  4. Tractive Adapter für Haustiere?
    6.3k
178 Beiträge 17 Kommentatoren 37.7k Aufrufe 15 Beobachtet
  • IssiI Issi
    @flexer, was für eine node Version hast du? der Adapter benötigt eine Node >= 16 Version
    W Online
    W Online
    Wildbill
    #76
    @issi Die Meldungen kommen im Minutentakt :
    2023-01-30 08:54:57.587
    warn
    State "tractive-gps.0.VGXXXKDJ.device_pos_report.course" has no existing object, this might lead to an error in future versions
    tractive-gps.0
    2023-01-30 08:54:57.577
    info
    State value to set for "tractive-gps.0.VGXXXKDJ.device_pos_report.pos_status" has to be type "string" but received type "object"
    tractive-gps.0
    2023-01-30 08:54:57.344
    warn
    State "tractive-gps.0.PBXXXSIX.tracker.hw_edition" has no existing object, this might lead to an error in future versions
    tractive-gps.0
    2023-01-30 08:54:57.181
    warn
    [Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
    tractive-gps.0
    2023-01-30 08:54:56.648
    warn
    [Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
    tractive-gps.0
    2023-01-30 08:53:55.642
    warn
    tractive-gps.0
    2023-01-30 08:53:55.581
    info
    tractive-gps.0
    2023-01-30 08:53:55.359
    warn
    tractive-gps.0
    2023-01-30 08:53:55.260
    warn
    tractive-gps.0
    2023-01-30 08:53:54.743
    warn
    tractive-gps.0
    2023-01-30 08:52:53.650
    warn
    tractive-gps.0
    2023-01-30 08:52:53.586
    info
    tractive-gps.0
    2023-01-30 08:52:53.283
    warn
    tractive-gps.0
    2023-01-30 08:52:53.150
    warn
    tractive-gps.0
    2023-01-30 08:52:52.553
    warn
    tractive-gps.0
    2023-01-30 08:51:51.360
    warn
    tractive-gps.0
    2023-01-30 08:51:51.344
    info
    tractive-gps.0
    2023-01-30 08:51:51.061
    warn
    tractive-gps.0
    2023-01-30 08:51:50.952
    warn
    tractive-gps.0
    2023-01-30 08:51:50.244
    warn
    tractive-gps.0
    2023-01-30 08:50:49.085
    warn
    tractive-gps.0
    2023-01-30 08:50:49.078
    info
    tractive-gps.0
    2023-01-30 08:50:48.875
    warn
    Die angemahnten Datenpunkte existieren auch nicht. Ich setze den Loglevel mal auf error, sonst ist ja ruck zuck das Log voll. 😊
    Was aber ankommt passt und deckt sich mit den Daten aus Homeassistant.
    Gruss, Jürgen
    IssiI 1 Antwort Letzte Antwort
    • W Wildbill
      warn
      tractive-gps.0
      info
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      info
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      info
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      info
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      warn
      tractive-gps.0
      info
      tractive-gps.0
      warn
      Gruss, Jürgen
      IssiI Offline
      IssiI Offline
      Issi
      #77
      @wildbill
      ja, der state hw_edition war bei meinem Test Tracker nicht verfügbar, da es verschied Tracker gibt und da auch verschiedene daten zurückkommen, den werde ich heute noch einbauen.
      Und zu den anderen davon können noch mehr kommen, die muss ich alle nach einender fixen, das ist einfach nur eine Info, dass der state den falschen type hat, da von der API sehr viel mit null zurückkommt und ich nicht weiß was da für ein type eigentlich sein sollte, habe ich einfach ein Standard wert gesetzt, wenn solche Meldungen auftauchen, bitte melden.
      W 1 Antwort Letzte Antwort
      • IssiI Issi
        @wildbill
        W Online
        W Online
        Wildbill
        #78
        @issi Hier melden oder im Github-Issue mit dazu schreiben?
        Gruss, Jürgen
        IssiI 2 Antworten Letzte Antwort
        • W Wildbill
          Gruss, Jürgen
          IssiI Offline
          IssiI Offline
          Issi
          #79
          @wildbill
          GitHub bitte da sehe ich es immer hier im Forum kann, das schnell untergehen
          • W Wildbill
            Gruss, Jürgen
            IssiI Offline
            IssiI Offline
            Issi
            #80
            @wildbill
            kannst du mir bitte den Inhalt von der json per pm schicken? Ich will alle type der state sehen, die bei dir sind.
            • IssiI Issi
              @wildbill
              W Online
              W Online
              Wildbill
              #81
              @issi Meinst Du, wenn ich in iobroker unter Objekten den Baum vom Adapter im Expertenmodus exportiere und als json speichere?
