  4. Fehlermeldungen, mit denen ich nichts anfangen kann
    5.5k
37 Beiträge 6 Kommentatoren 3.7k Aufrufe 4 Beobachtet
  • M MPF
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 3 Model B Plus Rev 1.3
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     18:44:18 up 17 min,  1 user,  load average: 0.43, 1.79, 1.72
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Feb 12 17:44:18 UTC 2023
    Sun Feb 12 18:44:18 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    Boot Target:    multi-user.target
    *** MEMORY ***
    Mem:            971M        605M        107M        0.0K        258M        339M
    Swap:            99M         12M         87M
    Total:          1.1G        618M        195M
              971 M total memory
              606 M used memory
              123 M active memory
              664 M inactive memory
              107 M free memory
               45 M buffer memory
              212 M swap cache
               99 M total swap
               12 M used swap
               87 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       15G  2.8G   12G  20% /
    devtmpfs       devtmpfs  358M     0  358M   0% /dev
    tmpfs          tmpfs     486M     0  486M   0% /dev/shm
    tmpfs          tmpfs     195M  956K  194M   1% /run
    /dev/sda1      vfat      255M   50M  206M  20% /boot
    /dev/sdb1      vfat      256M  5.8M  250M   3% /media/usbstick
    tmpfs          tmpfs      98M     0   98M   0% /run/user/1000
    Messages in dmesg:
    [Sun Feb 12 18:27:14 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=Composite-1:720x480@60i vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyS0,115200 console=tty1 root=PARTUUID=afe541dd-02 rootfstype=ext4 fsck.repair=yes rootwait
    [Sun Feb 12 18:27:19 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
    [Sun Feb 12 18:27:19 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
    [Sun Feb 12 18:27:23 2023] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
    TARGET              SOURCE    FSTYPE OPTIONS
    /                   /dev/sda2 ext4   rw,noatime
    |-/boot             /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    `-/media/usbstick   /dev/sda1 vfat   rw,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      `-/media/usbstick /dev/sdb1 vfat   rw,noatime,uid=1001,gid=1001,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
    /var:
    336M    /var/
    93M     /var/lib
    73M     /var/log/journal/672c2ebb91464d7c92f8f23137b63db0
    73M     /var/log
    /opt/iobroker/backups:
    4.0K    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    345M    /opt/iobroker/iobroker-data/
    146M    /opt/iobroker/iobroker-data/files
    102M    /opt/iobroker/iobroker-data/backup-objects
    51M     /opt/iobroker/iobroker-data/files/javascript.admin
    42M     /opt/iobroker/iobroker-data/files/devices.admin
    33M     /opt/iobroker/iobroker-data/objects.jsonl
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    9.6M    /opt/iobroker/iobroker-data/states.jsonl
    8.2M    /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js
    6.9M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/610.de0231c9.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/bin/npx            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u3 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    Adapters from github:   0
    Adapter State
    + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.backitup.0               : backitup              : iobroker-pi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : iobroker-pi                              - disabled
      system.adapter.devices.0                : devices               : iobroker-pi                              -  enabled
    + system.adapter.discovery.0              : discovery             : iobroker-pi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : iobroker-pi                              - disabled
      system.adapter.flot.0                   : flot                  : iobroker-pi                              - disabled
    + system.adapter.history.0                : history               : iobroker-pi                              -  enabled
    + system.adapter.info.0                   : info                  : iobroker-pi                              -  enabled
    + system.adapter.javascript.0             : javascript            : iobroker-pi                              -  enabled
    + system.adapter.shelly.0                 : shelly                : iobroker-pi                              -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.sonoff.0                 : sonoff                : iobroker-pi                              - disabled, port: 1883, bind: 192.168.0.40
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker-pi                              - disabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker-pi                              - disabled
      system.adapter.vis.0                    : vis                   : iobroker-pi                              -  enabled
    + system.adapter.web.1                    : web                   : iobroker-pi                              -  enabled, port: 8082, bind: 192.168.0.40, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : iobroker-pi                              -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "backitup"     : 2.5.12   , installed 2.5.12
    Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "shelly"       : 6.3.1    , installed 6.3.1
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        3116
    States:         2810
    Hit:1 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 20
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       15566      1166/io.shelly.0
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       13688      439/iobroker.js-con
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       11747      439/iobroker.js-con
    tcp        0      0 192.168.0.40:8082       0.0.0.0:*               LISTEN      1001       19422      2057/io.web.1
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11655      473/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       13774      604/io.admin.0
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11657      473/sshd: /usr/sbin
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12956      531/dhcpcd
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13556      341/avahi-daemon: r
    udp        0      0 0.0.0.0:33037           0.0.0.0:*                           108        13558      341/avahi-daemon: r
    udp6       0      0 :::39505                :::*                                108        13559      341/avahi-daemon: r
    udp6       0      0 :::5353                 :::*                                108        13557      341/avahi-daemon: r
    2023-02-12 18:40:12.766  - info: web.1 (2057) socket.io server listening on port 8082
    2023-02-12 18:40:12.785  - info: web.1 (2057) http server listening on port 8082
    2023-02-12 18:41:25.655  - info: admin.0 (604) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:41:59.880  - info: admin.0 (604) <== Disconnect system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:00.579  - info: admin.0 (604) ==> Connected system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:01.102  - info: zigbee.0 (659) List of port: [{"path":"/dev/ttyAMA0"},{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","serialNumber":"__0X00124B0018E1E87D","pnpId":"usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1E87D-if00","vendorId":"0451","productId":"16a8"}]
    2023-02-12 18:42:08.313  - info: admin.0 (604) <== Disconnect system.user.admin from ::ffff:192.168.0.50
    2023-02-12 18:42:58.543  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.431  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.456  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:42:59.476  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.288  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.309  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:09.346  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:15.167  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:15.223  - info: web.1 (2057) ==> Connected system.user.admin from 192.168.0.50
    2023-02-12 18:43:25.681  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.697  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 vis.0
    2023-02-12 18:43:25.711  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.713  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.715  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.717  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.718  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.720  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    2023-02-12 18:43:25.723  - info: web.1 (2057) <== Disconnect system.user.admin from 192.168.0.50 flot
    Jetzt sieht es doch ganz gut aus, oder ?
