    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • TomDukeT TomDuke
    @armilar
    du meinst die Config?
    export const config: Config = {
        panelRecvTopic: 'mqtt.0.SmartHome.NSPanel_1.tele.RESULT',       // anpassen
        panelSendTopic: 'mqtt.0.SmartHome.NSPanel_1.cmnd.CustomSend',   // anpassen
        firstScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Daily.Day1.Day.PrecipitationProbability', ScreensaverEntityIcon: 'weather-pouring', ScreensaverEntityText: 'Regen', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100} },
        secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
        //secondScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.WindSpeed', ScreensaverEntityIcon: 'weather-windy', ScreensaverEntityText: "Wind", ScreensaverEntityUnitText: 'km/h', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 120} },
        thirdScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.UVIndex', ScreensaverEntityIcon: 'solar-power', ScreensaverEntityText: 'UV', ScreensaverEntityUnitText: '', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 9} },
        fourthScreensaverEntity: { ScreensaverEntity: 'accuweather.0.Current.RelativeHumidity', ScreensaverEntityIcon: 'water-percent', ScreensaverEntityText: 'Luft', ScreensaverEntityUnitText: '%', ScreensaverEntityIconColor: {'val_min': 0, 'val_max': 100, 'val_best': 65} },
        alternativeScreensaverLayout: false,
        autoWeatherColorScreensaverLayout: true,
        mrIcon1ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.NSPanel_1.stat.POWER1', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
        mrIcon2ScreensaverEntity: { ScreensaverEntity: 'mqtt.0.SmartHome.NSPanel_1.stat.POWER2', ScreensaverEntityIcon: 'lightbulb', ScreensaverEntityOnColor: On, ScreensaverEntityOffColor: HMIOff  },
        timeoutScreensaver: 10,
        screenSaverDoubleClick: true,
        locale: 'de-DE',                    // en-US, de-DE, nl-NL, da-DK, es-ES, fr-FR, it-IT, ru-RU, etc.
        weatherEntity: 'alias.0.Recklinghausen',    // Dieser Alias muss erstellt werden, damit die 4 kleineren Icons (Wetter oder DP) angezeigt werden können
        defaultOffColor: Off,
        defaultOnColor: On,
        defaultColor: Off,
        defaultBackgroundColor: HMIDark,    //New Parameter
        temperatureUnit: '°C',
        pages: [
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #1349
    @tomduke
    Sorry, hat etwas länger gedauert...
    Die Config ist okay...
    Sende mal den kompletten oberen Teil mit den Konstanten also ab de Release Notes:
    let Icons = new IconsSelector();
    // _________________________________ Ab hier keine Konfiguration mehr
    Da fehlt bestimmt eine Farbe
    TomDukeT 2 Antworten Letzte Antwort
    • ArmilarA Armilar
      @tomduke
      TomDukeT Offline
      TomDukeT Offline
      TomDuke
      #1350
      @armilar
      let timeoutSlider: any;
      let manually_Update = false;
      const autoCreateAlias = true;                   //Für diese Option muss der Haken in setObjects in deiner javascript.X. Instanz gesetzt sein.
      const weatherAdapterInstance: string = 'accuweather.0.';  //Möglich 'accuweather.0.' oder 'daswetter.0.'
      const weatherScreensaverTempMinMax: string = 'MinMax';      // Mögliche Werte: 'Min', 'Max' oder 'MinMax'
      const NSPanel_Path = '0_userdata.0.NSPanel.1.';
      const NSPanel_Alarm_Path = '0_userdata.0.NSPanel.'; //Neuer Pfad für gemeinsame Nutzung durch mehrere Panels (bei Nutzung der cardAlarm)
      let AliasPath: string = 'alias.0.' + NSPanel_Path.substring(13, NSPanel_Path.length);
      const Debug = false;
      // Variablen zur Steuerung der Wettericons auf dem Screensaver (Steuerung in 0_userdata.0.XPANELX.ScreensaverInfo)
      // Wenn weatherForecastTimer auf true, dann Wechsel zwischen Datenpunkten und Wettervorhersage (30 Sekunden nach Minute (Zeit))
      // Wenn weatherForecastTimer auf false, dann Möglichkeit über weatherForecast, ob Datenpunkte oder Wettervorhersage (true = WeatherForecast/false = Datenpunkte)
      let weatherForecast: boolean; // Änderung zum Video --> Einstellung siehe Wiki
      const HMIOff:           RGB = { red:  68, green: 115, blue: 158 };     // Blau-Off - Original Entity Off
      const HMIOn:            RGB = { red:   3, green: 169, blue: 244 };     // Blau-On
      const HMIDark:          RGB = { red:  29, green:  29, blue:  29 };     // Original Background Color
      const Off:              RGB = { red: 253, green: 128, blue:   0 };     // Orange-Off - schönere Farbübergänge
      const On:               RGB = { red: 253, green: 216, blue:  53 };
      const MSRed:            RGB = { red: 251, green: 105, blue:  98 };
      const MSYellow:         RGB = { red: 255, green: 235, blue: 156 };
      const MSGreen:          RGB = { red: 121, green: 222, blue: 121 };
      const Red:              RGB = { red: 255, green:   0, blue:   0 };
      const White:            RGB = { red: 255, green: 255, blue: 255 };
