  4. Nach update admin, web, js-controler. Weder Admin GUI noch VIS
    5.7k
18 Beiträge 3 Kommentatoren 2.1k Aufrufe
  • Z Offline
    Z Offline
    Zippolighter
    Wenn ich wie in der Doku den admin aufrufe (admin.0 vorher gestoppt)
    ` > root@raspberrypi3_ioBroker:/opt/iobroker# node node_modules/iobroker.admin/admin.js –logs
    module.js:327
    throw err;
    Error: Cannot find module 'base64id'
    at Function.Module._resolveFilename (module.js:325:15)
    at Function.Module._load (module.js:276:25)
    at Module.require (module.js:353:17)
    at require (internal/module.js:12:17)
    at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/lib/server.js:8:16)
    at Module._compile (module.js:409:26)
    at Object.Module._extensions..js (module.js:416:10)
    at Module.load (module.js:343:32)
    at Function.Module._load (module.js:300:12)
    at Module.require (module.js:353:17)</anonymous> `
    Im log steht folgendes
    ` > 2017-08-25 20:49:31.103 - [31merror[39m: host.raspberrypi3_ioBroker instance system.adapter.admin.0 terminated with code 1 ()
    2017-08-25 20:49:31.109 - [32minfo[39m: web.0 system.adapter.admin.0: logging false
    2017-08-25 20:49:31.115 - [32minfo[39m: history.0 system.adapter.admin.0: logging false
    2017-08-25 20:49:31.112 - [32minfo[39m: javascript.0 system.adapter.admin.0: logging false
    2017-08-25 20:49:31.104 - [32minfo[39m: host.raspberrypi3_ioBroker Do not restart adapter system.adapter.admin.0 because disabled or deleted `
    • eric2905E Offline
      eric2905E Offline
      eric2905
      @Zippolighter:
      `2017-08-25 20:49:31.104  - [32minfo[39m: host.raspberrypi3_ioBroker Do not restart adapter system.adapter.admin.0 because disabled or deleted[/code]`
      versuche mal mit
      `~~[code]~~iobroker admin upload
      iobroker start admin[/code]`
      ihn wieder ans Laufen zu bekommen
      Gruß,
      Eric
      BTW: Alle Command zum ioBroker findet man hier : [https://github.com/ioBroker/ioBroker/wi ... daptername](https://github.com/ioBroker/ioBroker/wiki/Console-commands#iobroker-upload-adaptername)
      • Z Offline
        Z Offline
        Zippolighter
        Hi eric, danke für Deine Tipps.
        Leider ohne Erfolg. Der listener ist immer noch nicht da.
        Weisst Du ob ich irgendwie abfragen kann ob der Adapter admin.0 wirklich läuft??
        In den list instances wird er mir angezeigt mit enable und mit iobroker status heißt es iobroker ist running
        • eric2905E Offline
          eric2905E Offline
          eric2905
          schau mal hier (https://github.com/ioBroker/ioBroker/wi … oker-isrun)
          Schau mal, was
           iobroker isrun
          zurückgibt.
          Wie viele Admin-Instanzen werden Dir bei
           iobroker list adapters
          (ggf. kannst Du zur Eingrenzung auch
           iobroker list adapters | grep admin
          ````nehmen)
          angezeigt?
          Gruß,
          Eric
          Von unterwegs getippert
          • Z Offline
            Z Offline
            Zippolighter
            Ne, bringt alles leider keine Aussage.
            Habe admin.0. admin.1 habe ich nachinstalliert mit anderem port als admin.0 nicht erreichbar war. Beide admins öffnen kein listener port
            Ich hatte nach Anweisung in der Doku node deinstalliert. Hatte eine 4.x Version drauf. Nach der Neuinstallation habe ich eine 0.12.6 drauf. Admin war aber schon bei der alten node Version nicht erreichbar.
            Kann mir jemand sagen ob die Version funktioniert oder ob ich eine andere brauche und wie ich die installieren. War nach Anweisung in der Doku vorgegangen
            ` > Falls node.js neu installiert werden muss, dann muss man den erst deinstallieren:
            apt-get purge nodejs
            apt-get purge node
            apt-get autoremove
            reboot
            Und dann installieren (für RasPI):
            wget http://node-arm.herokuapp.com/node_archive_armhf.deb
            sudo dpkg -i node_archive_armhf.deb
            sudo apt-get install build-essential
            reboot `
            Auf jeden Fall ist jetzt nach einiger Zeit ca. 10 min der Raspberry 3 nicht mehr erreichbar und muss neugestartet werden (Speicher läuft leer).
