  4. npm ERR! Cannot read properties of null (reading 'parent')
37 Beiträge 4 Kommentatoren 4.6k Aufrufe 4 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    Was kommt denn dabei:
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    • wendy2702W wendy2702
      backfisch88
      schrieb am zuletzt editiert von backfisch88
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      /usr/bin/npx
      v16.19.0
      v16.19.0
      8.19.3
      8.19.3
      4.0.24
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      tty
      /home/pi
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:5 https://repos.influxdata.com/debian stretch InRelease [7,021 B]
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Err:5 https://repos.influxdata.com/debian stretch InRelease
        The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      Fetched 7,021 B in 2s (3,346 B/s)
      Reading package lists... Done
      26 packages can be upgraded. Run 'apt list --upgradable' to see them.
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      nodejs:
        Installed: 16.19.0-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
       *** 16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u3 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      wendy2702W B 2 Antworten Letzte Antwort
      • B backfisch88
        aarch64
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        /usr/bin/npx
        v16.19.0
        v16.19.0
        8.19.3
        8.19.3
        4.0.24
        pi
        tty
        /home/pi
        nodejs:
          Version table:
        wendy2702W Offline
        wendy2702W Offline
        @backfisch88 sagte in npm ERR! Cannot read properties of null (reading 'parent'):
        Hat vielleicht nicht direkt was mit deinem Problem zu tun, solltest du aber mal anpassen.
        kannst du noch die Ausgabe von
        iob diag
        zeigen
        • B backfisch88
          aarch64
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          /usr/bin/npx
          v16.19.0
          v16.19.0
          8.19.3
          8.19.3
          4.0.24
          pi
          tty
          /home/pi
          nodejs:
            Version table:
          backfisch88
          war natürlich Käse... hier nochmal das richtige
                               v.2023-01-02
          Operatingsystem:        Debian GNU/Linux 11 (bullseye)
          Installation:           Native
          Timezone:               Europe/Berlin
          User-ID:                1000
          X-Server:               false
          Boot Target:            multi-user.target
          Pending OS-Updates:     23
          Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                                  /usr/bin/node           v16.19.0
                                  /usr/bin/npm            8.19.3
                                  /usr/bin/npx            8.19.3
          ioBroker Core:          js-controller           4.0.24
                                  admin                   6.3.6
          Objects type: jsonl
          States  type: redis
          Status admin:
          + system.adapter.admin.0                  : admin                 : IOBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          Pending iob updates:    1
          Active repo(s): Beta (latest)
          Objects:                43953
          States:                 36034
          Size of iob-Database:
          42M     /opt/iobroker/iobroker-data/objects.jsonl
          44K     /opt/iobroker/iobroker-data/states.jsonl
          • B backfisch88
                                 v.2023-01-02
            User-ID:                1000
            X-Server:               false
                                    /usr/bin/npm            8.19.3
                                    /usr/bin/npx            8.19.3
                                    admin                   6.3.6
            Objects type: jsonl
            States  type: redis
            Status admin:
            Objects:                43953
            States:                 36034
            GlasfaserG Offline
            GlasfaserG Offline
            @backfisch88
            Mhh .. 🙄
            da stand doch vorhin mehr
            und du bist tief als BETA Tester unterwegs auch mit dem Alpha VIS 2 !?
            Mache mal :
            iobroker upload all
            npm prune
            sudo reboot
            dann
            iobroker upgrade tankerkoenig --debug
            • GlasfaserG Glasfaser
              @backfisch88
              Mhh .. 🙄
              Mache mal :
              iobroker upload all
              npm prune
              sudo reboot
              dann
              backfisch88
              @glasfaser ja das war der log zwischendrin war nicht fertig gelaufen. Das ist der Bericht.
              ne kein VIS2.
              Bin auch der Meinung, dass vorgestern das updaten noch ging... habe in der Zeit aber auch nichts gemacht...
              This upgrade of "tankerkoenig" will introduce the following changes:
              -> 3.3.7:
              added difference to jsonTable #116
              added a log message for the error `parameter error`
              set the name length to 34 characters
              Added verification if the api key is encrypted
              updated the Dependencies
              Would you like to upgrade tankerkoenig from @3.3.6 to @3.3.7 now? [(y)es, (n)o]: y
              Update tankerkoenig from @3.3.6 to @3.3.7
              host.IOBroker Adapter "system.adapter.tankerkoenig.0" is stopped.
              host.IOBroker Adapter "system.adapter.tankerkoenig.1" is stopped.
