  4. [gelöst]HILFEEEEEEEE : Toubles after VM restart
    5.5k
instanzjavasciprtnpmproblem
33 Beiträge 4 Kommentatoren 3.1k Aufrufe 3 Beobachtet
  • H homecineplexx
    Hallo
    Nach einem VM (Proxmox) restart geht keine JavaScript Instanz mehr...warum? weiss ich nicht.
    JavaScript Adapter: v6.1.4
    Js-Controller: 4.0.24
    NodeJs: v16.19.0
    Node: v16.19.0
    NPM:8.19.3
    Folgende Fehlermeldung kommt:
    host.ioBroker
    2023-02-06 19:34:25.806	info	Rebuild for adapter system.adapter.javascript.3 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    host.ioBroker
    2023-02-06 19:34:25.806	error	instance system.adapter.javascript.3 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: }
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: requestPath: 'coffeescript'
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
    host.ioBroker
    2023-02-06 19:34:25.805	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32) {
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
    host.ioBroker
    2023-02-06 19:34:25.804	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:981:27)
    host.ioBroker
    2023-02-06 19:34:25.803	error	Caught by controller[0]: at Function.Module._findPath (node:internal/modules/cjs/loader:613:18)
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: at tryPackage (node:internal/modules/cjs/loader:400:19)
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/lib/coffee-script/coffee-script'. Please verify that the package.json has a valid "main" entry
    host.ioBroker
    2023-02-06 19:34:25.802	error	Caught by controller[0]: ^
    host.ioBroker
    2023-02-06 19:34:25.801	error	Caught by controller[0]: throw err;
    host.ioBroker
    2023-02-06 19:34:25.801	error	Caught by controller[0]: node:internal/modules/cjs/loader:408
    host.ioBroker
    2023-02-06 19:34:25.749	info	Rebuild for adapter system.adapter.javascript.2 not successful in 3 tries. Adapter will not be restarted again. Please execute "npm install --production" in adapter directory manually.
    in welchem Verzeichnis sollte ich das tun bzw wie geht man da richtig vor?
    GlasfaserG Offline
    GlasfaserG Offline
    @homecineplexx sagte in Toubles after VM restart:
    Hast du auch die VM neu gestartet !?
    Zeige mal
    EDIT :
    in
    cd /opt/iobroker
    npm prune
    dann
    iobroker fix
    dann
    VM Neustarten
    H 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      Zeige mal
      EDIT :
      in
      cd /opt/iobroker
      npm prune
      dann
      iobroker fix
      dann
      VM Neustarten
      homecineplexx
      @glasfaser said in HILFEEEEEEEE : Toubles after VM restart:
      Zeige mal
      EDIT :
      in
      cd /opt/iobroker
      npm prune
      dann
      iobroker fix
      dann
      VM Neustarten
      das kommt raus
      chris@ioBroker:/opt/iobroker$ npm prune
      npm ERR! code ENOTEMPTY
      npm ERR! syscall rename
      npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node
      npm ERR! dest /opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m
      npm ERR! errno -39
      npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/node' -> '/opt/iobroker/node_modules/iobroker.javascript/node_modules/@types/.node-f0Rqzy2m'
      npm ERR!     /home/iobroker/.npm/_logs/2023-02-06T18_50_48_889Z-debug-0.log
      • H homecineplexx
        Zeige mal
        EDIT :
        in
        cd /opt/iobroker
        npm prune
        dann
        iobroker fix
        dann
        VM Neustarten
        das kommt raus
        npm ERR! errno -39
        GlasfaserG Offline
        GlasfaserG Offline
        @homecineplexx sagte in HILFEEEEEEEE : Toubles after VM restart:
        ist angepinnt !!!
          ist angepinnt !!!
          homecineplexx
          ist angepinnt !!!
          was heißt das? was ist zu tun?? mir sagt das nix :-(
          • H homecineplexx
            ist angepinnt !!!
            GlasfaserG Offline
            GlasfaserG Offline
            @homecineplexx
            einmal durchführen .
            dann kannst du erst JS wieder installieren !!!!!
