  4. npm ERR! Cannot read properties of null (reading 'parent')
37 Beiträge 4 Kommentatoren 4.6k Aufrufe 4 Beobachtet
  • B backfisch88
    @glasfaser ja das war der log zwischendrin war nicht fertig gelaufen. Das ist der Bericht.
    ne kein VIS2.
    Bin auch der Meinung, dass vorgestern das updaten noch ging... habe in der Zeit aber auch nichts gemacht...
    iobroker upgrade tankerkoenig --debug
    This upgrade of "tankerkoenig" will introduce the following changes:
    -> 3.3.7:
    added difference to jsonTable #116
    added a log message for the error `parameter error`
    set the name length to 34 characters
    Added verification if the api key is encrypted
    updated the Dependencies
    Would you like to upgrade tankerkoenig from @3.3.6 to @3.3.7 now? [(y)es, (n)o]: y
    Update tankerkoenig from @3.3.6 to @3.3.7
    host.IOBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
    host.IOBroker Adapter "system.adapter.tankerkoenig.1" is stopped.
    NPM version: 8.19.3
    Installing iobroker.tankerkoenig@3.3.7... (System call)
    npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
    upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
    upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
    upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
    upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
    upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
    host.IOBroker Adapter "system.adapter.tankerkoenig.0" is started
    host.IOBroker Adapter "system.adapter.tankerkoenig.1" is started
    der log
    0 verbose cli /usr/bin/node /usr/bin/npm
    1 info using npm@8.19.3
    2 info using node@v16.19.0
    3 timing npm:load:whichnode Completed in 1ms
    4 timing config:load:defaults Completed in 8ms
    5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
    6 timing config:load:builtin Completed in 5ms
    7 timing config:load:cli Completed in 25ms
    8 timing config:load:env Completed in 1ms
    9 timing config:load:file:/opt/iobroker/.npmrc Completed in 31ms
    10 timing config:load:project Completed in 48ms
    11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
    12 timing config:load:user Completed in 2ms
    13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
    14 timing config:load:global Completed in 1ms
    15 timing config:load:validate Completed in 1ms
    16 timing config:load:credentials Completed in 6ms
    17 timing config:load:setEnvs Completed in 5ms
    18 timing config:load Completed in 108ms
    19 timing npm:load:configload Completed in 109ms
    20 timing npm:load:mkdirpcache Completed in 4ms
    21 timing npm:load:mkdirplogs Completed in 7ms
    22 verbose title npm install iobroker.tankerkoenig@3.3.7
    23 verbose argv "install" "--save-exact" "iobroker.tankerkoenig@3.3.7"
    24 timing npm:load:setTitle Completed in 9ms
    25 timing config:load:flatten Completed in 17ms
    26 timing npm:load:display Completed in 22ms
    27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
    28 verbose logfile /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
    29 timing npm:load:logFile Completed in 36ms
    30 timing npm:load:timers Completed in 0ms
    31 timing npm:load:configScope Completed in 0ms
    32 timing npm:load Completed in 194ms
    33 timing arborist:ctor Completed in 7ms
    34 silly logfile start cleaning logs, removing 4 files
    35 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
    36 silly logfile done cleaning log files
    37 timing idealTree Completed in 8644ms
    38 timing command:install Completed in 8682ms
    39 verbose stack TypeError: Cannot read properties of null (reading 'parent')
    39 verbose stack     at Arborist.[resolveLinks] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:229:24)
    39 verbose stack     at Arborist.[loadFromShrinkwrap] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:103:29)
    39 verbose stack     at Arborist.loadVirtual (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:75:35)
    39 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:208:7)
    39 verbose stack     at async Promise.all (index 1)
    39 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:154:5)
    39 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
    39 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
    40 verbose cwd /opt/iobroker
    41 verbose Linux 5.15.84-v8+
    42 verbose node v16.19.0
    43 verbose npm  v8.19.3
    44 error Cannot read properties of null (reading 'parent')
    45 verbose exit 1
    46 timing npm Completed in 10677ms
    47 verbose unfinished npm timer reify 1676289034004
    48 verbose unfinished npm timer reify:loadTrees 1676289034023
    49 verbose unfinished npm timer idealTree:init 1676289034027
    50 verbose code 1
    51 error A complete log of this run can be found in:
    51 error     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
    GlasfaserG Offline
    GlasfaserG Offline
    @backfisch88 sagte in npm ERR! Cannot read properties of null (reading 'parent'):
    dann ...
    rm /opt/iobroker/node_modules/.package-lock.json
    rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.package-lock.json
    rm /opt/iobroker/package-lock.json
    iob rebuild
    B Thomas BraunT 2 Antworten Letzte Antwort
    • B backfisch88
      @glasfaser
      cd /opt/iobroker/node_modules
      npm install --omit=dev
      npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T12_02_04_657Z-debug-0.log
      :| das ist gut
      wendy2702W Online
      wendy2702W Online
      2023-02-13T12_02_04
      Mal so zwischendurch gefragt:
      Stimmen deine Zeiteinstellungen?
        backfisch88
        @wendy2702 ja stimmen :)
        • B backfisch88
          wendy2702W Online
          wendy2702W Online
          @backfisch88 Wieso dann im log eine Stunde hinter der Zeit oder steht der nicht in Deutschland bzw. in der gleichen Zeitzone?
