  4. Trashschedule Adapter läuft nach update nicht mehr
    5.5k
trash schedule
194 Beiträge 14 Kommentatoren 35.9k Aufrufe 13 Beobachtet
  • F Offline
    Flowski
    #184
    2023-02-09 12:28:08.504 - warn: trashschedule.0 (2204900) skipping invalid/empty trash name or match:
    2023-02-09 12:28:08.505 - warn: trashschedule.0 (2204900) skipping invalid/empty trash name or match:
    2023-02-09 12:28:08.561 - info: trashschedule.0 (2204900) [ical] configurured ical preview is 22 days - increase this value to find more events in the future
    2023-02-09 12:28:08.563 - info: trashschedule.0 (2204900) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
    2023-02-09 12:28:08.690 - warn: trashschedule.0 (2204900) no events matches type "Restabfall" with match "EB Restabfall-Tonne"
    2023-02-09 12:29:00.042 - info: jarvis.0 (16799) Client with IP 192.168.178.71 disconnected.
    2023-02-09 12:29:27.380 - info: host.IoBroker stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    2023-02-09 12:29:27.420 - info: trashschedule.0 (2204900) Got terminate signal TERMINATE_YOURSELF
    2023-02-09 12:29:27.423 - info: trashschedule.0 (2204900) cleaned everything up...
    2023-02-09 12:29:27.425 - info: trashschedule.0 (2204900) terminating
    2023-02-09 12:29:27.428 - info: trashschedule.0 (2204900) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-02-09 12:29:27.483 - info: host.IoBroker stopInstance system.adapter.trashschedule.0 send kill signal
    2023-02-09 12:29:28.003 - info: host.IoBroker instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-02-09 12:29:30.557 - info: host.IoBroker instance system.adapter.trashschedule.0 started with pid 2204963
    2023-02-09 12:29:33.248 - info: trashschedule.0 (2204963) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v16.19.0, js-controller: 4.0.23
    2023-02-09 12:29:33.532 - warn: trashschedule.0 (2204963) skipping invalid/empty trash name or match:
    2023-02-09 12:29:33.588 - info: trashschedule.0 (2204963) [ical] configurured ical preview is 22 days - increase this value to find more events in the future
    2023-02-09 12:29:33.590 - info: trashschedule.0 (2204963) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
    2023-02-09 12:29:33.720 - warn: trashschedule.0 (2204963) no events matches type "Restabfall" with match "EB Restabfall-Tonne"
    2023-02-09 12:29:33.792 - warn: trashschedule.0 (2204963) no events matches type "Restmüll" with match "Restmüll"
    2023-02-09 12:30:00.107 - info: host.IoBroker instance system.adapter.ical.0 started with pid 2204995
    2023-02-09 12:30:03.047 - info: ical.0 (2204995) starting. Version 1.13.2 in /opt/iobroker/node_modules/iobroker.ical, node: v16.19.0, js-controller: 4.0.23
    2023-02-09 12:30:03.721 - info: ical.0 (2204995) processing URL: Abfallkalender https://calendar.google.com/calendar/ical/xxx
    2023-02-09 12:30:04.070 - warn: trashschedule.0 (2204963) no events matches type "Restabfall" with match "EB Restabfall-Tonne"
    2023-02-09 12:30:04.123 - warn: trashschedule.0 (2204963) no events matches type "Restmüll" with match "Restmüll"
    2023-02-09 12:30:09.062 - info: ical.0 (2204995) Terminated (NO_ERROR): Without reason
    2023-02-09 12:30:09.602 - info: host.IoBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    2023-02-09 12:30:30.397 - info: host.IoBroker stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    2023-02-09 12:30:30.404 - info: trashschedule.0 (2204963) Got terminate signal TERMINATE_YOURSELF
    2023-02-09 12:30:30.407 - info: trashschedule.0 (2204963) cleaned everything up...
