  3. Einsteigerfragen
  4. Einbindung von Geräten
  5. MQTT Datenpunkte ohne Anzeigewert (IR-Lesekopf, Stromzähler)
73 Beiträge 4 Kommentatoren 8.9k Aufrufe 3 Beobachtet
  • mickymM mickym
    @bastel2021 oder einfach ein JSON Node dahinter.
           "id": "b0b19f18d7cb0589",
           "type": "inject",
           "z": "289f539dcc33814e",
           "name": "",
           "props": [
                   "p": "payload"
           "repeat": "",
           "crontab": "",
           "once": false,
           "onceDelay": 0.1,
           "topic": "",
           "payload": "{\"node-red.1\":true,\"linux-control.0\":true,\"tr-064.0\":true,\"yahka.0\":true,\"sql.0\":true,\"mqtt.1\":true,\"simple-api.0\":true,\"mercedesme.0\":true,\"socketio.0\":true,\"ping.0\":true,\"pi-hole.0\":true,\"tuya.0\":true,\"sourceanalytix.0\":true,\"node-red.0\":true,\"info.0\":true,\"web.0\":true,\"admin.0\":true,\"mqtt.2\":true,\"javascript.0\":true,\"backitup.0\":true}",
           "payloadType": "str",
           "x": 1070,
           "y": 3080,
           "wires": [
                   "d5b2ee208771c2d4",
                   "d40f3c482c5de7f3"
           "id": "d5b2ee208771c2d4",
           "type": "json",
           "name": "",
           "property": "payload",
           "action": "",
           "pretty": false,
           "x": 1270,
           "y": 3080,
           "wires": [
                   "766d62e8342abe09",
                   "f984f31a853335c9"
           "id": "d40f3c482c5de7f3",
           "type": "debug",
           "name": "String",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "complete": "payload",
           "targetType": "msg",
           "statusVal": "",
           "statusType": "auto",
           "x": 1210,
           "y": 3120,
           "wires": []
           "id": "766d62e8342abe09",
           "type": "debug",
           "name": "Objekt",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1470,
           "y": 3020,
           "wires": []
           "id": "f984f31a853335c9",
           "type": "change",
           "name": "",
           "rules": [
                   "t": "set",
                   "p": "payload",
                   "pt": "msg",
                   "to": "payload[\"mqtt.1\"]",
                   "tot": "msg"
           "action": "",
           "property": "",
           "from": "",
           "to": "",
           "reg": false,
           "x": 1490,
           "y": 3080,
           "wires": [
                   "06f62619237a8f89"
           "id": "06f62619237a8f89",
           "type": "debug",
           "name": "Wert",
           "active": true,
           "tosidebar": true,
           "console": false,
           "tostatus": false,
           "statusVal": "",
           "x": 1690,
           "y": 3080,
           "wires": []
    Ich hab dir einfach das Beispiel so zum Import zur Verfügung gestellt.
    Die JSON Node musst nicht mal konfigurieren, die erkennt automatisch was für ein Datentyp rein kommt und konvertiert den.
    Bei Dir macht die mqtt Node keinen großen Sinn, da Du den iobroker als mqtt Broker verwendest. Du könnst zwar theoretisch auch die mqtt-Nodes nutzen.
    Bei den mqtt-Nodes ist die JSON Node halt einfach schon eingebaut - mehr nicht:
    Wie gesagt, mach einfach eine JSON Node dahinter und kopiere immer den Pfad aus dem Debug Fenster, wenn es ein Objekt ist und dann bist Du auf der sicheren Seite.
    Bastel2021
    @mickym
    Habe jetzt nur in der Inject den String rein kopiert sonst noch nichts geändert
    Passt das so?
    • B Bastel2021
      @mickym
      Passt das so?
      mickymM Offline
      mickymM Offline
      mickym
      @bastel2021 Nein in Deiner Change Node passt das noch nicht. Klapp mal im Debug Fenster das Objekt auf und kopiere den Pfad in die Change Node.
      Pder kopiere mal den String hier in CodeTags, dann übernehme ich das in meinen Flow.
      Mach mal einen Screen shot vom Inhalt Deiner Change Node.
      B mickymM 2 Antworten Letzte Antwort
      • mickymM mickym
        Bastel2021
        @mickym
        • B Bastel2021
          @mickym
          Bastel2021
          @bastel2021
          {"Time":"2023-01-28T14:51:52","ED300L ":{"Total_in":3164.3,"Total_out":0,"Power_curr":190.8}}
          • mickymM mickym
            mickymM Offline
            mickymM Offline
            mickym
            @mickym Na da steht ja noch [mqtt1] drin.
            wie gesagt geh ins Debug Fenster mach das Objekt auf - und kopieren den Pfad in die Change Node, in dem Du neben den Wert mit der Maus gehst der Dich interessiert und dort kopierst Du den Pfad.
