  4. Frage : Migrate MySQL nach Influxdb
151 Beiträge 31 Kommentatoren 36.7k Aufrufe 25 Beobachtet
  • Thomas HerrmannT Thomas Herrmann
    @ullij Erstmal vielen Dank..
    Ich musste das Skript leicht anpassen auf sqlite, hab jetzt aber einen Fehler, der mit der Anpassung selbst eigentlich nichts zu tun hat:
    ### MySQL DB info ###
    #import MySQLdb
    #conn = MySQLdb.connect(host="localhost",  # your host, usually localhost
    #                     user="john",         # your username
    #                     passwd="megajonhy",  # your password
    #                     db="jonhydb")        # name of the data base
    ### PostgreSQL DB info ###
    #import psycopg2
    #import psycopg2.extras
    import sqlite3
    # connection data for PostgreSQL
    #conn = psycopg2.connect("dbname=xxx user=xxx password=xxx host=xxx.xxx.xxx.xxx port =5432")
    conn = sqlite3.connect('/opt/iobroker/iobroker-data/sqlite/sqlite.db')
    # InfluxDB info #
    from influxdb import InfluxDBClient
    #####connection data for InfluxDB#####
    influxClient = InfluxDBClient(host='localhost', port=8086, username='xxxx', password='xxxx!', database='xxxx')
    #influxClient.delete_database(influx_db_name)
    #influxClient.create_database(influx_db_name)
    # dictates how columns will be mapped to key/fields in InfluxDB
    schema = {
        "time_column": "time", # the column that will be used as the time stamp in influx
        "columns_to_fields" : ["ack","q", "from","value"], # columns that will map to fields
        # "columns_to_tags" : ["",...], # columns that will map to tags
        "table_name_to_measurement" : "name", # table name that will be mapped to measurement
    Generates an collection of influxdb points from the given SQL records
    def generate_influx_points(records):
        influx_points = []
        for record in records:
            #tags = {},
            fields = {}
            #for tag_label in schema['columns_to_tags']:
            #   tags[tag_label] = record[tag_label]
            for field_label in schema['columns_to_fields']:
                if field_label == "ack":
                    record[field_label] = bool(record[field_label])
                fields[field_label] = record[field_label]
            influx_points.append({
                "measurement": record[schema['table_name_to_measurement']],
                #"tags": tags,
                "time": record[schema['time_column']],
                "fields": fields
        return influx_points
    # query relational DB for all records
    curr = conn.cursor()
    # curr = conn.cursor(dictionary=True)
    # SQL query for PostgreSQL, syntax for MySQL differs
    # query provide desired columns as a view on the sql server
    # request data from SQL, adjust ...from <view name>
    curr.execute("Select * from xxx;")
    row_count = 0
    # process 1000 records at a time
    while True:
        print("Processing row #" + str(row_count + 1))
        selected_rows = curr.fetchmany(1000)
        influxClient.write_points(generate_influx_points(selected_rows))
        row_count += 1000
        if len(selected_rows) < 1000:
            break
    conn.close()
    Fehler:
    user@UbuntuHomeAutomation2:~$ python3 sql2influx3.py
    Processing row #1
    Traceback (most recent call last):
      File "sql2influx3.py", line 75, in <module>
      File "sql2influx3.py", line 50, in generate_influx_points
    TypeError: tuple indices must be integers or slices, not str
    Vielleicht hat ja jemand ne Lösung.
    U Offline
    U Offline
    UlliJ
    #136
    @thomas-herrmann
    wünsche ein frohes neues Jahr.
    Du meintest sicherlich @JackGruber.
    Ich kann Dir bei dem Skript (leider) nicht helfen.
    Proxmox auf iNuc, lxc für IoB, InfluxDB2, Grafana, u.a. *** Homematic & Homematic IP, Shellies, Zigbee etc
    Thomas HerrmannT 1 Antwort Letzte Antwort
    • U UlliJ
      @thomas-herrmann
      Thomas HerrmannT Offline
      Thomas Herrmann
      #137
      @ullij
      Wünsch dir ebenso ein frohes Neues.
