  4. Gelöst - VIS Adapter startet nicht - terminated with code 6
    5.6k
36 Beiträge 4 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • Bjoern KunderB Bjoern Kunder
                            v.2022-12-13
    Operatingsystem:        Ubuntu 20.04.5 LTS
    Installation:           lxc
    Timezone:               Etc/UTC
    User-ID:                1001
    X-Server:               false
    Pending OS-Updates:     0
    Nodejs-Installation:    /usr/bin/nodejs         v16.19.0
                            /usr/bin/node           v16.19.0
                            /usr/bin/npm            8.19.3
    ioBroker Core:          js-controller           4.0.24
                            admin                   6.3.5
    Objects type: jsonl
    States  type: jsonl
    Pending iob updates:    1
    Active repo(s): beta
    Objects:                6627
    States:                 5752
    Size of iob-Database:
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    13M     /opt/iobroker/iobroker-data/states.jsonl
    ====================== END OF SUMMARY ==================
    Bjoern KunderB Offline
    Bjoern Kunder
    @bjoern-kunder
    bkunder@iobroker:/opt/iobroker$ node node_modules/iobroker.vis/main.js --debug
    2022-12-30 14:22:48.047  - debug: vis.0 (490866) Redis Objects: Use Redis connection: 0.0.0.0:9001
    2022-12-30 14:22:48.075  - error: vis.0 (490866) uncaught exception: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.077  - error: vis.0 (490866) Error: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.078  - error: vis.0 (490866) Exception-Code: EACCES: EACCES: permission denied, open '/opt/iobroker/log/iobroker.2022-12-30.log'
    2022-12-30 14:22:48.107  - debug: vis.0 (490866) Objects client ready ... initialize now
    2022-12-30 14:22:48.111  - debug: vis.0 (490866) Objects create System PubSub Client
    2022-12-30 14:22:48.113  - debug: vis.0 (490866) Objects create User PubSub Client
    2022-12-30 14:22:48.173  - debug: vis.0 (490866) Objects client initialize lua scripts
    2022-12-30 14:22:48.182  - debug: vis.0 (490866) Objects connected to redis: 0.0.0.0:9001
    2022-12-30 14:22:48.221  - debug: vis.0 (490866) Redis States: Use Redis connection: 0.0.0.0:9000
    2022-12-30 14:22:48.242  - debug: vis.0 (490866) States create System PubSub Client
    2022-12-30 14:22:48.244  - debug: vis.0 (490866) States create User PubSub Client
    2022-12-30 14:22:48.319  - debug: vis.0 (490866) States connected to redis: 0.0.0.0:9000
    2022-12-30 14:22:48.582  - info: vis.0 (490866) terminating
    2022-12-30 14:22:48.584  - warn: vis.0 (490866) Terminated (UNCAUGHT_EXCEPTION): Without reason
    2022-12-30 14:22:48.645  - info: vis.0 (490866) starting. Version 2.0.16 (non-npm: iobroker/ioBroker.vis) in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    Thomas BraunT Bjoern KunderB 2 Antworten Letzte Antwort
      @bjoern-kunder
      @bjoern-kunder
      Du hast es aber irgendwie mit krummen Versionen.
      vis ist bei 4.x, wie kommst du da an 2.x?
      Und die Zeitzone richtig setzen.
        @bjoern-kunder
        Bjoern Kunder
        @bjoern-kunder
        iobroker logs --watch | uniq bringt bei VIS Adapterneustart diese Infos - sieht so aus, als ob er eine Datei nicht finden kann in www:
        2022-12-30 14:29:11.586  - error: vis.0 (492745) unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
        2022-12-30 14:29:11.590  - error: vis.0 (492745) Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
            at Object.openSync (node:fs:590:3)
            at Object.writeFileSync (node:fs:2202:35)
            at generateConfigPage (/opt/iobroker/node_modules/iobroker.vis/main.js:151:12)
            at async buildHtmlPages (/opt/iobroker/node_modules/iobroker.vis/main.js:665:27)
            at async Object.main [as ready] (/opt/iobroker/node_modules/iobroker.vis/main.js:804:5)
        2022-12-30 14:29:11.591  - error: vis.0 (492745) Exception-Code: ENOENT: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/www/config.js'
          @bjoern-kunder
          @bjoern-kunder
          Zeitzone setzen.