                   "type": "change",
                   "name": "",
                   "rules": [
                           "t": "set",
                           "p": "payload",
                           "pt": "msg",
                           "to": "payload[\"ED300L \"].Power_curr",
                           "tot": "msg"
                   "action": "",
                   "property": "",
                   "from": "",
                   "to": "",
                   "reg": false,
                   "x": 1490,
                   "y": 3080,
                   "wires": [
                           "06f62619237a8f89"
            • mickymM mickym
                     "type": "change",
                     "name": "",
                     "rules": [
                             "t": "set",
                             "p": "payload",
                             "pt": "msg",
                             "tot": "msg"
                     "action": "",
                     "property": "",
                     "from": "",
                     "to": "",
                     "reg": false,
                     "x": 1490,
                     "y": 3080,
                     "wires": [
                             "06f62619237a8f89"
              Bastel2021
              @mickym
              Jetzt sieht es auf jeden Fall erstmal richtig aus!
              Wenn ich den Pfad kopiere dann kopiere ich: 190.8
              Es sollte aber das sein;["ED300L "].Power_curr oder?
              B 2 Antworten Letzte Antwort
              • B Bastel2021
                @mickym
                Bastel2021
                @bastel2021
                und welches Debug Fenster meinst du? Das hinter der json node?
                • B Bastel2021
                  @mickym
                  Bastel2021
                  @bastel2021
                  ja natürlich, da sind die werte ja getrennt. Blöde Frage
                  Aber wie gesagt wenn ich den Pfad kopiere dann steht da nur der Wert
                  • mickymM Offline
                    mickymM Offline
                    mickym
                    @bastel2021 sagte in MQTT Datenpunkte ohne Anzeigewert (IR-Lesekopf, Stromzähler):
                    @bastel2021
                    Ja Du kopierst den Pfad neben dem Wert, der Dich interessiert in Deine Change Node:
                    • mickymM mickym
                      @bastel2021
                      Bastel2021
                      @mickym
                      Hm, Fehler gefunden! Sorry nicht Wert kopieren sondern Pfad 😕
                      • B Bastel2021
                        @mickym
                        mickymM Offline
                        mickymM Offline
                        mickym
                        @mickym
                        • mickymM mickym
                          @mickym
                          Bastel2021
                          schrieb am zuletzt editiert von Bastel2021
                          @mickym
                          Hm habe das nochmals nachgebaut und bei mir bekomme ich den Wert nicht raus!
                          Irgendwas ist noch falsch!
                          Wenn ich in der Inject Node den Pfad kopiere steht da nur; payload
                          Kopiere ich den Wert dann: {"Time":"2023-01-28T15:46:52","ED300L ":{"Total_in":3164.5,"Total_out":0,"Power_curr":202.2}}
                          D.h. in der Inject muss ich den Wert kopieren, richtig?
                          Und trotzdem Wird bei dem was ich nachgebaut habe kein Wert in der letzten Debug angezeigt
                          • mickymM mickym
                            @mickym
                            Bastel2021
                            @mickym
                            Merkwürdigerweise kommt aus der debug9 nichts raus. Aber warum?
                            • B Bastel2021
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              @bastel2021 Klar in die Inject Node kopierst Du den Wert. Wenn Du den so kopierst wie in den Code-Tags dann brauchst Du die JSON Node nicht, wenn Du es als Objekt definierst.
                              Wenn du es als String in die Inject Node kopierst, dann musst mit einer JSON Node noch umwandeln
                                     "id": "d222e644e68660a6",
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "payload": "{\"Time\":\"2023-01-28T14:51:52\",\"ED300L \":{\"Total_in\":3164.3,\"Total_out\":0,\"Power_curr\":190.8}}",
                                     "payloadType": "json",
                                     "x": 1550,
                                     "y": 3120,
                                     "wires": [
                                             "8c5ada7055d87d92"
                                     "id": "8c5ada7055d87d92",
                                     "type": "debug",
                                     "name": "Objekt",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1710,
                                     "y": 3120,
                                     "wires": []
                                     "id": "9bcc74a4cd4c34e9",
                                     "type": "inject",
                                     "name": "",
                                     "props": [
                                             "p": "payload"
                                     "repeat": "",
                                     "crontab": "",
                                     "once": false,
                                     "onceDelay": 0.1,
                                     "topic": "",
                                     "x": 1550,
                                     "y": 3180,
                                     "wires": [
                                             "e9d07d6d7548352d"
                                     "id": "e9d07d6d7548352d",
                                     "type": "debug",
                                     "name": "String",
                                     "active": true,
                                     "tosidebar": true,
                                     "console": false,
                                     "tostatus": false,
                                     "statusVal": "",
                                     "x": 1710,
                                     "y": 3180,
                                     "wires": []
                              • B Bastel2021
                                @mickym
                                mickymM Offline
                                mickymM Offline
                                mickym
                                @bastel2021 Du hast das wie eben geschrieben in Deiner Inject entweder als String oder Objekt definiert. Wenn Du eine json Node dahinter klemmst und es war schon ein Objekt wird es in einen String verwandelt umgekehrt, war es ein String dann in ein Objekt.
                                In Debug 8 sieht es nun so aus, als ob du in die Inject Node einen String eingegeben hast. Deswegen enthält die debug 9 das Objekt. Wenn du es gleich als Objekt in der Inject node definierst dann brauchst Du die Umwandlung nicht.