      Es bezieht sich auf das Skript in deinem Post vom 14. Apr. 2020, 20:42: [https://forum.iobroker.net/topic/12482/frage-migrate-mysql-nach-influxdb/26](Link Adresse)
      Aber vielleicht hat ja noch jemand eine Idee, woran es liegen kann.
      U 1 Antwort Letzte Antwort
        @ullij
        U Offline
        U Offline
        UlliJ
        #138
        @thomas-herrmann
        Hallo Thomas,
        ich versuche es doch mal, allerdings habe ich die Umgebung dafür nicht mehr aktiv...testen ist also nicht ohne weiteres. Und Sqlite habe ich noch nie nicht verwendet.
        Das Python skript habe ich 1:1 aus der genanntenten Quelle übernommen und nur den Input bereitgestellt,
        Du hast in dem Teil des Skriptes wo die Daten geschrieben werden sollen den Feldtyp geändert (Zeile 50). Die Fehlermeldung deutet darauf hin das Du einen String übergibst, aber ein Integer erwartet wird.
        Versuch doch mal das Skript im Original laufen zu lassen und die Inputdaten passend zur Verfügung zu stellen.
        Ulli
        • U UlliJ
          @thomas-herrmann
          Hallo Thomas,
          Ulli
          Thomas Herrmann
          #139
          @ullij Danke, aber das habe ich vorher natürlich schon versucht.
          Die Änderung stammt von @JackGruber [https://forum.iobroker.net/topic/12482/frage-migrate-mysql-nach-influxdb/36]
          • C Offline
            ChrPrk
            schrieb am zuletzt editiert von ChrPrk
            #140
            vielen Dank für das Script und da drumherum hier @JackGruber @UlliJ - ich bin gerade dabei, ca 60mio Datensätze von einer SQL auf eine influx zu migrieren.
            Ich stoße hierbei leider immer wieder mitten in der Übertragung auf folgenden Fehler:
            Total metrics in ts_number: 1
            0_userdata.0.Variablen.Strom.Steckdose_Dachgeschoss(ID: 9, type: float) (1/1)
            Processing row 1 to 1,000 from LIMIT 0 / 100,000 ts_number - 0_userdata.0.Variablen.Strom.Steckdose_Dachgeschoss (1/1)
            InfluxDB error
            float() argument must be a string or a real number, not 'NoneType'
            Kann ich das entweder irgendwie überspringen oder gar besser konvertieren in eine 0 oder etwas in der Art?
            Vielen Dank
            Christoph
              Sputnik24
              schrieb am zuletzt editiert von Sputnik24
              #141
              Falscher Thread, sorry. Bitte löschen.
              • C ChrPrk
                InfluxDB error
                Vielen Dank
                Christoph
                maxx8888
                schrieb am zuletzt editiert von maxx8888
                #142
                @chrprk
                Hatte gerade genau das gleiche Problem. Scheinbar sind da teilweise "nicht" float Werte in mysql DB vorhanden.
                z.b. null
                Habe es recht simple gelöst, indem einfach alle Werte die nicht Float sind auf 0 gesetzt werden.
                Änderung im Script war einfach beim float konvertieren ein "or 0" anfügen:
                            # Daten in richtigen Typ wandeln
                            if field_label == "value":
                                if datatype == 0:  # ts_number
                                    fields["value"] = float(record["value"] or 0)
                                elif datatype == 1:  # ts_string
                                    fields["value"] = str(record["value"])
                                elif datatype == 2:  # ts_bool
                                    fields["value"] = bool(record["value"])
                @JackGruber
                Vielen Dank für das coole Script. Einfach genial!
                • umbmU umbm
                  @jackgruber sagte in Frage : Migrate MySQL nach Influxdb:
                  Hab das script etwas angepasst, damit alle Daten übernommen werden und diese auch auf einem leistungsschwachen Rasperry Pi ausgelesen werden können.
                  Frage:
                  Läuft das Script auch mit influxdb v2.x?
                  Hintergrund:
                  Der externe Zugriff wird ab v2 ja über Token abgesichert.
