  3. Einsteigerfragen
  4. InfluxDB - Daten weg / Wiederherstellung [gelöst]
    5.5k
142 Beiträge 7 Kommentatoren 26.8k Aufrufe 4 Beobachtet
  • N Naturfreund
    @glasfaser
    Nichts auffälliges zu finden. Schon gar nichts, was mit der Uhrzeit zusammen fällt.
    Ich habe so einen Verdacht, dass wenn die Datenbank eine Größe von >= 1,3 GB erreicht, es zu dem Problem kommt. We will see...
    GlasfaserG Offline
    GlasfaserG Offline
    #76
    @naturfreund sagte in InfluxDB - Daten weg / Wiederherstellung:
    Geheim ... poste es trotzdem mal
    N 1 Antwort Letzte Antwort
    • GlasfaserG Glasfaser
      N Offline
      N Offline
      Naturfreund
      #77
      @glasfaser
      [Fr Jan 13 15:18:33 2023] FS-Cache: Netfs 'cifs' registered for caching
      [Fr Jan 13 15:18:33 2023] Key type cifs.spnego registered
      [Fr Jan 13 15:18:33 2023] Key type cifs.idmap registered
      [Fr Jan 13 15:18:33 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
      [Fr Jan 13 15:18:33 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 15:18:34 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
      [Fr Jan 13 15:18:34 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 15:18:34 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
      [Fr Jan 13 15:18:34 2023] CIFS VFS: cifs_mount failed w/return code = -95
      [Fr Jan 13 15:21:12 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
      [Fr Jan 13 15:21:12 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 15:21:12 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 15:21:12 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
      [Fr Jan 13 15:21:12 2023] CIFS VFS: cifs_mount failed w/return code = -95
      [Fr Jan 13 15:21:50 2023] CIFS: Attempting to mount //192.168.1.99/volume1/Smart                                                          Home/ioBroker/backupDir
      [Fr Jan 13 15:21:50 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 15:21:50 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 15:21:50 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
      [Fr Jan 13 15:21:50 2023] CIFS VFS: cifs_mount failed w/return code = -95
      [Fr Jan 13 15:42:36 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 15:43:07 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 15:44:50 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 15:45:17 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 15:45:47 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 15:47:20 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 16:06:16 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:14:33 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:14:39 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:14:39 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 23:14:39 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:14:39 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 23:14:45 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:14:45 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 23:36:01 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:36:07 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:36:07 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 23:36:07 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:36:07 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 23:36:13 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:36:13 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 23:39:38 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:39:44 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:39:44 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Fr Jan 13 23:39:44 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Fr Jan 13 23:39:44 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Fr Jan 13 23:39:50 2023] CIFS VFS: Error connecting to socket. Aborting operati                                                          on.
      [Fr Jan 13 23:39:50 2023] CIFS VFS: cifs_mount failed w/return code = -2
      [Sa Jan 14 08:03:54 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [So Jan 15 08:03:55 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [So Jan 15 14:08:21 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mo Jan 16 08:03:56 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Di Jan 17 08:03:56 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 08:03:57 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 08:15:42 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 08:15:43 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 08:15:43 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Mi Jan 18 08:15:43 2023] FS-Cache: Duplicate cookie detected
      [Mi Jan 18 08:15:43 2023] FS-Cache: O-cookie c=4cff64b5 [p=fb6e51ba fl=222 nc=1                                                           na=1]
      [Mi Jan 18 08:15:43 2023] FS-Cache: O-cookie d=9dc44908 n=ee5fbc8a
      [Mi Jan 18 08:15:43 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
      [Mi Jan 18 08:15:43 2023] FS-Cache: N-cookie c=a1814f56 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
      [Mi Jan 18 08:15:43 2023] FS-Cache: N-cookie d=9dc44908 n=cefe596f
      [Mi Jan 18 08:15:43 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
      [Mi Jan 18 08:15:43 2023] CIFS VFS: \\192.168.1.99 Dialect not supported by serv                                                          er. Consider specifying vers=1.0 or vers=2.0 on mount for accessing older server                                                          s
      [Mi Jan 18 08:15:43 2023] CIFS VFS: cifs_mount failed w/return code = -95
      [Mi Jan 18 08:45:26 2023] printk: systemd: 42 output lines suppressed due to rat                                                          elimiting
      [Mi Jan 18 08:45:26 2023] systemd[1]: systemd 241 running in system mode. (+PAM                                                           +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GN                                                          UTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hie                                                          rarchy=hybrid)
      [Mi Jan 18 08:45:26 2023] systemd[1]: Detected architecture arm.
