  4. Welche HW, der PI4 scheint zu langsam
    5.4k
21 Beiträge 4 Kommentatoren 2.7k Aufrufe 4 Beobachtet
  • M manu4771
    da schua an, nach dem fix hat es funktionert.
    reicht dir die Zusammenfassung?
    v.2022-12-31
    Operatingsystem: Raspbian GNU/Linux 10 (buster)
    Installation: Native
    Timezone: Europe/Berlin
    User-ID: 1000
    X-Server: true
    Boot Target: graphical.target
    Pending OS-Updates: 0
    Nodejs-Installation: /usr/bin/nodejs v14.21.1
    /usr/bin/node v14.21.1
    /usr/bin/npm 6.14.17
    ioBroker Core: js-controller 4.0.23
    admin 6.2.23
    ioBroker Status: iobroker is running on this host.
    Objects type: jsonl
    States type: jsonl
    Status admin:
    • system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    Pending iob updates: 18
    Active repo(s): stable
    Objects: 18240
    States: 15338
    Size of iob-Database:
    18M /opt/iobroker/iobroker-data/objects.jsonl
    4.6M /opt/iobroker/iobroker-data/states.jsonl
    Bin selbst drauf gekommen, NEIN!
    Skript v.2022-12-31
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.2
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     20:46:10 up 2 days, 18:32,  2 users,  load average: 1.71, 1.83, 1.21
    CPU threads: 4
    *** Time and Time Zones ***
    Fri Jan  6 19:46:10 UTC 2023
    Fri Jan  6 20:46:10 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       true
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.4G        1.0G        220M        1.4G        2.4G
    Swap:           99M          0B         99M
    Total:         3.9G        1.4G        1.1G
             3838 M total memory
             1399 M used memory
              607 M active memory
             1986 M inactive memory
             1023 M free memory
              202 M buffer memory
             1213 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       59G  6.5G   50G  12% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  5.0M  1.9G   1% /dev/shm
    tmpfs          tmpfs     1.9G  177M  1.8G  10% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M  8.0K  384M   1% /run/user/1000
    TARGET                SOURCE         FSTYPE          OPTIONS
    /                     /dev/mmcblk0p2 ext4            rw,noatime,commit=600
    |-/sys/fs/bpf         none           bpf             rw,nosuid,nodev,noexec,relatime,mode=700
    |-/run/user/1000/gvfs gvfsd-fuse     fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
    `-/boot               /dev/mmcblk0p1 vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    858M    /var/
    506M    /var/cache
    494M    /var/cache/apt
    434M    /var/cache/apt/archives
    126M    /var/lib
    /opt/iobroker/backups:
    205M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    423M    /opt/iobroker/iobroker-data/
    339M    /opt/iobroker/iobroker-data/files
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    59M     /opt/iobroker/iobroker-data/backup-objects
    48M     /opt/iobroker/iobroker-data/files/javascript.admin
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
    6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
    6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
    *** NodeJS-Installation ***
    nodejs:
      Installed: 14.21.1-deb-1nodesource1
      Candidate: 14.21.1-deb-1nodesource1
      Version table:
     *** 14.21.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.2.23
    javascript:     6.0.3
    Adapters from github:   8
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
    + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
    + system.adapter.deconz.0                 : deconz                : raspberrypi                              -  enabled, port: 80
      system.adapter.devices.0                : devices               : raspberrypi                              -  enabled
      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi                              -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi                              -  enabled
    + system.adapter.harmony.0                : harmony               : raspberrypi                              -  enabled
    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
    + system.adapter.hue.0                    : hue                   : raspberrypi                              -  enabled, port: 443
      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.3                   : ical                  : raspberrypi                              -  enabled
      system.adapter.ical.4                   : ical                  : raspberrypi                              -  enabled
      system.adapter.icons-material-png.0     : icons-material-png    : raspberrypi                              -  enabled
      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              -  enabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: raspberrypi                              -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi                              -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
      system.adapter.kodi.0                   : kodi                  : raspberrypi                              - disabled, port: 9090
    + system.adapter.linkeddevices.0          : linkeddevices         : raspberrypi                              -  enabled
      system.adapter.luftdaten.0              : luftdaten             : raspberrypi                              -  enabled
    + system.adapter.meross.0                 : meross                : raspberrypi                              -  enabled
      system.adapter.mihome-lamp.1            : mihome-lamp           : raspberrypi                              - disabled, port: 54321
      system.adapter.mobile-alerts.0          : mobile-alerts         : raspberrypi                              -  enabled
    + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
      system.adapter.rickshaw.0               : rickshaw              : raspberrypi                              -  enabled
      system.adapter.roomba.0                 : roomba                : raspberrypi                              - disabled
      system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
      system.adapter.simple-api.0             : simple-api            : raspberrypi                              - disabled, port: 8087, bind: 0.0.0.0, run as: admin