    2023-02-09 12:30:30.409 - info: trashschedule.0 (2204963) terminating
    2023-02-09 12:30:30.412 - info: trashschedule.0 (2204963) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2023-02-09 12:30:30.465 - info: host.IoBroker stopInstance system.adapter.trashschedule.0 send kill signal
    2023-02-09 12:30:30.992 - info: host.IoBroker instance system.adapter.trashschedule.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2023-02-09 12:30:33.539 - info: host.IoBroker instance system.adapter.trashschedule.0 started with pid 2205029
    2023-02-09 12:30:36.396 - info: trashschedule.0 (2205029) starting. Version 2.2.0 in /opt/iobroker/node_modules/iobroker.trashschedule, node: v16.19.0, js-controller: 4.0.23
    2023-02-09 12:30:36.587 - warn: trashschedule.0 (2205029) skipping invalid/empty trash name or match:
    2023-02-09 12:30:36.779 - info: trashschedule.0 (2205029) [ical] configurured ical preview is 22 days - increase this value to find more events in the future
    2023-02-09 12:30:36.781 - info: trashschedule.0 (2205029) [ical] found configured ical event "Vacation" without "display" flag. Activate the display flag on this entry if this is a relevant "trash event".
    2023-02-09 12:30:36.970 - warn: trashschedule.0 (2205029) no events matches type "Restabfall" with match "EB Restabfall-Tonne"
    F 1 Antwort Letzte Antwort
    • F Flowski
      Flowski
      #185
      @flowski so?
      • F Flowski
        @flowski so?
        #186
        @flowski
        Du musst das Loglevel der Instanz auf Debug ändern
        Das musst du noch tun.
        Und schau auch mal nach dem Update-Status des ioBrokers. Da dürfte noch etwas in der Pipeline liegen. Der js-controller z. B.
        • F Offline
          Flowski
          #187
          also ich habe mir nochmal manuell einen Termin angelegt mit identischer Bezeichnung und siehe da dieser wurde sofort im Jarvis und iobroker gefunden. Meine Vermutung liegt an einer defekten ical Datei,, evt. hat es auch was damit zu tun dass aufgrund von Karneval der Müll übernächste Woche DO statt MI geholt wird, im DO-Termin aber vermerkt ist dass es sich alle 2 Wochen MI wiederholt... evt. hat Iobroker hiermit ein Problem.
          HomoranH da_WoodyD 2 Antworten Letzte Antwort
          • F Flowski
            #188
            @flowski sagte in Trashschedule Adapter läuft nach update nicht mehr:
            Meine Vermutung
            müsste von dem noch ausstehenden Debug-log bestätigt werden
            • F Offline
              Flowski
              schrieb am zuletzt editiert von Flowski
              #189
              2023-02-10 13:46:54.060 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In 5 Tagen Ganztägig","event":"EB Papier-Behälter","_class":"ical_Abfallkalender ical_5days","_date":"2023-02-14T23:00:00.000Z","_end":"2023-02-15T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16759407752@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-14T23:00:00.000Z","datetype":"date","end":"2023-02-15T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230413"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-15T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-02-15T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"16759407752@muellmax.de","url":"http://www.muellmax.de","class":"PUBLIC","created":"2023-02-09T11:06:15.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-09T11:07:19.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Papier-Behälter","transparency":"TRANSPARENT","21668bc0-3ea6-46c6-a3e1-4631e95f1db8":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.497Z"},"11d7b947-a3fc-4fe4-8d7e-c3f3e5fa4b08":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.498Z"},"method":"PUBLISH"}} // originalDate: 2023-02-14T23:00:00.000Z // calculated date (with offset): Wed Feb 15 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.060 - debug: trashschedule.0 (2254370) (2) processing: "EB Papier-Behälter" (1676415600000) // dayDiff: 5 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.061 - debug: trashschedule.0 (2254370) (3) event match: "EB Papier-Behälter" matches type "Papiertonne" with pattern "EB Papier-Behälter"
              2023-02-10 13:46:54.142 - debug: trashschedule.0 (2254370) (4) filled type: "Papiertonne"
