  4. [gelöst]HILFEEEEEEEE : Toubles after VM restart
    1.6k
instanzjavasciprtnpmproblem
33 Beiträge 4 Kommentatoren 2.8k Aufrufe 3 Beobachtet
  • H Offline
    homecineplexx
    schrieb am zuletzt editiert von homecineplexx
    Hallo
    Nach einem VM (Proxmox) restart geht keine JavaScript Instanz mehr...warum? weiss ich nicht.
    JavaScript Adapter: v6.1.4
    Js-Controller: 4.0.24
    NodeJs: v16.19.0
    Node: v16.19.0
    NPM:8.19.3
    Folgende Fehlermeldung kommt:
    host.ioBroker
    2023-02-06 19:34:25.806	info	Rebuild for adapter system.adapter.javascript.3 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.ioBroker
    2023-02-06 19:34:25.806	error	instance system.adapter.javascript.3 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: }
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32) {
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:400:19)
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: ^
    host.ioBroker
    2023-02-06 19:34:25.801	error	Caught by controller[0]: throw err;
    host.ioBroker
    2023-02-06 19:34:25.801	error	Caught by controller[0]: node:internal/modules/cjs/loader:408
    host.ioBroker
    2023-02-06 19:34:25.749	info	Rebuild for adapter system.adapter.javascript.2 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    in welchem Verzeichnis sollte ich das tun bzw wie geht man da richtig vor?
    bahnuhrB GlasfaserG 2 Antworten Letzte Antwort
    • H homecineplexx
      Hallo
      NodeJs: v16.19.0
      Node: v16.19.0
      NPM:8.19.3
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      host.ioBroker
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @homecineplexx
      Das hab ich auch. Warum weiß ich aber nicht.
      Aber folgender workflow funktioniert:
      cd /opt/iobroker
      npm install javascript --production
      fertig.
      Danke.
      H 1 Antwort Letzte Antwort
      • bahnuhrB bahnuhr
        @homecineplexx
        cd /opt/iobroker
        fertig.
        homecineplexx
        @bahnuhr said in HILFEEEEEEEE : Toubles after VM restart:
        @homecineplexx
        cd /opt/iobroker
        fertig.
        muss ich da davor den iobroker stoppen?
        • H homecineplexx
          Hallo
          NodeJs: v16.19.0
          Node: v16.19.0
          NPM:8.19.3
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          host.ioBroker
          GlasfaserG Offline
          GlasfaserG Offline
          @homecineplexx sagte in Toubles after VM restart:
          Hast du auch die VM neu gestartet !?
          Zeige mal
          EDIT :
          in
          cd /opt/iobroker
          npm prune
          dann
          iobroker fix
          dann
          VM Neustarten
          • GlasfaserG Glasfaser
            Zeige mal
            EDIT :
            in
            cd /opt/iobroker
            npm prune
            dann
            iobroker fix
            dann
            VM Neustarten
            homecineplexx
            @glasfaser said in HILFEEEEEEEE : Toubles after VM restart:
            Zeige mal
            EDIT :
            in
            cd /opt/iobroker
            npm prune
            dann
            iobroker fix
            dann
            VM Neustarten
            das kommt raus
            chris@ioBroker:/opt/iobroker$ npm prune
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
            npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
            npm ERR!     /home/iobroker/.npm/_logs/2023-02-06T18_50_48_889Z-debug-0.log
            • H homecineplexx
              Zeige mal
              EDIT :
              in
              cd /opt/iobroker
              npm prune
              dann
              iobroker fix
              dann
              VM Neustarten
              das kommt raus
              npm ERR! errno -39
              GlasfaserG Offline
              GlasfaserG Offline
              @homecineplexx sagte in HILFEEEEEEEE : Toubles after VM restart:
              ist angepinnt !!!
                ist angepinnt !!!
                homecineplexx
                ist angepinnt !!!
                was heißt das? was ist zu tun?? mir sagt das nix :-(
                • H homecineplexx
                  ist angepinnt !!!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  @homecineplexx
                  einmal durchführen .
                  dann kannst du erst JS wieder installieren !!!!!
                    @homecineplexx
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @homecineplexx
                    So danach :
                    cd /opt/iobroker
                    sudo -H -u iobroker npm install iobroker.js-controller
                    iobroker restart
                      I moved this topic from iobroker general in the English section here.
                      Please let me know if tgere has been reasons for the other choice.
                      GlasfaserG H 2 Antworten Letzte Antwort
                        @homecineplexx
                        So danach :
                        cd /opt/iobroker
                        iobroker restart
                        homecineplexx
                        @homecineplexx
                        So danach :
                        cd /opt/iobroker
                        iobroker restart
                        hab ich gemacht, aber es geht weiter .....