                  In der database.json sind aber nur username/password für influxdb hinterlegt.
                  bvol
                  #143
                  @umbm influx v2 kann auch noch influx v1 api auth influx v1 auth create
                  • Z Offline
                    Z Offline
                    ZeroQool
                    #144
                    Ich muss 3 Jahre Daten importieren, aber irgendwann bekomme ich folgende Fehlermeldung:
                    InfluxDB error
                    HTTPConnectionPool(host='192.168.178.155', port=8086): Max retries exceeded with url: /write?db=iobroker&rp=autogen (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7fb8267db6d0>: Failed to establish a new connection: [Errno 111] Connection refused'))
                    Die Batchsize habe ich hoch und runter getestet. Der Fehler ist sehr sporadisch, aber kommt defintiv, entweder am Datensatz X oder Y.
                    Hat jemand noch eine Idee. Könnte mir vorstellen, dass es nur eine Server-Einstellung ist, aber ich finde die Stelle nicht. In Google findet man auch kaum etwas. Danke
                    • BananaJoeB Offline
                      BananaJoeB Offline
                      BananaJoe
                      #145
                      Jetzt muss ich auch noch mal was Banales nachfragen:
                      Bei den Datenpunkten ist ja im Moment die Aufzeichnung bei SQL aktiviert.
                      Ich nehme an ich muss erst die Aufzeichnung bei InfluxDB aktivieren damit es die Datenpunkte dort gibt und dann die Daten migrieren?
                      Oder?
                      • BananaJoeB BananaJoe
                        Oder?
                        #146
                        @bananajoe sagte in Frage : Migrate MySQL nach Influxdb:
                        Oder?
                        Moin,
                        ich bin mir mal wieder nicht sicher, ob ich alles korrekt verstehe, aber hilft Dir evtl. diese Lösung weiter?
                        Query SQL-DB und SQL Funktion damit solltest Du dir eigentlich das Bucket und layout in InfluxDb automatisch anlegen.
                        Alles nicht getestet, da ich gerade keine Postgresql oder mariadb zur Hand habe.
                        Bernd
                          BananaJoeB Offline
                          BananaJoe
                          #147
                          Ich meinte das:
                          ? T 2 Antworten Letzte Antwort
                            Ich meinte das:
                            #148
                            @bananajoe
                            ok, habe schon wieder zu kompliziert gedacht.
                            Bernd
                              Ich meinte das:
                              thomassch
                              #149
                              Hallo Zusammen,
                              erst mal vielen Dank an @JackGruber für das Script, es hat mir viel Arbeit erspart.
                              Da ich eine Microsoft SQL Datenbank haben, musste ich das Script etwas umschreiben (sorry @JackGruber ).
                              Falls jemand diese Änderung benötigt, hier ist sie:
                              1. Ihr benötigt Python, ich habe diese Version installiert
                                https://www.python.org/downloads/release/python-3125/
                              2. Die Jason Datei wie folgt ergänzen. Ich habe Sie als migrateMSQL.py umbenannt:
                                Bitte MSQL Login Daten entsprechend anpassen <xxxxx> und auch für die Influx Datenbank die Zugangsdaten anpassen. Hier ist es wichtig das Token zu verwenden das man
                                bei INfluxDB V2 anlegen muss.
                                Bei mir ist InfluxDB ein extra Container im Proxmox und daher musste ich hier auch noch die IP Adresse angeben.
                                "MSQL": {
                                  "server": "localhost",
                                  "user": "iobroker",
                                  "password": "xxxxxxxx",
                                  "database": "iobroker"
                                "MySQL": {
                                  "host": "localhost",
                                  "port": 3306,
                                  "database": "iobroker",
                                  "user": "iobroker",
                                  "password": "iobroker"
                                "InfluxDB": {
                                  "host": "192.168.2.xxx",
                                  "ssl": false,
                                  "port": 8086,
                                  "retention_policy": "autogen",
                                  "user": "admin",
                                  "password": "7TBAUCsxxxxxY2Sde9QAiAYTDo0WzwerJ8BqfOvxxxx19a8jwYzociuB_4RFVGIDAkN7MA==",
