  4. Growatt exception: Error: {"result":3}
    5.4k
81 Beiträge 3 Kommentatoren 10.2k Aufrufe 3 Beobachtet
  • N nobbiman
    growatt.0
    	2023-01-31 12:09:05.347	error	Growatt exception: Error: {"result":3}
    growatt.0
    	2023-01-31 12:09:04.051	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
    growatt.0
    	2023-01-31 12:09:00.030	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    growatt.0
    	2023-01-31 12:09:00.027	info	terminating
    growatt.0
    	2023-01-31 12:09:00.016	info	Scheduled restart.
    Oh, hatte ich übersehen. Die Version 4.0.24 müsste aber nun die aktuelle sein!?
    @nobbiman
    iob diag
    • N Offline
      N Offline
      nobbiman
      schrieb am zuletzt editiert von nobbiman
                           v.2023-01-02
      Operatingsystem:        Raspbian GNU/Linux 10 (buster)
      Installation:           Native
      Timezone:               Europe/Berlin
      User-ID:                1000
      X-Server:               true
      Boot Target:            multi-user.target
      Pending OS-Updates:     0
      Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                              /usr/bin/node           v16.19.0
                              /usr/bin/npm            8.19.3
                              /usr/bin/npx            8.19.3
      ioBroker Core:          js-controller           4.0.24
                              admin                   6.3.5
      Objects type: jsonl
      States  type: jsonl
      Status admin:
      + system.adapter.admin.0                  : admin                 : iobroker-pi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      Pending iob updates:    0
      Active repo(s): stable
      Objects:                9126
      States:                 7780
      Size of iob-Database:
      13M     /opt/iobroker/iobroker-data/objects.jsonl
      2.8M    /opt/iobroker/iobroker-data/objects.json.migrated
      2.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
      3.0M    /opt/iobroker/iobroker-data/states.jsonl
      28K     /opt/iobroker/iobroker-data/states.json.migrated
      28K     /opt/iobroker/iobroker-data/states.json.bak.migrated
      • N nobbiman
                             v.2023-01-02
        User-ID:                1000
        X-Server:               true
                                /usr/bin/npm            8.19.3
                                /usr/bin/npx            8.19.3
                                admin                   6.3.5
        Objects type: jsonl
        States  type: jsonl
        Status admin:
        Objects:                9126
        States:                 7780
        @nobbiman sagte in Growatt exception: Error: {"result":3}:
        Buster ist im September 2022 verstorben.
        Installier da den Nachfolger 'Bullseye' / Debian 11.
        N 1 Antwort Letzte Antwort
          N Offline
          N Offline
          nobbiman
          Komme leider nicht weiter. Ich habe das Upgrade nach der Anleitung https://schroederdennis.de/tutorial-howto/debian-10-buster-auf-debian-11-bullseye-linux-updaten-anleitung/) gemacht, das neue os will sich aber nicht einstellen.
          Meine Datei sources.list sieht so aus:
          #deb http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
          # Uncomment line below then 'apt-get update' to enable 'apt-get source'
          #deb-src http://raspbian.raspberrypi.org/raspbian/ buster main contrib non-free rpi
          deb http://deb.debian.org/debian/ bullseye main contrib non-free
          deb-src http://deb.debian.org/debian/ bullseye-updates main contrib non-free
          deb http://security.debian.org/debian-security bullseye-security main
          deb-src http://security.debian.org/debian-security bullseye-security main
          deb http://ftp.debian.org/debian bullseye-backports main contrib non-free
          Auch nach einem
          reboot
          erscheint nach
          apt update
          apt full-upgrade
          cat /etc/os-release
          die Buster-Version 10
          • N nobbiman
            Auch nach einem
            reboot
            erscheint nach
            apt update
            apt full-upgrade
            cat /etc/os-release
            @nobbiman
            Ich weiß ja nicht was der Schröder Dennis da treibt, ich mache es immer so:
            https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
              @nobbiman
              N Offline
              N Offline
              nobbiman
              Als Einsteiger bin ich doch hiermit ziemlich gefordert. Deinem Tipp bin ich gerne gefolgt, hänge aber leider fest:
              pi@iobroker-pi:~ $ sudo apt update
              Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:2 http://deb.debian.org/debian bullseye InRelease
              Hit:3 http://ftp.debian.org/debian bullseye-backports InRelease
              Hit:4 http://archive.raspberrypi.org/debian buster InRelease
              Hit:5 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:6 https://deb.nodesource.com/node_16.x buster InRelease
              Hit:7 https://www.debmatic.de/debmatic stable InRelease
              Reading package lists... Done
              Building dependency tree
              323 packages can be upgraded. Run 'apt list --upgradable' to see them.