          Dann
          iobroker update
          posten.
            @bjoern-kunder
            Bjoern Kunder
            ja komisch, irgendwie ist da alle verbogen....kann ich da irgendwie automatisiert fixen?
              @bjoern-kunder
              Ausgaben?
              Bjoern KunderB 1 Antwort Letzte Antwort
                @bjoern-kunder
                Ausgaben?
                Bjoern Kunder
                Current default time zone: 'Europe/Berlin'
                Local time is now:      Fri Dec 30 15:42:29 CET 2022.
                Universal Time is now:  Fri Dec 30 14:42:29 UTC 2022.
                bkunder@iobroker:~$ iobroker updates
                iobroker [command]
                Commands:
                  iobroker setup                                               Setup ioBroker
                  iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                  iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                  iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                  iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                  iobroker info                                                Shows the host info
                  iobroker logs [<adapter>]                                    Monitor log
                  iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                  iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                  iobroker rebuild [<module>]                                  Rebuild all native modules or path
                  iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                  iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                  iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                  iobroker update [<repositoryUrl>]                            Update repository and list adapters
                  iobroker upgrade                                             Upgrade management
                  iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                  iobroker object                                              Object management  [aliases: o]
                  iobroker state                                               State management  [aliases: s]
                  iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                  iobroker list <type> [<filter>]                              List all entries, like objects
                  iobroker chmod <mode> <file>                                 Change file rights
                  iobroker chown <user> <group> <file>                         Change file ownership
                  iobroker touch <file>                                        Touch file
                  iobroker rm <file>                                           Remove file
                  iobroker file                                                File management
                  iobroker user                                                User commands
                  iobroker group                                               group management
                  iobroker host <hostname>                                     Set host to given hostname
                  iobroker set <adapter>.<instance>                            Change settings of adapter config
                  iobroker license <license.file or license.text>              Update license by given file
                  iobroker cert                                                Certificate management
                  iobroker clean <yes>                                         Clears all objects and states
                  iobroker backup                                              Create backup
                  iobroker restore <backup name or path>                       Restore a specified backup
                  iobroker validate <backup name or path>                      Validate a specified backup
                  iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                  iobroker repo [<name>]                                       Show repo information
                  iobroker uuid                                                Show uuid of the installation  [aliases: id]
                  iobroker unsetup                                             Reset license, installation secret and language
                  iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                  iobroker multihost                                           Multihost management
                  iobroker compact                                             compact group management
                  iobroker plugin                                              Plugin management
                  iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                  iobroker [command]
                  Commands:
                  @bjoern-kunder
                  Oh, vertippt.
                  iobroker update
                  heißt das.
                    @bjoern-kunder
                    Bjoern Kunder
                    Ich kann den VIS Adapter nicht aktueller bekommen wie 2.0.16 in der WebGui
                      @bjoern-kunder
                      WebGUI interessiert ja auch nicht. Konsole ist das was zählt.
                        @bjoern-kunder
                        Oh, vertippt.
                        iobroker update
                        heißt das.
