  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.7k
766 Beiträge 51 Kommentatoren 323.3k Aufrufe 52 Beobachtet
  • wendy2702W Offline
    wendy2702W Offline
    #172
    @copystring sagte in Roborock Adapter tester gesucht:
    https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
    Habe auch gerade mal komplett gelöscht und neu installiert. So sieht das log aus:
    2023-01-27 09:11:45.094  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1075557
    2023-01-27 09:11:46.186  - debug: roborock.0 (1075557) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2023-01-27 09:11:46.247  - debug: roborock.0 (1075557) Objects client ready ... initialize now
    2023-01-27 09:11:46.252  - debug: roborock.0 (1075557) Objects create System PubSub Client
    2023-01-27 09:11:46.253  - debug: roborock.0 (1075557) Objects create User PubSub Client
    2023-01-27 09:11:46.331  - debug: roborock.0 (1075557) Objects client initialize lua scripts
    2023-01-27 09:11:46.334  - debug: roborock.0 (1075557) Objects connected to redis: 0.0.0.0:9001
    2023-01-27 09:11:46.369  - debug: roborock.0 (1075557) Redis States: Use Redis connection: 0.0.0.0:9000
    2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create System PubSub Client
    2023-01-27 09:11:46.405  - debug: roborock.0 (1075557) States create User PubSub Client
    2023-01-27 09:11:46.493  - debug: roborock.0 (1075557) States connected to redis: 0.0.0.0:9000
    2023-01-27 09:11:46.769  - info: roborock.0 (1075557) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
    2023-01-27 09:11:46.912  - debug: roborock.0 (1075557) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
    2023-01-27 09:11:46.940  - info: roborock.0 (1075557) MQTT initialized
    2023-01-27 09:11:46.953  - debug: roborock.0 (1075557) Robot key: roborock.vacuum.a15
    2023-01-27 09:11:47.081  - debug: roborock.0 (1075557) Latest data requested
    2023-01-27 09:11:47.083  - debug: roborock.0 (1075557) getParameter: get_mop_mode
    2023-01-27 09:11:47.085  - debug: roborock.0 (1075557) getParameter: get_water_box_custom_mode
    2023-01-27 09:11:47.086  - debug: roborock.0 (1075557) getParameter: get_status
    2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_consumable
    2023-01-27 09:11:47.087  - debug: roborock.0 (1075557) getParameter: get_network_info
    2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_mode
    2023-01-27 09:11:47.088  - debug: roborock.0 (1075557) getParameter: get_carpet_cleaning_mode
    2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_fw_features
    2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) Firmware features request
    2023-01-27 09:11:47.089  - debug: roborock.0 (1075557) getParameter: get_multi_maps_list
    2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) getParameter: get_room_mapping
    2023-01-27 09:11:47.090  - debug: roborock.0 (1075557) get_room_mapping
    2023-01-27 09:11:47.146  - debug: roborock.0 (1075557) dps debug: {"id":3,"result":[203]}
    2023-01-27 09:11:47.147  - debug: roborock.0 (1075557) dps debug: {"id":5,"result":[{"main_brush_work_time":581958,"side_brush_work_time":581958,"filter_work_time":36866,"filter_element_work_time":0,"sensor_dirty_time":50176,"dust_collection_work_times":26}]}
    2023-01-27 09:11:47.207  - debug: roborock.0 (1075557) dps debug: {"id":6,"result":{"ssid":"WXXXXXXXSOHO","ip":"192.168.178.73","mac":"b0XXX:72","bssid":"76:83:c2:9a:11:5d","rssi":-64}}
    2023-01-27 09:11:47.214  - debug: roborock.0 (1075557) dps debug: {"id":1,"result":[302]}
    2023-01-27 09:11:47.215  - debug: roborock.0 (1075557) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
    2023-01-27 09:11:47.216  - debug: roborock.0 (1075557) dps debug: {"id":7,"result":{"clean_time":581938,"clean_area":8566392500,"clean_count":355,"dust_collection_count":292,"records":[1674660336,1674660313,1674577216,1674310611,1673963198,1673962557,1673625667,1673624409,1673450020,1673279186,1673177137,1673177094,1672931751,1672839102,1672839052,1672676949,1672483666,1671550852,1671550717,1671292694]}}
    2023-01-27 09:11:47.223  - debug: roborock.0 (1075557) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1311,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
    2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) dps debug: {"id":12,"result":[[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]}
    2023-01-27 09:11:47.225  - debug: roborock.0 (1075557) get_room_mapping: [[23,"10397453"],[16,"10397445"],[17,"10397459"],[18,"10397463"],[20,"10397450"],[22,"10397457"]]
