  4. Sonos werden nicht gefunden
18 Beiträge 7 Kommentatoren 3.4k Aufrufe
    afunk
    Kleiner Nachtrag aus dem Log:
    @afunk:
    @tempestas:
    "sonos.0 2017-06-20 18:13:31.152 info http sonos server listening on port 8080
    sonos.0 2017-06-20 18:13:31.056 info starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.sonos, node: v6.11.0
    host.iobroker 2017-06-20 18:13:29.454 info instance system.adapter.sonos.0 started with pid 3447
    host.iobroker 2017-06-20 18:13:26.972 info instance system.adapter.sonos.0 terminated with code 0 (OK)
    sonos.0 2017-06-20 18:13:26.958 info terminating
    host.iobroker 2017-06-20 18:13:26.946 info stopInstance system.adapter.sonos.0 killing pid 3435
    sonos.0 2017-06-20 18:13:26.948 info terminating
    host.iobroker 2017-06-20 18:13:26.945 info object change system.adapter.sonos.0
    sonos.0 2017-06-20 18:12:47.733 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.732 info try to control id sonos.0.root.192_168_178_45.remove_from_group with {"val":"","ack":false,"ts":1497975167639,"q":0,"from":"system.adapter.sonos.0","lc":1497975167639}
    sonos.0 2017-06-20 18:12:47.732 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.731 info try to control id sonos.0.root.192_168_178_45.add_to_group with {"val":"","ack":false,"ts":1497975167639,"q":0,"from":"system.adapter.sonos.0","lc":1497975167639}
    sonos.0 2017-06-20 18:12:47.730 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.730 info try to control id sonos.0.root.192_168_178_45.tts with {"val":"","ack":false,"ts":1497975167639,"q":0,"from":"system.adapter.sonos.0","lc":1497975167639}
    sonos.0 2017-06-20 18:12:47.729 info try to control id sonos.0.root.192_168_178_45.favorites_set with {"val":"","ack":false,"ts":1497975167634,"q":0,"from":"system.adapter.sonos.0","lc":1497975167634}
    sonos.0 2017-06-20 18:12:47.729 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.728 info try to control id sonos.0.root.192_168_178_45.favorites_list with {"val":"","ack":false,"ts":1497975167634,"q":0,"from":"system.adapter.sonos.0","lc":1497975167634}
    sonos.0 2017-06-20 18:12:47.728 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.728 info try to control id sonos.0.root.192_168_178_45.current_elapsed_s with {"val":"00:00","ack":false,"ts":1497975167634,"q":0,"from":"system.adapter.sonos.0","lc":1497975167634}
    sonos.0 2017-06-20 18:12:47.727 info try to control id sonos.0.root.192_168_178_45.current_elapsed with {"val":0,"ack":false,"ts":1497975167633,"q":0,"from":"system.adapter.sonos.0","lc":1497975167633}
    sonos.0 2017-06-20 18:12:47.727 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.727 info try to control id sonos.0.root.192_168_178_45.current_type with {"val":0,"ack":false,"ts":1497975167632,"q":0,"from":"system.adapter.sonos.0","lc":1497975167632}
    sonos.0 2017-06-20 18:12:47.726 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.726 info try to control id sonos.0.root.192_168_178_45.current_duration_s with {"val":"00:00","ack":false,"ts":1497975167632,"q":0,"from":"system.adapter.sonos.0","lc":1497975167632}
    sonos.0 2017-06-20 18:12:47.726 info try to control id sonos.0.root.192_168_178_45.current_duration with {"val":0,"ack":false,"ts":1497975167632,"q":0,"from":"system.adapter.sonos.0","lc":1497975167632}
    sonos.0 2017-06-20 18:12:47.725 warn SONOS "" not found
    sonos.0 2017-06-20 18:12:47.722 info "
    Bin grad etwas ratlos.
    afunk `
    • Jey CeeJ Online
      Jey CeeJ Online
      Jey Cee
      Mach mal einen Screenshot von deiner aktuellen Konfiguration des Sonos Adapter.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
        afunk
        @Jey Cee:
        Habe im Vergleich zum Bild oben nur die IPs nachgetragen - die Zimmer werden nicht erkannt und bei Klick auf "Suchen" passiert auch nichts…
        Oder meinst Du was anders?
        afunk
        • Jey CeeJ Online
          Jey CeeJ Online
          Jey Cee
          Ich hätte jetzt darauf getippt das die Namen Fehlen.
          Trag mal noch einen Raum ein.
          Das die Suche nichts findet kann daran liegen das die ports der Sonos geblockt werden.
            @Jey Cee:
            Das die Suche nichts findet kann daran liegen das die ports der Sonos geblockt werden. `
            War auch meine erste Idee, gerade im Docker.
            @afunk:
            die Zimmer werden nicht erkannt `
            Hast du denn Zimmer angelegt in ioBroker?
              afunk
              @Homoran:
              Zimmer anlegen geht leider nicht, da bei den Adaptern ja keine Einstellungen kommen. Habe dann im "ExpertenModus" das direkt im Code eingetragen, aber auch nix.