              Also zunächst ein
              pi@iobroker-pi:~ $ sudo apt full-upgrade
              E: Could not get lock /var/lib/dpkg/lock-frontend - open (11: Resource temporarily unavailable)
              E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), is another process using it?
              ... und da ist Ende! Ich denke ich muss die Pakete zuerst upgraden oder?
              • N nobbiman
                Also zunächst ein
                @nobbiman
                Nein, irgendein anderer Prozess greift noch auf die dpkg-Datenbank zu.
                Ist da eine Desktop-Oberfläche mit im Spiel? Deren Benachrichtigungen können z. B. dazu führen. Oder du stehst in einem anderen Terminal noch drauf.
                  @nobbiman
                  N Offline
                  N Offline
                  nobbiman
                  Ja, an deiner Diagnose war was dran. Ich hatte noch ein putty-Fenster geöffnet, da ich ehrlich gesagt mit dem copy&paste beim nano für die Codes nicht hinkomme.
                  Nun ist alles upgedated, bullseye ist installiert, alle Paket sind up to date!
                  Alleine der Fehler ist nicht weg 😖 :
                  growatt.0
                  	2023-01-31 16:06:05.389	error	Growatt exception: Error: {"result":3}
                  growatt.0
                  	2023-01-31 16:06:04.190	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
                  growatt.0
                  	2023-01-31 16:06:00.030	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                  growatt.0
                  	2023-01-31 16:06:00.027	info	terminating
                  growatt.0
                  	2023-01-31 16:06:00.016	info	Scheduled restart.
                  Solltest du weiter helfen wollen, brauchst du noch neue Statusinformationen?
                  Bin aber heute Abend unterwegs!
                  Nachtrag: ich stelle gerade fest, dass bei Aktualisieren der logs, der Zeitstempel 45 Min. hinter meinem PC her hinkt. Aber das dürfte ja keine Relevanz haben, oder?
                  • N nobbiman
                    growatt.0
                    growatt.0
                    growatt.0
                    growatt.0
                    growatt.0
                    wendy2702W Online
                    wendy2702W Online
                    Kannst du jetzt wo alles aktuell ist die Instanz und den Adapter mal komplett loeschen, Server neu starten und dann Adapter wieder installieren.
                    Log von der Installation dann auch hier posten.