              2023-02-10 13:46:54.143 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In 5 Tagen Ganztägig","event":"EB Bio-Tonne","_class":"ical_Abfallkalender ical_5days","_date":"2023-02-14T23:00:00.000Z","_end":"2023-02-15T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"1675xxx7753@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-14T23:00:00.000Z","datetype":"date","end":"2023-02-15T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230223,20230404,20230413,20230504,20230601,20231005,20231102,20231228"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-15T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-31T00:00:00.000Z","interval":1,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-02-15T00:00:00.000Z","interval":1,"wkst":0,"count":null,"until":"2023-12-31T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"1675xxx7753@muellmax.de","url":"http://www.muellmax.de","class":"PUBLIC","created":"2023-02-09T11:06:15.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-09T11:07:19.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Bio-Tonne","transparency":"TRANSPARENT","e5e8eb65-50dd-4312-8a97-d4b7d421c3d5":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.500Z"},"fa993e17-7878-4d94-b508-2a8798506b95":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.501Z"},"method":"PUBLISH"}} // originalDate: 2023-02-14T23:00:00.000Z // calculated date (with offset): Wed Feb 15 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.146 - debug: trashschedule.0 (2254370) (2) processing: "EB Bio-Tonne" (1676415600000) // dayDiff: 5 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.147 - debug: trashschedule.0 (2254370) (3) event match: "EB Bio-Tonne" matches type "Biotonne" with pattern "EB Bio-Tonne"
              2023-02-10 13:46:54.206 - debug: trashschedule.0 (2254370) (4) filled type: "Biotonne"
              2023-02-10 13:46:54.207 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In 5 Tagen Ganztägig","event":"Bio","_class":"ical_Abfallkalender ical_5days","_date":"2023-02-14T23:00:00.000Z","_end":"2023-02-15T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16723512843@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-14T23:00:00.000Z","datetype":"date","dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512843@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:04:37.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Bio","transparency":"TRANSPARENT","574fbc51-8627-4bab-8034-0c0a21e4cf5a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"ad75752e-c2b5-4d3f-a286-5f499904ef19":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"end":"2023-02-15T23:00:00.000Z","method":"PUBLISH","recurrences":{"2023-01-03":{"type":"VEVENT","params":[],"start":"2023-01-04T09:00:00.000Z","datetype":"date-time","dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512843@muellmax.de","recurrenceid":"2023-01-03T23:00:00.000Z","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-30T07:50:17.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"1","status":"CONFIRMED","summary":"Bio","transparency":"TRANSPARENT","574fbc51-8627-4bab-8034-0c0a21e4cf5a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"ad75752e-c2b5-4d3f-a286-5f499904ef19":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"end":"2023-01-04T09:00:00.000Z","method":"PUBLISH"}},"exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230223,20230404,20230413,20230504,20230601,20231005,20231102,20231228"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-04T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-31T00:00:00.000Z","interval":1,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-01-04T00:00:00.000Z","interval":1,"wkst":0,"count":null,"until":"2023-12-31T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"371d37fa-4469-463d-b2e6-eade617249d6":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.511Z"},"8fb19296-ea77-43a6-b07f-07b1b2366a4a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.512Z"}}} // originalDate: 2023-02-14T23:00:00.000Z // calculated date (with offset): Wed Feb 15 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.208 - debug: trashschedule.0 (2254370) (2) processing: "Bio" (1676415600000) // dayDiff: 5 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.209 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In 5 Tagen Ganztägig","event":"Papier","_class":"ical_Abfallkalender ical_5days","_date":"2023-02-14T23:00:00.000Z","_end":"2023-02-15T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16723512842@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-14T23:00:00.000Z","datetype":"date","end":"2023-02-15T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230413"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-04T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-01-04T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512842@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:04:46.