      const Yellow:           RGB = { red: 255, green: 255, blue:   0 };
      const Green:            RGB = { red:   0, green: 255, blue:   0 };
      const Blue:             RGB = { red:   0, green:   0, blue: 255 };
      const DarkBlue:         RGB = { red:   0, green:   0, blue: 136 };
      const Gray:             RGB = { red: 136, green: 136, blue: 136 };
      const Black:            RGB = { red:   0, green:   0, blue:   0 };
      const colorSpotify:     RGB = { red:  30, green: 215, blue:  96 };
      const colorAlexa:       RGB = { red:  49, green: 196, blue: 243 };
      const colorRadio:       RGB = { red: 255, green: 127, blue:   0 };
      const BatteryFull:      RGB = { red:  96, green: 176, blue:  62 };
      const BatteryEmpty:     RGB = { red: 179, green:  45, blue:  25 };
      //Dynamische Indikatoren
      const colorScale0:      RGB = { red:   99, green: 190, blue: 123 };
      const colorScale1:      RGB = { red:  129, green: 199, blue: 126 };
      const colorScale2:      RGB = { red:  161, green: 208, blue: 127 };
      const colorScale3:      RGB = { red:  129, green: 217, blue: 126 };
      const colorScale4:      RGB = { red:  222, green: 226, blue: 131 };
      const colorScale5:      RGB = { red:  254, green: 235, blue: 132 };
      const colorScale6:      RGB = { red:  255, green: 210, blue: 129 };
      const colorScale7:      RGB = { red:  251, green: 185, blue: 124 };
      const colorScale8:      RGB = { red:  251, green: 158, blue: 117 };
      const colorScale9:      RGB = { red:  248, green: 131, blue: 111 };
      const colorScale10:     RGB = { red:  248, green: 105, blue: 107 };
      //Screensaver Default Theme Colors
      const scbackground:     RGB = { red:   0, green:    0, blue:   0};
      const scbackgroundInd1: RGB = { red: 255, green:   0,  blue:   0};
      const scbackgroundInd2: RGB = { red: 121, green: 222,  blue: 121};
      const scbackgroundInd3: RGB = { red: 255, green: 255,  blue:   0};
      const sctime:           RGB = { red: 255, green:  255, blue: 255};
      const sctimeAMPM:       RGB = { red: 255, green:  255, blue: 255};
      const scdate:           RGB = { red: 255, green:  255, blue: 255};
      const sctMainIcon:      RGB = { red: 255, green:  255, blue: 255};
      const sctMainText:      RGB = { red: 255, green:  255, blue: 255};
      const sctForecast1:     RGB = { red: 255, green:  255, blue: 255};
      const sctForecast2:     RGB = { red: 255, green:  255, blue: 255};
      const sctForecast3:     RGB = { red: 255, green:  255, blue: 255};
      const sctForecast4:     RGB = { red: 255, green:  255, blue: 255};
      const sctF1Icon:        RGB = { red: 255, green:  235, blue: 156};
      const sctF2Icon:        RGB = { red: 255, green:  235, blue: 156};
      const sctF3Icon:        RGB = { red: 255, green:  235, blue: 156};
      const sctF4Icon:        RGB = { red: 255, green:  235, blue: 156};
      const sctForecast1Val:  RGB = { red: 255, green:  255, blue: 255};
      const sctForecast2Val:  RGB = { red: 255, green:  255, blue: 255};
      const sctForecast3Val:  RGB = { red: 255, green:  255, blue: 255};
      const sctForecast4Val:  RGB = { red: 255, green:  255, blue: 255};
      const scbar:            RGB = { red: 255, green:  255, blue: 255};
      const sctMainIconAlt:   RGB = { red: 255, green:  255, blue: 255};
      const sctMainTextAlt:   RGB = { red: 255, green:  255, blue: 255};
      const sctTimeAdd:       RGB = { red: 255, green:  255, blue: 255};
      //Auto-Weather-Colors
      const swClearNight:     RGB = { red: 150, green: 150, blue: 100};
      const swCloudy:         RGB = { red:  75, green:  75, blue:  75};
      const swExceptional:    RGB = { red: 255, green:  50, blue:  50};
      const swFog:            RGB = { red: 150, green: 150, blue: 150};
      const swHail:           RGB = { red: 200, green: 200, blue: 200};
      const swLightning:      RGB = { red: 200, green: 200, blue:  0};
      const swLightningRainy: RGB = { red: 200, green: 200, blue: 150};
      const swPartlycloudy:   RGB = { red: 150, green: 150, blue: 150};
      const swPouring:        RGB = { red:  50, green:  50, blue: 255};
      const swRainy:          RGB = { red: 100, green: 100, blue: 255};
      const swSnowy:          RGB = { red: 150, green: 150, blue: 150};
      const swSnowyRainy:     RGB = { red: 150, green: 150, blue: 255};
      const swSunny:          RGB = { red: 255, green: 255, blue:   0};
      const swWindy:          RGB = { red: 150, green: 150, blue: 150};
      let vwIconColor = [];
      //-- Anfang der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ----------------
      let Licht1: PageGrid =
          "type": "cardGrid",
          "heading": "DECKENLAMPEN",
          "useColor": true,
          "subPage": false,
          "parent": undefined,
          "items": [
              <PageItem>{ id: "alias.0.Hue.Deckenlampe_Flur", name: "Flur", interpolateColor: false},