          • GlasfaserG Glasfaser
            dann ...
            iob rebuild
            backfisch88
            @glasfaser also das läuft durch.... und der
            scheint auch zu klappen... aus Interesse... was war es jetzt? :D
            • wendy2702W wendy2702
              backfisch88
              @wendy2702 said in npm ERR! Cannot read properties of null (reading 'parent'):
              das ist ne >hervorragende Frage... kann das eventuell mit der Sommer /Winterzeit zusammen hängen?
              pi@IOBroker:~ $ date
              Mon 13 Feb 13:17:47 CET 2023
                dann ...
                iob rebuild
                Thomas BraunT Offline
                @glasfaser
                Ich überlege, ob die vier Zeilen nicht auch was für den iob fix wären.
                Hat bei mir gestern in etwas anderem Zusammenhang auch geholfen.
                  @glasfaser
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @thomas-braun sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                  Ja ... ich weiß ...
                  Bei Github war ich auch kurz dabei nur konnte ich diesen ( Fehler ) nicht simulieren
                  • B backfisch88
                    ne kein VIS2.
                    -> 3.3.7:
                    NPM version: 8.19.3
                    der log
                    45 verbose exit 1
                    50 verbose code 1
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @Thomas-Braun
                    Man sollte beobachten , bzw. ist mir schon öfters auch schon aufgefallen , das diese Meldung bei vielen erscheint !?
                      @Thomas-Braun
                      @glasfaser sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                      Ja, das Format hat sich bei aktuelleren npm-Versionen geändert. Sollte eigentlich automatisch umgestellt werden, funktioniert aber offenbar nicht immer einwandfrei. Mit frischen package*-Files geht es dann.
                        backfisch88
                        @Glasfaser
                        @glasfaser
                        der Adapter ist jetzt geupdated.. Hab mal zum test einfach n neuen Adapter installiert... das dauert ewig und es geht nix voran
                        dann kommt irgendwann
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/Newan/ioBroker.yahoo-stock-market.git
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/Steiger04/ioBroker.radar-trap2.git
                        npm WARN skipping integrity check for git dependency ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git
                        sind alles Adapter aus github (nicht in der offiziellen list)
                        das geht dann aber irgendwann und dann kommt bei jedem update aber wieder der gleiche Fehler
                          @glasfaser
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Dann wäre es ein Vorschlag ... den man eventuell mit umsetzen sollte !
                          • B backfisch88
                            @Glasfaser
                            @glasfaser
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @backfisch88
                            zeige mal :
                            cd /opt/iobroker
                            npm list
                            • B backfisch88
                              @Glasfaser
                              @glasfaser
                              GlasfaserG Offline
                              GlasfaserG Offline
                              Warum ... hast du die Freigabe von den Adapterentwickler dazu . ( Enwickungsstatus )
                              Warum nicht über den Normalen weg installieren !
                                backfisch88
                                schrieb am zuletzt editiert von backfisch88
                                @glasfaser
                                die sind asum Forum zum Testen freigegeben ja und dann über den normalen weg via Katze installiert
                                  @backfisch88
                                  zeige mal :
                                  cd /opt/iobroker
                                  npm list
                                  backfisch88
                                  @glasfaser
                                   cd /opt/iobroker
                                  npm list
                                  iobroker.inst@3.0.0 /opt/iobroker
                                  ├── iobroker.admin@6.3.6
                                  ├── iobroker.alexa2@3.23.2
                                  ├── iobroker.backitup@2.5.12
                                  ├── iobroker.blockly-plus@0.0.1 invalid: "github:excal-foley/ioBroker.blockly-plus#8487239d69fc53c13853013110da15b42bc487e9" from the root project
                                  ├── iobroker.bosch-ebike@0.0.3
                                  ├── iobroker.bring@1.8.1
                                  ├── iobroker.daswetter@3.1.7
                                  ├── iobroker.device-watcher@2.6.0
                                  ├── iobroker.discovery@3.1.0
                                  ├── iobroker.dwd@2.8.3
                                  ├── iobroker.fahrplan@1.2.2
                                  ├── iobroker.fb-checkpresence@1.1.25
                                  ├── iobroker.feiertage@1.1.0
                                  ├── iobroker.history@2.2.4
                                  ├── iobroker.ical@1.13.2
                                  ├── iobroker.influxdb@3.2.0
                                  ├── iobroker.info@1.9.26
                                  ├── iobroker.javascript@6.1.4
                                  ├── iobroker.js-controller@4.0.24
                                  ├── iobroker.mihome-vacuum@3.9.5
                                  ├── iobroker.mqtt@4.0.7