              @homecineplexx
              GlasfaserG Offline
              GlasfaserG Offline
              @homecineplexx
              So danach :
              cd /opt/iobroker
              sudo -H -u iobroker npm install iobroker.js-controller
              iobroker restart
                I moved this topic from iobroker general in the English section here.
                Please let me know if tgere has been reasons for the other choice.
                GlasfaserG H 2 Antworten Letzte Antwort
                  @homecineplexx
                  So danach :
                  cd /opt/iobroker
                  iobroker restart
                  homecineplexx
                  @homecineplexx
                  So danach :
                  cd /opt/iobroker
                  iobroker restart
                  hab ich gemacht, aber es geht weiter .....
                  host.ioBroker
                  2023-02-06 20:00:44.818	info	system.adapter.javascript.2 will be rebuilt
                  host.ioBroker
                  2023-02-06 20:00:44.818	info	Adapter system.adapter.javascript.2 needs rebuild and will be restarted afterwards.
                  host.ioBroker
                  2023-02-06 20:00:44.818	error	instance system.adapter.javascript.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
                  host.ioBroker
                  2023-02-06 20:00:44.817	error	Caught by controller[1]: }
                  host.ioBroker
                  2023-02-06 20:00:44.817	error	Caught by controller[1]: ]
                  host.ioBroker
                  2023-02-06 20:00:44.817	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                  host.ioBroker
                  2023-02-06 20:00:44.817	error	Caught by controller[1]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js',
                  host.ioBroker
                  2023-02-06 20:00:44.817	error	Caught by controller[1]: requireStack: [
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: code: 'MODULE_NOT_FOUND',
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: {
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: at node:internal/main/run_main_module:22:47
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                  host.ioBroker
                  2023-02-06 20:00:44.816	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                  host.ioBroker
                  2023-02-06 20:00:44.815	error	Caught by controller[1]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                  host.ioBroker
                  2023-02-06 20:00:44.815	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                  host.ioBroker
                  2023-02-06 20:00:44.815	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:22:24)
                  host.ioBroker
                  2023-02-06 20:00:44.815	error	Caught by controller[1]: at require (node:internal/modules/cjs/helpers:103:18)
                  host.ioBroker
                  2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                  host.ioBroker
                  2023-02-06 20:00:44.814	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                  host.ioBroker
                  2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                  host.ioBroker
                  2023-02-06 20:00:44.814	error	Caught by controller[1]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                  host.ioBroker
                  2023-02-06 20:00:44.814	error	Caught by controller[1]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js:3:18)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: at require (node:internal/modules/cjs/helpers:103:18)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                  host.ioBroker
                  2023-02-06 20:00:44.813	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                  host.ioBroker
                  2023-02-06 20:00:44.812	error	Caught by controller[1]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/virtual-tsc/build/index.js
                  host.ioBroker
                  2023-02-06 20:00:44.812	error	Caught by controller[1]: Require stack:
                  host.ioBroker
                  2023-02-06 20:00:44.812	error	Caught by controller[1]: Error: Cannot find module './compiler'
                  host.ioBroker
                  2023-02-06 20:00:44.812	error	Caught by controller[1]: ^
                  host.ioBroker
                  2023-02-06 20:00:44.812	error	Caught by controller[1]: throw err;
                  host.ioBroker
                  2023-02-06 20:00:44.811	error	Caught by controller[1]: node:internal/modules/cjs/loader:998
                  • H homecineplexx
                    @homecineplexx
                    So danach :
                    cd /opt/iobroker
                    iobroker restart
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    host.ioBroker
                    GlasfaserG Offline
                    GlasfaserG Offline
                    @homecineplexx
                    Dann
                    cd /opt/iobroker/node_modules/iobroker.javascript
                    npm install --omit=dev
                    sudu reboot
                      @homecineplexx
                      Dann
                      sudu reboot
                      homecineplexx
                      @homecineplexx
                      Dann
                      sudu reboot
                      hab ich durchgeführt:
                      chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev
                      > iobroker.javascript@6.1.4 postinstall
                      > node ./install/installTypings.js
                      Installing NodeJS typings...