      [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:26: Unknown lvalue 'ProtectClock' in section 'Service', ignoring
      [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:29: Unknown lvalue 'ProtectHostname' in section 'Service', ignoring
      [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:30: Unknown lvalue 'ProtectKernelLogs' in section 'Service', ignoring
      [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:33: Unknown lvalue 'ProtectProc' in section 'Service', ignoring
      [Mi Jan 18 08:45:26 2023] systemd[1]: /usr/lib/systemd/system/grafana-server.ser                                                          vice:39: Unknown lvalue 'RestrictSUIDSGID' in section 'Service', ignoring
      [Mi Jan 18 08:45:26 2023] systemd[1]: Stopping Journal Service...
      [Mi Jan 18 08:45:26 2023] systemd-journald[112]: Received SIGTERM from PID 1 (sy                                                          stemd).
      [Mi Jan 18 08:45:26 2023] systemd[1]: systemd-journald.service: Succeeded.
      [Mi Jan 18 08:45:26 2023] systemd[1]: Stopped Journal Service.
      [Mi Jan 18 08:47:33 2023] Adding 102396k swap on /var/swap.  Priority:-2 extents                                                          :1 across:102396k SSFS
      [Mi Jan 18 08:47:51 2023] debugfs: File 'le_min_key_size' in directory 'hci0' al                                                          ready present!
      [Mi Jan 18 08:47:51 2023] debugfs: File 'le_max_key_size' in directory 'hci0' al                                                          ready present!
      [Mi Jan 18 09:01:42 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:19:32 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:21:34 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:21:34 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Mi Jan 18 17:21:34 2023] FS-Cache: Duplicate cookie detected
      [Mi Jan 18 17:21:34 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
      [Mi Jan 18 17:21:34 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
      [Mi Jan 18 17:21:34 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
      [Mi Jan 18 17:21:34 2023] FS-Cache: N-cookie c=392813d8 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
      [Mi Jan 18 17:21:34 2023] FS-Cache: N-cookie d=9dc44908 n=eecf4bf2
      [Mi Jan 18 17:21:34 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
      [Mi Jan 18 17:25:41 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:25:41 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Mi Jan 18 17:25:41 2023] FS-Cache: Duplicate cookie detected
      [Mi Jan 18 17:25:41 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
      [Mi Jan 18 17:25:41 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
      [Mi Jan 18 17:25:41 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
      [Mi Jan 18 17:25:41 2023] FS-Cache: N-cookie c=a288688c [p=fb6e51ba fl=2 nc=0 na                                                          =1]
      [Mi Jan 18 17:25:41 2023] FS-Cache: N-cookie d=9dc44908 n=6eb2b1f4
      [Mi Jan 18 17:25:41 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
      [Mi Jan 18 17:36:35 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:36:36 2023] CIFS: Attempting to mount //192.168.1.99/SmartHome/ioB                                                          roker/backupDir
      [Mi Jan 18 17:36:36 2023] No dialect specified on mount. Default has changed to                                                           a more secure dialect, SMB2.1 or later (e.g. SMB3), from CIFS (SMB1). To use the                                                           less secure SMB1 dialect to access old servers which do not support SMB3 (or SM                                                          B2.1) specify vers=1.0 on mount.