              <PageItem>{ id: "alias.0.Hue.Deckenlampe_Küche", name: "Küche", minValueBrightness: 0, maxValueBrightness: 50, interpolateColor: false},
              <PageItem>{ id: "alias.0.Hue.Deckenlampe_Bad", name: "Badezimmer", minValueBrightness: 0, maxValueBrightness: 20, interpolateColor: false},
              //<PageItem>{ id: "alias.0.Hue.Weihnachtsbaum_.ON_ACTUAL", name: "Weihnachtsbaum", minValueColorTemp: 500, maxValueColorTemp: 6500, interpolateColor: true}
      //Only DEV --> Test
      //let CardChartExample: PageChart =
      //    "type": "cardChart",
      //   "heading": "Stromzähler L1+L2+L3",
      //    "useColor": true,
      //    "subPage": false,
      //    "parent": undefined,
      //    "items": [<PageItem>{
      //                id: 'alias.0.NSPanel_1.cardChart',
      //                yAxis: 'Leistung [kW]',
      //                yAxisTicks: [2,4,6,8,10,2,4,6,8,20,2],
                      onColor: Yellow
      let CardPowerExample: PagePower =
          "type": "cardPower",
          "heading": "cardPower Emulator",
          "useColor": true,
          "subPage": false,
          "items": [
              <PageItem>{ id: 'alias.0.NSPanel_1.Power.PowerCard' },
      //let Test_Licht2: PageEntities =
      //    "type": "cardEntities",
      //    "heading": "Color Aliase 2",
      //    "items": [
      //        //Beispiel für RGB Light mit neuem PageItem-Parameter colormode: "xy" alternativ colormode: "rgb" oder weglassen
      //        //Steuert im z.B. DeConz Adapter unter Lampen die Farben per CIE (XY)
      //        <PageItem>{ id: "alias.0.NSPanel_2.WZ_E14_Fenster_rechts", name: "Fensterbank rechts", minValueBrightness: 0, maxValueBrightness: 100, minValueColorTemp: 500, maxValueColorTemp: 150, interpolateColor: true, colormode: "xy"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestFarbtemperatur", name: "Farbtemperatur", interpolateColor: true},
      //let Temperatur: PageEntities =
      //    "heading": "Innentemperatur",
      //    "items": [
      //       <PageItem>{ id: "alias.0.Hue.Temperatur.ACTUAL",name: "Innentemperatur", icon: "thermometer", onColor: White },
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestLautstärke", offColor: MSRed, onColor: MSGreen, name: "Echo Spot Büro", minValue: 0, maxValue: 100 },
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestFeuchtigkeit", name: "Luftfeuchte außen", icon: "water-percent", unit: "%H", onColor: White },
      //        //<PageItem>{ id: "alias.0.NSPanel_1.TestInfo", name: "Windstärke", icon: "wind-power-outline", offColor: MSRed, onColor: MSGreen, unit: "bft", minValue: 0, maxValue: 12, interpolateColor: true, useColor: true },
      //        <PageItem>{ id: "alias.0.NSPanel_1.Ventilator.Fan_1",name: "Ventilator", icon: "fan", onColor: On, offColor: HMIOff, modeList: ['Low', 'Medium', 'High', 'Move', 'Sleep', 'Auto', 'Manual']},
      //let Buero_Seite_1: PageEntities =
      //    "heading": "Büro",
      //    "items": [
      //        <PageItem>{ id: "alias.0.NSPanel_1.Schreibtischlampe", interpolateColor: true},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", interpolateColor: true},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Testlampe2", name: "Filamentlampe", minValueBrightness: 0, maxValueBrightness: 70, interpolateColor: true},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", icon2: "power",offColor: MSRed, onColor: MSGreen}
      //let Fenster_1: PageEntities =
      //    "heading": "Fenster und Türen",
      //    "items": [
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestFenster", offColor: MSRed, onColor: MSGreen, name: "Büro Fenster"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Haustuer", offColor: MSRed, onColor: MSGreen, name: "Haustür"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", icon: "blinds-horizontal", offColor: White, onColor: Yellow, name: "Büro", secondRow: "Hier Text für 2. Zeile"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestDoorlock", offColor: MSRed, onColor: MSGreen, name: "Türschloss"},
      //<PageItem>{ id: "alias.0.NS-Panel.Buero.Rollade", icon: "blinds-horizontal", offColor: White, onColor: Yellow, name: "Büro", secondRow: "Hier Text für 2. Zeile"},
      let Button_1: PageEntities =
          "heading": "Button Aliase",
          "useColor": true,
          "subPage": false,
          "items": [
              <PageItem>{ id: "alias.0.NSPanel_1.TestTastensensor", name: "Tastensensor (FFN)"},
              <PageItem>{ id: "alias.0.NSPanel_1.Radio.NDR2", icon: "radio", name: "Taste (NDR2)", onColor: colorRadio},
              <PageItem>{ id: "alias.0.NSPanel_1.TestVentil1", icon: "valve-open", icon2: "valve-closed",offColor: MSRed, onColor: MSGreen, name: "Test-Ventil 1"},
              <PageItem>{ id: "alias.0.NSPanel_1.Radio.NDR2", icon: 'alarm-light', name: "Alert mit Zielseite", offColor: MSGreen, onColor: MSRed, targetPage: 'Abfall', buttonText: 'Popup'},
      //let Subpages_1: PageEntities =
      //    "heading": "Test Subpages",
      //    "items": [
