  4. Test Adapter ioBroker.backitup v3.1.x
    1.0k
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.8m Aufrufe 113 Beobachtet
  • JackDanielJ Offline
    JackDanielJ Offline
    JackDaniel
    #2191
    Started iobroker ...
    [DEBUG] [iobroker] - host.iobroker 45332 states saved
    [DEBUG] [iobroker] - host.iobroker 35216 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-08_32_53_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker"
    Error: backup path must be specified as a single positional argument
    was muss ich hier machen damit mein backup wieder funktioniert, danke im voraus
    Carpe diem
    • Thomas BraunT Online
      #2192
      @jackdaniel sagte in Test Adapter ioBroker.backitup v2.5.x:
      Das mal geprüft?
      https://forum.iobroker.net/topic/57284/gelöst-backitup-error
        JackDanielJ Offline
        JackDaniel
        schrieb am zuletzt editiert von JackDaniel
        #2193
        ja das hatte ich schon gefunden, der token passt zu 100% (hab extra einen neuen erstellt)
        jackdaniel@iobroker:~$ influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==
        ID                      Description     Token        User Name        User ID                 Permissions
        0aba8d818e0ed000        iob backup      1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA==        JackDaniel      0ab0654b30378000        [read:orgs/f101a4afa60bf046/annotations write:orgs/f101a4afa60bf046/annotations read:orgs/f101a4afa60bf046/authorizations write:orgs/f101a4afa60bf046/authorizations read:orgs/f101a4afa60bf046/buckets write:orgs/f101a4afa60bf046/buckets read:orgs/f101a4afa60bf046/checks write:orgs/f101a4afa60bf046/checks read:orgs/f101a4afa60bf046/dashboards write:orgs/f101a4afa60bf046/dashboards read:orgs/f101a4afa60bf046/dbrp write:orgs/f101a4afa60bf046/dbrp read:orgs/f101a4afa60bf046/documents write:orgs/f101a4afa60bf046/documents read:orgs/f101a4afa60bf046/labels write:orgs/f101a4afa60bf046/labels read:orgs/f101a4afa60bf046/notebooks write:orgs/f101a4afa60bf046/notebooks read:orgs/f101a4afa60bf046/notificationEndpoints write:orgs/f101a4afa60bf046/notificationEndpoints read:orgs/f101a4afa60bf046/notificationRules write:orgs/f101a4afa60bf046/notificationRules read:/orgs/f101a4afa60bf046 read:orgs/f101a4afa60bf046/remotes write:orgs/f101a4afa60bf046/remotes read:orgs/f101a4afa60bf046/replications write:orgs/f101a4afa60bf046/replications read:orgs/f101a4afa60bf046/scrapers write:orgs/f101a4afa60bf046/scrapers read:orgs/f101a4afa60bf046/secrets write:orgs/f101a4afa60bf046/secrets read:orgs/f101a4afa60bf046/sources write:orgs/f101a4afa60bf046/sources read:orgs/f101a4afa60bf046/tasks write:orgs/f101a4afa60bf046/tasks read:orgs/f101a4afa60bf046/telegrafs write:orgs/f101a4afa60bf046/telegrafs read:/users/0ab0654b30378000 write:/users/0ab0654b30378000 read:orgs/f101a4afa60bf046/variables write:orgs/f101a4afa60bf046/variables read:orgs/f101a4afa60bf046/views write:orgs/f101a4afa60bf046/views]
        Carpe diem
        • JackDanielJ JackDaniel
          simatecS Offline
          simatecS Offline
          simatec
          #2194
          [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t influx auth list -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-08_33_06_backupiobroker" Error: backup path must be specified as a single positional argument
          Also das influx auth list -t hat im Token nichts zu suchen.
          Da hast du sicher copy & paste gemacht
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          JackDanielJ 1 Antwort Letzte Antwort
          • simatecS simatec
            JackDanielJ Offline
            JackDanielJ Offline
            JackDaniel
            #2195
            @simatec sagte in Test Adapter ioBroker.backitup v2.5.x:
            sorry aber das ist die ausgabe wenn ich im admin ein backup manuell starte
            was meinst du mit "sicher mit c&p gemacht" ?