      system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi                              -  enabled, port: 1883, bind: 192.168.2.2
    + system.adapter.sony-bravia.0            : sony-bravia           : raspberrypi                              -  enabled
      system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              - disabled
    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
      system.adapter.tuya.0                   : tuya                  : raspberrypi                              - disabled
      system.adapter.vis-bars.0               : vis-bars              : raspberrypi                              -  enabled
      system.adapter.vis-colorpicker.0        : vis-colorpicker       : raspberrypi                              -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi                              -  enabled
      system.adapter.vis-google-fonts.0       : vis-google-fonts      : raspberrypi                              -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi                              -  enabled
      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              -  enabled
    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi                              -  enabled
      system.adapter.vis-lcars.0              : vis-lcars             : raspberrypi                              -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi                              -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi                              -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi                              -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi                              -  enabled
      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
    + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 192.168.2.2, run as: admin
    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
      system.adapter.windows-control.0        : windows-control       : raspberrypi                              - disabled
    + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
      system.adapter.yeelight-2.0             : yeelight-2            : raspberrypi                              - disabled
      system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled
    + instance is alive
    ioBroker-Repositories
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "admin"        : 6.3.5    , installed 6.2.23 [Updatable]
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.9    , installed 2.4.12 [Updatable]
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "deconz"       : 1.3.21   , installed 1.3.21
    Adapter    "devices"      : 1.1.2    , installed 1.0.12 [Updatable]
    Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.19 [Updatable]
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "history"      : 2.2.4    , installed 2.2.0  [Updatable]
    Adapter    "homekit-controller": 0.5.1, installed 0.5.1
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "ical"         : 1.13.2   , installed 1.13.1 [Updatable]
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "javascript"   : 6.1.4    , installed 6.0.3  [Updatable]
    Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
    Adapter    "kodi"         : 2.0.8    , installed 2.0.8
    Adapter    "linkeddevices": 1.5.5    , installed 1.5.5
    Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "mihome-lamp"  : 1.1.0    , installed 1.1.0
    Adapter    "pi-hole"      : 1.3.4    , installed 1.3.4
    Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
    Adapter    "roomba"       : 1.1.4    , installed 1.1.4
    Adapter    "simple-api"   : 2.7.2    , installed 2.7.0  [Updatable]
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "sony-bravia"  : 1.0.9    , installed 1.0.9
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
    Adapter    "tankerkoenig" : 3.1.0    , installed 2.1.1  [Updatable]
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.16 [Updatable]
    Adapter    "tuya"         : 3.12.1   , installed 3.8.1  [Updatable]
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-google-fonts": 1.0.4 , installed 1.0.3  [Updatable]
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.89.0 [Updatable]
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.5  [Updatable]
    Adapter    "weatherunderground": 3.4.2, installed 3.4.2
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.2  [Updatable]
    Adapter    "windows-control": 0.1.5  , installed 0.1.5
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "yeelight-2"   : 1.1.2    , installed 1.1.2
    Adapter    "zigbee"       : 1.8.10   , installed 1.7.5  [Updatable]
    Objects and States
    Objects:        18227
    States:         15325
    Hit:1 http://phoscon.de/apt/deconz buster InRelease
    Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:3 http://archive.raspberrypi.org/debian buster InRelease
    Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      1000       27036      1775/deCONZ
    tcp        0      0 192.168.2.2:8082        0.0.0.0:*               LISTEN      1001       10738821   17212/io.web.0
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          17191      564/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17241      558/sshd
    tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          7392835    3926/cupsd
    tcp        0      0 0.0.0.0:8088            0.0.0.0:*               LISTEN      1000       27191      1775/deCONZ
    tcp        0      0 192.168.2.2:1883        0.0.0.0:*               LISTEN      1001       10726888   15105/io.sonoff.0
    tcp        0      0 127.0.0.1:33345         0.0.0.0:*               LISTEN      1001       10738142   17408/io.yahka.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       10723191   14262/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10723184   14262/iobroker.js-c
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10723285   14341/io.admin.0
    tcp6       0      0 :::53                   :::*                    LISTEN      0          17193      564/dnsmasq
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17251      558/sshd
    tcp6       0      0 ::1:3350                :::*                    LISTEN      0          18655      546/xrdp-sesman
    tcp6       0      0 ::1:631                 :::*                    LISTEN      0          7392834    3926/cupsd
    tcp6       0      0 :::3389                 :::*                    LISTEN      115        18283      581/xrdp
