  4. Gelöst - VIS Adapter startet nicht - terminated with code 6
    5.6k
36 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • Bjoern KunderB Bjoern Kunder
    @bjoern-kunder
    bkunder@iobroker:/opt/iobroker$ node node_modules/iobroker.vis/main.js --debug
    2022-12-30 14:22:48.047  - debug: vis.0 (490866) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-12-30 14:22:48.075  - error: vis.0 (490866) uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.077  - error: vis.0 (490866) Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.078  - error: vis.0 (490866) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.107  - debug: vis.0 (490866) Objects client ready ... initialize now
    2022-12-30 14:22:48.111  - debug: vis.0 (490866) Objects create System PubSub Client
    2022-12-30 14:22:48.113  - debug: vis.0 (490866) Objects create User PubSub Client
    2022-12-30 14:22:48.173  - debug: vis.0 (490866) Objects client initialize lua scripts
    2022-12-30 14:22:48.182  - debug: vis.0 (490866) Objects connected to redis: 0.0.0.0:9001
    2022-12-30 14:22:48.221  - debug: vis.0 (490866) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-12-30 14:22:48.242  - debug: vis.0 (490866) States create System PubSub Client
    2022-12-30 14:22:48.244  - debug: vis.0 (490866) States create User PubSub Client
    2022-12-30 14:22:48.319  - debug: vis.0 (490866) States connected to redis: 0.0.0.0:9000
    2022-12-30 14:22:48.582  - info: vis.0 (490866) terminating
    2022-12-30 14:22:48.584  - warn: vis.0 (490866) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-30 14:22:48.645  - info: vis.0 (490866) starting. Version 2.0.16 (non-npm: iobroker/ioBroker.vis) in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    Bjoern KunderB Offline
    Bjoern Kunder
    @bjoern-kunder
    iobroker logs --watch | uniq bringt bei VIS Adapterneustart diese Infos - sieht so aus, als ob er eine Datei nicht finden kann in www:
    2022-12-30 14:29:11.586  - error: vis.0 (492745) unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
    2022-12-30 14:29:11.590  - error: vis.0 (492745) Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
        at Object.openSync (node:fs:590:3)
        at Object.writeFileSync (node:fs:2202:35)
        at generateConfigPage (/opt/iobroker/node_modules/iobroker.vis/main.js:151:12)
        at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis/main.js:665:27)
        at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis/main.js:804:5)
    2022-12-30 14:29:11.591  - error: vis.0 (492745) Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
      @bjoern-kunder
      @bjoern-kunder
      Zeitzone setzen.
      Dann
      iobroker update
      posten.
        @bjoern-kunder
        Du hast es aber irgendwie mit krummen Versionen.
        vis ist bei 4.x, wie kommst du da an 2.x?
        Und die Zeitzone richtig setzen.
        Bjoern Kunder
        ja komisch, irgendwie ist da alle verbogen....kann ich da irgendwie automatisiert fixen?
          @bjoern-kunder
          Ausgaben?
          Bjoern KunderB 1 Antwort Letzte Antwort
            @bjoern-kunder
            Ausgaben?
            Bjoern Kunder
            Current default time zone: 'Europe/Berlin'
            Local time is now:      Fri Dec 30 15:42:29 CET 2022.
            Universal Time is now:  Fri Dec 30 14:42:29 UTC 2022.
            bkunder@iobroker:~$ iobroker updates
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
              iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
              iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
              iobroker rebuild [<module>]                                  Rebuild all native modules or path
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
              iobroker object                                              Object management  [aliases: o]
              iobroker state                                               State management  [aliases: s]
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation  [aliases: id]
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
              iobroker [command]
              Commands:
              @bjoern-kunder
              Oh, vertippt.
              iobroker update
              heißt das.
                @bjoern-kunder
                Bjoern Kunder
                Ich kann den VIS Adapter nicht aktueller bekommen wie 2.0.16 in der WebGui
                  @bjoern-kunder
                  WebGUI interessiert ja auch nicht. Konsole ist das was zählt.
                    @bjoern-kunder
                    Oh, vertippt.
                    iobroker update
                    heißt das.
                    Bjoern Kunder
                    @thomas-braun said in VIS Adapter startet nicht - terminated with code 6:
                    iobroker update
                    Used repository: beta
                    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
                    Adapter    "cloud"        : 4.3.1    , installed 4.3.1
                    Adapter    "daswetter"    : 3.1.6    , installed 3.1.6
                    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                    Adapter    "email"        : 1.1.4    , installed 1.1.4
                    Adapter    "fhem"         : 2.0.2    , installed 2.0.2
                    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                    Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
                    Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                    Adapter    "hue"          : 3.7.1    , installed 3.7.1
                    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                    Adapter    "linux-control": 1.1.5    , installed 1.1.5
                    Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                    Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                    Adapter    "moma"         : 1.2.9    , installed 1.2.9
                    Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                    Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                    Adapter    "socketio"     : 6.3.3    , installed 6.3.3
                    Adapter    "tankerkoenig" : 3.3.1    , installed 3.2.5  [Updatable]
                    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                    Adapter    "trashschedule": 2.1.0    , installed 2.1.0
                    Adapter    "vis"          : 1.4.15   , installed 2.0.16
                    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                    Adapter    "web"          : 5.4.1    , installed 5.4.1
                    Adapter    "worx"         : 2.0.3    , installed 2.0.3
                    Adapter    "ws"           : 2.3.4    , installed 2.3.4
                      iobroker update
                      @bjoern-kunder
                      iobroker upgrade vis@1.4.15
                        iobroker update
                        @bjoern-kunder
                        Und bist du sicher, dass du im Beta-Zweig gut aufgehoben bist? Ich nämlich nicht.
