  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
  • N noidea
    Started iobroker ...
    [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/Generic-MassStorage/partition1","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
    [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups"
    [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
    mount error: Server abruptly closed the connection.
    This can happen if the server does not support the SMB version you are trying to use.
    The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
    mount error(112): Host is down
    Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
    [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,file_mode=0777,dir_mode=0777 //192.168.2.1/Generic-MassStorage/partition1 /opt/iobroker/backups
    Thomas BraunT Offline
    @noidea sagte in BackitUp NAS Error Speedport Smart 4:
    Welche Version von backitup läuft da eigentlich?
    N 1 Antwort Letzte Antwort
      N Offline
      N Offline
      noidea
      2.5.9
      Habe gerade gesehen, das die 2.5.10 Verfügbar ist. Aber irgendwie zweilfel ich daran, dass das alles ändern wird.
      • N noidea
        2.5.9
        @noidea
        Grundsätzlich hält man sein System auf Stand und fährt die letzten stabil verfügbaren Versionen.
        • N noidea
          2.5.9
          @noidea was sagt iobroker update -i?
            N Offline
            N Offline
            noidea
            @homoran sagte in BackitUp NAS Error Speedport Smart 4:
            iobroker update -i
            Ein paar Instanzen brauchen ein update, u.a. der BackitPu und der Admin. Die habe ich jetzt mal durchgeführt, aber die Fehlermedlung ist leider immer noch die selbe
            • N noidea
              iobroker update -i
              iobroker update -i
              das ist nicht die vollständige Ausgabe
                iobroker update -i
                N Offline
                N Offline
                noidea
                Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
                Adapter    "backitup"     : 2.5.10   , installed 2.5.10
                Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
                Adapter    "influxdb"     : 3.2.0    , installed 3.1.8  [Updatable]
                Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
                Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                Adapter    "modbus"       : 5.0.11   , installed 5.0.5  [Updatable]
                Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                Adapter    "robonect"     : 0.1.4    , installed 0.1.4
                Adapter    "sainlogic"    : 0.10.0   , installed 0.9.0  [Updatable]
                Adapter    "shelly"       : 6.0.0    , installed 6.0.0
                Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                Adapter    "terminal"     : 1.0.0    , installed 0.2.6  [Updatable]
                Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
                • N noidea
                  iobroker update -i
                  Das kann nicht sein, weil der Backitup-Adapter jetzt etwas anders gemountet wird. Die Meldung muss (leicht) anders sein.
                  Und bring die Kiste vollständig auf Stand.
                  • N noidea
                    @noidea wo kommt das jetzt her?
                    kein Prompt, kein Pfad, kein Befehl??
                      N Offline
                      N Offline
                      noidea
                      user@iobroker:~$ iobroker update -i
                      Used repository: stable
                      user@iobroker:~$
                      Das ist alles, was angezeigt wird, nicht mehr und nicht weniger.
                      Die nic. Nicht auf Stand gebrachten Instanzen, haben doch ersteinmal nichts mit dem Problem zu, oder?
                      • N noidea
                        user@iobroker:~$
                        @noidea
                        Und bring die Kiste vollständig auf Stand!
                        Wie schaut es beim OS aus?
                        sudo apt update
                          @noidea
                          sudo apt update
                          N Offline
                          N Offline
                          noidea
                          user@iobroker:~$ sudo apt update
                          [sudo] password for user:
                          Hit:1 https://repos.influxdata.com/debian jammy InRelease
                          Hit:2 https://deb.nodesource.com/node_16.x jammy InRelease
                          Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
                          Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
                          Get:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
                          Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [831 kB]
                          Get:7 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [566 kB]
                          Get:8 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [785 kB]
                          Get:9 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 c-n-f Metadata [14.6 kB]
                          Fetched 2422 kB in 2s (1226 kB/s)
                          Reading package lists... Done
                          61 packages can be upgraded. Run 'apt list --upgradable' to see them.
                          W: https://repos.influxdata.com/debian/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
                          user@iobroker:~$
                          • N noidea
                            user@iobroker:~$
                            War mir fast klar. Auch Update-Stau.
                            Alles updaten.
                              Alles updaten.
                              N Offline
                              N Offline
                              noidea
                              Das mach ich mit,richtig?
                              apt update
                              • N noidea
                                apt update
                                @noidea
                                Zuerst das influx-Repo korrigieren.
                                https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden/22
                                Dann
                                iob stop
                                sudo apt update
                                sudo apt full-upgrade
                                sudo reboot
                                  @noidea
                                  Dann
                                  iob stop
                                  sudo apt update
                                  sudo reboot
                                  N Offline
                                  N Offline
                                  noidea
                                  Hab jetzt alles uptodate, aber nachwievor die gleiche Fehlermeldung
                                  [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
                                  [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                  [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
                                  [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                  [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                  • N noidea
                                    @noidea
                                    smbclient -L 192.168.2.1 -U speedport
                                    Und
                                    ls -lA /opt/iobroker/backups
                                      @noidea
                                      Und
                                      N Offline
                                      N Offline
                                      noidea
                                      schrieb am zuletzt editiert von noidea
                                      user@iobroker:~$ smbclient -L 192.168.2.1 -U speedport
                                      Password for [WORKGROUP\speedport]:
                                              Sharename       Type      Comment
                                              speedport       Disk
                                              IPC$            IPC       IPC Service (Speedport Smart 4 Typ A File-Server)
                                      Reconnecting with SMB1 for workgroup listing.
                                              Server               Comment
                                              Workgroup            Master
                                              WORKGROUP            SPEEDPORT
                                      user@iobroker:~$ ls -lA /opt/iobroker/backups
                                      total 5416
                                      -rw-rw-r--+ 1 iobroker iobroker    5423 Jan 22 18:36 grafana_2023_01_22-18_36_10_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker    5420 Jan 22 19:59 grafana_2023_01_22-19_59_31_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker  141185 Jan 22 18:36 influxDB_2023_01_22-18_36_08_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker  143345 Jan 22 19:59 influxDB_2023_01_22-19_59_29_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 2563931 Jan 22 18:36 iobroker_2023_01_22-18_36_04_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker 2563010 Jan 22 19:59 iobroker_2023_01_22-19_59_25_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker    4691 Jan 22 18:36 jarvis.0_2023_01_22-18_36_15_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker    4691 Jan 22 19:59 jarvis.0_2023_01_22-19_59_36_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker   41159 Jan 22 18:36 javascripts_2023_01_22-18_36_15_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker   41157 Jan 22 19:59 javascripts_2023_01_22-19_59_36_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker    2685 Jan 22 18:36 zigbee.0_2023_01_22-18_36_09_backupiobroker.tar.gz
                                      -rw-rw-r--+ 1 iobroker iobroker    2681 Jan 22 19:59 zigbee.0_2023_01_22-19_59_30_backupiobroker.tar.gz
                                      user@iobroker:~$
                                      Der Ordner backups ist wieder voll. Muss ich wieder leeren,oder?
                                      Hab jetzt alles in dem Ordner gelöscht
                                      • N noidea
                                                speedport       Disk
                                                Server               Comment
                                                Workgroup            Master
                                                WORKGROUP            SPEEDPORT
                                        total 5416
                                        user@iobroker:~$
                                        Ja.
                                        sudo -u iobroker rm /opt/iobroker/backups/*
                                        Versuch mal von Hand zu mounten:
                                          Ja.
                                          N Offline
                                          N Offline
                                          noidea
                                          user@iobroker:/$ sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                                          mount error(13): Permission denied
                                          user@iobroker:/$