                      latest @types: 18, installed node: 16
                      up to date, audited 199 packages in 39s
                      28 packages are looking for funding
                        run `npm fund` for details
                      1 high severity vulnerability
                      To address all issues, run:
                        npm audit fix
                      Run `npm audit` for details.
                      chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ sudo reboot
                      aber leider ohne erfolg.
                      meine JavaScript Instanzen sind rot und :
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	instance system.adapter.javascript.3 terminated with code 1 (JS_CONTROLLER_STOPPED)
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: }
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: ]
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/main.js'
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/lib/request.js',
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js',
                      host.ioBroker
                      2023-02-06 20:14:59.231	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js',
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: requireStack: [
                      host.ioBroker
                      2023-02-06 20:14:59.230	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: {
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: at node:internal/main/run_main_module:22:47
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.229	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:44:23)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.228	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/lib/request.js:5:18)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.227	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js:143:19)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.226	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:23:11)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.225	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js:5:16)
                      host.ioBroker
                      2023-02-06 20:14:59.224	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.223	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js:1:11)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.222	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js:3:21)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.221	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.220	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.220	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js:3:15)
                      host.ioBroker
                      2023-02-06 20:14:59.220	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1043:32)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1165:14)
                      host.ioBroker
                      2023-02-06 20:14:59.219	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js:5:12)
                      host.ioBroker
                      2023-02-06 20:14:59.218	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
                      host.ioBroker
                      2023-02-06 20:14:59.218	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1067:19)
                      host.ioBroker
                      2023-02-06 20:14:59.218	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                      host.ioBroker
                      2023-02-06 20:14:59.218	error	Caught by controller[0]: at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                      host.ioBroker
                      2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/main.js
                      host.ioBroker
                      2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/lib/request.js
                      host.ioBroker
                      2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/index.js
                      host.ioBroker
                      2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js
                      host.ioBroker
                      2023-02-06 20:14:59.217	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/request/lib/har.js
                      host.ioBroker
                      2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/har-validator/lib/promise.js
                      host.ioBroker
                      2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/ajv.js
                      host.ioBroker
                      2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/index.js
                      host.ioBroker
                      2023-02-06 20:14:59.216	error	Caught by controller[0]: - /opt/iobroker/node_modules/iobroker.javascript/node_modules/ajv/lib/compile/resolve.js
                      host.ioBroker
                      2023-02-06 20:14:59.216	error	Caught by controller[0]: Require stack:
                      host.ioBroker
                      2023-02-06 20:14:59.215	error	Caught by controller[0]: Error: Cannot find module './util'
                      host.ioBroker
                      2023-02-06 20:14:59.215	error	Caught by controller[0]: ^
                      host.ioBroker
                      2023-02-06 20:14:59.215	error	Caught by controller[0]: throw err;
                      host.ioBroker
                      2023-02-06 20:14:59.215	error	Caught by controller[0]: node:internal/modules/cjs/loader:998
                      host.ioBroker
                      2023-02-06 20:14:59.214	info	system.adapter.javascript.1 will be rebuilt
                      host.ioBroker
                      2023-02-06 20:14:59.213	info	Adapter system.adapter.javascript.1 needs rebuild and will be restarted afterwards.
                      • H homecineplexx
                        @homecineplexx
                        Dann
                        sudu reboot
                          npm audit fix
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        host.ioBroker
                        GlasfaserG Offline
                        GlasfaserG Offline
                        mach mal
                        npm install --omit=dev --debug
                        und hier die Ausgabe zeigen !
                          mach mal
                          homecineplexx
                          chris@ioBroker:/opt/iobroker/node_modules/iobroker.javascript$ npm install --omit=dev --debug
                          [sudo] Passwort für chris:
                          up to date, audited 199 packages in 20s
                            npm audit fix
                          • H homecineplexx
                              npm audit fix
                            GlasfaserG Offline
                            GlasfaserG Offline
                            @homecineplexx
                            Was hast du gemacht ... also von einem VM Neustart kommt das nicht !
                            Hast du Nodejs oder was anderes installiert !?