              • W Wildbill
                IssiI Offline
                IssiI Offline
                Issi
                #82
                @wildbill
                W NegaleinN 2 Antworten Letzte Antwort
                • IssiI Issi
                  @wildbill
                  W Online
                  W Online
                  Wildbill
                  #83
                  @issi Hast PM.
                  Gruss, Jürgen
                  • IssiI Issi
                    @wildbill
                    NegaleinN Offline
                    NegaleinN Offline
                    Negalein
                    #84
                    @issi
                    ein paar States inkl. Beschreibung
                    tractive-gps.0.VSVLINVJ.tracker.state --> OPERATIONAL = eingeschaltet
                    tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used --> GPS = unterwegs
                    tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used --> KNOWN_WIFI = Energiesparzone
                    tractive-gps.0.VSVLINVJ.tracker.state_reason --> POWER_SAVING = Energiesparzone
                    tractive-gps.0.VSVLINVJ.tracker.power_saving_zone_id ändert sich nicht.
                    Man kann aber tractive-gps.0.VSVLINVJ.device_pos_report.sensor_used verwenden, um zu sehen, ob Miezi oder Wufti Zuhause sind.
                    ° Fixer ---> iob fix
                    • NegaleinN Negalein
                      @issi
                      IssiI Offline
                      IssiI Offline
                      Issi
                      #85
                      @negalein sagte in Tractive Adapter für Haustiere?:
                      Die sollte ganz weg sein, wen das Tier aus der Energiesparzone raus ist, das hat jedenfalls der Test mit Flexer gezeigt.
                      Interessant ist es, ob sie sich bei einer anderen Energiesparzone ändert.
                      • IssiI Issi
                        NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        #86
                        @issi sagte in Tractive Adapter für Haustiere?:
                        Ok, eventuell war es zu kurz wo er außerhalb der Zone war.
                        Ich logge mal den DP.
                        Werde zusätzlich die SSID vom Nachbarn verwenden. Kann das aber erst morgen machen.
                          IssiI Offline
                          IssiI Offline
                          Issi
                          schrieb am zuletzt editiert von Issi
                          #87
                          @negalein
                          kein Stress bin ohnehin gerade etwas angeschlagen (Corona) und kann nicht so viel daran arbeiten
                          W NegaleinN H 3 Antworten Letzte Antwort
                          • IssiI Issi
                            @negalein
                            W Online
                            W Online
                            Wildbill
                            #88
                            @issi Gute Besserung. 👍
                            • IssiI Issi
                              @negalein
                              NegaleinN Offline
                              NegaleinN Offline
                              Negalein
                              #89
                              @issi
                              Gute Besserung. 👍
                              • IssiI Issi
                                @negalein
                                homecineplexx
                                #90
                                @issi zuerst mal, super und großes danke für deine arbeit....und baldige gute besserung
                                ich hab den adapter ebenfalls gerade zuerst installiert und da kommt einige warnings
                                tractive-gps.0
                                2023-01-30 10:37:45.677	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:37:45.514	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:37:45.471	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:37:45.287	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:37:44.978	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:37:44.906	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:36:44.100	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:36:43.932	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:36:43.903	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:36:43.726	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:36:43.291	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:36:43.223	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:35:42.279	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:35:42.057	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:35:41.996	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:35:41.771	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:35:41.307	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:35:41.257	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:34:40.407	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:34:40.213	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:34:40.171	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:34:39.937	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:34:39.475	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:34:39.397	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:33:38.274	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:33:38.065	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:33:38.021	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:33:37.796	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:33:37.356	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:33:37.309	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:32:36.441	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:32:36.213	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:32:36.178	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:32:36.012	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:32:35.664	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:32:35.590	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:31:34.567	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:31:34.341	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:31:34.290	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:31:33.994	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:31:33.598	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:31:33.533	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                host.ioBroker
                                2023-01-30 10:30:38.559	info	instance system.adapter.yr.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                tractive-gps.0
                                2023-01-30 10:30:32.231	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:30:31.979	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:30:31.923	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:30:31.585	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:30:30.892	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:30:30.745	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                host.ioBroker
                                2023-01-30 10:30:12.519	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.ioBroker
                                2023-01-30 10:30:08.264	info	instance system.adapter.yr.0 started with pid 24261
                                host.ioBroker
                                2023-01-30 10:30:05.708	info	instance system.adapter.meteoalarm.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                host.ioBroker
                                2023-01-30 10:30:04.174	info	instance system.adapter.daswetter.0 started with pid 24250
                                host.ioBroker
                                2023-01-30 10:30:00.116	info	instance system.adapter.meteoalarm.0 started with pid 24233
                                tractive-gps.0
