  4. Node-Red
  5. Victron
    6.5k
Victron
135 Beiträge 4 Kommentatoren 26.2k Aufrufe 5 Beobachtet
  • D Dirk 4
    @mickym
            "id": "2613d4ea00521116",
            "type": "tab",
            "label": "Flow 1",
            "disabled": false,
            "info": "",
            "env": []
            "id": "7e6104c37b4b85c6",
            "type": "debug",
            "z": "2613d4ea00521116",
            "name": "debug 1",
            "active": true,
            "tosidebar": true,
            "console": false,
            "tostatus": false,
            "complete": "false",
            "statusVal": "",
            "statusType": "auto",
            "x": 820,
            "y": 460,
            "wires": []
            "id": "a6bf33cc5e341dd6",
            "type": "victron-input-ess",
            "service": "com.victronenergy.settings",
            "path": "/Settings/CGwacs/BatteryLife/MinimumSocLimit",
            "serviceObj": {
                "name": "ESS System Settings",
                "paths": [
                        "path": "/Settings/CGwacs/AcPowerSetPoint",
                        "type": "integer",
                        "name": "Grid set-point (W)"
                        "type": "integer",
                        "name": "Minimum Discharge SOC (%)"
                        "path": "/Settings/CGwacs/BatteryLife/SocLimit",
                        "type": "integer",
                        "name": "Active SOC limit (%)"
                        "path": "/Settings/CGwacs/BatteryLife/State",
                        "type": "enum",
                        "name": "ESS state",
                        "enum": {
                            "1": "BatteryLife enabled (GUI controlled)",
                            "2": "Optimized Mode /w BatteryLife: self consumption",
                            "3": "Optimized Mode /w BatteryLife: self consumption, SoC exceeds 85%",
                            "4": "Optimized Mode /w BatteryLife: self consumption, SoC at 100%",
                            "5": "Optimized Mode /w BatteryLife: SoC below dynamic SoC limit",
                            "6": "Optimized Mode /w BatteryLife: SoC has been below SoC limit for more than 24 hours. Charging the battery (5A)",
                            "7": "Optimized Mode /w BatteryLife: Inverter/Charger is in sustain mode",
                            "8": "Optimized Mode /w BatteryLife: recharging, SoC dropped by 5% or more below the minimum SoC",
                            "9": "'Keep batteries charged' mode is enabled",
                            "10": "Optimized mode w/o BatteryLife: self consumption, SoC at or above minimum SoC",
                            "11": "Optimized mode w/o BatteryLife: self consumption, SoC is below minimum SoC",
                            "12": "Optimized mode w/o BatteryLife: recharging, SoC dropped by 5% or more below minimum SoC"
                        "path": "/Settings/CGwacs/Hub4Mode",
                        "type": "enum",
                        "name": "ESS mode",
                        "enum": {
                            "1": "Optimized mode or 'keep batteries charged' and phase compensation enabled",
                            "2": "Optimized mode or 'keep batteries charged' and phase compensation disabled",
                            "3": "External control"
                        "path": "/Settings/CGwacs/MaxDischargePower",
                        "type": "integer",
                        "name": "Max inverter power (W)"
                        "path": "/Settings/CGwacs/OvervoltageFeedIn",
                        "type": "enum",
                        "name": "Feed excess DC-coupled PV into grid",
                        "enum": {
                            "0": "Don’t feed excess DC-tied PV into grid",
                            "1": "Feed excess DC-tied PV into the grid"
                        "path": "/Settings/CGwacs/PreventFeedback",
                        "type": "enum",
                        "name": "Don’t feed excess AC-coupled PV into grid",
                        "enum": {
                            "0": "Feed excess AC-tied PV into grid",
                            "1": "Don’t feed excess AC-tied PV into the grid"
                        "path": "/Settings/SystemSetup/MaxChargeCurrent",
                        "type": "float",
                        "name": "DVCC Charge current limit (A)"
                        "path": "/Settings/SystemSetup/MaxChargeVoltage",
                        "type": "float",
                        "name": "DVCC Maximum charge voltage (V)"
            "pathObj": {
                "type": "integer",
            "name": "",
            "x": 350,
            "y": 460,
            "wires": [
                    "7e6104c37b4b85c6"
    mickymM Offline
    mickymM Offline
    mickym
    @dirk-4 Bitte in Codetags und das ist ja erst mal für Dich - ich kann damit nichts anfangen - also hänge das mal in Code-Tags.