    tcp6       0      0 :::33605                :::*                    LISTEN      1001       10738049   17408/io.yahka.0
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       10731009   15750/io.harmony.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       10731010   15750/io.harmony.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          17190      564/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          20547      455/dhcpcd
    udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          7392854    3927/cups-browsed
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       10738050   17408/io.yahka.0
    udp        0      0 192.168.2.240:5353      0.0.0.0:*                           1001       10725358   15215/io.tr-064.0
    udp        0      0 192.168.2.2:5353        0.0.0.0:*                           1001       10725357   15215/io.tr-064.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14998      363/avahi-daemon: r
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10728750   15591/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       10728747   15591/io.deconz.0
    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       27202      1775/deCONZ
    udp        0      0 0.0.0.0:34690           0.0.0.0:*                           108        15000      363/avahi-daemon: r
    udp6       0      0 :::45582                :::*                                108        15001      363/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          20927      455/dhcpcd
    udp6       0      0 :::53                   :::*                                0          17192      564/dnsmasq
    udp6       0      0 :::5353                 :::*                                108        14999      363/avahi-daemon: r
    udp6       0      0 :::1900                 :::*                                1001       10728752   15591/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       10728751   15591/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       10728749   15591/io.deconz.0
    udp6       0      0 :::1900                 :::*                                1001       10728748   15591/io.deconz.0
    2023-01-06 20:47:06.126  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:06.127  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:06.128  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:06.129  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:06.130  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:06.131  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.004  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.006  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.007  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.008  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.009  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.010  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.011  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:13.012  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.114  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.115  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.116  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.117  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.118  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.119  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.120  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.122  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    2023-01-06 20:47:16.123  - error: pi-hole.0 (16615) Error: connect EHOSTUNREACH 192.168.2.5:80
    Da piHole aktuell nicht läuft habe ich die Instanz mal gleich gestoppt. =)
    @manu4771
    Das reicht zumindest um zu sehen, dass du da auf einem toten System mit graphischer Oberfläche, alter nodejs-Version und 18 verpennten iob-Updates unterwegs bist.
    Da könntest du mit Sicherheit noch einiges herauskitzeln. Alleine der X-Server bringt schon einiges an unnötigem Ballast mit.
      @manu4771
      manu4771
      Die graphische Oberfläche war tatsächlich gewollt, da ich DeConz gerne in der GUI bediene.
      Soll jetzt keine Ausrede sein, die Adapater könnten sich aber gerne automatisch installieren. Wenn das System nur laufen soll will ich mich nicht ständig damit beschäfftigen MÜSSEN.
      Ist das Linux wirklich schon out-dated und bekomme es nicht mehr hochgezogen ohne neuinstallation?
      • M manu4771
        @manu4771 sagte in Welche HW, der PI4 scheint zu langsam:
        Ja. Buster ist im September 2022 dahingeschieden. Nach den bei Debian üblichen 3 Jahren mit einem Jahr Parallelbetrieb zur aktuellen Stable 'Bullseye'. Das kommt nicht überraschend oder unangekündigt.
        Hoch ziehen kannst du das (zumindest versuchen). Hatte mal ein HowTo dazu geschrieben.
        • M manu4771
          Bloß keine Auto-Updates. Das will keiner.
            manu4771
            So dann mal Butter bei die Fische, was machen wir?
            Hilft es den den PI von DeConz zu befreien oder ist der Load minimal?
            Dann könnte ich auch auf die grafische Oberfläche verzichten.
            Aber wohin damit?
            Bei der Übung wäre dann natürlich eine saubere Neuinstallation kein Problem.
            Kommen wir aber nochmal zur Eingangsfrage.
            Wenn ich wirklich Spaß mit dem ioBroker haben will, was kaufe ich mir dann als kleinen Home Server ohne gleich ein Rack zu brauchen?
            Hier fristet auch noch ein QNAP TS-853A-4G 8 Bay Desktop NAS Gehäuse mit 4GB RAM ein trostloses dasein, da der Streamingmarkt die Nutzung obsolot gemacht hat.
            Ist mittlerweile aber auch schon wieder 5 Jahre alt das gute Ding.
            Thomas BraunT HomoranH 3 Antworten Letzte Antwort
            • M manu4771
              Aber wohin damit?
              Aber wohin damit?
              Bring den doch über den zigbee-Adapter in den ioBroker. Dann sparste dir den deCONZ-Kram auch schon ein. Zusammen mit dem Desktop dann halt.
              • M manu4771
                Aber wohin damit?
                Mir reicht hier ein RPi4 mit 8 GB RAM vollkommen aus. Ist halt bei jedem verschieden, was da alles drüber laufen soll.
                  Aber wohin damit?
                  manu4771
                  warte, ich brauche die in meinen Augen bescheide DeConz SW nicht zwingend? Der Zigbee Adapter arbeitet genau so mit dem Conbee II?