                                Ich hab Dir das ja im vorherigen Post dargestellt.
                                • mickymM mickym
                                  Bastel2021
                                  @mickym
                                  okay soweit ist das klar, und ich kann das auch Simulieren!
                                  Nach der Change Node ist dann aber bei beiden Versionen schluss. Hast du eine Idee warum
                                  1.Variante
                                  1. Variante
                                  • B Bastel2021
                                    @mickym
                                    1.Variante
                                    1. Variante
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    @bastel2021 Du setzt die payload auf einen String und nicht auf ein Nachrichtenobjekt:
                                    Falsch:
                                    Richtig:
                                    Ich erkenne auch keinen Unterschied zwischen Deinen beiden Varianten.
                                    • mickymM mickym
                                      Falsch:
                                      Richtig:
                                      Bastel2021
                                      @mickym
                                      Mit Brille wäre das nicht passiert! Also in der Change lag der Fehler.
                                      Die Varianten waren nur Inject - String und Injekt - Objekt
                                      • B Bastel2021
                                        @mickym
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        @bastel2021 Also mal ganz generell:
                                        Hier mal die Begrifflichkeiten erklärt und die Datentypen : https://forum.iobroker.net/post/852974
                                        und hier: https://forum.iobroker.net/post/905403
                                        Das zu verstehen, welche Datentypen es gibt in Javascript ist essentiell für NodeRed, Blockly, JS Programmierung generell und somit auch für den iobroker.
                                        Im Prinzip kannst Du Dir einfach merken, dass Du mit einem JSON String einfach Javascript-Objekte als String (Zeichenkette) zwischen verschiedenen Systemen (z. Bsp. Browser) austauschen kannst und dabei die Datentypen erhalten bleiben.
                                        Wenn Du in einer Inject Node ein Objekt selbst erstellst:
                                        nutzt Du die geschweifte Klammer - dort kannst Du dann über den JSON Editor das manuell eintragen:
                                        oder Du nutzt den visuellen Editor um Werte in deinem Objekt zu definieren (nächster Tab):
                                        NodeRed- Array Visueller Editor.mp4
                                        • B Bastel2021
                                          @mickym
                                          mickymM Offline
                                          mickymM Offline
                                          mickym
                                          @bastel2021 Wenn Du nur einen reinen String hast, dann musst Du mittels JSON in ein Objekt umwandeln:
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 1450,
                                                 "y": 3120,
                                                 "wires": [
                                                         "8c5ada7055d87d92",
                                                         "0dd804093323bcf0"
                                                 "type": "debug",
                                                 "name": "Objekt",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1710,
                                                 "y": 3120,
                                                 "wires": []
                                                 "type": "inject",
                                                 "name": "",
                                                 "props": [
                                                         "p": "payload"
                                                 "repeat": "",
                                                 "crontab": "",
                                                 "once": false,
                                                 "onceDelay": 0.1,
                                                 "topic": "",
                                                 "x": 1450,
                                                 "y": 3220,
                                                 "wires": [
                                                         "e9d07d6d7548352d",
                                                         "13632c6c2a4e7b78"
                                                 "type": "debug",
                                                 "name": "String",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1710,
                                                 "y": 3220,
                                                 "wires": []
                                                 "id": "0dd804093323bcf0",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1750,
                                                 "y": 3160,
                                                 "wires": [
                                                         "10180a8bd8f0b836"
                                                 "id": "10180a8bd8f0b836",
                                                 "type": "debug",
                                                 "name": "Wert",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1930,
                                                 "y": 3160,
                                                 "wires": []
                                                 "id": "2a56ec2865b7173d",
                                                 "type": "change",
                                                 "name": "",
                                                 "rules": [
                                                         "t": "set",
                                                         "p": "payload",
                                                         "pt": "msg",
                                                         "tot": "msg"
                                                 "action": "",
                                                 "property": "",
                                                 "from": "",
                                                 "to": "",
                                                 "reg": false,
                                                 "x": 1750,
                                                 "y": 3280,
                                                 "wires": [
                                                         "e6c08337d7f19555"
                                                 "id": "e6c08337d7f19555",
                                                 "type": "debug",
                                                 "name": "Wert",
                                                 "active": true,
                                                 "tosidebar": true,
                                                 "console": false,
                                                 "tostatus": false,
                                                 "statusVal": "",
                                                 "x": 1930,
                                                 "y": 3280,
                                                 "wires": []
                                                 "id": "13632c6c2a4e7b78",
                                                 "type": "json",
                                                 "name": "",
                                                 "action": "",
                                                 "pretty": false,
                                                 "x": 1590,
                                                 "y": 3280,
                                                 "wires": [
                                                         "2a56ec2865b7173d"
                                          Die obere Inject Node definiert direkt das Objekt:
                                          die untere nur den String:
                                          und muss deshalb via JSON node noch in ein Objekt umgewandelt werden.
                                          Deshalb:
                                          Aus der iobroker-IN Node erhälst Du nur den String, deshalb musst Du da dann noch eine JSON Node dranhängen!