                                  "store_ack_boolean": true
                              1. Bitte dann die PYMSSQL Bibliothek installieren, diese wird für den Zugriff auf MSQL benötigt.
                                Ich habe das in der Commandozeile unter einem Windows Betriebsystem gemacht, in dieser Reihenfolge:
                              pip install -r requirements.txt
                              pip install pymssql
                              1. Achtet darauf, dass Ihr im IOBroker die InfluxDB Schnittstelle zusätzlich zu euren SQL Interface installiert und ich musste leider für alle Datenpunkte die InfluxDB Protokollierung einzeln aktivieren und ein
                                stellen. Da die InfluxDB Schnittstelle keine individuelle Löschung pro Datenpunkte erlaubt, habe ich 2 InfluxDB Instanzen installiert mit unterschiedlichen Löschzeiten (eigentlich eine für unbegrenzt und eine für 1 Jahr).
                                Hier werde ich noch schauen was InfluxDB kann, soweit ich weiß sollte man das in Influx direkt programmieren und damit entsprechende Daten verdichten bzw. löschen.
                              2. Und nun das Phyton Script ausführen, hier gibt es ein paar Anpassungen wegen MSQL z.B. "import pymssql", wie Ihr unten im geänderten SourceCode seht.
                                Ich habe bewusst darauf verzichtet meine Änderungen "schön zu machen", da ich es nur einmalig brauche, aber wichtig für mich war, es funktioniert.
                                Die Ausführung kann sehr sehr lange dauern, daher habt Geduld. Damit Ihr die Scriptausgaben auch seht, nicht einfach auf migrateMSQL.py klicken, sonst geht das Command Fenster sofort wieder zu.
                                Öffnet am Besten ein CMD, wechselt in der Verzeichnis wo Ihr requirements.txt und migrateMSQL.py abgelegt habt und gebt dann folgende Zeile ein.
                              python migrateMSQL.py ALL
                              Und hier nun der Inhalt von migrateMSQL.py:
                              import json
                              import os
                              import sys
                              import time
                              import pymssql
                              try:
                                  import pymssql
                              except Exception as ex:
                                  print(ex)
                                  print("Please install all requirements!")
                                  sys.exit(1)
                              if not sys.version_info >= (3, 6):
                                  print("Python version to old!")
                                  print(sys.version)
                                  sys.exit(1)
                              # Load DB Settings
                              database_file = os.path.join(os.path.dirname(
                                  os.path.realpath(__file__)), "database.json")
                              if not os.path.exists(database_file):
                                  print("Please rename database.json.example to database.json")
                                  sys.exit(1)
                              f = open(database_file, 'r')
                              db = f.read()
                              f.close()
                              try:
                                  db = json.loads(db)
                              except json.decoder.JSONDecodeError as ex:
                                  print(database_file + "Json is not valid!")
                                  print(ex)
                                  sys.exit(1)
                                  print("Unhandeld Exception")
                                  print(ex)
                                  sys.exit(1)
                              try:
                                  print("SQL CONNECT: server="+db['MSQL']['server'])
                                  MSSQL_CONNECTION = pymssql.connect(server=db['MSQL']['server'],
        user=db['MSQL']['user'],
        password=db['MSQL']['password'],
        database=db['MSQL']['database'],
                              					as_dict=True)
                              #    MYSQL_CONNECTION = pymysql.connect(host=db['MySQL']['host'],
                              #                                       port=db['MySQL']['port'],
                              #                                       user=db['MySQL']['user'],
                              #                                       password=db['MySQL']['password'],
                              #                                       db=db['MySQL']['database'])
                              except pymssql.OperationalError as error:
                                  print(error)
                                  sys.exit(1)
                                  print("MSSQL connection error")
                                  print(ex)
                                  sys.exit(1)
                              INFLUXDB_CONNECTION = InfluxDBClient(host=db['InfluxDB']['host'],
        ssl=db['InfluxDB']['ssl'],
        verify_ssl=True,
        port=db['InfluxDB']['port'],
        username=db['InfluxDB']['user'],
        password=db['InfluxDB']['password'],
        database=db['InfluxDB']['database'])
                              # Select datapoints
                              if len(sys.argv) > 1 and sys.argv[1].upper().strip() == "ALL":
                                  MIGRATE_DATAPOINT = ""
                                  print("Migrate ALL datapoints ...")