            Carpe diem
            Thomas BraunT simatecS 2 Antworten Letzte Antwort
              #2196
              @jackdaniel
              Zeig mal die Seite mit den Einstellungen in Backitup.
                simatecS Offline
                simatecS Offline
                simatec
                #2197
                @jackdaniel
                Du hast in der Config von Backitup folgenden Inhalt als Token gespeichert.
                Ändere das bitte mit dem reinen Token:
                • simatecS simatec
                  @jackdaniel
                  JackDanielJ Offline
                  JackDanielJ Offline
                  JackDaniel
                  #2198
                  erledigt, nun bekomme ich wieder das
                  [DEBUG] [iobroker] - host.iobroker 45451 states saved
                  [DEBUG] [iobroker] - host.iobroker 35356 objects saved
                  [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2023_02_10-13_11_48_backupiobroker.tar.gz
                  [ERROR] [influxDB] - Error: Command failed: influx backup --bucket iobroker -t 1pRxyeDJKPVX_QkyLz-jiGerRGU43WBKyguqQJqTA4VVb1UmZWttZITeE5njbYQWrf5-Bd__-8u9tjQvryADPA== "/opt/iobroker/backups/influxDB_2023_02_10-13_12_02_backupiobroker"
                  2023/02/10 13:12:02 INFO: Downloading metadata snapshot
                  Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
                  Carpe diem
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #2199
                    @jackdaniel Dann ist es wohl kein Admin Token...
                      simatecS Offline
                      simatecS Offline
                      simatec
                      #2200
                      @jackdaniel Lese dir mal das hier durch ...
                      https://forum.iobroker.net/post/929325
                      • simatecS simatec
                        JackDanielJ Offline
                        JackDanielJ Offline
                        JackDaniel
                        #2201
                        hmm da kann man(n) eigentlich nicht viel falsch machen ...
                        Carpe diem
                        • simatecS simatec
                          JackDanielJ Offline
                          JackDanielJ Offline
                          JackDaniel
                          #2202
                          mach ich morgen, hab heute leider keine zeit :(
                          Carpe diem
                            simatecS Offline
                            simatecS Offline
                            simatec
                            #2203
                            @jackdaniel
                            Mit welchem User bist du eingeloggt?
                            Lies da mal in der Doku. Denke der Token muss definitiv mit dem Admin Account erstellt werden.
                            Hier gab es dazu auch einen Thread
                            • simatecS Offline
                              simatecS Offline
                              simatec
                              #2204
                              Ab sofort steht auf Github und in kürze auch im latest die Version 2.6.0 zum testen bereit.
                              Changelog
                              2.6.0 (2023-02-16)
                              • (simatec) Onedrive-Api added
                              • (simatec) Matrix Messenger added
                              • (simatec) TLS for FTP added
                              • (simatec) Tab Extra-Settings added
                              • (simatec) Node-Red Backup added
                              • (simatec) SQLLite Backup added
                              • (simatec) Zigbee2MQTT Backup added
                              • (simatec) Local-Storage check added
                              • (simatec) System-Message added
                              • (simatec) Jarvis Backup updated
                              • (simatec) many small Fixes
                              • simatecS simatec
                                Changelog
                                2.6.0 (2023-02-16)
                                jay-jey
                                #2205
                                @simatec Hallo ich wollte jetzt mal das Backup auf Onedrive testen. Aber ich bekomme dabei einen immer einen Fehler. Irgendwas wird getan, weil im Onedrive werden Dateien angelegt aber nur kleine mit 8KB
                                hier mal das Ende vom Log:
                                [DEBUG] [grafana] - found Dashboard: heizung
                                [DEBUG] [grafana] - start Grafana backup compress ...