            • eric2905E Offline
              eric2905E Offline
              eric2905
              Moin,
              welche Doku (bitte Link dazu) zieht Du heran?
              [edit bzw. Nachtrag]
              Ich denke, Du verwendest die falsche Doku.
              Daher die Nachfrage.
              Richtig wäre diese http://www.iobroker.net/docu/?page_id=5106&lang=de
              Dieser Teil passt nämlich überhaupt nicht
              <u>[/edit bzw. Nachtrag]</u>
              Gruß,
              Eric
              • Z Offline
                Z Offline
                Zippolighter
                Guten morgen Eric,
                ich habe die Doku genommen von iobroker läuft nicht mehr http://www.iobroker.net/docu/?page_id=3928&lang=de
                Da ist zum Thema node tatsächlich ja was ganz anderes drin.
                Werde ich erstmal anpassen.
                Gruß Zippolighter
                  STOP!
                  Diese Version gilt für Raspi 1
                  Für alle anderen bitte hier nach vorgehen!
                  http://www.iobroker.net/docu/?page_id=5 … ion_Nodejs
                  Muss ich am Wochenende korrigieren :oops:
                  • Z Offline
                    Z Offline
                    Zippolighter
                    Guten morgen Rainer,
                    dann hat es ja zumindest was gebracht, das ich meinen Raspi zerschossen habe.
                    Habe jetzt mir Eric wieder node V6 am laufen. Also soweit alles gut.
                    Leider funktioniert der Admin nicht (kein listener) werde wohl auf die Backups zurückgreifen müssen
                    Zippo
                    • eric2905E Offline
                      eric2905E Offline
                      eric2905
                      Nee, warte noch.
                      Deinstalliere alle Admins, die Du installiert hast.
                      Und dann installiere nur einen (admin.0) und reboot.
                      Dann mal schauen. Backup bzw. Restore kann man immer noch machen
                      Gruß,
                      Eric
                      • Z Offline
                        Z Offline
                        Zippolighter
                        Sorry, hat etwas länger gedauert, da ich parallel eine zweite Instanz vom iobroker installiert habe und dort das Backup eingespielt habe. Hier ist jetzt leider das Problem das im Karteireiter Scripte nur noch tab.html fehlt erscheint und alle Scripte weg sind. Aber hierfür mach ich einen neuen Post auf.
                        Bei der ursprünglichen habe ich beide admins deinstalliert. Reboot
                        Neuen admin installiert. Reboot
                        Instanz überprüft
                        > system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                        Listener überprüft auf Port 8081. Nicht vorhanden
                        • eric2905E Offline
                          eric2905E Offline
                          eric2905
                          Läßt sich der Admin nun aufrufen, oder nicht?
                          Welche Version js-controller, admin, web sind drauf?
                          Gruß,
                          Eric
                          • Z Offline
                            Z Offline
                            Zippolighter
                            Nur zur Info. Problem mit den nicht vorhandenen Scripten unter der Karteikarte Skripte konnte ich lösen.
                            Bluefox hatte dazu in einem anderen Post http://forum.iobroker.net/viewtopic.php … ound#p6967
                            den Hinweis gegeben > iobroker upload javascript
                            Habe jetzt eine zweite neue lauffähige instanz und kann mit der anderen weitere Sachen ausprobieren falls noch Ideen da sind
                            • Z Offline
                              Z Offline
                              Zippolighter
                              Nein admin lässt sich nicht aufrufen, da ja keine listener für 8081 da ist.
                              Versionen sind:
                              admin 2.0.2
                              web 2.1.3
                              js-controller 1.1.2
                              • eric2905E Offline
                                eric2905E Offline
                                eric2905
                                Hast Du es mal mit dem „normalen“ Aufruf im Browser probiert, oder nur die Ports abgefragt?
                                • Z Offline
                                  Z Offline
                                  Zippolighter
                                  Ja mache immer beides Browser und listener überprüfen.
                                  Den Port 8081 habe ich überprüft mit
                                  > netstat -n -a -p TCP |grep 8081
                                  Keine Ausgabe, also sollte der Port frei sein