      //        <PageItem>{ navigate: true, id: "Abfall", onColor: White, name: "Abfallkalender"},
      //        <PageItem>{ navigate: true, id: "WLAN", onColor: White, name: "Gäste WLAN"},
      //        //Subpage 1 von Subpages_1
      //        let Abfall: PageEntities =
      //            "heading": "Abfallkalender",
      //            "subPage": true,
      //            "parent": Subpages_1,
      //            "items": [
      //                <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event1",icon: "trash-can"},
      //                <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event2",icon: "trash-can"},
      //                <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event3",icon: "trash-can"},
      //                <PageItem>{ id: "alias.0.NSPanel_1.Abfall.event4",icon: "trash-can"}
              //Subpage 2 von Subpages_1
      //        let WLAN: PageQR =
      //            "type": "cardQR",
      //            "heading": "Gäste WLAN",
      //            "subPage": true,
      //            "items": [<PageItem>{ id: "alias.0.NSPanel_1.Guest_Wifi", hidePassword: true }]
      //let Buero_Seite_2: PageGrid =
      //    "type": "cardGrid",
      //    "heading": "Büro 2",
      //    "items": [
      //        <PageItem>{ id: "alias.0.Hue.HUE_Deckenlampe_Flur", name: "Deckenlampe Flur"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Deckenbeleuchtung", name: "Deckenlampe"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Luftreiniger", icon: "power", offColor: MSRed, onColor: MSGreen},
      //        <PageItem>{ id: "alias.0.NSPanel_1.TestBlind", icon: "projector-screen", onColor: White, name: "Beamer", secondRow: "auch Text"},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Radio.Bob", icon: "play", onColor: White, name: "TuneIn"}
      //let Radiosender: PageGrid =
      //    "items": [
      //        <PageItem>{ id: "alias.0.NSPanel_1.Radio.Bob", icon: "radio", name: "Radio BOB", onColor: colorRadio},
      //        <PageItem>{ id: "alias.0.NSPanel_1.Countdown", icon: "timer-outline", name: "Timer", onColor: White}
      //let WLED: PageGrid =
      //    "heading": "WLED Stripes WZ",
      //    "items": [
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.On", name: "Power", icon: "power", onColor: HMIOn, offColor: HMIOff},
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Sync", name: "Sync", icon: "sync", onColor: HMIOn, offColor: White},
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Segments", icon: "heart-outline", name: "Presets", onColor: White, modeList: ['Preset 0', 'Add Preset']},
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Colors", icon: "palette", name: "Colors", onColor: White,
      //                    modeList: ['Default', '* Color 1', '* Color Gradient', '* Colors 1&2', '* Colors Only', '* Random Cycle', 'Analogus','April Night', 'Aqua Flash', 'Atlantica', 'Aurora',
      //                               'Beach', 'Beech', 'Blink Red', 'Breeze', 'C9', 'C9 New', 'Candy', 'Candy2', 'Cloud',
      //                               'Cyane', 'Departure', 'Drywet', 'Fairy Reaf', 'Fire', 'Forest', 'etc'
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Effects", icon: "emoticon-outline", name: "Effects", onColor: White,
      //                    modeList: ['Solid', 'Android', 'Aurora', 'Blends', 'Blink', 'Blink Rainbow', 'Bouncing Balls','Bpm', 'Breathe', 'Candle', 'Candle Multi',
      //                               'Candy Cane', 'Chase', 'Chase 1', 'Chase 2', 'Chase 3', 'Chase Flash', 'Chase Flash Rnd', 'Chase Rainbow', 'Chase Random',
      //                               'Chunchun', 'Colorful', 'Colorloop', 'Colortwinkles', 'Colorwaves', 'Dancing Shadows', 'etc'
      //        <PageItem>{ id: "alias.0.NSPanel_1.WLED.Example.Segments", icon: "layers", name: "Segments", onColor: White, modeList: ['Segment 0', 'Add Segment']},
      let SensorGrid: PageGrid =
          "type": "cardGrid",
          "heading": "Sensor Werte",
          "useColor": true,
          "subPage": false,
          "items": [
              <PageItem>{ id: "alias.0.NSPanel_1.TestTemperatur", name: "Außentemp. °C", offColor: MSRed, onColor: MSGreen, useValue: true },
              <PageItem>{ id: "alias.0.NSPanel_1.TestFeuchtigkeit", name: "Luftfeuchte %", offColor: MSYellow, onColor: MSYellow , useValue: true },
              <PageItem>{ id: "alias.0.NSPanel_1.Taupunkt", name: "Taupunkt °C", offColor: MSRed, onColor: MSGreen, useValue: true },
              <PageItem>{ id: "alias.0.NSPanel_1.UV_Index", name: "UV Index", offColor: White , onColor: White, useValue: true },
              <PageItem>{ id: "alias.0.NSPanel_1.Windstaerke", name: "Windstärke bft", offColor: White , onColor: White, useValue: true },
              <PageItem>{ id: "alias.0.NSPanel_1.Luftdruck", name: "Luftdruck hPa", offColor: White , onColor: White, useValue: true }
      // NEW: Neue Definition von Medien-Aliasen
      // adapterPlayerInstance = alexa2.0. or spotify-premium.0. or sonos.0. or chromecast.0.
