  4. Update auf Bullseye klappt nicht - dhcp startet nicht
    5.5k
162 Beiträge 10 Kommentatoren 11.6k Aufrufe 7 Beobachtet
    @glasfaser
    Das war die hier.....
    link text
    @Glasfaser
    pi@raspberrypi:~ $ apt policy nodejs
    nodejs:
      Installiert:           14.21.2-deb-1nodesource1
      Installationskandidat: 14.21.2-deb-1nodesource1
      Versionstabelle:
     *** 14.21.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    sudo apt install nodejs=16.19.0-deb-1nodesource1
    Wäre das richtig?
      @Glasfaser
      nodejs:
        Versionstabelle:
      Wäre das richtig?
      GlasfaserG Offline
      GlasfaserG Offline
      @tobi83 sagte in Echarts verschwindet:
      Zeige erstmal was du hast !
      https://forum.iobroker.net/post/943335
      • GlasfaserG Glasfaser
        @glasfaser
        Skript v.2023-01-02
        *** BASE SYSTEM ***
        Model           : Raspberry Pi 4 Model B Rev 1.1
        Architecture:   armv7l
        Docker:         false
        Virtualization: none
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
        NAME="Raspbian GNU/Linux"
        VERSION_ID="10"
        VERSION="10 (buster)"
        VERSION_CODENAME=buster
        ID=raspbian
        ID_LIKE=debian
        HOME_URL="http://www.raspbian.org/"
        SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
        BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
        Systemuptime and Load:
         20:31:47 up 6 min,  2 users,  load average: 0.00, 0.10, 0.07
        CPU threads: 4
        *** Time and Time Zones ***
        Wed Feb  8 19:31:47 UTC 2023
        Wed Feb  8 20:31:47 CET 2023
        CET +0100
        Europe/Berlin
        *** User and Groups ***
        pi
        /home/pi
        pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        *** X-Server-Setup ***
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Mem:           3.8G         59M        3.4G        8.0M        334M        3.6G
        Swap:           99M          0B         99M
        Total:         3.9G         59M        3.5G
                 3838 M total memory
                   60 M used memory
                  142 M active memory
                  200 M inactive memory
                 3443 M free memory
                   46 M buffer memory
                  288 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /dev/root      ext4       59G  7.1G   49G  13% /
        devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
        tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
        tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
        tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
        Messages in dmesg:
        [Wed Feb  8 20:25:05 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:08:8A:C5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Wed Feb  8 20:25:06 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Wed Feb  8 20:25:06 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Wed Feb  8 20:25:08 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        TARGET        SOURCE         FSTYPE OPTIONS
        /             /dev/mmcblk0p2 ext4   rw,noatime
        |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
        `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        504M    /var/
        302M    /var/cache
        296M    /var/cache/apt
        237M    /var/cache/apt/archives
        97M     /var/lib
        /opt/iobroker/backups:
        54M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        1.5G    /opt/iobroker/iobroker-data/
        769M    /opt/iobroker/iobroker-data/history
        433M    /opt/iobroker/iobroker-data/files
        148M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        25M     /opt/iobroker/iobroker-data/objects.json.migrated
        25M     /opt/iobroker/iobroker-data/objects.json.broken
        25M     /opt/iobroker/iobroker-data/objects.json.bak.migrated
        24M     /opt/iobroker/iobroker-data/objects.jsonl
        22M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.5c7ca159.js.map
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v14.21.2
        /usr/bin/node           v14.21.2
        /usr/bin/npm            6.14.17
        /usr/bin/npx            6.14.17
        nodejs:
          Installed: 14.21.2-deb-1nodesource1
          Candidate: 14.21.2-deb-1nodesource1
          Version table:
        *** ioBroker-Installation ***
        ioBroker Status
          @Glasfaser
          nodejs:
            Versionstabelle:
          Wäre das richtig?
          GlasfaserG Offline
          GlasfaserG Offline
          raspbian buster
          ist Out ....
          Nimm bullseye
            raspbian buster
            ist Out ....