    2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674662405,"length":12,"name":"Erdgeschoss ","bak_maps":[{"mapFlag":4,"add_time":1674310084}]}]}]}
    2023-01-27 09:11:47.228  - debug: roborock.0 (1075557) dps debug: {"id":9,"result":"unknown_method"}
    2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) Unknown parameter: "unknown_method"
    2023-01-27 09:11:47.229  - debug: roborock.0 (1075557) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
    2023-01-27 09:11:47.230  - debug: roborock.0 (1075557) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1312,"state":8,"battery":100,"clean_time":1975,"clean_area":30992500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":1,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":302,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
    2023-01-27 09:11:47.233  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.234  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.235  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.236  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.237  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.238  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.239  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.240  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.250  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_ver" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.252  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.msg_seq" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_time" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.clean_area" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.253  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.error_code" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_present" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_cleaning" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_returning" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.254  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.in_fresh_state" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lab_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dnd_enabled" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.255  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.map_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.is_locating" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.lock_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.256  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_box_carriage_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_forbidden_enable" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.adbumper_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.water_shortage_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_type" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.257  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dust_collection_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.auto_dust_collection" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.mop_mode" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.261  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.debug_mode" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.262  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.dock_error_status" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.267  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_reason" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.268  - warn: roborock.0 (1075557) State "roborock.0.Devices.52m2c9HI3hPqZNb571xDmr.deviceStatus.unsave_map_flag" has no existing object, this might lead to an error in future versions
    2023-01-27 09:11:47.269  - debug: roborock.0 (1075557) dps debug: {"id":15,"result":[{"begin":1674577216,"end":1674583431,"duration":3658,"area":39990000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.271  - debug: roborock.0 (1075557) dps debug: {"id":13,"result":[{"begin":1674660336,"end":1674662311,"duration":1975,"area":30992500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.272  - debug: roborock.0 (1075557) dps debug: {"id":14,"result":[{"begin":1674660313,"end":1674660315,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0}]}
    2023-01-27 09:11:47.273  - debug: roborock.0 (1075557) dps debug: {"id":18,"result":[{"begin":1673962557,"end":1673962598,"duration":15,"area":0,"error":0,"complete":0,"start_type":1,"clean_type":1,"finish_reason":21,"dust_collection_status":0}]}
