  4. Fehlermeldungen, mit denen ich nichts anfangen kann
    5.5k
37 Beiträge 6 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • M MPF
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     18:44:18 up 17 min,  1 user,  load average: 0.43, 1.79, 1.72
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Feb 12 17:44:18 UTC 2023
    Sun Feb 12 18:44:18 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            971M        605M        107M        0.0K        258M        339M
    Swap:            99M         12M         87M
    Total:          1.1G        618M        195M
              971 M total memory
              606 M used memory
              123 M active memory
              664 M inactive memory
              107 M free memory
               45 M buffer memory
              212 M swap cache
               99 M total swap
               12 M used swap
               87 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       15G  2.8G   12G  20% /
    devtmpfs       devtmpfs  358M     0  358M   0% /dev
    tmpfs          tmpfs     486M     0  486M   0% /dev/shm
    tmpfs          tmpfs     195M  956K  194M   1% /run
    /dev/sda1      vfat      255M   50M  206M  20% /boot
    /dev/sdb1      vfat      256M  5.8M  250M   3% /media/usbstick
    tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
    Messages in dmesg:
    [Sun Feb 12 18:27:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=afe541dd-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 12 18:27:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Feb 12 18:27:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Feb 12 18:27:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET              SOURCE    FSTYPE OPTIONS
    /                   /dev/sda2 ext4   rw,noatime
    |-/boot             /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick   /dev/sda1 vfat   rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/media/usbstick /dev/sdb1 vfat   rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    336M    /var/
    93M     /var/lib
    73M     /var/log/journal/672c2ebb91464d7c92f8f23137b63db0
    73M     /var/log
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    345M    /opt/iobroker/iobroker-data/
    146M    /opt/iobroker/iobroker-data/files
    102M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/devices.admin
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    9.6M    /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-pi                              - disabled
      system.adapter.devices.0                : devices               : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-pi                              - disabled
      system.adapter.flot.0                   : flot                  : iobroker-pi                              - disabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              - disabled, port: 1883, bind: 192.168.0.40
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              - disabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.web.1                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 192.168.0.40, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        3116
    States:         2810
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 20
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15566      1166/io.shelly.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13688      439/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11747      439/iobroker.js-con
    tcp        0      0 192.168.0.40:8082       0.0.0.0:*               LISTEN      1001       19422      2057/io.web.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11655      473/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13774      604/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11657      473/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12956      531/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13556      341/avahi-daemon: r
    udp        0      0 0.0.0.0:33037           0.0.0.0:*                           108        13558      341/avahi-daemon: r
    udp6       0      0 :::39505                :::*                                108        13559      341/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13557      341/avahi-daemon: r
    2023-02-12 18:40:12.766  - info: web.1 (2057) socket.io server listening on port 8082
    2023-02-12 18:40:12.785  - info: web.1 (2057) http server listening on port 8082
    2023-02-12 18:41:25.655  - info: admin.0 (604) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:41:59.880  - info: admin.0 (604) <== Disconnect system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:00.579  - info: admin.0 (604) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:01.102  - info: zigbee.0 (659) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E1E87D","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1E87D-if00","vendorId":"0451","productId":"16a8"}]
    2023-02-12 18:42:08.313  - info: admin.0 (604) <== Disconnect system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:58.543  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.431  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.456  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.476  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.288  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.309  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.346  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:15.167  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:15.223  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:25.681  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.697  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 vis.0
    2023-02-12 18:43:25.711  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.713  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.715  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.717  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.718  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.720  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.723  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    Jetzt sieht es doch ganz gut aus, oder ?
    Allerdings blitzt die grüne LED immer noch 4mal ?
    Keine SD-Karte mehr drin, deshalb das grüne blitzen ? Iob läuft nun über USB-Stick !
    Ro75R Offline
    Ro75R Offline
    Ro75
    @mpf Ich habe mehrere RPI4 mit SSD, ohne SD-Card. Da blinkt die grüne LED auch im Takt. Sollte dann beim RPI3 auch sein. Habe zwar einen, aber das ist eine SD-Card drin und von daher blinkt es dort auch.
    • Ro75R Ro75
      MPF
      schrieb am zuletzt editiert von MPF
      @ro75 hat er halt vorher, als alles über SD-Card lief, nicht gemacht. Nur mal so geflackert, wenn Datenaktivität war.