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Papier","transparency":"TRANSPARENT","a0fd6812-4a68-4e4c-b33a-9462b5dfa9dd":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.510Z"},"a6b09dde-dc96-40f3-b6be-c08f4e098e3b":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.510Z"},"method":"PUBLISH"}} // originalDate: 2023-02-14T23:00:00.000Z // calculated date (with offset): Wed Feb 15 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.209 - debug: trashschedule.0 (2254370) (2) processing: "Papier" (1676415600000) // dayDiff: 5 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.210 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In einer Woche Ganztägig","event":"EB Gelber Sack","_class":"ical_Abfallkalender ical_oneweek","_date":"2023-02-16T23:00:00.000Z","_end":"2023-02-17T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"5bjbuco1j7mrr5jgbul2m2h6i5@google.com","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-16T23:00:00.000Z","datetype":"date","end":"2023-02-17T23:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-17T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":4}]},"options":{"freq":2,"dtstart":"2023-02-17T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[4],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"5bjbuco1j7mrr5jgbul2m2h6i5@google.com","class":"PUBLIC","created":"2023-02-10T11:53:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-10T11:53:24.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Gelber Sack","transparency":"TRANSPARENT","edf41bc6-bebb-42bf-b8e5-3f5b29aa0e86":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.490Z"},"30741f84-7ae8-4b12-b7cf-a9218337c7e8":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.491Z"},"method":"PUBLISH"}} // originalDate: 2023-02-16T23:00:00.000Z // calculated date (with offset): Fri Feb 17 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.212 - debug: trashschedule.0 (2254370) (2) processing: "EB Gelber Sack" (1676588400000) // dayDiff: 7 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.212 - debug: trashschedule.0 (2254370) (3) event match: "EB Gelber Sack" matches type "GelberSack" with pattern "EB Gelber Sack"
              2023-02-10 13:46:54.275 - debug: trashschedule.0 (2254370) (4) filled type: "GelberSack"
              2023-02-10 13:46:54.276 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"In einer Woche Ganztägig","event":"Gelber Sack","_class":"ical_Abfallkalender ical_oneweek","_date":"2023-02-16T23:00:00.000Z","_end":"2023-02-17T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"xxx@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-16T23:00:00.000Z","datetype":"date","end":"2023-02-17T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230415,20230610"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-06T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":4}]},"options":{"freq":2,"dtstart":"2023-01-06T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[4],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"xxx@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:05:12.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Gelber Sack","transparency":"TRANSPARENT","2abc746b-24c4-4e10-926e-15860b21628b":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.508Z"},"a392d195-93ff-41f6-b5ed-eba19f47bd8c":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.508Z"},"method":"PUBLISH"}} // originalDate: 2023-02-16T23:00:00.000Z // calculated date (with offset): Fri Feb 17 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.277 - debug: trashschedule.0 (2254370) (2) processing: "Gelber Sack" (1676588400000) // dayDiff: 7 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.278 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"23.02. Ganztägig","event":"EB Restabfall-Tonne","_class":"ical_Abfallkalender ","_date":"2023-02-22T23:00:00.000Z","_end":"2023-02-23T23:00:00.000Z","_section":"","_IDID":"5h10sf2cp6ptdichtrovv4thes@google.com","_allDay":true,"_private":false,"_rule":" ","location":"","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-22T23:00:00.000Z","datetype":"date","end":"2023-02-23T23:00:00.000Z","dtstamp":"2023-02-10T12:30:03.000Z","uid":"5h10sf2cp6ptdichtrovv4thes@google.com","created":"2023-02-10T12:17:18.000Z","description":"","lastmodified":"2023-02-10T12:17:18.000Z","location":"","sequence":"0","status":"CONFIRMED","summary":"EB Restabfall-Tonne","transparency":"TRANSPARENT","5d609648-8ba5-4488-b026-43a51e6d475a":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.488Z"},"0c8efc87-bcc0-4c50-9bc1-3e6f24d9be73":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.489Z"},"method":"PUBLISH"}} // originalDate: 2023-02-22T23:00:00.000Z // calculated date (with offset): Thu Feb 23 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.279 - debug: trashschedule.0 (2254370) (2) processing: "EB Restabfall-Tonne" (1677106800000) // dayDiff: 13 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.279 - debug: trashschedule.0 (2254370) (3) event match: "EB Restabfall-Tonne" matches type "EB Restabfall-Tonne" with pattern "EB Restabfall-Tonne"