      [Mi Jan 18 17:36:36 2023] FS-Cache: Duplicate cookie detected
      [Mi Jan 18 17:36:36 2023] FS-Cache: O-cookie c=3532cb2c [p=fb6e51ba fl=222 nc=1                                                           na=1]
      [Mi Jan 18 17:36:36 2023] FS-Cache: O-cookie d=9dc44908 n=5ddd7c80
      [Mi Jan 18 17:36:36 2023] FS-Cache: O-key=[8] '020001bdc0a80163'
      [Mi Jan 18 17:36:36 2023] FS-Cache: N-cookie c=392813d8 [p=fb6e51ba fl=2 nc=0 na                                                          =1]
      [Mi Jan 18 17:36:36 2023] FS-Cache: N-cookie d=9dc44908 n=63f33383
      [Mi Jan 18 17:36:36 2023] FS-Cache: N-key=[8] '020001bdc0a80163'
      GlasfaserG crunchipC 3 Antworten Letzte Antwort
      • N Naturfreund
        @glasfaser
        GlasfaserG Offline
        GlasfaserG Offline
        #78
        @naturfreund
        Wenn du mal Zeit hast ... starte deine Kiste neu und dann das Log hier rein posten !
        N GlasfaserG 2 Antworten Letzte Antwort
        • N Naturfreund
          @glasfaser
          GlasfaserG Offline
          GlasfaserG Offline
          #79
          cifs_mount failed
          das ist das einzige was jetzt aktuell zu sehen ist , wie oft machst du ein Backup ...
          Edit :
          deine Backupeinstellungen würde ich auch mal überprüfen ... unabhängig davon:
          • N Naturfreund
            @glasfaser
            crunchipC Offline
            crunchipC Offline
            #80
            @naturfreund und was ist mit den großen Uhrzeitsprüngen?
            Ggf auch mal mit 'top' nachsehen mit welcher Last die Kiste läuft
              @naturfreund
              N Offline
              N Offline
              Naturfreund
              #81
              @glasfaser
              Ich hab das NAS neu eingebunden. Hatte ich bisher nicht. Den User den ich im NAS abgelegt hatte, der hatte nicht die nötigen Rechte.
              Die Meldung mit der SMB Version hab ich auch schon gesehen. Meine NAS unterstützt bis SMB 3 alles und so hab ich es auch konfiguriert:
              Im Synology Adapter kann ich nichts weiter zum SMB Dienst einstellen.
              Backup läuft täglich um 8:00 Uhr.
              Du hattest recht, im Backitup war noch SMB 1.0 eingetragen.
                N Offline
                N Offline
                Naturfreund
                schrieb am zuletzt editiert von Naturfreund
                #82
                @crunchip
                Welche Uhrzeitsprünge meinst du? Weil im Log ne längere Zeit nichts passiert?
                Also mich wundert das nicht, nachdem vom 10. Juni bis 13. Januar kein Eintrag drin war.
                top - 22:22:10 up 222 days,  9:05,  1 user,  load average: 0,37, 0,58, 0,60
                Tasks: 139 total,   4 running, 135 sleeping,   0 stopped,   0 zombie
                %Cpu(s): 16,0 us,  2,2 sy,  0,0 ni, 81,4 id,  0,0 wa,  0,0 hi,  0,4 si,  0,0 st
                MiB Mem :   7875,9 total,   2868,3 free,   1567,3 used,   3440,3 buff/cache
                MiB Swap:    100,0 total,    100,0 free,      0,0 used.   6258,6 avail Mem
                crunchipC GlasfaserG 2 Antworten Letzte Antwort
                • N Naturfreund
                  @crunchip
                  crunchipC Offline
                  crunchipC Offline
                  #83
                  @naturfreund solltes wirklich mal neu starten, zwischendrin vllt mal grössere Upgrades gefahren, welche einen reboot benötigen?
                  Es gibt doch auch ein log für influx (var/log/syslog), sind da irgendwelche Meldungen
                  • N Naturfreund
                    @crunchip
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #84
                    up 222 days
                    ... Uih ....... 😵
                    @glasfaser sagte in InfluxDB - Daten weg / Wiederherstellung:
                    @naturfreund
                    ebenfalls schonmal erwähnt ....