      Ro75R 1 Antwort Letzte Antwort
      • M MPF
        Ro75R Offline
        Ro75R Offline
        Ro75
        @mpf Das ist zu 100% korrekt. Mit SD-Card hast du dieses flackern nicht.
          @mpf sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
          Erklärt das auch dass schnelle Blitzen der grünen LED auf dem Rasberry ?
          Du meinst vermutlich die Netzwerk-LED? Die regiert auf Datenpakete.
          @thomas-braun sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
          nee, eher die CPU BUSY LED
          • M MPF
            Skript v.2023-01-02
            *** BASE SYSTEM ***
            Docker:         false
            Release:        11
            Codename:       bullseye
            VERSION_ID="11"
            ID=raspbian
            ID_LIKE=debian
            CPU threads: 4
            CET +0100
            Europe/Berlin
            pi
            /home/pi
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Swap:            99M         12M         87M
                      971 M total memory
                      606 M used memory
                      123 M active memory
                      107 M free memory
                       45 M buffer memory
                      212 M swap cache
                       99 M total swap
                       12 M used swap
                       87 M free swap
            *** FILESYSTEM ***
            Messages in dmesg:
            /var:
            336M    /var/
            93M     /var/lib
            73M     /var/log
            /usr/bin/npm            8.19.3
            /usr/bin/npx            8.19.3
            nodejs:
              Version table:
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            admin:          6.3.5
            javascript:     6.1.4
            Adapter State
            + instance is alive
            Objects and States
            Objects:        3116
            States:         2810
            Pending Updates: 20
            Bis auf die offenen 20 Updates.
            Spiel die ein, das ganze dann regelmäßig im Auge behalten.
              MPF
              @thomas-braun hab ich erledigt,
              Muss man diese Updates immer manuell durchführen ?
              • M MPF
                Natürlich. Wie auch sonst?
                Man will ja wissen was da passiert und kein Auto-Update reingedrückt bekommen.
                • M MPF
                  Skript v.2023-01-02
                  *** BASE SYSTEM ***
                  Docker:         false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                  CPU threads: 4
                  CET +0100
                  Europe/Berlin
                  pi
                  /home/pi
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M         12M         87M
                            971 M total memory
                            606 M used memory
                            123 M active memory
                            107 M free memory
                             45 M buffer memory
                            212 M swap cache
                             99 M total swap
                             12 M used swap
                             87 M free swap
                  *** FILESYSTEM ***
                  Messages in dmesg:
                  /var:
                  336M    /var/
                  93M     /var/lib
                  73M     /var/log
                  /usr/bin/npm            8.19.3
                  /usr/bin/npx            8.19.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  javascript:     6.1.4
                  Adapter State
                  + instance is alive
                  Objects and States
                  Objects:        3116
                  States:         2810
                  Pending Updates: 20
                  Im Gegensatz zu Windows, die ja inzwischen die Updatefaulheit durch automatische Zwangsupdates bekämpfen wollen, muss bei Linux noch manuell upgedated werden
                    Meister MopperM Online
                    Meister Mopper
                    schrieb am zuletzt editiert von Meister Mopper
                    @homoran sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
                    Stimmt aber nach meinen Recherchen nicht.
                    Unter Linux gibt es u. a. den unattended-upgrades.service .
                    Den würde ich aber nie nutzen, da möchte ich schon wissen, was mit meinen hosts passiert.
                    edit: Aber klar, hast doch recht, den muss man ja erst aktivieren 😲
                    Proxmox und HA ...
                    Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
                      @meister-mopper sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
                      das kann man nutzen, aber unter WIN muss man es
                      EDIT: alter Editeur!
                        Soweit ich weiß ist das aber so'n Ubuntu-Sonderstrick für deren Desktop-Version.
                        Auf Server-Betriebssystemen darf/sollte sowas nicht aktiv sein.
                        Meister MopperM wendy2702W 2 Antworten Letzte Antwort
                          Meister Mopper
                          Ich habe es noch nicht ausprobiert. Bin auch dank Dir eher so'n cli-Tipper.
                          Proxmox und HA ...
                            MPF
                            @thomas-braun ok
                              wendy2702W Offline
                              wendy2702W Offline
                              Richtig, meine alten Ex Windows Touchpanels die seit geraumer Zeit mit Ubuntu laufen haben das per default aktiv.
                              Kann man natürlich alles deaktivieren/konfigurieren wie man möchte…. Im Gegensatz zu Windows (oder ich habe es dort noch nicht gefunden)