              NPM version: 8.19.3
              Installing iobroker.tankerkoenig@3.3.7... (System call)
              npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
              upload [4] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js build/index.js application/javascript
              upload [3] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/build/index.js.map build/index.js.map application/json
              upload [2] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/index_m.html index_m.html text/html
              upload [1] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/style.css style.css text/css
              upload [0] tankerkoenig.admin /opt/iobroker/node_modules/iobroker.tankerkoenig/admin/tankerkoenig.png tankerkoenig.png image/png
              host.IOBroker Adapter "system.adapter.tankerkoenig.0" is started
              host.IOBroker Adapter "system.adapter.tankerkoenig.1" is started
              der log
              0 verbose cli /usr/bin/node /usr/bin/npm
              1 info using npm@8.19.3
              2 info using node@v16.19.0
              3 timing npm:load:whichnode Completed in 1ms
              4 timing config:load:defaults Completed in 8ms
              5 timing config:load:file:/usr/lib/node_modules/npm/npmrc Completed in 3ms
              6 timing config:load:builtin Completed in 5ms
              7 timing config:load:cli Completed in 25ms
              8 timing config:load:env Completed in 1ms
              9 timing config:load:file:/opt/iobroker/.npmrc Completed in 31ms
              10 timing config:load:project Completed in 48ms
              11 timing config:load:file:/home/iobroker/.npmrc Completed in 1ms
              12 timing config:load:user Completed in 2ms
              13 timing config:load:file:/usr/etc/npmrc Completed in 0ms
              14 timing config:load:global Completed in 1ms
              15 timing config:load:validate Completed in 1ms
              16 timing config:load:credentials Completed in 6ms
              17 timing config:load:setEnvs Completed in 5ms
              18 timing config:load Completed in 108ms
              19 timing npm:load:configload Completed in 109ms
              20 timing npm:load:mkdirpcache Completed in 4ms
              21 timing npm:load:mkdirplogs Completed in 7ms
              22 verbose title npm install iobroker.tankerkoenig@3.3.7
              23 verbose argv "install" "--save-exact" "iobroker.tankerkoenig@3.3.7"
              24 timing npm:load:setTitle Completed in 9ms
              25 timing config:load:flatten Completed in 17ms
              26 timing npm:load:display Completed in 22ms
              27 verbose logfile logs-max:10 dir:/home/iobroker/.npm/_logs
              28 verbose logfile /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
              29 timing npm:load:logFile Completed in 36ms
              30 timing npm:load:timers Completed in 0ms
              31 timing npm:load:configScope Completed in 0ms
              32 timing npm:load Completed in 194ms
              33 timing arborist:ctor Completed in 7ms
              34 silly logfile start cleaning logs, removing 4 files
              35 verbose shrinkwrap failed to load node_modules/.package-lock.json out of date, updated: node_modules
              36 silly logfile done cleaning log files
              37 timing idealTree Completed in 8644ms
              38 timing command:install Completed in 8682ms
              39 verbose stack TypeError: Cannot read properties of null (reading 'parent')
              39 verbose stack     at Arborist.[resolveLinks] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:229:24)
              39 verbose stack     at Arborist.[loadFromShrinkwrap] (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:103:29)
              39 verbose stack     at Arborist.loadVirtual (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/load-virtual.js:75:35)
              39 verbose stack     at async Arborist.buildIdealTree (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/build-ideal-tree.js:208:7)
              39 verbose stack     at async Promise.all (index 1)
              39 verbose stack     at async Arborist.reify (/usr/lib/node_modules/npm/node_modules/@npmcli/arborist/lib/arborist/reify.js:154:5)
              39 verbose stack     at async Install.exec (/usr/lib/node_modules/npm/lib/commands/install.js:145:5)
              39 verbose stack     at async module.exports (/usr/lib/node_modules/npm/lib/cli.js:78:5)
              40 verbose cwd /opt/iobroker
              41 verbose Linux 5.15.84-v8+
              42 verbose node v16.19.0
              43 verbose npm  v8.19.3
              44 error Cannot read properties of null (reading 'parent')
              45 verbose exit 1
              46 timing npm Completed in 10677ms
              47 verbose unfinished npm timer reify 1676289034004
              48 verbose unfinished npm timer reify:loadTrees 1676289034023
              49 verbose unfinished npm timer idealTree:init 1676289034027
              50 verbose code 1
              51 error A complete log of this run can be found in:
              51 error     /home/iobroker/.npm/_logs/2023-02-13T11_50_32_017Z-debug-0.log
              GlasfaserG 3 Antworten Letzte Antwort
              • B backfisch88
                ne kein VIS2.