              Sonos benötigt ja eine Menge Ports… puh. Alle von Fritzbox auf Synology leiten? - oder kann man da in Docker was nachtragen? Bislang hab ich in Docker 8080 bis 8084 angegeben....
              Ach man..
              afunk
                Machst du jetzt Portfreigaben in der Fritzbox?
                Damit jeder von draußen in dein Netz kann?
                Lass das!
                  afunk
                  … ja werde ich nicht machen. Vielleicht findet sich ein anderer Weg noch. Versuche grade in Docker Ports einzutragen... mal sehen...
                    Mit Docker kenne ich mich nicht aus :(
                    @afunk:
                    Zimmer anlegen geht leider nicht, da bei den Adaptern ja keine Einstellungen kommen `
                    Die Zimmer müssen unter enum rooms liegen.
                    Im Admin unter Aufzählungen
                    • F Offline
                      fraenkie76
                      leider endet der Thread hier ohne Lösung….
                      Ich habe fast die gleiche Situation bei mir. Habe den iobroker auf einem pi nicht auf der Synology, aber sonst analog:
                      Der Adapter findet meine Sonos Play 1 nicht.
                      Über die Suche findet er auf Port 8080 nichts, über 8083 auch nichts.
                      Manueller Eintrag funktioniert auch nicht.
                      Habe den Adapter auch schon gelöscht und wieder angelegt.
                      Fehlermeldungen im Log analog wie oben
                      Vielen Dank schon mal für eure Hilfe.
                      fraenkie
                        dwm
                        Exakt auf genau das gleiche Problem aufgeschlagen.
                        Aus Docker ist der Sonos Adapter schlicht und ergreifend tot…
                        Sch .... ade.
                        Ich wär da für ein Rezept recht dankbar :)
                        Edith sagt:
                        Wenn man das image mit
                        docker run --network host ...
                        startet, klappt's.
                        Anscheinend ist das Problem, dass Sonos im Netzwerk Mulitcasts verwendet und das mit der Docker bridge erst mal nicht funktioniert.
                        Das löst auch mein zweites Problem: SayIt leitete als Webserver Adresse die Docker-Interne 172.... Adresse weiter, die der Sonos nicht findet :(
                        • cashC Offline
                          cashC Offline
                          cash
                          Bei mir laufen im Docker insgesamt 4 Sonos. Alles funktioniert wie es soll. Morgens werde ich im Schlafzimmer geweckt (endlich per Zufallswieeergabe). Danach gruppiert er alle und wenn ich vom Gassi wieder komme spielt überall Radio. Abends werden die Gruppen aufgelöst.
                          Also 0 Probleme. Musste keine Ports umbiegen oder sonst was machen.
                          Vielleicht laufen bei euch auf der Synology noch andere Sachen die die nötigen Ports blocken?
                            dwm
                            Interessant … mit welchem image hast Du das gemacht?
                            Bei mir läufts übrigens auch nicht in der Synology sondern auf nem Ubuntu 16.04 LTS ...
                            Image selbst nach Vorlage der Synology gebastelt, aber auf der Ubuntu: lastest Basis.
                            Nach Recherche im Netz liegts wie gesagt an der Docker Bridge, die das Multicast nicht per se unterstützt,
                            aber das ist grad hörensagen ;)
                            Benutzt Du die Sonos auch mit sayit?
                            Und noch ne Docker Frage: Hast Du mal nen snapshot mit docker commit probiert?
                            Cu Werner
                            • cashC Offline
                              cashC Offline
                              cash
                              Sayit habe ich installiert und beim testen lief auch das. Allerdings gefallen mir die Stimmen nicht. Deshalb nutze ich ihn nicht aktiv.
                              Eine entgültige Entscheidung habe ich dort noch nicht getroffen.
                              Das Image ist von https://github.com/buanet/docker-iobroker
                              Wozu sollte ich ein Snapshot machen? Ich kenne mich mit Docker nicht so aus. Bin eigentlich froh das alles läuft und die Sicherung auch jede Woche funktioniert. Bei mir läuft auch yahka ohne Probleme damit scheint es ja auch öfter Proboeme im Docker zu geben.
                                dwm
                                Danke :) Wieder was kapiert, glaub ich…
                                Ich hab mir grade die Anleitung vom Docker auf der Synology mal durchgelesen:
                                > Unter Netzwerk wähle "Dasselbe Netzwerk wie Docker Host verwenden". Diese Einstellung sorgt dafür, dass siche ioBroker später "anfühlt" als würde es direkt auf der DiskStation laufen und vermeidet Probleme mit dem Hostnamen.
                                Yup. Das ist genau der````
                                --network host
                                Dann wird das Netzwerk direkt vom Host benutzt, die Port "Expose" aus dem Docker image sind damit schlicht redundant bzw. werden nicht benutzt.
                                Das ist auch gut so, Homematic funktioniert sonst auch nur sehr eingeschränkt, die Ports für die RPC Rückkanäle sind im Image abgewürgt …
                                CU
                                Werner