      let Alexa: PageMedia =
          'type': 'cardMedia',
          'heading': 'Alexa',
          'useColor': true,
          'subPage': false,
          'parent': undefined,
          'items': [<PageItem>{
                      id: AliasPath + 'Media.PlayerAlexa',
                      adapterPlayerInstance: 'alexa2.0.',
                      mediaDevice: 'G0XXXXXXXXXXXXXX', //Eigene Seriennummer des primären Alexa-Device einstellen
                      speakerList: ['Überall','Gartenhaus','Esszimmer','Heimkino','Echo Dot Küche','Echo Spot Buero'],
                      //analog alexa2 Music-Provider
                      playList: ['Spotify-Playlist.PartyPlaylist',
                                 'Amazon-Music-Playlist.Mein Discovery Mix',
                                 'My-Library-Playlist.2020',
                                 'My-Library-Playlist.2021',
                                 'TuneIn.Radio Bob Rock',
                                 'TuneIn.NDR2',
                                 'Spotify-Playlist.Sabaton Radio',
                                 'Spotify-Playlist.Rock Party',
                                 'Spotify-Playlist.This Is Nightwish',
                                 'Spotify-Playlist.Metal Christmas'],
                      equalizerList: ['Bassboost','Klassik','Dance', 'Deep', 'Electronic', 'Flat', 'Hip-Hop', 'Rock',
                                      'Metal', 'Jazz', 'Latin', 'Tonstärke', 'Lounge', 'Piano'],
                      colorMediaIcon: colorAlexa,
                      colorMediaArtist: Yellow,
                      colorMediaTitle: Yellow,
                      autoCreateALias : true
      let Sonos: PageMedia =
          'heading': 'Sonos',
          'useColor': true,
          'subPage': false,
                      id: AliasPath + 'Media.PlayerSonos',
                      adapterPlayerInstance: "sonos.0.",
                      mediaDevice: "10_55_28_132",
                      speakerList: ['Küche'],
                      colorMediaIcon: colorSpotify,
      let SpotifyPremium: PageMedia =
          "type": "cardMedia",
          "heading": "Spotify",
          "useColor": true,
          "subPage": false,
                      id: AliasPath + 'Media.PlayerSpotifyPremium',
                      adapterPlayerInstance: "spotify-premium.0.",
                      //Favoriten Playlists aus Spotify in Liste eintragen
                      playList: ['Toms Lieblingssongs','80er','#BeatsRadio','Italo Disco 80s','Ben Böhmer live above Cappadocia in Turkey for Cercle'],
                      repeatList: ['off','context','track'],
      let SqueezeboxRPC: PageMedia =
          "heading": "SqueezeboxRPC",
          "useColor": true,
          "subPage": false,
                      adapterPlayerInstance: "squeezeboxrpc.0.Players.SqueezePlay.",
                      speakerList: ['SqueezePlay']
      let Buero_Themostat: PageThermo =
          "type": "cardThermo",
          "heading": "Test Thermostat",
          "useColor": true,
          "subPage": false,
          "items": [<PageItem>{ id: "alias.0.NSPanel_1.Thermostat_Buero", minValue: 50, maxValue: 300 }]
      let Buero_Klimaanlage: PageThermo =
          "heading": "Test Klimaanlage",
          "useColor": true,
          "subPage": false,
                      minValue: 50,
                      maxValue: 250,
                      popupThermoMode1: ['Auto','0','1','2','3'],
                      popupThermoMode2: ['Auto','0','1','2','3','4','5'],
                      popupThermoMode3: ['Auto','Manual','Boost',],
                      popUpThermoName: ["Schwenk-Modus", 'Speed', 'Temperatur'],
                      icon: 'fan',
                      setThermoAlias: ['MODE1','MODE2','MODE3'],
                      setThermoDestTemp2: 'ACTUAL2'
      let Buero_Alarm: PageAlarm =
          "type": "cardAlarm",
          "heading": "Alarm",
          "useColor": true,
          "subPage": false,
          "items": [<PageItem>{ id: "alias.0.Alarm" }]
      let button1Page: PageGrid =
          'type': 'cardGrid',
          'heading': 'Radio',
          'useColor': true,
          'subPage': false,
          'items': [
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.FFN', icon: 'radio', name: 'FFN', onColor: colorRadio},
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Antenne' , icon: 'radio', name: 'Antenne Nds.', onColor: colorRadio},
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.NDR2', icon: 'radio', name: 'NDR2', onColor: colorRadio},