                        host.ioBroker
                        2023-02-06 20:00:44.818	info	system.adapter.javascript.2 will be rebuilt
                        host.ioBroker
                        2023-02-06 20:00:44.818	info	Adapter system.adapter.javascript.2 needs rebuild and will be restarted afterwards.
                        host.ioBroker
                        2023-02-06 20:00:44.818	error	instance system.adapter.javascript.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                        host.ioBroker
                        2023-02-06 20:00:44.817	error	Caught by controller[1]: }
                        host.ioBroker
                        2023-02-06 20:00:44.817	error	Caught by controller[1]: ]
                        host.ioBroker
                        2023-02-06 20:00:44.817	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                        host.ioBroker
                        2023-02-06 20:00:44.817	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js',
                        host.ioBroker
                        2023-02-06 20:00:44.817	error	Caught by controller[1]: requireStack: [
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: code: 'MODULE_NOT_FOUND',
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: {
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: at node:internal/main/run_main_module:22:47
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                        host.ioBroker
                        2023-02-06 20:00:44.816	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                        host.ioBroker
                        2023-02-06 20:00:44.815	error	Caught by controller[1]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                        host.ioBroker
                        2023-02-06 20:00:44.815	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                        host.ioBroker
                        2023-02-06 20:00:44.815	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:22:24)
                        host.ioBroker
                        2023-02-06 20:00:44.815	error	Caught by controller[1]: at require (node:internal/modules/cjs/helpers:103:18)
                        host.ioBroker
                        2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                        host.ioBroker
                        2023-02-06 20:00:44.814	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                        host.ioBroker
                        2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                        host.ioBroker
                        2023-02-06 20:00:44.814	error	Caught by controller[1]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                        host.ioBroker
                        2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js:3:18)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: at require (node:internal/modules/cjs/helpers:103:18)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                        host.ioBroker
                        2023-02-06 20:00:44.813	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                        host.ioBroker
                        2023-02-06 20:00:44.812	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js
                        host.ioBroker
                        2023-02-06 20:00:44.812	error	Caught by controller[1]: Require stack:
                        host.ioBroker
                        2023-02-06 20:00:44.812	error	Caught by controller[1]: Error: Cannot find module './compiler'
                        host.ioBroker
                        2023-02-06 20:00:44.812	error	Caught by controller[1]: ^
                        host.ioBroker
                        2023-02-06 20:00:44.812	error	Caught by controller[1]: throw err;
                        host.ioBroker
                        2023-02-06 20:00:44.811	error	Caught by controller[1]: node:internal/modules/cjs/loader:998
                        • H homecineplexx
                          @homecineplexx
                          So danach :
                          cd /opt/iobroker
                          iobroker restart
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          host.ioBroker
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @homecineplexx
                          Dann
                          cd /opt/iobroker/node_modules/iobroker.javascript
                          npm install --omit=dev
                          sudu reboot
                            @homecineplexx
                            Dann
                            sudu reboot
                            homecineplexx
                            @homecineplexx
                            Dann
                            sudu reboot
                            hab ich durchgeführt:
                            chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev
                            > iobroker.javascript@6.1.4 postinstall
                            > node ./install/installTypings.js
                            Installing NodeJS typings...
                            latest @types: 18, installed node: 16
                            up to date, audited 199 packages in 39s
                            28 packages are looking for funding
                              run `npm fund` for details
                            1 high severity vulnerability
                            To address all issues, run:
                              npm audit fix
                            Run `npm audit` for details.
                            chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ sudo reboot
                            aber leider ohne erfolg.
                            meine JavaScript Instanzen sind rot und :
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	instance system.adapter.javascript.3 terminated with code 1 (JS_CONTROLLER_STOPPED)
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: }
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: ]
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/lib/request.js',
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js',
                            host.ioBroker
                            2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js',
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: requireStack: [
                            host.ioBroker
                            2023-02-06 20:14:59.230	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: {
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: at node:internal/main/run_main_module:22:47
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.229	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.227	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:23:11)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js:5:16)
                            host.ioBroker
                            2023-02-06 20:14:59.224	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.223	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js:1:11)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js:3:21)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.221	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.220	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.220	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js:3:15)
                            host.ioBroker
                            2023-02-06 20:14:59.220	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                            host.ioBroker
                            2023-02-06 20:14:59.219	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js:5:12)
                            host.ioBroker
                            2023-02-06 20:14:59.218	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                            host.ioBroker
                            2023-02-06 20:14:59.218	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                            host.ioBroker
                            2023-02-06 20:14:59.218	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                            host.ioBroker
                            2023-02-06 20:14:59.218	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                            host.ioBroker
                            2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                            host.ioBroker
                            2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/lib/request.js
                            host.ioBroker
                            2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js
                            host.ioBroker
                            2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js
                            host.ioBroker
                            2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js
                            host.ioBroker
                            2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js
                            host.ioBroker
                            2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js
                            host.ioBroker
                            2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js
                            host.ioBroker
                            2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js
                            host.ioBroker
                            2023-02-06 20:14:59.216	error	Caught by controller[0]: Require stack:
                            host.ioBroker
                            2023-02-06 20:14:59.215	error	Caught by controller[0]: Error: Cannot find module './util'
                            host.ioBroker
                            2023-02-06 20:14:59.215	error	Caught by controller[0]: ^
                            host.ioBroker
                            2023-02-06 20:14:59.215	error	Caught by controller[0]: throw err;
                            host.ioBroker
                            2023-02-06 20:14:59.215	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
                            host.ioBroker
                            2023-02-06 20:14:59.214	info	system.adapter.javascript.1 will be rebuilt
                            host.ioBroker
                            2023-02-06 20:14:59.213	info	Adapter system.adapter.javascript.1 needs rebuild and will be restarted afterwards.