                                  ├── iobroker.net-tools@0.2.0
                                  ├── iobroker.netatmo-crawler@0.8.1
                                  ├── iobroker.nuki-extended@2.6.5 invalid: "github:iobroker-community-adapters/ioBroker.nuki-extended" from the root project
                                  ├── iobroker.owfs@0.7.0
                                  ├── iobroker.parcel@0.0.25
                                  ├── iobroker.payback@ invalid: "file:node_modules/ioBroker.payback" from the root project
                                  ├── iobroker.ping@1.5.3
                                  ├── iobroker.pollenflug@1.0.6
                                  ├── iobroker.radar-trap2@1.0.0 invalid: "github:Steiger04/ioBroker.radar-trap2#490ba164008d7127b3c6977d03928b72aa42165d" from the root project
                                  ├── iobroker.rssfeed@2.6.1
                                  ├── iobroker.samsung@0.5.11
                                  ├── iobroker.shelly@6.4.0
                                  ├── iobroker.shuttercontrol@1.4.21
                                  ├── iobroker.simple-api@2.7.2
                                  ├── iobroker.socketio@6.3.3
                                  ├── iobroker.sonoff@2.5.1 invalid: "github:ioBroker/ioBroker.sonoff" from the root project
                                  ├── iobroker.switchbot-ble@0.4.3 invalid: "github:mrbungle64/ioBroker.switchbot-ble#97256911e3cb887a3f4d182fa248bd201b902a8b" from the root project
                                  ├── iobroker.switchbot-hub@0.1.2 invalid: "github:DrozmotiX/ioBroker.switchbot-hub#e9019b544b39c1d39585898a195088b8e15c8576" from the root project
                                  ├── iobroker.tankerkoenig@3.3.6
                                  ├── iobroker.telegram@1.15.2
                                  ├── iobroker.toyota@0.0.3
                                  ├── iobroker.tr-064@4.2.18
                                  ├── iobroker.upnp@1.0.21
                                  ├── iobroker.vis-2-beta@2.0.9
                                  ├── iobroker.vis-2-widgets-energy@0.1.3
                                  ├── iobroker.vis-2-widgets-gauges@0.1.4
                                  ├── iobroker.vis-2-widgets-material@0.2.1
                                  ├── iobroker.vis-inventwo@3.3.3
                                  ├── iobroker.vis-justgage@1.0.2
                                  ├── iobroker.vis-materialdesign@0.5.9
                                  ├── iobroker.vis-timeandweather@1.2.2
                                  ├── iobroker.vis@1.4.16
                                  ├── iobroker.web@5.4.3
                                  ├── iobroker.wled@0.6.7
                                  ├── iobroker.ws@2.3.5
                                  ├── iobroker.yahka@0.17.0 invalid: "github:jensweigele/ioBroker.yahka#f0a14bef96a949fa4c63e9c677b48af76a28ab1b" from the root project
                                  ├── iobroker.yahoo-stock-market@0.0.4 invalid: "github:Newan/ioBroker.yahoo-stock-market#174c9171dbd0fdcf31dbedbe847476fc41643cf3" from the root project
                                  └── iobroker.zigbee@1.8.10
                                  npm ERR! code ELSPROBLEMS
                                  npm ERR! invalid: iobroker.blockly-plus@0.0.1 /opt/iobroker/node_modules/iobroker.blockly-plus
                                  npm ERR! invalid: iobroker.nuki-extended@2.6.5 /opt/iobroker/node_modules/iobroker.nuki-extended
                                  npm ERR! invalid: iobroker.payback@ /opt/iobroker/node_modules/iobroker.payback
                                  npm ERR! invalid: iobroker.radar-trap2@1.0.0 /opt/iobroker/node_modules/iobroker.radar-trap2
                                  npm ERR! invalid: iobroker.sonoff@2.5.1 /opt/iobroker/node_modules/iobroker.sonoff
                                  npm ERR! invalid: iobroker.switchbot-ble@0.4.3 /opt/iobroker/node_modules/iobroker.switchbot-ble
                                  npm ERR! invalid: iobroker.switchbot-hub@0.1.2 /opt/iobroker/node_modules/iobroker.switchbot-hub
                                  npm ERR! invalid: iobroker.yahka@0.17.0 /opt/iobroker/node_modules/iobroker.yahka
                                  npm ERR! invalid: iobroker.yahoo-stock-market@0.0.4 /opt/iobroker/node_modules/iobroker.yahoo-stock-market
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T12_34_14_886Z-debug-0.log
                                  pi@IOBroker:/opt/iobroker $ npm list
                                  npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T12_35_12_228Z-debug-0.log
                                  • B backfisch88
                                    @glasfaser
                                    Das ist alles andere als 'der normale Weg'.
                                    Die ganzen invalid Dinger entweder rauswerfen oder neuinstallieren.
                                    • GlasfaserG Offline
                                      GlasfaserG Offline
                                      Mhh ... ich dacht du hast kein VIS 2 ..
                                      ne kein VIS2.
                                      aber egal ...
                                        ne kein VIS2.
                                        aber egal ...
                                        backfisch88
                                        @glasfaser
                                        hatte das mal installiert, ja... aktuell aber eigentlich nicht mehr installiert
                                        Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                                        • B backfisch88
                                          @glasfaser
                                          Aber eigentlich doch installiert...