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Bob', icon: 'radio', name: 'Radio BOB', onColor: colorRadio},
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Spotify', icon: 'spotify', name: 'Party Playlist', onColor: colorSpotify},
              <PageItem>{ id: 'alias.0.NSPanel_1.Radio.Alexa', icon: 'playlist-music', name: 'Playlist 2021', onColor: colorAlexa}
      let button2Page: PageEntities =
          'type': 'cardEntities',
          'heading': 'Flur',
          'useColor': true,
          'subPage': false,
          'items': [
      //-- ENDE der Beispiele für Seitengestaltung -- Selbstdefinierte Aliase erforderlich ------------------
      //Service Pages mit Auto-Alias (Nachfolgende Seiten werden mit Alias automatisch angelegt)
      let Service: PageEntities =
          "heading": "NSPanel Service",
          "useColor": true,
          "subPage": false,
          "items": [
              <PageItem>{ id: AliasPath + 'autoUpdate', name: "Auto-Updates" ,icon: "update", offColor: MSRed, onColor: MSGreen},
              <PageItem>{ navigate: true, id: "NSPanel_Infos", icon: "information-outline", onColor: White, name: "NSPanel Infos"},
              <PageItem>{ navigate: true, id: "NSPanel_Firmware_Info", icon: "update", onColor: White, name: "Firmware Infos"},
              <PageItem>{ navigate: true, id: "NSPanel_Einstellungen", icon: "wrench-outline", onColor: White, name: "Screensaver"}
              //Subpage 1 von Subpages_2
              let NSPanel_Infos: PageEntities =
                  "heading": "NSPanel Infos",
                  "useColor": true,
                  "subPage": true,
                  "parent": Service,
                  "items": [
                      <PageItem>{ id: AliasPath + 'Tasmota.Hardware', name: 'Hardware', icon: 'memory', offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Sensor.ESP32.Temperature', name: "ESP Temperatur", icon: "thermometer", unit: "°C", offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Tasmota.Uptime', name: "Uptime", icon: "timeline-clock-outline", offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Tasmota.Wifi.RSSI', name: "Wifi-Signal", icon: "signal-distance-variant", unit: "dBm", offColor: MSYellow, onColor: MSYellow, useColor: true}
              //Subpage 2 von Subpages_2
              let NSPanel_Einstellungen: PageEntities =
                  'heading': 'Screensaver',
                  'useColor': true,
                  'subPage': true,
                  'parent': Service,
                  'items': [
                      <PageItem>{ id: AliasPath + 'Dimmode.brightnessDay', name: 'Brightness Tag', icon: 'brightness-5', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 5, maxValue: 10},
                      <PageItem>{ id: AliasPath + 'Dimmode.brightnessNight', name: 'Brightness Nacht', icon: 'brightness-4', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 4},
                      <PageItem>{ id: AliasPath + 'Dimmode.hourDay', name: 'Stunde Tag', icon: 'sun-clock', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23},
                      <PageItem>{ id: AliasPath + 'Dimmode.hourNight', name: 'Stunde Nacht', icon: 'sun-clock-outline', offColor: MSYellow, onColor: MSYellow, useColor: true, minValue: 0, maxValue: 23}
              //Subpage 3 von Subpages_2
              let NSPanel_Firmware_Info: PageEntities =
                  'heading': 'Firmware-Updates',
                  'useColor': true,
                  'subPage': true,
                  'parent': Service,
                  'items': [
                      <PageItem>{ id: AliasPath + 'Tasmota.Version', name: 'Tasmota Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Display.TFTVersion', name: 'TFT-Firmware', offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Display.BerryDriver', name: 'Berry-Treiber', offColor: MSYellow, onColor: MSYellow, useColor: true},
                      <PageItem>{ id: AliasPath + 'Display.Model', name: 'NSPanel Version', offColor: MSYellow, onColor: MSYellow, useColor: true}
      • ArmilarA Armilar
        @tomduke
        TomDukeT Offline
        TomDukeT Offline
        TomDuke
        #1351
        @armilar sagte in SONOFF NSPanel mit Lovelace UI:
        @tomduke
        alles gut, sitze auch nicht ständig am Mac, bin ja froh das du mir hilfst
        • W Wuschl
          @kuckuckmann habe geduldig gewartet :-)
          um deine Fragen gerne zu beantworten..
          • die Datenpunkte sind nach dem Neustart leer
          • ein Display berühre ich regelmäßig, befindet sich direkt neben der Haustür.