    2023-01-27 09:11:47.274  - debug: roborock.0 (1075557) dps debug: {"id":17,"result":[{"begin":1673963198,"end":1673970437,"duration":2672,"area":37172500,"error":0,"complete":1,"start_type":1,"clean_type":1,"finish_reason":52,"dust_collection_status":1}]}
    2023-01-27 09:11:47.293  - debug: roborock.0 (1075557) dps debug: {"id":19,"result":[{"begin":1673625667,"end":1673628366,"duration":2699,"area":39452500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":16,"result":[{"begin":1674310611,"end":1674311055,"duration":444,"area":6152500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.294  - debug: roborock.0 (1075557) dps debug: {"id":22,"result":[{"begin":1673279186,"end":1673280386,"duration":1200,"area":18042500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":23,"result":[{"begin":1673177137,"end":1673179722,"duration":2585,"area":36967500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.295  - debug: roborock.0 (1075557) dps debug: {"id":26,"result":[{"begin":1672839102,"end":1672847459,"duration":2861,"area":39335000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":28,"result":[{"begin":1672676949,"end":1672678212,"duration":1263,"area":17982500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":20,"result":[{"begin":1673624409,"end":1673624479,"duration":70,"area":1490000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
    2023-01-27 09:11:47.296  - debug: roborock.0 (1075557) dps debug: {"id":29,"result":[{"begin":1672483666,"end":1672484896,"duration":1230,"area":17945000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":21,"result":[{"begin":1673450020,"end":1673452606,"duration":2586,"area":39457500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.297  - debug: roborock.0 (1075557) dps debug: {"id":30,"result":[{"begin":1671550852,"end":1671553922,"duration":3062,"area":39902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.298  - debug: roborock.0 (1075557) dps debug: {"id":25,"result":[{"begin":1672931751,"end":1672934471,"duration":2720,"area":40607500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.301  - debug: roborock.0 (1075557) dps debug: {"id":27,"result":[{"begin":1672839052,"end":1672839065,"duration":13,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
    2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":32,"result":[{"begin":1671292694,"end":1671294598,"duration":1904,"area":27470000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1}]}
    2023-01-27 09:11:47.302  - debug: roborock.0 (1075557) dps debug: {"id":31,"result":[{"begin":1671550717,"end":1671550797,"duration":80,"area":1050000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":1}]}
    2023-01-27 09:11:47.303  - debug: roborock.0 (1075557) dps debug: {"id":24,"result":[{"begin":1673177094,"end":1673177102,"duration":8,"area":0,"error":0,"complete":0,"start_type":4,"clean_type":1,"finish_reason":60,"dust_collection_status":0}]}
    2023-01-27 09:11:48.417  - debug: roborock.0 (1075557) deviceStatus 120 set with value: 0
    2023-01-27 09:11:48.423  - debug: roborock.0 (1075557) deviceStatus 121 set with value: 8
    2023-01-27 09:11:48.426  - debug: roborock.0 (1075557) deviceStatus 122 set with value: 100
    2023-01-27 09:11:48.430  - debug: roborock.0 (1075557) deviceStatus 123 set with value: 104
    2023-01-27 09:11:48.433  - debug: roborock.0 (1075557) deviceStatus 124 set with value: 203
    2023-01-27 09:11:48.437  - debug: roborock.0 (1075557) deviceStatus 125 set with value: 47
    2023-01-27 09:11:48.440  - debug: roborock.0 (1075557) deviceStatus 126 set with value: 20
    2023-01-27 09:11:48.446  - debug: roborock.0 (1075557) deviceStatus 127 set with value: 94
    So die Objekte:
    Gibt es in der API eine Übersicht was die "8" bei Device State bedeutet? Bei Xiaomi war es "Lädt"
    • copystringC Offline
      copystringC Offline
      copystring
      #173
      Danke für die vielen logs. Ich habe schon ein paar gute Ideen und werde die sehr wahrscheinlich am Wochenende umsetzen können.
      Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
      https://paypal.me/copystring
      Black ThunderB 1 Antwort Letzte Antwort
      • copystringC copystring
        Black ThunderB Offline
        Black Thunder
        #174
        @copystring Weiß zwar nicht, ob du es vielleicht schon selbst rausgefunden hast, aber ich konnte mein Absturzproblem beim Absetzen von Kommandos lösen. Und zwar funktioniert die Art, wie du das Extrahieren der Device-ID aus dem State implementiert hast, in meinem Fall nicht sauber. Meine Device-ID ist 21 Stellen lang, dein Code geht aber fix von 22 Stellen aus. Deswegen kommt es zu der Exception beim Zugriff auf das "vacuums"-Array.