              2023-02-10 13:46:54.342 - debug: trashschedule.0 (2254370) (4) filled type: "EB Restabfall-Tonne"
              2023-02-10 13:46:54.343 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"01.03. Ganztägig","event":"EB Papier-Behälter","_class":"ical_Abfallkalender ","_date":"2023-02-28T23:00:00.000Z","_end":"2023-03-01T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16759407752@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-28T23:00:00.000Z","datetype":"date","end":"2023-03-01T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230413"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-15T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-02-15T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"16759407752@muellmax.de","url":"http://www.muellmax.de","class":"PUBLIC","created":"2023-02-09T11:06:15.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-09T11:07:19.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Papier-Behälter","transparency":"TRANSPARENT","21668bc0-3ea6-46c6-a3e1-4631e95f1db8":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.497Z"},"11d7b947-a3fc-4fe4-8d7e-c3f3e5fa4b08":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.498Z"},"method":"PUBLISH"}} // originalDate: 2023-02-28T23:00:00.000Z // calculated date (with offset): Wed Mar 01 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.343 - debug: trashschedule.0 (2254370) (2) processing: "EB Papier-Behälter" (1677625200000) // dayDiff: 19 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.344 - debug: trashschedule.0 (2254370) (3) event match: "EB Papier-Behälter" matches type "Papiertonne" with pattern "EB Papier-Behälter"
              2023-02-10 13:46:54.345 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"01.03. Ganztägig","event":"EB Bio-Tonne","_class":"ical_Abfallkalender ","_date":"2023-02-28T23:00:00.000Z","_end":"2023-03-01T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"1675xxx7753@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-28T23:00:00.000Z","datetype":"date","end":"2023-03-01T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230223,20230404,20230413,20230504,20230601,20231005,20231102,20231228"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-15T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-31T00:00:00.000Z","interval":1,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-02-15T00:00:00.000Z","interval":1,"wkst":0,"count":null,"until":"2023-12-31T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"1675xxx7753@muellmax.de","url":"http://www.muellmax.de","class":"PUBLIC","created":"2023-02-09T11:06:15.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-09T11:07:19.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Bio-Tonne","transparency":"TRANSPARENT","e5e8eb65-50dd-4312-8a97-d4b7d421c3d5":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.500Z"},"fa993e17-7878-4d94-b508-2a8798506b95":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.501Z"},"method":"PUBLISH"}} // originalDate: 2023-02-28T23:00:00.000Z // calculated date (with offset): Wed Mar 01 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.345 - debug: trashschedule.0 (2254370) (2) processing: "EB Bio-Tonne" (1677625200000) // dayDiff: 19 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.346 - debug: trashschedule.0 (2254370) (3) event match: "EB Bio-Tonne" matches type "Biotonne" with pattern "EB Bio-Tonne"
              2023-02-10 13:46:54.346 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"01.03. Ganztägig","event":"Bio","_class":"ical_Abfallkalender ","_date":"2023-02-28T23:00:00.000Z","_end":"2023-03-01T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16723512843@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-28T23:00:00.000Z","datetype":"date","dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512843@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:04:37.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Bio","transparency":"TRANSPARENT","574fbc51-8627-4bab-8034-0c0a21e4cf5a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"ad75752e-c2b5-4d3f-a286-5f499904ef19":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"end":"2023-03-01T23:00:00.000Z","method":"PUBLISH","recurrences":{"2023-01-03":{"type":"VEVENT","params":[],"start":"2023-01-04T09:00:00.000Z","datetype":"date-time","dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512843@muellmax.de","recurrenceid":"2023-01-03T23:00:00.000Z","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-30T07:50:17.