          • der Haken im MQTT Adapter ist nicht gesetzt
          Kuckuckmann
          #1352
          @wuschl
          ja, dann die nächsten Fragen:
          • Welche node js Version hast Du installiert?
          • welche NPM Version hast Du installiert?
          • Welche Version des TS-Skriptes nutzt Du?
          • welche JS-Version hast Du installiert?
          Danke Dir und LG
          NSPanel Dokumentation im GitHub Wiki:
          W 1 Antwort Letzte Antwort
          • TomDukeT TomDuke
            @tomduke
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #1353
            @tomduke sagte in SONOFF NSPanel mit Lovelace UI:
            Hm... ist auch alles Top
            Wir sollten kurz die erweiterte Protokollierung anschalten, damit man lokalisieren kann wo die Warnungen auftauchen...
            oben in der Ecke ist ein Schraubenschlüssel
            Haken rein und einmal Script durchstarten ab026e25-9dd5-4625-baaf-85c440c46101-image.png
            Dann das Log senden in dem die Warnungen sind und ein wenig normale Meldungen drumherum...
            TomDukeT 1 Antwort Letzte Antwort
            • K Kuckuckmann
              @wuschl
              Danke Dir und LG
              W Offline
              W Offline
              Wuschl
              #1354
              @kuckuckmann okay... :-)
              • node js 16.19.0
              • npm 8.19.3
              • ts-skript 3.7.0
              • js 6.1.4
              sehr gerne
              • W Wuschl
                • node js 16.19.0
                • npm 8.19.3
                • ts-skript 3.7.0
                • js 6.1.4
                sehr gerne
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #1355
                @wuschl
                Was genau läuft denn nicht?
                Also Uhrzeit hatte ich gelesen funktioniert...
                Was aktualisiert sich denn nicht?:
                • Datum?
                • Status Relais Icons oben?
                • Großes Wettersymbol?
                • Außentemperatur?
                • Kleine Icons unten?
                Irgendetwas individuell am Code verändert?
                Gibt es Warnungen?
                • ArmilarA Armilar
                  @wuschl
                  • Datum?
                  • Außentemperatur?
                  Gibt es Warnungen?
                  W Offline
                  W Offline
                  Wuschl
                  schrieb am zuletzt editiert von Wuschl
                  #1356
                  @armilar wenn der iobroker einen Neustart macht, dann ist an den Panels der Screensaver aktiv, aber sonst keinerlei Reaktion mehr wenn man auf das Display tippt. Erst wenn ich das Skript stoppe und wieder starte dann gehts wieder.
                  Nichts verändert, gestern Abend noch die 3.7.3 aufgespielt.
                  • W Wuschl
                    ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #1357
                    @wuschl
                    Was ist die 1. Seite für eine? Also wenn die in der Config mal auskommentiert wird?
                    • ArmilarA Armilar
                      @wuschl
                      W Offline
                      W Offline
                      Wuschl
                      #1358
                      @armilar
                      var Flur: PageEntities =
                          "heading": "Flur",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                              <PageItem>{ id: "alias.0.NsPanelGarage.Fernsehen", name: "Fernsehen", interpolateColor: true},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Garage-Bernd", offColor: MSGreen, onColor: MSRed, name: "Garagentor", icon: "garage-variant", icon2: "garage-open-variant"},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Radio_ein", name: "Radio", interpolateColor: true},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Deko-Flur", name: "Flur-Deko", minValueBrightness: 0, maxValueBrightness: 100, interpolateColor: true},
                      var Luftfeuchte: PageEntities =
                          "heading": "Luftfeuchte",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                              <PageItem>{ id: "alias.0.Luftfeuchte.Wohnzimmer", name: "Wohnzimmer", icon: "water-percent", unit: "%H", onColor: White },
                              <PageItem>{ id: "alias.0.Luftfeuchte.Bad", name: "Badezimmer", icon: "water-percent", unit: "%H", onColor: White },
                              <PageItem>{ id: "alias.0.Luftfeuchte.Schlafzimmer", name: "Schlafzimmer", icon: "water-percent", unit: "%H", onColor: White },
                              <PageItem>{ id: "alias.0.Luftfeuchte.Küche", name: "Küche", icon: "water-percent", unit: "%H", onColor: White },
                      var Küche: PageEntities =
                          "heading": "Küche",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                              <PageItem>{ id: "alias.0.NsPanelGarage.Küche", name: "Küche", interpolateColor: true},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Spüle", name: "Spüle", interpolateColor: true},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Rollo", onColor: White, name: "Rollo Küche"},
                              <PageItem>{ id: "alias.0.NsPanelGarage.Deko-Küche", name: "Küche-Deko", minValueBrightness: 0, maxValueBrightness: 100, interpolateColor: true},
                      var Garagen: PageEntities =
                          "heading": "Garagen",
                          "useColor": true,
                          "subPage": false,
                          "items": [
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Audi", offColor: MSGreen, onColor: MSRed, name: "Garage Audi", icon: "garage-variant", icon2: "garage-open-variant"},
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Polo", offColor: MSGreen, onColor: MSRed, name: "Garage Polo", icon: "garage-variant", icon2: "garage-open-variant"},
                              <PageItem>{ id: "alias.0.Garagen-Papa.Garage-Fahrräder", offColor: MSGreen, onColor: MSRed, name: "Garage Fahrräder", icon: "garage-variant", icon2: "garage-open-variant"},
                      var WLAN: PageQR =
                          "type": "cardQR",
                          "useColor": true,
                          "subPage": false,
                          "items": [<PageItem>{ id: "alias.0.NsPanelGarage.WLAN" }]
                      • W Wuschl
                        @armilar
                            "heading": "Flur",
                            "useColor": true,
                            "subPage": false,
                            "items": [
                            "useColor": true,
                            "subPage": false,
                            "items": [
                            "heading": "Küche",
                            "useColor": true,
                            "subPage": false,
                            "items": [
                            "useColor": true,
                            "subPage": false,
                            "items": [
                        var WLAN: PageQR =
                            "type": "cardQR",
                            "useColor": true,
                            "subPage": false,
                        ArmilarA Offline
                        ArmilarA Offline
                        Armilar
                        #1359
                        @wuschl
                        Und die erreichst du alle nicht mehr?