                    • N Offline
                      N Offline
                      Naturfreund
                      #85
                      Never change a running system 😂
                      • N Naturfreund
                        #86
                        @naturfreund
                        Dementsprechend regiert bei Updates auch der Gammel, oder?
                        Pack das System an!
                          @naturfreund
                          Pack das System an!
                          N Offline
                          N Offline
                          Naturfreund
                          #87
                          Ne, das ist up to date (Adapter, Grafana, Influx)
                          Was meinst du mit Pack das System an?
                          • N Naturfreund
                            #88
                            @naturfreund
                            sudo apt update
                            zeigen.
                              @naturfreund
                              sudo apt update
                              zeigen.
                              N Offline
                              N Offline
                              Naturfreund
                              #89
                              Connecting to 192.168.1.100 port 22, please wait...
                              login as: pi pi@192.168.1.100's password:
                              Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l
                              The programs included with the Debian GNU/Linux system are free software;
                              the exact distribution terms for each program are described in the
                              individual files in /usr/share/doc/*/copyright.
                              Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                              permitted by applicable law.
                              Last login: Thu Jan 19 20:12:17 2023 from 192.168.1.67
                              pi@raspberrypi:~ $ sudo apt update
                              0% [Wird verarbeitet]
                              Holen:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB]
                              0% [1 InRelease 0 B/15,0 kB 0%] [Verbunden mit archive.raspbian.org (93.93.128.
                              0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Verbunden mit apt.graf
                              OK:2 https://repos.influxdata.com/debian buster InRelease
                              Holen:3 https://apt.grafana.com stable InRelease [5.984 B]
                              0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [3 InRelease 2.742 B/5.
                              0% [Verbunden mit archive.raspbian.org (93.93.128.191)] [Warten auf Kopfzeilen]
                              OK:4 https://deb.nodesource.com/node_16.x buster InRelease
                              0% [Warten auf Kopfzeilen] [Warten auf Kopfzeilen]
                              Holen:5 http://archive.raspberrypi.org/debian buster InRelease [32,6 kB]
                              0% [Warten auf Kopfzeilen] [5 InRelease 2.705 B/32,6 kB 8%]
                              Holen:6 https://archive.raspbian.org/raspbian buster InRelease [15,0 kB]
                              0% [6 InRelease 15,0 kB/15,0 kB 100%] [5 InRelease 23,0 kB/32,6 kB 70%]
                              0% [5 InRelease 23,0 kB/32,6 kB 70%]
                              Holen:7 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB]
                              0% [7 Packages 14,2 kB/13,0 MB 0%]
                              0% [7 Packages 3.997 kB/13,0 MB 31%]
                              0% [7 Packages 12,5 MB/13,0 MB 96%]
                              0% [7 Packages store 0 B]
                              Holen:8 https://archive.raspbian.org/raspbian buster/main Sources [11,4 MB]
                              0% [7 Packages store 0 B] [8 Sources 32,5 kB/11,4 MB 0%]
                              53% [7 Packages store 0 B] [8 Sources 3.260 kB/11,4 MB 29%]
                              Holen:9 http://archive.raspberrypi.org/debian buster/main armhf Packages [392 kB]
                              58% [7 Packages store 0 B] [8 Sources 5.292 kB/11,4 MB 47%] [9 Packages 1.221 B
                              64% [7 Packages store 0 B] [8 Sources 7.811 kB/11,4 MB 69%]
                              71% [7 Packages store 0 B]
                              Holen:10 https://archive.raspbian.org/raspbian buster/main armhf Packages [13,0 MB]
                              71% [7 Packages store 0 B] [10 Packages 24,6 kB/13,0 MB 0%]
                              88% [7 Packages store 0 B] [10 Packages 8.081 kB/13,0 MB 62%]
                              99% [7 Packages store 0 B]
                              99% [7 Packages store 0 B]                                       6.075 kB/s 0 s
                              99% [Wird verarbeitet]                                           6.075 kB/s 0 s
                              99% [9 Packages store 0 B]                                       6.075 kB/s 0 s
                              99% [8 Sources store 0 B]                                        6.075 kB/s 0 s
                              100% [Wird verarbeitet]                                          6.075 kB/s 0 s
                              100% [10 Packages store 0 B]                                     6.075 kB/s 0 s
                              Es wurden 37,9 MB in 25 s geholt (1.513 kB/s).