                    • wendy2702W wendy2702
                      N Offline
                      N Offline
                      nobbiman
                      @wendy2702
                      So, alles wie beschrieben erledigt:
                      $ iobroker add growatt auto --host iobroker-pi --debug
                      NPM version: 8.19.3
                      Installing iobroker.growatt@2.0.0... (System call)
                      npm WARN deprecated querystring@0.2.0: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
                      88 packages are looking for funding run `npm fund` for details
                      host.iobroker-pi install adapter growatt
                      upload [4] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/glogo.png glogo.png image/png
                      upload [3] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/growatt.png growatt.png image/png
                      upload [2] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/index_m.html index_m.html text/html
                      upload [1] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/style.css style.css text/css
                      upload [0] growatt.admin /opt/iobroker/node_modules/iobroker.growatt/admin/words.js words.js application/javascript
                      host.iobroker-pi object system.adapter.growatt created/updated
                      host.iobroker-pi create instance growatt
                      host.iobroker-pi object system.adapter.growatt.0.alive created
                      host.iobroker-pi object system.adapter.growatt.0.connected created
                      host.iobroker-pi object system.adapter.growatt.0.compactMode created
                      host.iobroker-pi object system.adapter.growatt.0.cpu created
                      host.iobroker-pi object system.adapter.growatt.0.cputime created
                      host.iobroker-pi object system.adapter.growatt.0.memHeapUsed created
                      host.iobroker-pi object system.adapter.growatt.0.memHeapTotal created
                      host.iobroker-pi object system.adapter.growatt.0.memRss created
                      host.iobroker-pi object system.adapter.growatt.0.uptime created
                      host.iobroker-pi object system.adapter.growatt.0.inputCount created
                      host.iobroker-pi object system.adapter.growatt.0.outputCount created
                      host.iobroker-pi object system.adapter.growatt.0.eventLoopLag created
                      host.iobroker-pi object system.adapter.growatt.0.sigKill created
                      host.iobroker-pi object system.adapter.growatt.0.logLevel created
                      host.iobroker-pi object growatt.0.info created
                      host.iobroker-pi object growatt.0.info.connection created
                      host.iobroker-pi Set default value of growatt.0.info.connection: false
                      host.iobroker-pi object system.adapter.growatt.0 created
                      Process exited with code 0
                      Die Warnmeldung sehe ich, weiß aber nicht, wie ich damit umgehen soll?
                      Die installierte npm-Version ist die 8.19.3. Wie installiere ich die 88 Paket nach?
                      Im Log erscheint
                      growatt.0
                      	2023-02-01 13:42:05.660	error	Growatt exception: Error: {"result":3}
                      growatt.0
                      	2023-02-01 13:40:04.972	error	Growatt exception: Error: {"result":3}
                      growatt.0
                      	2023-02-01 13:38:03.714	error	Growatt exception: Error: {"result":3}
                      growatt.0
                      	2023-02-01 13:38:02.753	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
                      growatt.0
                      	2023-02-01 13:37:57.299	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      growatt.0
                      	2023-02-01 13:37:57.297	info	terminating
                      growatt.0
                      	2023-02-01 13:37:57.293	info	Got terminate signal TERMINATE_YOURSELF
                      growatt.0
                      	2023-02-01 13:37:25.968	info	not connected
                      growatt.0
                      	2023-02-01 13:37:25.965	warn	Login:{}
                      Mich irritiert auch immer noch der Zeitunterschied der Fehlermeldungen mit der Systemzeit des RasPi und meinem PC (richtige Zeit), obwohl am RasPi die korrekte Zeitzone eingestellt ist
                      • N nobbiman
                        @wendy2702
                        NPM version: 8.19.3
                        Im Log erscheint
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        Gar nicht.
                        Auch gar nicht. Das sind 88 Pakete, die gerne finanziell unterstützt werden wollen, keine fehlenden Module auf deiner Installation.
                        date && date -u && cat /etc/timezone && timedatectl
                        prüfen.
                          Gar nicht.
                          prüfen.
                          N Offline
                          N Offline
                          nobbiman
                          @thomas-braun said in Growatt exception: Error: {"result":3}:
                          pi@iobroker-pi:~ $ date && date -u && cat /etc/timezone && timedatectl
                          Wed  1 Feb 14:42:09 CET 2023
                          Wed  1 Feb 13:42:09 UTC 2023
                          Europe/Berlin
                                         Local time: Wed 2023-02-01 14:42:09 CET
                                     Universal time: Wed 2023-02-01 13:42:09 UTC
                                           RTC time: n/a
                          System clock synchronized: no
                                        NTP service: n/a
                                    RTC in local TZ: no
                          • N nobbiman
                            Europe/Berlin
                                             RTC time: n/a
                                          NTP service: n/a
                                      RTC in local TZ: no
                            Die ist falsch. Müsste 14:42:09 UTC sein.
                            Das ist auch falsch:
                            NTP service: n/a
                            Schalte den NTP service wieder ein, dann passt auch nach einem Reboot die Zeit.