        Hab dir gerade mal auf GitHub einen PR als Vorschlag geschickt, wie man das lösen könnte, ohne eine fixe Länge zu erwarten. Kannst dir ja mal bei Gelegenheit angucken. ;)
        O 1 Antwort Letzte Antwort
        • Black ThunderB Black Thunder
          O Offline
          O Offline
          oxident
          #175
          @black-thunder @copystring Ich habe mal den Branch nach dem Merge des PR getestet und leider mit meinen S7 Max ProV keinen Erfolg gehabt:
          host.iobroker
          2023-01-28 12:39:50.439	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          roborock.0
          2023-01-28 12:39:50.000	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.924	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.923	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.923	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.921	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.920	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.919	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.918	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.917	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.916	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.915	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.886	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.884	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.881	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.878	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.877	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.875	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.872	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.869	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.861	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.847	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
          roborock.0
          2023-01-28 12:39:49.846	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
          roborock.0
          2023-01-28 12:39:49.844	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
          roborock.0
          2023-01-28 12:39:49.819	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
          roborock.0
          2023-01-28 12:39:49.817	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
          roborock.0
          2023-01-28 12:39:49.816	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
          roborock.0
          2023-01-28 12:39:49.807	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-61}}
          roborock.0
          2023-01-28 12:39:49.804	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
          roborock.0
          2023-01-28 12:39:49.794	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
          roborock.0
          2023-01-28 12:39:49.791	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
          roborock.0
          2023-01-28 12:39:49.789	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
          roborock.0
          2023-01-28 12:39:49.774	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
          roborock.0
          2023-01-28 12:39:49.765	error	Cannot read properties of undefined (reading 'divider')
          roborock.0
          2023-01-28 12:39:49.764	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
          roborock.0
          2023-01-28 12:39:49.764	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
          roborock.0
          2023-01-28 12:39:49.763	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2023-01-28 12:39:49.759	debug	get_status: {"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
          roborock.0
          2023-01-28 12:39:49.757	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1091,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
          roborock.0
          2023-01-28 12:39:49.691	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          roborock.0
          2023-01-28 12:39:49.690	info	terminating
          roborock.0
          2023-01-28 12:39:49.683	error	Cannot read properties of undefined (reading 'model')
          roborock.0
          2023-01-28 12:39:49.682	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
          roborock.0
          2023-01-28 12:39:49.681	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
          roborock.0
          2023-01-28 12:39:49.680	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2023-01-28 12:39:49.676	debug	get_room_mapping
          roborock.0
          2023-01-28 12:39:49.675	debug	getParameter: get_room_mapping
          roborock.0
          2023-01-28 12:39:49.673	debug	getParameter: get_multi_maps_list
          roborock.0
          2023-01-28 12:39:49.672	debug	Firmware features request
          roborock.0
          2023-01-28 12:39:49.672	debug	getParameter: get_fw_features
