren Waffen machen.
                      Irgendwas klemmt da noch.
                      sudo apt update
                      sudo apt install python3-software-properties software-properties-common
                      W 2 Antworten Letzte Antwort
                        sudo apt update
                        W Offline
                        W Offline
                        woupi
                        #76
                        bernhard@influxdb:~$ sudo apt update
                        Hit:2 http://archive.ubuntu.com/ubuntu jammy-updates InRelease
                        Hit:3 https://repos.influxdata.com/debian stable InRelease
                        Hit:4 http://archive.ubuntu.com/ubuntu jammy-security InRelease
                        Hit:5 https://apt.grafana.com stable InRelease
                        bernhard@influxdb:~$ sudo apt install python3-software-properties software-properties-common
                        Need to get 42.9 kB of archives.
                        After this operation, 0 B of additional disk space will be used.
                        Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 software-properties-common all 0.99.22.5 [14.1 kB]
                        Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 python3-software-properties all 0.99.22.5 [28.8 kB]
                        Fetched 42.9 kB in 0s (219 kB/s)
                        (Reading database ... 30033 files and directories currently installed.)
                        Preparing to unpack .../software-properties-common_0.99.22.5_all.deb ...
                        Unpacking software-properties-common (0.99.22.5) over (0.99.22.3) ...
                        Preparing to unpack .../python3-software-properties_0.99.22.5_all.deb ...
                        Unpacking python3-software-properties (0.99.22.5) over (0.99.22.3) ...
                        Setting up python3-software-properties (0.99.22.5) ...
                        Setting up software-properties-common (0.99.22.5) ...
                        Processing triggers for man-db (2.10.2-1) ...
                        Processing triggers for dbus (1.12.20-2ubuntu4.1) ...
                        • W woupi
                          W Offline
                          W Offline
                          woupi
                          #77
                          Ich hoffe, dass jetzt alles gut ist, vielen vielen Dank auf jeden Fall für deine Geduld und deine Hilfe.
                          Ohne deine Hilfe hätte ich das nicht hinbekommen.
                          Sascha
                            sudo apt update
                            W Offline
                            W Offline
                            woupi
                            #78
                            Guten Morgen,
                            ich habe gerade festgestellt, dass der lxc statt 46G jetzt nur noch 2,83G hat.
                            Ich habe keine Ahnung, was dass gestern damit zu tun hatte, aber ganz offensichtlich hat es geholfen.
                            Ich muss mich nochmal ganz Herzlich bei dir bedanken.
                            Vielen Dank und einen schönen Tag.
                            Sascha
                            E 1 Antwort Letzte Antwort
                            • W woupi
                              Guten Morgen,
                              Sascha
                              Einstein67
                              #79
                              @woupi said in (gelöst) influxdb mir unbekannte Probleme:
                              Wow Super, und Daten sind auch noch vorhanden?
                              ... ich kenne übrigens eine Möglichkeit um Proxmox-Container wieder zu verkleinern!
                              • E Einstein67
                                W Offline
                                W Offline
                                woupi
                                #80
                                @einstein67 sagte in (gelöst) influxdb mir unbekannte Probleme:
                                Offensichtlich ja, ich vermisse zu mindestens nichts.
                                Ok, imo passt ja alles, aber eventuell komme ich da nochmal drauf zurück,
                                oder meinst Du die von mir auf 100G wieder rückgängig machen?
                                Das wäre ja eventuell Sinnvoll und dadurch auch jetzt interessant.