                        Stell das auf stable um..
                          @bjoern-kunder
                          Bjoern Kunder
                          Repo habe ich auf Stable umgestellt und die Version 1.4.15 ist nun auch korrekt
                          trotzdem will der Adapter immer noch nicht so richtig
                          host.iobroker
                          2022-12-30 15:58:30.617	info	Restart adapter system.adapter.vis.0 because enabled
                          host.iobroker
                          2022-12-30 15:58:30.616	info	instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                          host.iobroker
                          2022-12-30 15:58:26.213	info	instance system.adapter.vis.0 started with pid 501917
                            host.iobroker
                            host.iobroker
                            host.iobroker
                            @bjoern-kunder
                            Warum? Ist doch offenbar neugestartet.
                              @bjoern-kunder
                              Bjoern Kunder
                              es scheint zu laufen und ich bekomme in der VIS View nun auch keine Lizenzmeldung mehr aber die Instanz wird immer noch rot dargestellt
                                @bjoern-kunder
                                Neustart des Adapters schaut genau wie im Logfile aus?
                                  @bjoern-kunder
                                  Bjoern Kunder
                                  host.iobroker
                                  2022-12-30 16:07:18.629	info	Restart adapter system.adapter.vis.0 because enabled
                                  host.iobroker
                                  2022-12-30 16:07:18.628	info	instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                                  host.iobroker
                                  2022-12-30 16:07:14.113	info	instance system.adapter.vis.0 started with pid 504699
                                  host.iobroker
                                  2022-12-30 16:07:13.387	info	instance system.adapter.vis.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                  host.iobroker
                                  2022-12-30 16:07:12.038	info	stopInstance system.adapter.vis.0 killing pid 504678
                                  host.iobroker
                                  2022-12-30 16:07:11.034	info	stopInstance system.adapter.vis.0 send kill signal
                                  host.iobroker
                                  2022-12-30 16:07:10.947	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                                  host.iobroker
                                  2022-12-30 16:07:10.604	info	instance system.adapter.vis.0 started with pid 504678
                                  host.iobroker
                                  2022-12-30 16:06:46.277	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  • DJMarc75D Offline
                                    DJMarc75D Offline
                                    DJMarc75
                                    Dubiose Geschichte wie hier:
                                    https://forum.iobroker.net/topic/61448/vis-probleme?_=1672412398071
                                    VIS hat eigentlich keine "Ampel" 🤔
                                    Lehrling seit 1975 !!!
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      host.iobroker
                                      @bjoern-kunder
                                      iob logs --watch
                                      Und dann den Adapter neustarten.
                                        @bjoern-kunder
                                        iob logs --watch
                                        Bjoern Kunder
                                        iob logs --watch
                                        2022-12-30 16:17:03.804  - info: host.iobroker instance system.adapter.vis.0 started with pid 507799
                                        2022-12-30 16:17:06.076  - info: vis.0 (507799) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
                                        2022-12-30 16:17:06.494  - info: vis.0 (507799) vis license is OK.
                                        2022-12-30 16:17:07.669  - info: vis.0 (507799) terminating
                                        2022-12-30 16:17:07.677  - info: vis.0 (507799) Terminated (NO_ERROR): Without reason
                                        2022-12-30 16:17:08.269  - info: host.iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                                        2022-12-30 16:17:08.271  - info: host.iobroker Restart adapter system.adapter.vis.0 because enabled
                                        022-12-30 16:17:21.308  - info: host.iobroker instance system.adapter.vis.0 started with pid 507908
                                        2022-12-30 16:17:23.619  - info: fhem.0 (498120) stateChange (out): fhem.0.info.Commands.sendFHEM | set fhem.0.alive on-for-timer 360 > set fhem.0.alive on-for-timer 360
                                        2022-12-30 16:17:23.862  - info: vis.0 (507908) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
                                        2022-12-30 16:17:24.225  - info: vis.0 (507908) vis license is OK.
                                        2022-12-30 16:17:25.701  - info: vis.0 (507908) terminating
                                        2022-12-30 16:17:25.703  - info: vis.0 (507908) Terminated (NO_ERROR): Without reason
                                        2022-12-30 16:17:26.286  - info: host.iobroker instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                                        2022-12-30 16:17:26.287  - info: host.iobroker Restart adapter system.adapter.vis.0 because enabled
                                          iob logs --watch
                                          @bjoern-kunder
                                          iobroker list instances