                            Nochmal
                            zeige
                            cd /opt/iobroker
                            npm prune
                            Sonst noch ... Full Ausgabe zeigen !
                            iob diag
                              @homecineplexx
                              Nochmal
                              zeige
                              cd /opt/iobroker
                              npm prune
                              iob diag
                              homecineplexx
                              @homecineplexx
                              Nochmal
                              zeige
                              cd /opt/iobroker
                              npm prune
                              iob diag
                              mein system ist jetzt ewig gelaufen. heute ist aus irgendeinem grund ein device hängen geblieben aus dem grund dachte ich, gut - restartest mal die VM, schon ewig her - und danach keine chance mehr...mehrmals rebootet, iobroker mehrmals restartet...nix installiert..schon lange nicht
                              removed 955 packages, and changed 1 package in 35s
                              131 packages are looking for funding
                              		     v.2023-01-02
                              Operatingsystem: 	Debian GNU/Linux 11 (bullseye)
                              Installation: 		kvm
                              Timezone: 		Europe/Vienna
                              User-ID: 		1000
                              X-Server: 		false
                              Boot Target: 		graphical.target
                              Pending OS-Updates: 	0
                              Nodejs-Installation: 	/usr/bin/nodejs 	v16.19.0
                              			/usr/bin/node 		v16.19.0
                              			/usr/bin/npm 		8.19.3
                              			/usr/bin/npx 		8.19.3
                              ioBroker Core: 		js-controller 		4.0.24
                              			admin 			6.3.5
                              ioBroker Status: 	iobroker is running on this host.
                              Objects type: jsonl
                              States  type: redis
                              Status admin:
                              + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, compact disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              Pending iob updates: 	0
                              Active repo(s): stable
                              Objects: 		39643
                              States: 		33762
                              Size of iob-Database:
                              29M	/opt/iobroker/iobroker-data/objects.jsonl
                              15M	/opt/iobroker/iobroker-data/objects.json.migrated
                              15M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                              81M	/opt/iobroker/iobroker-data/states.jsonl
                              2.5M	/opt/iobroker/iobroker-data/states.json.migrated
                              2.5M	/opt/iobroker/iobroker-data/states.json.bak.migrated
                              • H homecineplexx
                                @homecineplexx
                                Nochmal
                                zeige
                                cd /opt/iobroker
                                npm prune
                                iob diag
                                		     v.2023-01-02
                                Installation: 		kvm
                                User-ID: 		1000
                                X-Server: 		false
                                			/usr/bin/npm 		8.19.3
                                			/usr/bin/npx 		8.19.3
                                			admin 			6.3.5
                                Objects type: jsonl
                                States  type: redis
                                Status admin:
                                Objects: 		39643
                                States: 		33762
                                GlasfaserG Offline
                                GlasfaserG Offline
                                @homecineplexx
                                das ist nicht die Full Ausgabe von iob diag .
                                Deinstalliere den javascript Adapter inkl. Instanz , dann neu !
                                  @homecineplexx
                                  homecineplexx
                                  @homecineplexx
                                  das ist die ausgabe, die er mir gemacht hat und gesagt hat "copy text starting here"
                                  gibts da mehr das ich kopieren kann?
                                  wenn ich den javascript adapter inkl instanzen lösche, sind dann meine javascript files auch alle weg???
                                  • H homecineplexx
                                    @homecineplexx
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    Die bleiben ... hast du kein Backup dazu eingestellt !?
                                      homecineplexx
                                      nein hab leider kein backup. Noch nicht. Darum hab ich mich noch nicht gekümmert.
                                      Dh auch wenn ich 3 Instanzen habe und die Files den unterschiedlichen Instanzen zugeordnet waren bleiben die. bleibt da auch nach dem deinstallieren und installieren pro file obs aktiv oder inaktiv war?
                                      • H homecineplexx
                                        GlasfaserG Offline
                                        GlasfaserG Offline
                                        Ich will dich jetzt nicht an den Pranger stellen .... aber das ist das A ..und O .
                                          homecineplexx
                                          ja weiß ich....ich könnt ja eh heulen, dass ichs nicht schon gemacht habe