                              elif len(sys.argv) == 2:
                                  MIGRATE_DATAPOINT = " AND name LIKE '" + sys.argv[1] + "' "
                                  print("Migrate '" + sys.argv[1] + "' datapoint(s) ...")
                              else:
                                  print("To migrate all datapoints run '" + sys.argv[0] + " ALL'")
                                  print("To migrate one datapoints run '" + sys.argv[0] + " <DATAPONTNAME>'")
                                  print("To migrate a set of datapoints run '" +
                                        sys.argv[0] + ' "hm-rega.0.%"' + "'")
                                  sys.exit(1)
                              print("")
                              SCHEMA = {
                                  "columns_to_fields": ["ack", "q", "from", "value"],
                                  "table_name_to_measurement": "name",
                              DATATYPES = ["float", "string", "boolean"]
                              # Generates an collection of influxdb points from the given SQL records
                              def generate_influx_points(datatype, records):
                                  influx_points = []
                                      #tags = {},
                                      fields = {}
                                      # for tag_label in SCHEMA['columns_to_tags']:
                                      for field_label in SCHEMA['columns_to_fields']:
                                          if db['InfluxDB']['store_ack_boolean'] == True:
                                                  if (record[field_label] == 1 or record[field_label] == "True" or record[field_label] == True):
                                                      record[field_label] = True
                                                  else:
                                                      record[field_label] = False
                                          "measurement": record[SCHEMA['table_name_to_measurement']],
                                          # "tags": tags,
                                          "time": record[SCHEMA['time_column']],
                                          "fields": fields
                              def query_metrics(table):
                                  MSSQL_CURSOR.execute(
                                      "SELECT name, id, type FROM datapoints WHERE id IN(SELECT DISTINCT id FROM " + table + ")" + MIGRATE_DATAPOINT)
                                  rows = MSSQL_CURSOR.fetchall()
                                  print('Total metrics in ' + table + ": " + str(MSSQL_CURSOR.rowcount))
                                  return rows
                              def migrate_datapoints(table):
                                  query_max_rows = 100000  # prevent run out of mermory limit on SQL DB
                                  process_max_rows = 1000
                                  migrated_datapoints = 0
                                  metrics = query_metrics(table)
                                  metric_nr = 0
                                  metric_count = str(len(metrics))
                                  processed_rows = 0
                                  for metric in metrics:
                                      metric_nr += 1
                                      print(metric['name'] + "(ID: " + str(metric['id']) + ", type: " + DATATYPES[metric['type']] + ")" +
                                            " (" + str(metric_nr) + "/" + str(metric_count) + ")")
                                      start_row = 0
                                      processed_rows = 0
                                      while True:
                                          query = """SELECT d.name,
                                              m.ack AS ack,
                                              CAST(m.q AS FLOAT) AS q,
                                              s.name AS [from],
                                              m.val AS value,
                                              CAST(m.ts * 1000000 AS BIGINT) AS time
                                              FROM [dbo].[""" + table + """] AS m
                                              LEFT JOIN [dbo].[datapoints] AS d ON m.id = d.id
                                              LEFT JOIN [dbo].[sources] AS s ON m._from = s.id
                                              WHERE m.q = 0 AND d.id = """ + str(metric['id']) + """
                                              ORDER BY m.ts DESC
                                              OFFSET """ + str(start_row) + """ ROWS
                                              FETCH NEXT """ + str(query_max_rows) + """ ROWS ONLY; """
                              #### alte query für MySQL
                              #            query = """SELECT d.name,
                              #                                m.ack AS 'ack',
                              #                                (m.q*1.0) AS 'q',
                              #                                s.name AS "from",
                              #                                m.val AS 'value',
                              #                                (m.ts*1000000) AS'time'
                              #                                FROM """ + table + """ AS m
                              #                                LEFT JOIN datapoints AS d ON m.id=d.id
                              #                                LEFT JOIN sources AS s ON m._from=s.id