                            • H homecineplexx
                              @homecineplexx
                              Dann
                              sudu reboot
                                npm audit fix
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              host.ioBroker
                              GlasfaserG Offline
                              GlasfaserG Offline
                              mach mal
                              npm install --omit=dev --debug
                              und hier die Ausgabe zeigen !
                                mach mal
                                homecineplexx
                                chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev --debug
                                [sudo] Passwort für chris:
                                up to date, audited 199 packages in 20s
                                  npm audit fix
                                • H homecineplexx
                                    npm audit fix
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  @homecineplexx
                                  Was hast du gemacht ... also von einem VM Neustart kommt das nicht !
                                  Hast du Nodejs oder was anderes installiert !?
                                  Nochmal
                                  zeige
                                  cd /opt/iobroker
                                  npm prune
                                  Sonst noch ... Full Ausgabe zeigen !
                                  iob diag
                                    @homecineplexx
                                    Nochmal
                                    zeige
                                    cd /opt/iobroker
                                    npm prune
                                    iob diag
                                    homecineplexx
                                    @homecineplexx
                                    Nochmal
                                    zeige
                                    cd /opt/iobroker
                                    npm prune
                                    iob diag
                                    mein system ist jetzt ewig gelaufen. heute ist aus irgendeinem grund ein device hängen geblieben aus dem grund dachte ich, gut - restartest mal die VM, schon ewig her - und danach keine chance mehr...mehrmals rebootet, iobroker mehrmals restartet...nix installiert..schon lange nicht
                                    removed 955 packages, and changed 1 package in 35s
                                    131 packages are looking for funding
                                    		     v.2023-01-02
                                    Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                                    Installation: 		kvm
                                    Timezone: 		Europe/Vienna
                                    User-ID: 		1000
                                    X-Server: 		false
                                    Boot Target: 		graphical.target
                                    Pending OS-Updates: 	0
                                    Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                                    			/usr/bin/node 		v16.19.0
                                    			/usr/bin/npm 		8.19.3
                                    			/usr/bin/npx 		8.19.3
                                    ioBroker Core: 		js-controller 		4.0.24
                                    			admin 			6.3.5
                                    ioBroker Status: 	iobroker is running on this host.
                                    Objects type: jsonl
                                    States  type: redis
                                    Status admin:
                                    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    Pending iob updates: 	0
                                    Active repo(s): stable
                                    Objects: 		39643
                                    States: 		33762
                                    Size of iob-Database:
                                    29M	/opt/iobroker/iobroker-data/objects.jsonl
                                    15M	/opt/iobroker/iobroker-data/objects.json.migrated
                                    15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                                    81M	/opt/iobroker/iobroker-data/states.jsonl
                                    2.5M	/opt/iobroker/iobroker-data/states.json.migrated
                                    2.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                                    • H homecineplexx
                                      @homecineplexx
                                      Nochmal
                                      zeige
                                      cd /opt/iobroker
                                      npm prune
                                      iob diag
                                      		     v.2023-01-02
                                      Installation: 		kvm
                                      User-ID: 		1000
                                      X-Server: 		false
                                      			/usr/bin/npm 		8.19.3
                                      			/usr/bin/npx 		8.19.3
                                      			admin 			6.3.5
                                      Objects type: jsonl
                                      States  type: redis
                                      Status admin:
                                      Objects: 		39643
                                      States: 		33762
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @homecineplexx
                                      das ist nicht die Full Ausgabe von iob diag .
                                      Deinstalliere den javascript Adapter inkl. Instanz , dann neu !
                                        @homecineplexx
                                        homecineplexx
                                        @homecineplexx
                                        das ist die ausgabe, die er mir gemacht hat und gesagt hat "copy text starting here"
                                        gibts da mehr das ich kopieren kann?
                                        wenn ich den javascript adapter inkl instanzen lösche, sind dann meine javascript files auch alle weg???
                                        • H homecineplexx
                                          @homecineplexx
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          Die bleiben ... hast du kein Backup dazu eingestellt !?
                                          82.9k