          roborock.0
          2023-01-28 12:39:49.670	debug	getParameter: get_carpet_clean_mode
          roborock.0
          2023-01-28 12:39:49.668	debug	getParameter: get_carpet_mode
          roborock.0
          2023-01-28 12:39:49.666	debug	getParameter: get_network_info
          roborock.0
          2023-01-28 12:39:49.664	debug	getParameter: get_consumable
          roborock.0
          2023-01-28 12:39:49.663	debug	getParameter: get_water_box_custom_mode
          roborock.0
          2023-01-28 12:39:49.657	debug	getParameter: get_status
          roborock.0
          2023-01-28 12:39:49.655	debug	Latest data requested
          roborock.0
          2023-01-28 12:39:49.227	debug	Robot key: roborock.vacuum.a27
          roborock.0
          2023-01-28 12:39:49.222	info	MQTT initialized
          roborock.0
          2023-01-28 12:39:49.135	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          roborock.0
          2023-01-28 12:39:48.829	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
          roborock.0
          2023-01-28 12:39:48.544	debug	States connected to redis: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:48.532	debug	States create User PubSub Client
          roborock.0
          2023-01-28 12:39:48.530	debug	States create System PubSub Client
          roborock.0
          2023-01-28 12:39:48.514	debug	Redis States: Use Redis connection: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:48.481	debug	Objects connected to redis: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:48.474	debug	Objects client initialize lua scripts
          roborock.0
          2023-01-28 12:39:48.034	debug	Objects create User PubSub Client
          roborock.0
          2023-01-28 12:39:48.033	debug	Objects create System PubSub Client
          roborock.0
          2023-01-28 12:39:48.031	debug	Objects client ready ... initialize now
          roborock.0
          2023-01-28 12:39:47.999	debug	Redis Objects: Use Redis connection: 127.0.0.1:6379
          host.iobroker
          2023-01-28 12:39:40.788	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          roborock.0
          2023-01-28 12:39:40.407	debug	dps debug: {"id":23,"result":[{"begin":1673790868,"end":1673791759,"duration":757,"area":6572500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":25,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.406	debug	dps debug: {"id":30,"result":[{"begin":1672816905,"end":1672819367,"duration":2105,"area":30145000,"error":0,"complete":1,"start_type":2,"clean_type":1,"finish_reason":52,"dust_collection_status":1,"avoid_count":73,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.404	debug	dps debug: {"id":26,"result":[{"begin":1673443346,"end":1673445453,"duration":1823,"area":12277500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":82,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.402	debug	dps debug: {"id":27,"result":[{"begin":1673441693,"end":1673442596,"duration":770,"area":6805000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":24,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.346	debug	dps debug: {"id":29,"result":[{"begin":1673087904,"end":1673088810,"duration":778,"area":6795000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":32,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.343	debug	dps debug: {"id":21,"result":[{"begin":1673794518,"end":1673796598,"duration":2080,"area":14382500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":91,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.342	debug	dps debug: {"id":18,"result":[{"begin":1674377442,"end":1674378273,"duration":701,"area":6650000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":27,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.339	debug	dps debug: {"id":16,"result":[{"begin":1674408702,"end":1674409650,"duration":813,"area":14437500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":21,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.336	debug	dps debug: {"id":28,"result":[{"begin":1673098529,"end":1673100615,"duration":1955,"area":14240000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":67,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.335	debug	dps debug: {"id":22,"result":[{"begin":1673792905,"end":1673793280,"duration":375,"area":3085000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":12,"wash_count":1,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.333	debug	dps debug: {"id":19,"result":[{"begin":1674292081,"end":1674294350,"duration":2154,"area":14755000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":60,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.330	debug	dps debug: {"id":24,"result":[{"begin":1673725522,"end":1673727792,"duration":2150,"area":14295000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":62,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.329	