                -> 3.3.7:
                NPM version: 8.19.3
                der log
                45 verbose exit 1
                50 verbose code 1
                GlasfaserG Offline
                GlasfaserG Offline
                hast du ein NodeJS upgrade mal gemacht !?
                versuche mal :
                cd /opt/iobroker/node_modules
                npm install --omit=dev
                sudo reboot
                Ich habe keine Ahnung was das ist 'parent' , auf was es sich bezieht ...
                  versuche mal :
                  sudo reboot
                  backfisch88
                  @glasfaser
                  npm ERR!     /home/iobroker/.npm/_logs/2023-02-13T12_02_04_657Z-debug-0.log
                  :| das ist gut
                  • B backfisch88
                    ne kein VIS2.
                    -> 3.3.7:
                    NPM version: 8.19.3
                    der log
                    45 verbose exit 1
                    50 verbose code 1
                    GlasfaserG Offline
                    GlasfaserG Offline
                    dann ...
                    rm /opt/iobroker/node_modules/.package-lock.json
                    rm /opt/iobroker/node_modules/iobroker.javascript/node_modules/.package-lock.json
                    rm /opt/iobroker/package-lock.json
                    iob rebuild
                    B Thomas BraunT 2 Antworten Letzte Antwort
                    • B backfisch88
                      @glasfaser
                      :| das ist gut
                      wendy2702W Offline
                      wendy2702W Offline
                      2023-02-13T12_02_04
                      Mal so zwischendurch gefragt:
                      Stimmen deine Zeiteinstellungen?
                        backfisch88
                        @wendy2702 ja stimmen :)
                        • B backfisch88
                          wendy2702W Offline
                          wendy2702W Offline
                          @backfisch88 Wieso dann im log eine Stunde hinter der Zeit oder steht der nicht in Deutschland bzw. in der gleichen Zeitzone?
                            dann ...
                            iob rebuild
                            backfisch88
                            @glasfaser also das läuft durch.... und der
                            scheint auch zu klappen... aus Interesse... was war es jetzt? :D
                              backfisch88
                              @wendy2702 said in npm ERR! Cannot read properties of null (reading 'parent'):
                              das ist ne >hervorragende Frage... kann das eventuell mit der Sommer /Winterzeit zusammen hängen?
                              pi@IOBroker:~ $ date
                              Mon 13 Feb 13:17:47 CET 2023
                                dann ...
                                iob rebuild
                                Thomas BraunT Offline
                                @glasfaser
                                Ich überlege, ob die vier Zeilen nicht auch was für den iob fix wären.
                                Hat bei mir gestern in etwas anderem Zusammenhang auch geholfen.
                                  @glasfaser
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @thomas-braun sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                                  Ja ... ich weiß ...
                                  Bei Github war ich auch kurz dabei nur konnte ich diesen ( Fehler ) nicht simulieren
                                  • B backfisch88
                                    ne kein VIS2.
                                    -> 3.3.7:
                                    NPM version: 8.19.3
                                    der log
                                    45 verbose exit 1
                                    50 verbose code 1
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    @Thomas-Braun
                                    Man sollte beobachten , bzw. ist mir schon öfters auch schon aufgefallen , das diese Meldung bei vielen erscheint !?
                                      @Thomas-Braun
                                      @glasfaser sagte in npm ERR! Cannot read properties of null (reading 'parent'):
                                      Ja, das Format hat sich bei aktuelleren npm-Versionen geändert. Sollte eigentlich automatisch umgestellt werden, funktioniert aber offenbar nicht immer einwandfrei. Mit frischen package*-Files geht es dann.
                                        backfisch88
                                        @Glasfaser
                                        @glasfaser
                                        der Adapter ist jetzt geupdated.. Hab mal zum test einfach n neuen Adapter installiert... das dauert ewig und es geht nix voran
                                        dann kommt irgendwann
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/Newan/ioBroker.yahoo-stock-market.git
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/Steiger04/ioBroker.radar-trap2.git
                                        npm WARN skipping integrity check for git dependency ssh://git@github.com/excal-foley/ioBroker.blockly-plus.git
                                        sind alles Adapter aus github (nicht in der offiziellen list)
                                        das geht dann aber irgendwann und dann kommt bei jedem update aber wieder der gleiche Fehler
                                          @glasfaser
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Dann wäre es ein Vorschlag ... den man eventuell mit umsetzen sollte !
