  4. [gelöst] Animationen in der Iobroker app laufen nicht
13 Beiträge 5 Kommentatoren 465 Aufrufe 4 Beobachtet
  • J Offline
    Joschi1711
    Hallo Leute,
    ich habe unter Vis ein HTML Widget mit css angelegt, welchen im Browser läuft, allerdings auf dem Tablet mit der App nicht.
    kann da wer was dazu sagen?
    [{"tpl":"tplHqCircle","data":{"g_fixed":true,"g_visibility":true,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":"true","visibility-groups-action":"hide","oid":"","displayPrevious":true,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_center":true,"descriptionLeft":"active media progress","hideNumber":true,"angleOffset":"0","oid-working":"","caption":"","oid-battery":"","oid-signal":"","g_value":false,"min":"0","max":"100","digits":"0","step":"1","is_comma":"true","angleArc":"1","class":"spinnerright ","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_style":true,"thickness":"0.2","color":"#8a8a8a","bgcolor":"#25f613","linecap":false,"cursor":"","anticlockwise":false,"visibility-oid":"sonos.0.root.10_10_20_222.state_simple"},"style":{"left":"492px","top":"269px","width":"140px","height":"140px","z-index":"25","box-shadow":"0px 0px 25px #8a8a8a","border-radius":"270px","border-width":"","border-style":"","margin-left":"","border-color":"","background":"","background-color":"transparent","padding-left":"","padding":"","padding-top":"","padding-bottom":"","margin-bottom":""},"widgetSet":"hqwidgets"}]
    css
    .spinnerleft {
    animation-name: spin;
    animation-duration: 5000ms;
    animation-iteration-count: infinite;
    animation-timing-function: linear;
    @keyframes spin {
      from {
          transform:rotate(360deg);
      to {
          transform:rotate(0deg);
    .spinnerright {
    animation-name: spin2;
    @keyframes spin2 {
      from {
      to {
    Raspberrymatic x86,
    iobroker
    Plattform linux
    Architektur x64
    CPUs 4
    Geschwindigkeit 3092 MHz
    Modell Common KVM processor
    RAM 2.88 GB
    Node.js v14.19.1
    NPM 6.14.16
    Aktive Instanzen 35
    • J Joschi1711
      Hallo Leute,
      css
      .spinnerleft {
      @keyframes spin {
        from {
        to {
      .spinnerright {
      @keyframes spin2 {
        from {
        to {
      DJMarc75D Offline
      DJMarc75D Offline
      DJMarc75
      @joschi1711 in der APP in Deinem Netzwerk lokal oder von extern ?
      Lehrling seit 1975 !!!
      • DJMarc75D DJMarc75
        Joschi1711
        @djmarc75 in der App Lokal
        Grafik ist da, rotiert nur leider nicht.
        Iobroker ist allerding in anderem Netzwerk (VLAN) wie die Tablets.
        Raspberrymatic x86,
        iobroker
        Plattform linux
        Architektur x64
        CPUs 4
        RAM 2.88 GB
        Node.js v14.19.1
        NPM 6.14.16
        Aktive Instanzen 35
        DJMarc75D CodierknechtC OliverIOO 3 Antworten Letzte Antwort
        • J Joschi1711
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          @joschi1711 sagte in Animationen in der Iobroker app laufen nicht:
          ok, also quasi dann doch "extern" ... aber bei sowas wie VLAN kann ich leider nicht helfen, sorry.... da gibts bestimmt aber Hilfe - bissle warten 🤙
          • J Joschi1711
            CodierknechtC Offline
            Codierknecht
            @joschi1711
            1.) Anderes VLAN ist - wie @DJMarc75 schon schrieb - ja auch quasi "extern".
            2.) Welches Endgerät? Vielleicht wird das CSS auch nicht vollständig unterstützt?
            https://developer.mozilla.org/en-US/docs/Web/CSS/animation-duration?retiredLocale=de#browser_compatibility
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
            • CodierknechtC Codierknecht
              @joschi1711
              Joschi1711
              das Problem ist gelöst, die App Iobroker.vis musste neu installiert werden, da warscheinlich beim Neustart doch nicht alles von Server neu geladen wird. nach neuer Installation wurden alle CSS Einträge geladen und die Rotation funktioniert.
              Getestet auf Lenovo Tablet Android 10 und Samsung Tablet Android 7.
              Eben nochmal mit Samsung TAB3 und Android 9 getestet, ein resync in den App-Einstellung hilft auch.