    Also erst auf das Auge klicken, dann auf die Codetags (spitze Klammern) und da kopierst Du den Code rein.
    Wenn Du den Flow exportieren kannst. Dann kannst Du mal den Node-Red Adapter im iobroker installieren und dann diesen Flow dort importieren und dann fehlen wahrscheinlich noch NOdes die wir nachinstallieren müssen.
    In diesem 2. Video sehe ich dass man diese Nodes installieren muss - der verwendet die direkt:
    • D Dirk 4
      @homoran Hallo
      In der Console beim Cerbo auf Firmware/Online Updates/Image Typ dort dann Large auswählen
      fertig. Dann noch in den Einstellungen in der Console ganz unten Large Funktionen Node Red an machen.
      Dann kannst du das im Browser aufrufen.
      @dirk-4 sagte in Victron:
      Large auswählen
      fertig.
      Das Image hab ich gerade gefunden, aber mit einer Versionsnummer, die nicht gerade stabil klingt.
      Bei mir hängt das ganze Haus dran, incl. Notstrom. Da bin ich mit sowas erstmal vorsichtig.
      das hatte ich bei mir mit port 1881 und 1880 versucht, ohne Erfolg.
      @mickym sagte in Victron:
      @homoran Ich weiss nicht was das mit einer Cloud zu tun haben soll
      das hier sind gerade zwei verschiedene Themen.
      Der node-red auf dem CERBO ist flammneu.
      Um mit node-red auf einem externen Rechner auf deine Anlage zugreifen zu können, muss diese Anlage in der cloud (VRM-Portal) verfügbar sein.
      (wurde mir zumindest so gesagt)
      • mickymM mickym
        Dirk 4
        schrieb am zuletzt editiert von Dirk 4
        @mickym
               "type": "tab",
               "label": "Flow 1",
               "disabled": false,
               "info": "",
               "env": []
               "type": "debug",
               "name": "debug 1",
               "active": true,
               "tosidebar": true,
               "console": false,
               "tostatus": false,
               "statusVal": "",
               "x": 820,
               "y": 460,
               "wires": []
               "serviceObj": {
                   "paths": [
                           "type": "integer",
                           "type": "integer",
                           "type": "integer",
                           "type": "enum",
                           "enum": {
                           "type": "enum",
                           "name": "ESS mode",
                           "enum": {
                           "type": "integer",
                           "type": "enum",
                           "enum": {
                           "type": "enum",
                           "enum": {
                           "type": "float",
                           "type": "float",
               "pathObj": {
                   "type": "integer",
               "name": "",
               "x": 350,
               "y": 460,
               "wires": [
                       "7e6104c37b4b85c6"
        OK so
        • D Dirk 4
          @mickym
                 "type": "tab",
                 "label": "Flow 1",
                 "disabled": false,
                 "info": "",
                 "env": []
                 "type": "debug",
                 "name": "debug 1",
                 "active": true,
                 "tosidebar": true,
                 "console": false,
                 "tostatus": false,
                 "statusVal": "",
                 "x": 820,
                 "y": 460,
                 "wires": []
                 "serviceObj": {
                     "paths": [
                             "type": "integer",
                             "type": "integer",
                             "type": "integer",
                             "type": "enum",
                             "enum": {
                             "type": "enum",
                             "name": "ESS mode",
                             "enum": {
                             "type": "integer",
                             "type": "enum",
                             "enum": {
                             "type": "enum",
                             "enum": {
                             "type": "float",
                             "type": "float",
                 "pathObj": {
                     "type": "integer",
                 "name": "",
                 "x": 350,
                 "y": 460,
                 "wires": [
                         "7e6104c37b4b85c6"
          OK so
          mickymM Offline
          mickymM Offline
          mickym
          Na Ok - das ist nur die Victron Node und sonst nichts - das ist also noch nicht mal ein richtiger Flow. ;)
          Hast Du eigentlich die Videos mal geschaut?