debug	dps debug: {"id":25,"result":[{"begin":1673709970,"end":1673711137,"duration":1036,"area":8980000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":15,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.325	debug	dps debug: {"id":12,"result":[{"begin":1674546444,"end":1674548420,"duration":1632,"area":14375000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":53,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.324	debug	dps debug: {"id":11,"result":[{"begin":1674766662,"end":1674768345,"duration":1563,"area":14082500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":34,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.322	debug	dps debug: {"id":17,"result":[{"begin":1674381086,"end":1674383413,"duration":2199,"area":14752500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":1,"avoid_count":70,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.320	debug	dps debug: {"id":20,"result":[{"begin":1673806389,"end":1673807002,"duration":479,"area":4270000,"error":0,"complete":1,"start_type":2,"clean_type":2,"finish_reason":54,"dust_collection_status":1,"avoid_count":3,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.317	debug	dps debug: {"id":14,"result":[{"begin":1674542249,"end":1674542741,"duration":366,"area":6537500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":13,"wash_count":2,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.302	debug	dps debug: {"id":13,"result":[{"begin":1674546431,"end":1674546433,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":37,"dust_collection_status":0,"avoid_count":0,"wash_count":0,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.298	debug	dps debug: {"id":15,"result":[{"begin":1674522197,"end":1674524890,"duration":2341,"area":14192500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0,"avoid_count":82,"wash_count":3,"map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.263	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.cleaning_brush_work_times" has no existing object, this might lead to an error in future versions
          roborock.0
          2023-01-28 12:39:40.262	warn	State "roborock.0.Devices.3d0nqqH2ONtxeYVtkE3H4d.consumables.strainer_work_times" has no existing object, this might lead to an error in future versions
          roborock.0
          2023-01-28 12:39:40.255	debug	dps debug: {"id":9,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674768662,"length":13,"name":"Obergeschoss ","bak_maps":[{"mapFlag":4,"add_time":1671647485}]}]}]}
          roborock.0
          2023-01-28 12:39:40.253	debug	get_room_mapping: [[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]
          roborock.0
          2023-01-28 12:39:40.252	debug	dps debug: {"id":10,"result":[[16,"8113307",1],[17,"8043479",15],[18,"8113298",1],[19,"8070271",8],[20,"8168423",8]]}
          roborock.0
          2023-01-28 12:39:40.241	debug	dps debug: {"id":7,"result":[{"carpet_clean_mode":1}]}
          roborock.0
          2023-01-28 12:39:40.239	debug	dps debug: {"id":4,"result":{"ssid":"bwnetz","ip":"192.168.37.142","mac":"b0:4a:39:4b:a5:11","bssid":"b4:fb:e4:d5:64:a3","rssi":-62}}
          roborock.0
          2023-01-28 12:39:40.237	error	Cannot read properties of undefined (reading 'divider')
          roborock.0
          2023-01-28 12:39:40.236	error	TypeError: Cannot read properties of undefined (reading 'divider') at /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js:166:52 at processTicksAndRejections (node:internal/process/task_queues:96:5)
          roborock.0
          2023-01-28 12:39:40.236	error	unhandled promise rejection: Cannot read properties of undefined (reading 'divider')
          roborock.0
          2023-01-28 12:39:40.235	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2023-01-28 12:39:40.232	debug	get_status: {"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}
          roborock.0
          2023-01-28 12:39:40.231	debug	dps debug: {"id":1,"result":[{"msg_ver":2,"msg_seq":1090,"state":8,"battery":100,"clean_time":1563,"clean_area":14082500,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"back_type":-1,"wash_phase":0,"wash_ready":0,"fan_power":104,"dnd_enabled":0,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":1,"mop_forbidden_enable":1,"camera_status":3493,"is_exploring":0,"home_sec_status":0,"home_sec_enable_password":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":3,"dust_collection_status":0,"auto_dust_collection":1,"avoid_count":34,"mop_mode":300,"debug_mode":0,"collision_avoid_status":0,"switch_map_mode":0,"dock_error_status":0,"charge_status":1,"unsave_map_reason":0,"unsave_map_flag":0}]}
          roborock.0
          2023-01-28 12:39:40.229	debug	dps debug: {"id":8,"result":[111,112,113,114,115,116,117,118,119,120,121,122,123,124,125]}