                        Bjoern Kunder
                        @thomas-braun said in VIS Adapter startet nicht - terminated with code 6:
                        iobroker update
                        Used repository: beta
                        Adapter    "backitup"     : 2.5.9    , installed 2.5.9
                        Adapter    "cloud"        : 4.3.1    , installed 4.3.1
                        Adapter    "daswetter"    : 3.1.6    , installed 3.1.6
                        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                        Adapter    "email"        : 1.1.4    , installed 1.1.4
                        Adapter    "fhem"         : 2.0.2    , installed 2.0.2
                        Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
                        Adapter    "hm-rega"      : 3.0.43   , installed 3.0.43
                        Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
                        Adapter    "hue"          : 3.7.1    , installed 3.7.1
                        Adapter    "javascript"   : 6.1.4    , installed 6.1.4
                        Adapter    "linux-control": 1.1.5    , installed 1.1.5
                        Adapter    "logparser"    : 1.1.0    , installed 1.1.0
                        Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
                        Adapter    "moma"         : 1.2.9    , installed 1.2.9
                        Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                        Adapter    "pollenflug"   : 1.0.6    , installed 1.0.6
                        Adapter    "pushover"     : 3.0.3    , installed 3.0.3
                        Adapter    "socketio"     : 6.3.3    , installed 6.3.3
                        Adapter    "tankerkoenig" : 3.3.1    , installed 3.2.5  [Updatable]
                        Adapter    "telegram"     : 1.15.2   , installed 1.15.2
                        Adapter    "trashschedule": 2.1.0    , installed 2.1.0
                        Adapter    "vis"          : 1.4.15   , installed 2.0.16
                        Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
                        Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                        Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
                        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                        Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                        Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
                        Adapter    "web"          : 5.4.1    , installed 5.4.1
                        Adapter    "worx"         : 2.0.3    , installed 2.0.3
                        Adapter    "ws"           : 2.3.4    , installed 2.3.4
                          iobroker update
                          @bjoern-kunder
                          iobroker upgrade vis@1.4.15
                            iobroker update
                            @bjoern-kunder
                            Und bist du sicher, dass du im Beta-Zweig gut aufgehoben bist? Ich nämlich nicht.
                            Stell das auf stable um..
                              @bjoern-kunder
                              Bjoern Kunder
                              Repo habe ich auf Stable umgestellt und die Version 1.4.15 ist nun auch korrekt
                              trotzdem will der Adapter immer noch nicht so richtig
                              host.iobroker
                              2022-12-30 15:58:30.617	info	Restart adapter system.adapter.vis.0 because enabled
                              host.iobroker
                              2022-12-30 15:58:30.616	info	instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                              host.iobroker
                              2022-12-30 15:58:26.213	info	instance system.adapter.vis.0 started with pid 501917
                                host.iobroker
                                host.iobroker
                                host.iobroker
                                @bjoern-kunder
                                Warum? Ist doch offenbar neugestartet.
                                  @bjoern-kunder
                                  Bjoern Kunder
                                  es scheint zu laufen und ich bekomme in der VIS View nun auch keine Lizenzmeldung mehr aber die Instanz wird immer noch rot dargestellt
                                    @bjoern-kunder
                                    Neustart des Adapters schaut genau wie im Logfile aus?
                                      @bjoern-kunder
                                      Bjoern Kunder
                                      host.iobroker
                                      2022-12-30 16:07:18.629	info	Restart adapter system.adapter.vis.0 because enabled
                                      host.iobroker
                                      2022-12-30 16:07:18.628	info	instance system.adapter.vis.0 terminated with code 0 (NO_ERROR)
                                      host.iobroker
                                      2022-12-30 16:07:14.113	info	instance system.adapter.vis.0 started with pid 504699
                                      host.iobroker
                                      2022-12-30 16:07:13.387	info	instance system.adapter.vis.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                      host.iobroker
                                      2022-12-30 16:07:12.038	info	stopInstance system.adapter.vis.0 killing pid 504678
                                      host.iobroker
                                      2022-12-30 16:07:11.034	info	stopInstance system.adapter.vis.0 send kill signal
                                      host.iobroker
                                      2022-12-30 16:07:10.947	info	stopInstance system.adapter.vis.0 (force=false, process=true)
                                      host.iobroker
                                      2022-12-30 16:07:10.604	info	instance system.adapter.vis.0 started with pid 504678
                                      host.iobroker
                                      2022-12-30 16:06:46.277	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      • DJMarc75D Offline
                                        DJMarc75D Offline
                                        DJMarc75
                                        Dubiose Geschichte wie hier:
                                        https://forum.iobroker.net/topic/61448/vis-probleme?_=1672412398071
                                        VIS hat eigentlich keine "Ampel" 🤔
                                        Lehrling seit 1975 !!!
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          host.iobroker
                                          @bjoern-kunder
                                          iob logs --watch
                                          Und dann den Adapter neustarten.