                              Paketlisten werden gelesen... 0%
                              Paketlisten werden gelesen... 24%
                              Paketlisten werden gelesen... 42%
                              Paketlisten werden gelesen... 48%
                              Paketlisten werden gelesen... 49%
                              Paketlisten werden gelesen... 90%
                              Paketlisten werden gelesen... 97%
                              Paketlisten werden gelesen... 98%
                              Paketlisten werden gelesen... 99%
                              Paketlisten werden gelesen... Fertig
                              Abhängigkeitsbaum wird aufgebaut.... 0%
                              Abhängigkeitsbaum wird aufgebaut.... 50%
                              Statusinformationen werden eingelesen.... 0%
                              Statusinformationen werden eingelesen.... Fertig
                              Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
                              pi@raspberrypi:~ $
                              • N Naturfreund
                                pi@raspberrypi:~ $
                                #90
                                @naturfreund
                                Buster ist tot. Geh auf das aktuelle stable-Release Bullseye.
                                  @naturfreund
                                  N Offline
                                  N Offline
                                  Naturfreund
                                  #91
                                  Wie mache ich das?
                                  Google fördert 2 unterschiedliche Vorgehensweisen zu Tage. Kann nicht einschätzen welche davon "richtiger" ist.
                                  • N Naturfreund
                                    Wie mache ich das?
                                    #92
                                    @naturfreund
                                    Hab ich mal ein kleines HowTo zu geschrieben. Schau durch meine Themen durch.
                                    • N Naturfreund
                                      Wie mache ich das?
                                      #93
                                      @naturfreund
                                      https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
                                      Ich würde aber wohl auf ein 64bit-Release wechseln, wenn dein Raspi das kann. Muss allerdings dann komplett neuinstalliert werden, ein Wechsel der Architektur ist so nicht möglich.
                                        @naturfreund
                                        N Offline
                                        N Offline
                                        Naturfreund
                                        #94
                                        Ich finde deine Beiträge immer echt super. Die haben mir schon ein paar mal weiter geholfen. Würde auch auf 64 Bit wechseln wollen, den Aufwand muss ich aber zeitlich dahin verlagern wo ich auch genug Zeit habe mich damit auseinander zu setzen.
                                        Ich aktualisiere jetzt erst mal nach deinem Tutorial.
                                        pi@raspberrypi:~ $ neofetch
                                          `.::///+:/-.        --///+//-:``    pi@raspberrypi
                                         `+oooooooooooo:   `+oooooooooooo:    --------------
                                          /oooo++//ooooo:  ooooo+//+ooooo.    OS: Raspbian GNU/Linux 11 (bullseye) armv
                                          `+ooooooo:-:oo-  +o+::/ooooooo:     Host: Raspberry Pi 4 Model B Rev 1.4
                                           `:oooooooo+``    `.oooooooo+-      Kernel: 5.15.84-v7l+
                                             `:++ooo/.        :+ooo+/.`       Uptime: 9 mins
                                                ...`  `.----.` ``..           Packages: 714 (dpkg)
                                             .::::-``:::::::::.`-:::-`        Shell: bash 5.1.4
                                            -:::-`   .:::::::-`  `-:::-       Terminal: /dev/pts/0
                                           `::.  `.--.`  `` `.---.``.::`      CPU: BCM2711 (4) @ 1.500GHz
                                               .::::::::`  -::::::::` `       Memory: 1221MiB / 7898MiB
                                        top - 22:55:01 up 3 min,  1 user,  load average: 1,04, 0,91, 0,40
                                        Tasks: 161 total,   1 running, 160 sleeping,   0 stopped,   0 zombie
                                        %CPU(s): 11,9 us,  1,7 sy,  0,0 ni, 85,5 id,  0,1 wa,  0,0 hi,  0,8 si,  0,0 st
                                        MiB Spch:   7898,9 total,   6200,7 free,   1211,3 used,    486,9 buff/cache
                                        MiB Swap:    100,0 total,    100,0 free,      0,0 used.   6805,6 avail Spch
                                        Läuft, danke dir!