                                [DEBUG] [grafana] - Backup created: /opt/iobroker/backups/grafana_2023_02_24-07_32_50_backupiobroker.tar.gz
                                [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                                [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                                [DEBUG] [grafana] - done
                                [DEBUG] [onedrive] - Onedrive: Copy iobroker_2023_02_24-07_31_49_backupiobroker.tar.gz...
                                [ERROR] [onedrive] - upload Onedrive: {"name":"HTTPError","code":"ERR_NON_2XX_3XX_RESPONSE","timings":{"start":1677220377193,"socket":1677220377194,"lookup":1677220377206,"connect":1677220377228,"secureConnect":1677220377280,"upload":1677220401641,"response":1677220402872,"end":1677220402876,"phases":{"wait":1,"dns":12,"tcp":22,"tls":52,"request":24361,"firstByte":1231,"download":4,"total":25683}}}
                                [DEBUG] [onedrive] - Onedrive: Copy influxDB_2023_02_24-07_32_21_backupiobroker.tar.gz...
                                [ERROR] [onedrive] - upload Onedrive: {"name":"HTTPError","code":"ERR_NON_2XX_3XX_RESPONSE","timings":{"start":1677220402896,"socket":1677220402897,"lookup":1677220402909,"connect":1677220402931,"secureConnect":1677220402984,"upload":1677220440784,"response":1677220445642,"end":1677220445647,"phases":{"wait":1,"dns":12,"tcp":22,"tls":53,"request":37800,"firstByte":4858,"download":5,"total":42751}}}
                                [DEBUG] [onedrive] - Onedrive: Copy zigbee.0_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                [DEBUG] [onedrive] - zigbee.0_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145904 saved on Onedrive
                                [DEBUG] [onedrive] - Onedrive: Copy zigbee.1_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                [DEBUG] [onedrive] - zigbee.1_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145905 saved on Onedrive
                                [DEBUG] [onedrive] - Onedrive: Copy zigbee.2_2023_02_24-07_32_49_backupiobroker.tar.gz...
                                [DEBUG] [onedrive] - zigbee.2_2023_02_24-07_32_49_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145906 saved on Onedrive
                                [DEBUG] [onedrive] - Onedrive: Copy grafana_2023_02_24-07_32_50_backupiobroker.tar.gz...
                                [DEBUG] [onedrive] - grafana_2023_02_24-07_32_50_backupiobroker.tar.gz with Id: 8EAB853A46DB9335!145907 saved on Onedrive
                                [DEBUG] [onedrive] - done
                                [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
                                [DEBUG] [clean] - done
                                [DEBUG] [historyHTML] - new history html values created
                                [DEBUG] [historyHTML] - done
                                [DEBUG] [historyJSON] - new history json values created
                                [DEBUG] [historyJSON] - done
                                [EXIT] 0
                                • J jay-jey
                                  [EXIT] 0
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #2206
                                  @jay-jey Wie groß sind denn deinen Backup Files für iobroker und Influx?
                                  • simatecS simatec
                                    jay-jey
                                    #2207
                                    @simatec Hallo, danke für die promte Antwort. So schnell hab ich nicht damit gerechnet, daher jetzt erst: Also das Iobroker ist 113mb und Influx ist 180mb
                                    • J jay-jey
                                      simatecS Offline
                                      simatecS Offline
                                      simatec
                                      #2208
                                      @jay-jey Speicherplatz in der Onedrive ist genug vorhanden?
                                      Ich schaue mir das mal an, ob es in der Onedrive Api da Begrenzungen gibt. Mir ist erstmal nichts bekannt.
                                      • simatecS simatec
                                        jay-jey
                                        #2209
                                        @simatec Ja noch mehr als 600Gb. 218ea906-219d-4f3c-a1ea-03d7a09b521b-grafik.png
                                        • J jay-jey
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #2210
                                          @jay-jey Teste mal bitte die v.2.6.4.
                                          Dort habe ich umgestellt auf eine Upload-Session.
                                          Sollte damit auch möglich sein, größere Files hochzuladen