          roborock.0
          2023-01-28 12:39:40.227	debug	dps debug: {"id":2,"result":{"water_box_mode":203}}
          roborock.0
          2023-01-28 12:39:40.225	debug	dps debug: {"id":6,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
          roborock.0
          2023-01-28 12:39:40.221	debug	dps debug: {"id":3,"result":[{"main_brush_work_time":233648,"side_brush_work_time":233648,"filter_work_time":233648,"filter_element_work_time":0,"sensor_dirty_time":14330,"strainer_work_times":53,"dust_collection_work_times":179,"cleaning_brush_work_times":53}]}
          roborock.0
          2023-01-28 12:39:40.199	debug	dps debug: {"id":5,"result":{"clean_time":233648,"clean_area":2087355000,"clean_count":221,"dust_collection_count":179,"records":[1674766662,1674546444,1674546431,1674542249,1674522197,1674408702,1674381086,1674377442,1674292081,1673806389,1673794518,1673792905,1673790868,1673725522,1673709970,1673443346,1673441693,1673098529,1673087904,1672816905]}}
          roborock.0
          2023-01-28 12:39:40.096	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          roborock.0
          2023-01-28 12:39:40.095	info	terminating
          roborock.0
          2023-01-28 12:39:40.091	error	Cannot read properties of undefined (reading 'model')
          roborock.0
          2023-01-28 12:39:40.091	error	TypeError: Cannot read properties of undefined (reading 'model') at Roborock.onReady (/opt/iobroker/node_modules/iobroker.roborock/main.js:170:39)
          roborock.0
          2023-01-28 12:39:40.091	error	unhandled promise rejection: Cannot read properties of undefined (reading 'model')
          roborock.0
          2023-01-28 12:39:40.090	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2023-01-28 12:39:40.088	debug	get_room_mapping
          roborock.0
          2023-01-28 12:39:40.088	debug	getParameter: get_room_mapping
          roborock.0
          2023-01-28 12:39:40.087	debug	getParameter: get_multi_maps_list
          roborock.0
          2023-01-28 12:39:40.087	debug	Firmware features request
          roborock.0
          2023-01-28 12:39:40.086	debug	getParameter: get_fw_features
          roborock.0
          2023-01-28 12:39:40.086	debug	getParameter: get_carpet_clean_mode
          roborock.0
          2023-01-28 12:39:40.085	debug	getParameter: get_carpet_mode
          roborock.0
          2023-01-28 12:39:40.084	debug	getParameter: get_network_info
          roborock.0
          2023-01-28 12:39:40.083	debug	getParameter: get_consumable
          roborock.0
          2023-01-28 12:39:40.082	debug	getParameter: get_water_box_custom_mode
          roborock.0
          2023-01-28 12:39:40.079	debug	getParameter: get_status
          roborock.0
          2023-01-28 12:39:40.078	debug	Latest data requested
          roborock.0
          2023-01-28 12:39:39.756	debug	Robot key: roborock.vacuum.a27
          roborock.0
          2023-01-28 12:39:39.752	info	MQTT initialized
          roborock.0
          2023-01-28 12:39:39.655	debug	RoomIDs debug: {"8043477":"Wohnzimmer","8043479":"Badezimmer","8070271":"Flur","8113298":"Schlafzimmer","8113299":"Schlafzimmer1","8113307":"Laura","8168423":"Schrank","10294341":"Treppenhaus"}
          roborock.0
          2023-01-28 12:39:39.390	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
          roborock.0
          2023-01-28 12:39:39.036	debug	States connected to redis: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:39.025	debug	States create User PubSub Client
          roborock.0
          2023-01-28 12:39:39.023	debug	States create System PubSub Client
          roborock.0
          2023-01-28 12:39:39.011	debug	Redis States: Use Redis connection: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:38.983	debug	Objects connected to redis: 127.0.0.1:6379
          roborock.0
          2023-01-28 12:39:38.976	debug	Objects client initialize lua scripts
          roborock.0
          2023-01-28 12:39:38.572	debug	Objects create User PubSub Client
          roborock.0
          2023-01-28 12:39:38.571	debug	Objects create System PubSub Client
          roborock.0
          2023-01-28 12:39:38.570	debug	Objects client ready ... initialize now
            copystringC Offline
            copystring
            schrieb am zuletzt editiert von copystring
            #176
            Ich bedanke mich für das fleißige Testen! Dadurch konnte ich einen ersten alpha release erstellen.
            https://github.com/copystring/ioBroker.roborock hat jetzt einen alpha (v0.0.2-alpha.0) release. Bitte testen und bei Fehlern mit entsprechenden Log ein Issue auf Github öffnen. Die ganzen Protokolle sind mir hier zu viel geworden ich und weiß gar nicht mehr welche tatsächlich noch relevant sind.