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"1","status":"CONFIRMED","summary":"Bio","transparency":"TRANSPARENT","574fbc51-8627-4bab-8034-0c0a21e4cf5a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"ad75752e-c2b5-4d3f-a286-5f499904ef19":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.507Z"},"end":"2023-01-04T09:00:00.000Z","method":"PUBLISH"}},"exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230223,20230404,20230413,20230504,20230601,20231005,20231102,20231228"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-04T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-31T00:00:00.000Z","interval":1,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-01-04T00:00:00.000Z","interval":1,"wkst":0,"count":null,"until":"2023-12-31T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"371d37fa-4469-463d-b2e6-eade617249d6":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.511Z"},"8fb19296-ea77-43a6-b07f-07b1b2366a4a":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.512Z"}}} // originalDate: 2023-02-28T23:00:00.000Z // calculated date (with offset): Wed Mar 01 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.347 - debug: trashschedule.0 (2254370) (2) processing: "Bio" (1677625200000) // dayDiff: 19 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.348 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"01.03. Ganztägig","event":"Papier","_class":"ical_Abfallkalender ","_date":"2023-02-28T23:00:00.000Z","_end":"2023-03-01T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"16723512842@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-02-28T23:00:00.000Z","datetype":"date","end":"2023-03-01T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230413"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-04T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":2}]},"options":{"freq":2,"dtstart":"2023-01-04T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[2],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"16723512842@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:04:46.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Papier","transparency":"TRANSPARENT","a0fd6812-4a68-4e4c-b33a-9462b5dfa9dd":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.510Z"},"a6b09dde-dc96-40f3-b6be-c08f4e098e3b":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.510Z"},"method":"PUBLISH"}} // originalDate: 2023-02-28T23:00:00.000Z // calculated date (with offset): Wed Mar 01 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.349 - debug: trashschedule.0 (2254370) (2) processing: "Papier" (1677625200000) // dayDiff: 19 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.349 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"03.03. Ganztägig","event":"EB Gelber Sack","_class":"ical_Abfallkalender ","_date":"2023-03-02T23:00:00.000Z","_end":"2023-03-03T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"5bjbuco1j7mrr5jgbul2m2h6i5@google.com","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-03-02T23:00:00.000Z","datetype":"date","end":"2023-03-03T23:00:00.000Z","rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-02-17T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":4}]},"options":{"freq":2,"dtstart":"2023-02-17T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[4],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"5bjbuco1j7mrr5jgbul2m2h6i5@google.com","class":"PUBLIC","created":"2023-02-10T11:53:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2023-02-10T11:53:24.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"EB Gelber Sack","transparency":"TRANSPARENT","edf41bc6-bebb-42bf-b8e5-3f5b29aa0e86":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.490Z"},"30741f84-7ae8-4b12-b7cf-a9218337c7e8":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.491Z"},"method":"PUBLISH"}} // originalDate: 2023-03-02T23:00:00.000Z // calculated date (with offset): Fri Mar 03 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.350 - debug: trashschedule.0 (2254370) (2) processing: "EB Gelber Sack" (1677798000000) // dayDiff: 21 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.350 - debug: trashschedule.0 (2254370) (3) event match: "EB Gelber Sack" matches type "GelberSack" with pattern "EB Gelber Sack"