                                2023-01-30 10:29:29.435	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:29:29.290	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:29:29.245	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:29:28.981	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:29:28.675	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:29:28.628	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:28:27.764	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:28:27.537	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:28:27.498	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:28:26.904	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:28:23.637	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:28:23.279	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:27:22.398	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:27:22.200	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:27:22.157	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:27:21.851	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:27:21.374	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:27:21.259	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:26:20.266	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:26:20.020	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:26:19.968	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:26:19.675	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:26:19.206	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:26:19.146	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:25:18.148	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:25:17.938	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:25:17.899	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:25:17.526	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:25:17.117	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:25:17.050	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:24:16.142	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:24:16.015	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:24:15.993	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:24:15.803	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:24:15.415	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:24:15.360	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:23:14.398	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:23:14.133	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:23:14.105	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:23:13.934	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:23:13.636	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:23:13.580	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:22:12.727	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:22:12.407	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:22:12.376	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:22:12.146	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:22:11.638	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:22:11.580	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                tractive-gps.0
                                2023-01-30 10:21:10.695	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:21:10.482	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:21:10.416	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:21:10.147	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:21:09.616	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:21:09.565	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                host.ioBroker
                                2023-01-30 10:20:47.589	info	instance system.adapter.fuelpricemonitor.0 terminated with code 0 (NO_ERROR)
                                host.ioBroker
                                2023-01-30 10:20:25.315	info	instance system.adapter.fuelpricemonitor.0 started with pid 24160
                                tractive-gps.0
                                2023-01-30 10:20:08.704	warn	State "tractive-gps.0.XAOXGCMV.device_pos_report.course" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:20:08.567	warn	State "tractive-gps.0.XAOXGCMV.tracker.read_only_since" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:20:08.543	warn	State "tractive-gps.0.XAOXGCMV.tracker.hw_edition" has no existing object, this might lead to an error in future versions
                                tractive-gps.0
                                2023-01-30 10:20:08.433	warn	[Adapter v.0.0.1 createStates] no state attribute found for course in device_pos_report
                                tractive-gps.0
                                2023-01-30 10:20:08.041	warn	[Adapter v.0.0.1 createStates] no state attribute found for read_only_since in tracker
                                tractive-gps.0
                                2023-01-30 10:20:07.978	warn	[Adapter v.0.0.1 createStates] no state attribute found for hw_edition in tracker
                                • H homecineplexx
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  host.ioBroker
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  host.ioBroker
                                  host.ioBroker
                                  host.ioBroker
                                  host.ioBroker
                                  host.ioBroker
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  host.ioBroker
                                  host.ioBroker
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  tractive-gps.0
                                  IssiI Offline
                                  IssiI Offline
                                  Issi
                                  #91
                                  @homecineplexx sagte in Tractive Adapter für Haustiere?:
                                  read_only_since
                                  Schicke mir bitte entweder die json per PM oder den Inhalt von read_only_since den musst du in der json suchen den state hatte bisher noch niemand gehabt.
                                  • H Offline
                                    homecineplexx
                                    #92
                                    @issi said in Tractive Adapter für Haustiere?:
                                    read_only_since
                                    ok, super schick ich dir, aber wie gesagt, es ist überhaupt nicht wichtig, schau lieber dass du gesund wirst
                                    • IssiI Offline
                                      IssiI Offline
                                      Issi
                                      #93
                                      Installiert bitte alle von GitHub hab ein Fix für die fehler gemacht
                                      • IssiI Issi
                                        W Online
                                        W Online
                                        Wildbill
                                        #94
                                        @issi Log ist gleich viel ruhiger, hab natürlich wieder auf Info gestellt. Für einen meiner zwei Tracker bekomme ich noch folgende Meldung im Log:
                                        Im Datenpunkt steht als Wert (dauerhaft, wie es scheint)
                                        ["LAST_VALID_FIX"]
                                        Beim zweiten Tracker kommt keine Meldung diesbezüglich. Der Datenpunkt existiert, enthält aber
                                        (null)
                                        Das scheint irgendwas zu sein, was der ältere der beiden Tracker gar nicht kennt.
                                        Gruss, Jürgen
                                        • IssiI Issi
                                          NegaleinN Offline
                                          NegaleinN Offline
                                          Negalein
                                          #95
                                          0.0.1 bleibt aber gleich?
                                          Meldungen im Log sind nun viel weniger. :)