                                        • N Naturfreund
                                          ich hatte es bereits in einem älteren Topic probiert, wollte keinen neuen Thread starten.
                                          Da es bislang keine Antworten gibt, mache ich doch einen neuen auf.
                                          Die Daten in einem gewissen Zeitraum sind bei mir in der InfluxDB einfach verschwunden.
                                          Der Zeitraum beginnt genau bei 0:00 Uhr eines Tages und endet auch bei 0:00 Uhr eines Folgetages. Das ist mir jetzt bereits im Dezember und nun auch im Januar wieder passiert.
                                          Mit Backitup sichere ich die InfluxDB. Eine Wiederherstellung hat bisher nichts gebracht.
                                          Ich verstehe es einfach nicht.
                                          Heute morgen hatte ich im Log von ioBroker folgenden Eintrag gefunden:
                                          2023-01-11 05:10:05.356 - error: influxdb.0 (13722) Error: connect ECONNREFUSED 127.0.0.1:8086
                                          2023-01-11 05:10:15.357 - info: influxdb.0 (13722) Connecting http://localhost:8086/ ...
                                          Ich komm hier alleine nicht mehr weiter
                                          N Offline
                                          N Offline
                                          Naturfreund
                                          #95
                                          Ich hab jetzt nochmal die Historie in einem Post zusammen gefasst.
                                          @naturfreund said in InfluxDB - Daten weg / Wiederherstellung:
                                          Nach dem Update sind Daten die in der Vergangenheit schon mal weg waren, wieder aufgetaucht (nach dem 13.01.2023) :
                                          Vor der Update auf bullseye gab es 3 Einträge ECONNREFUSED, aber anscheinend ohne die Auswirkung, das weitere Daten verschwinden.
                                          2023-01-19 15:03:16.967 - info: shelly.0 (11384) [MQTT] Device 192.168.1.113 (shellyht / shellyht-F4423D / SHHT-1#F4423D#1) connected! Polltime set to 5 sec.
                                          2023-01-19 15:03:44.307 - info: influxdb.0 (15156) Store 1001 buffered influxDB history points
                                          2023-01-19 15:03:44.377 - warn: influxdb.0 (15156) Error on writeSeries: Error: connect ECONNREFUSED 127.0.0.1:8086
                                          2023-01-19 15:03:44.378 - info: influxdb.0 (15156) Host not available, move all points back in the Buffer
                                          2023-01-19 15:03:54.381 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                                          2023-01-19 15:03:54.381 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                                          2023-01-19 15:03:54.389 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                                          2023-01-19 15:04:04.389 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                                          2023-01-19 15:04:04.390 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                                          2023-01-19 15:04:04.396 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                                          2023-01-19 15:04:14.397 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                                          2023-01-19 15:04:14.397 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                                          2023-01-19 15:04:14.404 - error: influxdb.0 (15156) Error: connect ECONNREFUSED 127.0.0.1:8086
                                          2023-01-19 15:04:24.405 - info: influxdb.0 (15156) Connecting http://127.0.0.1:8086/ ...
                                          2023-01-19 15:04:24.406 - info: influxdb.0 (15156) Influx DB Version used: 1.x
                                          2023-01-19 15:04:24.703 - info: influxdb.0 (15156) Store 1424 buffered influxDB history points