                              #                                WHERE q=0 AND d.id = """ + str(metric['id']) + """
                              #                                ORDER BY m.ts desc
                              #                                LIMIT """ + str(start_row) + """, """ + str(query_max_rows)
                                          MSSQL_CURSOR.execute(query)
                                          if MSSQL_CURSOR.rowcount == 0:
                                              break
                                          # process x records at a time
                                          while True:
                                              selected_rows = MSSQL_CURSOR.fetchmany(process_max_rows)
                                              if len(selected_rows) == 0:
                                                  break
                                              print(f"Processing row {processed_rows + 1:,} to {processed_rows + len(selected_rows):,} from LIMIT {start_row:,} / {start_row + query_max_rows:,} " +
                                                    table + " - " + metric['name'] + " (" + str(metric_nr) + "/" + str(metric_count) + ")")
                                              migrated_datapoints += len(selected_rows)
                                              try:
                                                  INFLUXDB_CONNECTION.write_points(generate_influx_points(metric['type'],
                                                      selected_rows), retention_policy=db['InfluxDB']['retention_policy'])
                                                  print("InfluxDB error")
                                                  print(ex)
                                                  sys.exit(1)
                                              processed_rows += len(selected_rows)
                                          start_row += query_max_rows
                                      print("")
                                  return migrated_datapoints
                              #MSSQL_CURSOR = MSSQL_CONNECTION.cursor(cursor=pymssql.cursors.DictCursor)
                              MSSQL_CURSOR = MSSQL_CONNECTION.cursor()
                              migrated = 0
                              migrated += migrate_datapoints("ts_number")
                              migrated += migrate_datapoints("ts_bool")
                              migrated += migrate_datapoints("ts_string")
                              print(f"Migrated: {migrated:,}")
                              MSSQL_CONNECTION.close()
                              1. Ausgeführt
                              Final habe ich damit 45,770,061 Datensätzen auf einmal migrieren können und stichprobenartig mal über die Weboberfläche von INfluxDB geprüft ob soweit alles passt, noch ist mir kein Fehler aufgefallen.
                              Ich hoffe diese Anleitung hilft denen weiter die statt mySQL ein MSSQL verwenden.
                              Danke nochmals an @JackGruber für die tolle Arbeit.
                              Gruss
                              Thomas
                              ******* iobroker auf Intel PC, Raspberry PI4 + Homematic CCU *******
                                Micha70
                                #150
                                Ich versuche das Script von @JackGruber zu benutzen um meine Daten aus der Homeassistant MariaDB nach Influx zu transferieren. Bekomme aber leider folgenden Fehler:
                                (.venv) pi@raspberrypi:~/migrate2influxdb_JackGruber $ python migrate.py ALL
                                (1698, "Access denied for user 'homeassistant'@'localhost'")
                                Der User homeassistant hat aber meiner Meinung nach die richtigen Rechte:
                                Anbei auch die Konfiguration von database.json:
                                  "MySQL": {
                                    "port": 3306,
                                    "database": "homeassistant",
                                    "user": "homeassistant",
                                    "password": "XXXXXX"
                                  "InfluxDB": {
                                    "ssl": false,
                                    "port": 8086,
                                    "database": "Test_temp",
                                    "user": "Micha",
                                    "password": "XXXXXX",
                                Hat jemand eine Idee und kann mir helfen? Vielen Dank schonmal ....
                                • M Micha70
                                    "MySQL": {
                                      "port": 3306,
                                    "InfluxDB": {
                                      "ssl": false,
                                      "port": 8086,
                                      "user": "Micha",
                                  BananaJoeB Offline
                                  BananaJoeB Offline
                                  BananaJoe
                                  #151
                                  @micha70 pffft % könnte sein das das für alle Hosts steht ...
                                  was passiert denn wenn du
                                  mysql -uhomeassistent -pdeinpasswort homeassistent
                                  eingibst? kannst du dich verbinden oder nicht? Wenn nicht passen die rechte eben nicht.
                                  Benutzertyp "datenbankspezifisch" macht mich nachdenklich.
                                  Was hats du denn im SQL-Adapater von ioBroker eingetragen als Benutzer?