              Danke an Codierknecht und DJMarc75.
              Raspberrymatic x86,
              iobroker
              Plattform linux
              Architektur x64
              CPUs 4
              RAM 2.88 GB
              Node.js v14.19.1
              NPM 6.14.16
              Aktive Instanzen 35
              • J Joschi1711
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @joschi1711 sagte in [gelöst] Animationen in der Iobroker app laufen nicht:
                wenn die grafik da ist, dann greift das css nicht.
                leider ist das oben ganz übel formatiert.
                kannst du das nochmal richtig in die code Tags setzen?
                Knopf </>
                Meine Adapter und Widgets
                Links im Profil
                J HomoranH 3 Antworten Letzte Antwort
                • OliverIOO OliverIO
                  Knopf </>
                  Joschi1711
                  @oliverio so schaut die css aus (geändert)
                  diese liegt global und ein Widget (Image) hat das in den Generell als CSS-Klasse stehen
                  .drehen {
                    -webkit-animation: rotate 4s linear infinite;
                  @-webkit-keyframes rotate {
                    0% {
                     -webkit-transform: rotate(0deg);
                    100% {
                      -webkit-transform: rotate(360deg);
                  Raspberrymatic x86,
                  iobroker
                  Plattform linux
                  Architektur x64
                  CPUs 4
                  RAM 2.88 GB
                  Node.js v14.19.1
                  NPM 6.14.16
                  Aktive Instanzen 35
                    Knopf </>
                    Joschi1711
                    wie geschrieben, nach resync der App hat er die CSS genommen, nach normalen Neustart nicht, obwohl der Haken für alles immer von Server laden gesetzt ist.
                    Raspberrymatic x86,
                    iobroker
                    Plattform linux
                    Architektur x64
                    CPUs 4
                    RAM 2.88 GB
                    Node.js v14.19.1
                    NPM 6.14.16
                    Aktive Instanzen 35
                    • J Joschi1711
                      Joschi1711
                      hier nochmal die andere Variante, welche hier aus dem Forum stammt:
                      die CSS
                       .spinnerleft {
                      @keyframes spin {
                        from {
                        to {
                      .spinnerright {
                      @keyframes spin2 {
                        from {
                        to {
                      Das Widget
                       [{"tpl":"tplHqCircle","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":true,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","oid":"","displayPrevious":true,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"g_center":true,"descriptionLeft":"active media progress","hideNumber":true,"angleOffset":"0","oid-working":"","caption":"","oid-battery":"","oid-signal":"","g_value":false,"min":"0","max":"100","digits":"0","step":"1","is_comma":"true","angleArc":"1","class":"spinnerright ","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"g_style":true,"thickness":"0.05","color":"#8a8a8a","bgcolor":"#8a8a8a","linecap":true,"cursor":"","anticlockwise":false},"style":{"left":"669px","top":"42px","width":"240px","height":"240px","z-index":"21","box-shadow":"0px 0px 25px #8a8a8a","border-radius":"270px","border-width":"","border-style":"","margin-left":"","border-color":"","background":"","background-color":"transparent","padding-left":"","padding":"","padding-top":"","padding-bottom":"","margin-bottom":""},"widgetSet":"hqwidgets"}]
                      Raspberrymatic x86,
                      iobroker
                      Plattform linux
                      Architektur x64
                      CPUs 4
                      RAM 2.88 GB
                      Node.js v14.19.1
                      NPM 6.14.16
                      Aktive Instanzen 35
                      • J Joschi1711
                        .drehen {
                          0% {
                          100% {
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @joschi1711
                        also das funktioniert jetzt?
                        wenn du überall noch das webkit wegmachst, dann dürfte es auf jeder art von browser laufen.
                        Links im Profil
                          Knopf </>
                          HomoranH Offline
                          HomoranH Offline
                          @oliverio sagte in [gelöst] Animationen in der Iobroker app laufen nicht:
                          sag das doch!
                          Hab oben die code-tags korrigiert
                            @joschi1711
                            Joschi1711
                            Jap, es funktioniert.
                            war Fehler der Iobroker-VIS App.
                            nochmal vielen Dank.
                            Raspberrymatic x86,
                            iobroker
                            Plattform linux
                            Architektur x64
                            CPUs 4
                            RAM 2.88 GB
                            Node.js v14.19.1
                            NPM 6.14.16
                            Aktive Instanzen 35