                  • M manu4771
                    Mittlerweile ja.
                    • M manu4771
                      Aber wohin damit?
                      das nicht, aber auch noch lange nicht kritisch.
                      Aber wohin damit?
                      in den Orcus, über den Jordan, egal!
                      QNAP TS-853A-4G
                      schon besser, über 1000 bei passmark, aber noch lange nicht gut.
                      Auch nur 4GB RAM und damit soll noch einiges anderes laufen.
                      ein 8Bay frisst aber gut Strom!
                      bleib beim Raspi würde ich sagen
                        Aber wohin damit?
                        QNAP TS-853A-4G
                        manu4771
                        Gut, danke jungs. Dann machen wir mal die Tage ne sauber neuinstallation und verzichten auf DeConz, ich erhoffe mir da auch weitere vorteile bzw. eine bessere implemntierung in ioBroker, manche Datenpunkte von DeConz sind schon... naja. Performanter wirds dann ja auch sein. Ich bin gespannt =)=)
                        • M manu4771
                          Moin zusammen,
                          mein System läuft schon ne ganze Zeit auf dem PI4 mit 4GB Ram und das auch relativ solide.
                          Zudem läuft auf dem PI parallel noch DeConz mit dem ConBee II.
                          Wenn alles läuft sucht man ja beklanntlich nach Optimierungen. Hier und da genehmigt sich der PI doch schon etwas lange zum laden. Auch das reagieren von Bewegungsmelden ( DeConz --> Blockly-Script --> HUE Leuchten über Adapter und eigenen Bridge) dauert doch manchmal etwas lange.
                          Ich habe hier noch einen alten Intel NUC (Intel DCCP847DYE NUC (Intel Celeron 847 CPU 2x 1.1) rumstehen, würde der besser performen als der PI? vergleichenede Benchmarks finde ich dazu nicht, ist wohl zu sehr Nische.
                          Der PI könnte sich dann weiterhin mit DeConz und ggf. noch Pi-Hole beschäftigen und der NUC macht ioBroker.
                          Was sind eure Meinungen dazu?
                          Wäre ggf. eine solide Neuanschaffung besser wenn mir die Perfomance so wichtig ist?
                          Natürlich stellt sich mir auch die Frage ob meine gefühlten Verzögerungen überhautp auf die HW zurückzuführen sind oder eine unsaubere SW dafür verantworltich ist, gibt es hier Möglichkeiten mein System ggf. vorab mal zu testen?
                          Danek vorab
                          eher nicht! zumindest nicht serverseitig
                          • M manu4771
                            v.2022-12-31
                            User-ID: 1000
                            X-Server: true
                            admin 6.2.23
                            Objects type: jsonl
                            States type: jsonl
                            Status admin:
                            Objects: 18240
                            States: 15338
                            Skript v.2022-12-31
                            *** BASE SYSTEM ***
                            Docker:         false
                            Release:        10
                            Codename:       buster
                            VERSION_ID="10"
                            ID=raspbian
                            ID_LIKE=debian
                            CPU threads: 4
                            CET +0100
                            Europe/Berlin
                            pi
                            /home/pi
                            X-Server:       true
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Swap:           99M          0B         99M
                                     3838 M total memory
                                     1399 M used memory
                                      607 M active memory
                                     1023 M free memory
                                      202 M buffer memory
                                     1213 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            *** FILESYSTEM ***
                            /var:
                            858M    /var/
                            506M    /var/cache
                            494M    /var/cache/apt
                            126M    /var/lib
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            admin:          6.2.23
                            javascript:     6.0.3
                            Adapter State
                            + instance is alive
                            Objects and States
                            Objects:        18227
                            States:         15325
                            Pending Updates: 0
                            sprobstS Offline
                            sprobstS Offline
                            sprobst
                            @manu4771 ok, also am Speicher oder CPU liegt das sicher nicht. Die Distribution ist alt aber ok. Ob X-Server ja oder nein, ist bei 1GB freiem Speicher auch egal. Kannst Du mal schauen wie sich io-wait im Kommando "top" in so einer "langsam Phase" verhält? Ich tippe mal mehr auf langsamen IO auf USB-Stick oder SD-Card. (Dann geht auch der "CPU-Load" hoch, weil der gibt ja nur an dass ein Prozess wartet, was nicht notwendigerweise CPU sein muss, sondern auch IO sein kann). Lösung könnte eine USB-SSD o.Ä. sein (da sollte man jedenfalls alle iobroker relevanten Verz. drauf legen).
                            -1
                            • sprobstS sprobst
                              @sprobst
                              Auf einem Server läuft kein X.
                              Grundsätzlich nicht.