            Es kann dadurch vorkommen, dass ihr den gleiche Fehler (@oxident) nochmal posten müsst aber nur dadurch kann ich die Fehler sauber im Blick behalten.
              wendy2702W Offline
              wendy2702W Offline
              #177
              Danke für deine Arbeit!
              Installiert und Issue angelegt.
              https://github.com/copystring/ioBroker.roborock/issues/14
                DonToben
                #178
                Aktuelle 0.0.5 Alpha funktioniert bei mir überhaupt nicht. Adapter startet ständig neu.
                Wie kommt man auf einen älteren Stand? Mir wird in iobroker keine andere Version angezeigt ...
                • D DonToben
                  wendy2702W Offline
                  wendy2702W Offline
                  #179
                  @dontoben sagte in Roborock Adapter tester gesucht:
                  Ist 0.0.5 ein Tippfehler?
                  Vielleicht macht es Sinn wenn du @copystring das Logfile mit dem Fehler in Github zukommen lässt damit er sich das anschauen kann. Sonst wird der Fehler ja nicht behoben.
                  • wendy2702W wendy2702
                    DonToben
                    #180
                    @wendy2702
                    nein ist kein Tippfehler. Ich bin gerade unterwegs. Evtl. könnte das kurz jemand anderes testen. Danke
                    wendy2702W 2 Antworten Letzte Antwort
                    • D DonToben
                      @wendy2702
                      wendy2702W Offline
                      wendy2702W Offline
                      #181
                      @dontoben Gar nicht mitbekommen das wir schon bei 0.0.5 sind.
                      Mal testen
                      • D DonToben
                        @wendy2702
                        wendy2702W Offline
                        wendy2702W Offline
                        #182
                        @wendy2702
                        Version 0.0.5 läuft bei mir
                          DonToben
                          schrieb am zuletzt editiert von DonToben
                          #183
                          Issue zur 0.0.5 alpha auf github angelegt
                          https://github.com/copystring/ioBroker.roborock/issues/27
                          • D DonToben
                            wendy2702W Offline
                            wendy2702W Offline
                            #184
                            @dontoben Mal Instanz und Adapter gelöscht und komplett neu installiert?
                              simplyclever
                              #185
                              @copystring Super Arbeit!
                              Der Test Branch aus issue https://github.com/copystring/ioBroker.roborock/issues/26 funktioniert soweit, nur noch 1 Warning.
                              Kannst Du in GitHub auflisten, welche Commands schon funktionieren?
                              Ich kann den Roboter starten, aber stoppen oder aufladen funktioniert wohl noch nicht, oder?
                              copystringC 1 Antwort Letzte Antwort
                              • S simplyclever
                                copystringC Offline
                                copystringC Offline
                                copystring
                                #186
                                @simplyclever mit https://github.com/copystring/ioBroker.roborock/tree/report_unknown_attributes sollte alles laufen. Habe gerad eben noch einen Fehler behoben. Dadurch laufen jetzt wieder alle commands.
                                S wendy2702W 2 Antworten Letzte Antwort
                                  simplyclever
                                  #187
                                  @copystring Ja, funktioniert.
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    #188
                                    @copystring machst du das wieder in eine Alpha?
                                      copystringC Offline
                                      copystringC Offline
                                      copystring
                                      #189
                                      @wendy2702 ja heute Abend. Ein Ticket ist noch offen. Wenn keine weiteren Fehler auftreten mache ich heute Abend 0.0.6 daraus.
                                      O wendy2702W 2 Antworten Letzte Antwort
                                        O Offline
                                        O Offline
                                        oxident
                                        #190
                                        @copystring
                                        https://github.com/copystring/ioBroker.roborock/issues/21
                                        Das war mein's ... und ist erledigt!
                                        Danke ;-)
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          #191
                                          Cool.
                                          Kann ich heute Abend testen wenn ich zu Hause bin