          Du solltest da links diese Nodes haben.
          @hormoran - wir können ja mal anschauen, wie diese Nodes konfiguriert sind - glaube nicht, dass man damit was kaputt macht.
          • D Dirk 4
            @mickym
                   "type": "tab",
                   "label": "Flow 1",
                   "disabled": false,
                   "info": "",
                   "env": []
                   "type": "debug",
                   "name": "debug 1",
                   "active": true,
                   "tosidebar": true,
                   "console": false,
                   "tostatus": false,
                   "statusVal": "",
                   "x": 820,
                   "y": 460,
                   "wires": []
                   "serviceObj": {
                       "paths": [
                               "type": "integer",
                               "type": "integer",
                               "type": "integer",
                               "type": "enum",
                               "enum": {
                               "type": "enum",
                               "name": "ESS mode",
                               "enum": {
                               "type": "integer",
                               "type": "enum",
                               "enum": {
                               "type": "enum",
                               "enum": {
                               "type": "float",
                               "type": "float",
                   "pathObj": {
                       "type": "integer",
                   "name": "",
                   "x": 350,
                   "y": 460,
                   "wires": [
                           "7e6104c37b4b85c6"
            OK so
            mickymM Offline
            mickymM Offline
            mickym
            @dirk-4 So alles was Dein Flow bislang war ist somit dies hier:
            korrekt?
            • mickymM mickym
              damit nicht! Aber es ist ja das gesamte Betriebssystem, dass dann anders ist als vorher.
              • mickymM mickym
                korrekt?
                Dirk 4
                @mickym Das ist richtig mehr ist das nicht.
                Links sind die Nodes.
                  mickymM Offline
                  mickymM Offline
                  mickym
                  @homoran Nee wir haben ja nur den Flow exportiert und machen nun gar nichts mehr vorerst an dem System. Um zu testen, ob er vom iobroker via dieser Nodes darauf zugreifen kann ist das ganz easy zu sehen. Bei mir hört es nämlich schon auf. ;)
                  @Dirk-4 dann poste doch mal was da drin steht als Screen shot in der Node ;)
                  Sprich wenn wir aus dem iobroker diese Node nicht mit der entsprechenden Auswahl bekommen, dann bekommen wir auch keine Verbindung zu Deinem System.
                  Lt. dem Video gibts doch da eine große Auswahl:
                  • mickymM mickym
                    ich sag doch: wir haben hier zwei unabhängige Themen, von denen geredet wird!
                    ich müsste das Betriebssystem auf meiner Anlage wechseln, damit ich dort node-red drauf bekäme.
                    zum Testen für diesen Thread ist mir das zu heiß!
                    • D Dirk 4
                      mickymM Offline
                      mickymM Offline
                      mickym
                      Nee Du sollst die blaue Node aufmachen und schauen, was da eingetragen ist.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @homoran sagte in Victron:
                        Er soll ja erst mal nichts machen . Für mich stellt sich das wie folgt dar.
                        1. Aus dem jetzigen Node (ESS Node) kommt was raus und das sieht er über die debug Node.
                        2. Diese Nodes kann man doch mal auf einer Node-Red Instanz installieren und dort den Flow importieren.
                        3. Entweder bekommt die Node eine Verbindung wie jetzt auch oder es tut sich nichts - > also stoppen wir hier
                        4. Wenn was rauskommt, dann ist das jetzt in der debug Node und das können wir im iobroker ja wegschreiben. damit senden wir doch überhaupt nichts an die Anlage?