            Nimm bullseye
            @glasfaser
            Hab das ganze nun wieder gestartet und läuft erst einmal
            Der Wechsel zu "bullseye" ist wieder ne größere Op?!
            passende Anleitung?
            Thomas BraunT wendy2702W 2 Antworten Letzte Antwort
              @glasfaser
              passende Anleitung?
              @tobi83
              Nein, keine große OP, die Anleitung ist richtig.
              Ich würde allerdings die Gelegenheit nutzen und gleich ein 64bit-System aufsetzen. Das muss allerdings von Grund auf erfolgen, geht nicht per Upgrade.
                @glasfaser
                passende Anleitung?
                wendy2702W Offline
                wendy2702W Offline
                @tobi83 Ja, passende Anleitung.
                Oder iobroker Backup
                SD Karte mit Bullseye neu aufsetzen
                Iobroker mit Einzeiler installieren
                Backup restore
                • wendy2702W wendy2702
                  Backup restore
                  @wendy2702
                  Mit dem Backup hat in der Vergangengheit immer was gefehlt oder hat geklemmt ohne Ende wo ich damals Probleme mit den SD Karten hatte.
                    @wendy2702
                    wendy2702W Offline
                    wendy2702W Offline
                    @tobi83 Wie du meinst.
                    Hatte ich persönlich noch nie und zu 99% lag der Fehler vor dem Bildschirm ;-)
                      @wendy2702
                      @Thomas-Braun
                      Hab damals mehrere Karten gehabt die immer wieder nicht erkannt wurde.
                      Lasse gerade das Update laufen.
                      Er hat gerade "sudo apt full-upgrade" abgearbeitet nachdem ich die einträge auf Bullseye umgestellt habe.
                      So nun bootet er ist aber nicht mehr ansprechbar.
                      Beim Boot erscheint:
                      Failed : Failed to start Login Service
                      Failed : Failed to start dhcp on all inferfaces
                      Ist per Putty auch nicht mehr ansprechbar
                      hab das so entsprechend geändert:
                      Wenn da alt sowas drin steht:
                      [Service]
                      ExecStart=
                      ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -w
                      ändern wir es auf neu:
                      [Service]
                      ExecStart=
                      ExecStart=/usr/sbin/dhcpcd -q -w
                        @wendy2702
                        @Thomas-Braun
                        [Service]
                        ExecStart=
                        [Service]
                        ExecStart=
                        wendy2702W Offline
                        wendy2702W Offline
                        @tobi83 Hast du da jetzt Bildschirm und Tastatur dran?
                        • ? Offline
                          @wendy2702
                          Hab ein Monitor am PI hängen daher konnte ich das sehen
                          Tastatur ist auch da
                          Er meckert auch wegen der Zeit anscheinend
                            @wendy2702
                            wendy2702W Offline
                            wendy2702W Offline
                            @tobi83 zeig mal:
                            sudo cat /etc/systemd/system/dhcpcd.service.d/wait.conf
                            Da ist nicht zufällig irgendwas falsches mit reingerutscht?
                              @tobi83 zeig mal:
                              @wendy2702
                              mit welchen Daten melde ich mich an?
                              pi und raspberry geht nicht
                                @wendy2702
                                wendy2702W Offline
                                wendy2702W Offline
                                @tobi83 denke das ist der User den du früher benutzt hast?
                                Mal „root“ probiert ?
                                • ? Offline
                                  Hab mich mit pi und raspberry über putty angemeldet
                                  Die Daten gehen nicht
                                  wendy2702W Thomas BraunT 2 Antworten Letzte Antwort
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @tobi83 Mal „y“ und „z“ getauscht?
                                    Also:
                                    raspberrz
                                      Also:
                                      raspberrz
                                      @wendy2702
                                      OMG 👏
                                        @tobi83
                                        raspberrz
                                        mal probiert?
                                        Davon abgesehen nutzt man weder den User pi noch das Standardpasswort auf einem gescheit eingerichteten System.
                                          @tobi83
                                          raspberrz
                                          mal probiert?
                                          @wendy2702
                                          Ergebnis