    Allerdings blitzt die grüne LED immer noch 4mal ?
    Keine SD-Karte mehr drin, deshalb das grüne blitzen ? Iob läuft nun über USB-Stick !
    @mpf sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
    Bis auf die offenen 20 Updates.
    Spiel die ein, das ganze dann regelmäßig im Auge behalten.
      MPF
      @thomas-braun hab ich erledigt,
      Muss man diese Updates immer manuell durchführen ?
      • M MPF
        Natürlich. Wie auch sonst?
        Man will ja wissen was da passiert und kein Auto-Update reingedrückt bekommen.
        • M MPF
          Skript v.2023-01-02
          *** BASE SYSTEM ***
          Docker:         false
          Release:        11
          Codename:       bullseye
          VERSION_ID="11"
          ID=raspbian
          ID_LIKE=debian
          CPU threads: 4
          CET +0100
          Europe/Berlin
          pi
          /home/pi
          X-Server:       false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Swap:            99M         12M         87M
                    971 M total memory
                    606 M used memory
                    123 M active memory
                    107 M free memory
                     45 M buffer memory
                    212 M swap cache
                     99 M total swap
                     12 M used swap
                     87 M free swap
          *** FILESYSTEM ***
          Messages in dmesg:
          /var:
          336M    /var/
          93M     /var/lib
          73M     /var/log
          /usr/bin/npm            8.19.3
          /usr/bin/npx            8.19.3
          nodejs:
            Version table:
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          admin:          6.3.5
          javascript:     6.1.4
          Adapter State
          + instance is alive
          Objects and States
          Objects:        3116
          States:         2810
          Pending Updates: 20
          Im Gegensatz zu Windows, die ja inzwischen die Updatefaulheit durch automatische Zwangsupdates bekämpfen wollen, muss bei Linux noch manuell upgedated werden
            Meister MopperM Online
            Meister Mopper
            schrieb am zuletzt editiert von Meister Mopper
            @homoran sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
            Stimmt aber nach meinen Recherchen nicht.
            Unter Linux gibt es u. a. den unattended-upgrades.service .
            Den würde ich aber nie nutzen, da möchte ich schon wissen, was mit meinen hosts passiert.
            edit: Aber klar, hast doch recht, den muss man ja erst aktivieren 😲
            Proxmox und HA ...
            Ich schreibe den Code nicht mehr selbst – ich schimpfe mit der KI, bis er funktioniert.
              @meister-mopper sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
              das kann man nutzen, aber unter WIN muss man es
              EDIT: alter Editeur!
                Soweit ich weiß ist das aber so'n Ubuntu-Sonderstrick für deren Desktop-Version.
                Auf Server-Betriebssystemen darf/sollte sowas nicht aktiv sein.
                Meister MopperM wendy2702W 2 Antworten Letzte Antwort
                  Meister Mopper
                  Ich habe es noch nicht ausprobiert. Bin auch dank Dir eher so'n cli-Tipper.
                  Proxmox und HA ...
                    MPF
                    @thomas-braun ok
                      wendy2702W Offline
                      wendy2702W Offline
                      @thomas-braun sagte in Fehlermeldungen, mit denen ich nichts anfangen kann:
                      Richtig, meine alten Ex Windows Touchpanels die seit geraumer Zeit mit Ubuntu laufen haben das per default aktiv.
                      Kann man natürlich alles deaktivieren/konfigurieren wie man möchte…. Im Gegensatz zu Windows (oder ich habe es dort noch nicht gefunden)