                              NTP service: n/a
                              N Offline
                              N Offline
                              nobbiman
                              service npt start
                              ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
                              Authentication is required to start 'npt.service'.
                              Authenticating as: ,,, (pi)
                              Password:
                              ==== AUTHENTICATION COMPLETE ===
                              Failed to start npt.service: Unit npt.service not found.
                              Falscher Befehl?
                              • N nobbiman
                                service npt start
                                Password:
                                Falscher Befehl?
                                @nobbiman
                                Falscher Befehl?
                                Gleich mehrfach falsch.
                                Lies hier:
                                https://blog.doenselmann.com/uhrzeit-ueber-systemd-timesyncd-synchronisieren/
                                  @nobbiman
                                  Falscher Befehl?
                                  Lies hier:
                                  N Offline
                                  N Offline
                                  nobbiman
                                  Damit komme ich nicht klar:
                                  pi@iobroker-pi:~ $ sudo nano /etc/systemd/timesyncd.conf
                                  pi@iobroker-pi:~ $ sudo timedatectl set-ntp true
                                  Failed to set ntp: NTP not supported
                                  pi@iobroker-pi:~ $ systemctl status systemd-timesyncd
                                  Unit systemd-timesyncd.service could not be found.
                                  pi@iobroker-pi:~ $
                                  In die Datei timesyncd.conf werden, wenn ich es richtig verstehe, einfach die Zeitserver gem. Beispiel hineinkopiert, oder?
                                  • N nobbiman
                                    pi@iobroker-pi:~ $
                                    @nobbiman
                                    Ja, bei mir ist die allerdings leer.
                                    Warum läuft denn bei dir der Service nicht?
                                    Sollte eigentlich so aussehen:
                                    Last login: Wed Feb  1 15:51:10 2023 from 100.75.198.95
                                    echad@chet:~ $ systemctl status systemd-timesyncd.service
                                    ● systemd-timesyncd.service - Network Time Synchronization
                                         Loaded: loaded (/lib/systemd/system/systemd-timesyncd.ser>     Active: active (running) since Thu 2023-01-26 19:00:34 CE>       Docs: man:systemd-timesyncd.service(8)
                                       Main PID: 362 (systemd-timesyn)
                                         Status: "Initial synchronization to time server [2a03:400>      Tasks: 2 (limit: 9037)
                                            CPU: 1.605s
                                         CGroup: /system.slice/systemd-timesyncd.service
                                                 └─362 /lib/systemd/systemd-timesyncd
                                    Jan 26 19:00:34 chet systemd[1]: Starting Network Time Synchro>Jan 26 19:00:34 chet systemd[1]: Started Network Time Synchron>Jan 26 19:01:19 chet systemd-timesyncd[362]: Initial synchroni>lines 1-14/14 (END)
                                      @nobbiman
                                              CPU: 1.605s
                                      N Offline
                                      N Offline
                                      nobbiman
                                      @thomas-braun Wenn ich das wüsste, muss mich aber für heute aus dem Forum ausklinken - morgen mehr! Danke bis hier hin!
                                      • N nobbiman
                                        pi@iobroker-pi:~ $
                                        @nobbiman
                                        sudo apt update
                                        sagt?
                                        N 2 Antworten Letzte Antwort
                                          @nobbiman
                                          sudo apt update
                                          sagt?
                                          N Offline
                                          N Offline
                                          nobbiman
                                          sudo apt update
                                          Hit:1 http://deb.debian.org/debian bullseye InRelease
                                          Get:2 http://deb.debian.org/debian bullseye-updates InRelease [44.1 kB]
                                          Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
                                          Get:4 http://ftp.debian.org/debian bullseye-backports InRelease [49.0 kB]
                                          Hit:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                                          E: Release file for http://deb.debian.org/debian/dists/bullseye-updates/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied.
                                          E: Release file for http://ftp.debian.org/debian/dists/bullseye-backports/InRelease is not valid yet (invalid for another 2min 50s). Updates for this repository will not be applied.