                        Wenn du das Video guckst, dann sieht man, dass wenn es keine Verbindung gibt - dann sind diese Nodes alle leer.
                        • mickymM mickym
                          Dirk 4
                          Das ist jetzt der eine Flow den ich brauche.
                          • D Dirk 4
                            mickymM Offline
                            mickymM Offline
                            mickym
                            @dirk-4 So wie gesagt - wir lassen Dein System jetzt komplett in Ruhe - so dass da nichts kaputt geht. Du installierst einfach mal NOde-Red in Deinem iobroker dann diese NOdes und dann schaust Du ob Du da was auswählen kannst, Wenn nicht - wars das und Du löscht einfach die NodeRed Instanz auf Deinem iobroker wieder.
                            Wenn das nicht klappt - dann haben wir immer noch die Möglichkeit die Daten aus Deiner Node-Red Instanz auf Deiner Anlage zu der Node-Red Instanz auf dem iobroker zu schicken.
                            Sag Bescheid - wenn Du die Node-Red Instanz auf Deinem iobroker installiert hast.
                            • D Dirk 4
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @dirk-4 Hast Du Node-Red unter iobroker installiert?
                              • mickymM mickym
                                Dirk 4
                                @mickym Auf dem iobroker hab ich die victron Flows schon mal installiert da kann ich aber nichts eingeben die Felder lassen sich nicht bearbeiten. Hab ich dann auch wieder gelöscht.
                                Wenn das nicht geht ist das auch nicht so schlimm.
                                • D Dirk 4
                                  mickymM Offline
                                  mickymM Offline
                                  mickym
                                  @dirk-4 Wir haben schon noch eine Möglichkeit ich habe mir sowas schon gedacht. ;)
                                  Wir nehmen jetzt einfach den Flow - auf Deinem Venus OS und versuchen mal ein paar Daten zu schicken ok?
                                  • mickymM mickym
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @mickym Mach mal Deine iobroker NodeRed Instanz auf. ;)
                                    Dort machen wir einen kleinen Webserver auf und an den schicken wir die daten aus dem Venus OS. OK?
                                           "id": "538dea2ec68a916b",
                                           "type": "comment",
                                           "z": "7e6af0015415146d",
                                           "name": "Webserver",
                                           "info": "",
                                           "x": 140,
                                           "y": 80,
                                           "wires": []
                                           "id": "5ad1968a8316fc4f",
                                           "type": "http in",
                                           "name": "",
                                           "url": "/venus",
                                           "method": "post",
                                           "upload": false,
                                           "swaggerDoc": "",
                                           "x": 290,
                                           "y": 160,
                                           "wires": [
                                                   "3b93146c70e848f4",
                                                   "bf787b018da02270"
                                           "id": "bf787b018da02270",
                                           "type": "http response",
                                           "name": "",
                                           "statusCode": "",
                                           "headers": {},
                                           "x": 550,
                                           "y": 160,
                                           "wires": []
                                           "id": "3b93146c70e848f4",
                                           "type": "debug",
                                           "name": "Daten aus VenusOS",
                                           "active": true,
                                           "tosidebar": true,
                                           "console": false,
                                           "tostatus": false,
                                           "complete": "payload",
                                           "targetType": "msg",
                                           "statusVal": "",
                                           "x": 520,
                                           "y": 220,
                                           "wires": []
                                    Diesen Flow importierst Du nun in deine iobroker Node-Red Instanz.
                                    Ist wie Export nur Import und hier aus der Zwischenablage kopieren.
                                    • D Dirk 4
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      @dirk-4 Wenn Du soweit bist, sag Bescheid.
                                      • mickymM mickym
                                        Dirk 4
                                        @mickym OK Hab ich
                                        • D Dirk 4
                                          @mickym OK Hab ich
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @dirk-4 Gut das werden wir dann noch anwenderfreundlicher machen.
                                          In Deinem NodeRed auf der Venus Seite hängst Du nun an die blaue Node noch eine http Request Node dran. Wenn Du das hast, sag Bescheid.