              2023-02-10 13:46:54.351 - debug: trashschedule.0 (2254370) (1) parsing next event {"date":"03.03. Ganztägig","event":"Gelber Sack","_class":"ical_Abfallkalender ","_date":"2023-03-02T23:00:00.000Z","_end":"2023-03-03T23:00:00.000Z","_section":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","_IDID":"xxx@muellmax.de","_allDay":true,"_private":false,"_rule":" rrule ","location":"55131 Mainz-Oberstadt, Münchener Straße 41","_calName":"Abfallkalender","_calColor":"#0067ff","_object":{"type":"VEVENT","params":[],"start":"2023-03-02T23:00:00.000Z","datetype":"date","end":"2023-03-03T23:00:00.000Z","exdate":[],"rdate":{"params":{"VALUE":"DATE"},"val":"20230415,20230610"},"rrule":{"_cache":{"all":false,"before":[],"after":[],"between":[]},"origOptions":{"dtstart":"2023-01-06T00:00:00.000Z","freq":2,"wkst":{"weekday":0},"until":"2023-12-24T00:00:00.000Z","interval":2,"byweekday":[{"weekday":4}]},"options":{"freq":2,"dtstart":"2023-01-06T00:00:00.000Z","interval":2,"wkst":0,"count":null,"until":"2023-12-24T00:00:00.000Z","bysetpos":null,"bymonth":null,"bymonthday":[],"bynmonthday":[],"byyearday":null,"byweekno":null,"byweekday":[4],"bynweekday":null,"byhour":[0],"byminute":[0],"bysecond":[0],"byeaster":null}},"dtstamp":"2023-02-10T12:30:03.000Z","uid":"xxx@muellmax.de","class":"PUBLIC","created":"2022-12-29T22:01:24.000Z","description":"Entsorgungsbetrieb der Stadt Mainz\nZwerchallee 24\n55120 Mainz\n\nTelefon: +49 6131 12 34 56 (Abfallberatung)\nTelefax: +49 6131 12 34 83\n\nDer Entsorgungsbetrieb ist ein Eigenbetrieb der Stadt München.","lastmodified":"2022-12-29T22:05:12.000Z","location":"55131 Mainz-Oberstadt, Münchener Straße 41","sequence":"0","status":"CONFIRMED","summary":"Gelber Sack","transparency":"TRANSPARENT","2abc746b-24c4-4e10-926e-15860b21628b":{"type":"VALARM","params":[],"action":"DISPLAY","description":"This is an event reminder","trigger":"-P0DT0H30M0S","end":"2023-02-11T12:30:03.508Z"},"a392d195-93ff-41f6-b5ed-eba19f47bd8c":{"type":"VALARM","params":[],"action":"EMAIL","description":"This is an event reminder","summary":"Alarm notification","attendee":"mailto:xxx@gmail.com","trigger":"-P0DT7H30M0S","end":"2023-02-11T12:30:03.508Z"},"method":"PUBLISH"}} // originalDate: 2023-03-02T23:00:00.000Z // calculated date (with offset): Fri Mar 03 2023 00:00:00 GMT+0100 (Central European Standard Time)
              2023-02-10 13:46:54.352 - debug: trashschedule.0 (2254370) (2) processing: "Gelber Sack" (1677798000000) // dayDiff: 21 // current hour (date): 13 // skipsamedayathour (config): 22
              2023-02-10 13:46:54.461 - debug: trashschedule.0 (2254370) (5) filling "next" event with data: {"minDays":5,"minDate":"2023-02-14T23:00:00.000Z","minTypes":["Papiertonne","Biotonne"]}
              2023-02-10 13:46:54.515 - debug: trashschedule.0 (2254370) (5) filling "nextAfter" event with data: {"minDays":7,"minDate":"2023-02-16T23:00:00.000Z","minTypes":["GelberSack"]}
              2023-02-10 13:51:03.772 - info: admin.0 (956) <== Disconnect system.user.admin from ::ffff:192.168.178.21 admin
              2023-02-10 13:51:04.982 - info: admin.0 (956) ==> Connected system.user.admin from ::ffff:192.168.178.21
              so?
              • F Flowski
                Hallo, mir ist heute aufgefallen, dass in meinem Trashschedule 3 von 4 "Müllarten" korrekt angezeigt werden, nur einer zeigt "null" im Jarvis an. Hat jemand eine Idee wie ich das beheben könnnte? Zu vor lief immer alles reibungslos?!
                haus-automatisierungH Offline
                #190
                Laut Debug-Log werden aber auch 4 gefüllt:
                • Papiertonne
                • Biotonne
                • GelberSack
                • EB Restabfall-Tonne
                Was genau ist deine Frage nochmal?
                • F Flowski
                  da_WoodyD Offline
                  da_WoodyD Offline
                  #191
                  nicht die datei ist defekt, sondern die einträge.
                  woher hast du die ical?
                  ich bekomm die an jahresende über die gemeinde. die wird dann importiert, fertig. karneval wirds ja nicht nur heuer geben.
                  das kann IMHO in keiner ical stehn...
                  • F Offline
                    Flowski
                    #192
                    diese werden jetzt gefüllt nachdem ich manuelle Einträge im Kalender durchgeführt habe, aber davor waren im Iobroker alle Datenpunkte der Restmülltonne leer. Ich hatte die Restmülltonne heute zwischenzeitlich auch mal umbenannt weil ich eine neue Datei von Müllmax importiert habe - mit dem selben Ergebnis, dass alle Müllsorten außer des Restmülls funktionierten.
                    • F Flowski
                      #193
                      @flowski Gut, ich kann hier nicht helfen... Du lieferst ja einfach kein Log vom Fehlerfall.
                        Flowski
                        #194
                        @haus-automatisierung sorry dachte mein vorletzter Post wäre nun der richtige Log. Habe in der Instanz auf debug gestellt und das Protokoll refreshed. Ich gucke mir dass nochmal an.