                        • ArmilarA Armilar
                          @wuschl
                          W Offline
                          W Offline
                          Wuschl
                          #1360
                          @armilar nein keine Reaktion mehr, aber auf allen 3 Panels die aktiv sind
                          • W Wuschl
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #1361
                            @wuschl
                            werf mal von einem Panel die 0_userdata weg (komplett)
                            Dann anlegen lassen durch das Script
                            Wobei das schon interessant ist, dass alle nicht laufen...
                            • ArmilarA Armilar
                              @wuschl
                              W Offline
                              W Offline
                              Wuschl
                              #1362
                              @armilar schon probiert gestern, ändert nichts.
                              • W Wuschl
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #1363
                                @wuschl
                                Was sagt das Tasmota-Log wenn du es rebootest?
                                ArmilarA W 2 Antworten Letzte Antwort
                                • ArmilarA Armilar
                                  @wuschl
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #1364
                                  @armilar
                                  Spannend ist wirklich das alle betroffen sind. Das spricht doch eigentlich mehr für ein globaleres Problem. Der erste Aufbau funktioniert und danach keine Aktualisierung mehr...
                                  • ArmilarA Armilar
                                    @wuschl
                                    W Offline
                                    W Offline
                                    Wuschl
                                    #1365
                                    @armilar Wie meinst du das Tasmota Log, aus der Konsole?
                                    • W Wuschl
                                      ArmilarA Offline
                                      ArmilarA Offline
                                      Armilar
                                      #1366
                                      @wuschl
                                      Ja die Console, kurz nach dem Reboot eines Panels
                                      • ArmilarA Armilar
                                        @wuschl
                                        W Offline
                                        W Offline
                                        Wuschl
                                        #1367
                                        @armilar
                                        20:28:53.253 MQT: Attempting connection...
                                        20:28:53.279 MQT: Connected
                                        20:28:53.284 MQT: tele/NS-Panel-Vroni_0BEC90/LWT = Online (retained)
                                        20:28:53.287 MQT: cmnd/NS-Panel-Vroni_0BEC90/POWER =
                                        20:28:53.293 MQT: tele/NS-Panel-Vroni_0BEC90/INFO1 = {"Info1":{"Module":"NSPanel","Version":"12.3.1(nspanel)","FallbackTopic":"cmnd/DVES_0BEC90_fb/","GroupTopic":"cmnd/tasmotas/"}}
                                        20:28:53.308 MQT: tele/NS-Panel-Vroni_0BEC90/INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"NS-Panel-Vroni-0BEC90-3216","IPAddress":"192.168.178.199"}}
                                        20:28:53.322 MQT: tele/NS-Panel-Vroni_0BEC90/INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":37}}
                                        20:28:53.336 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:53.338 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:53.345 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER2":"OFF"}
                                        20:28:53.348 MQT: stat/NS-Panel-Vroni_0BEC90/POWER2 = OFF
                                        20:28:53.484 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:53.487 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:53.606 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:53.630 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:53.632 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:53.751 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:53.789 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:53.799 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:53.905 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:53.942 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:53.950 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:54.050 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:55.538 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"POWER1":"OFF"}
                                        20:28:55.546 MQT: stat/NS-Panel-Vroni_0BEC90/POWER1 = OFF
                                        20:28:55.902 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.100 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.128 MQT: tele/NS-Panel-Vroni_0BEC90/RESULT = {"CustomRecv":"event,startup,46,eu"}
                                        20:28:56.209 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.249 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.298 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.359 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.485 MQT: stat/NS-Panel-Vroni_0BEC90/RESULT = {"CustomSend":"Done"}
                                        20:28:56.908 QPC: Reset
                                        aber das Problem ist ja nicht nach dem Neustart des Panels, sondern nach dem Neustart des IOBrokers
                                        • W Wuschl
                                          @armilar
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #1368
                                          @wuschl
                                          Wie sieht das Problem denn aus? Also mit dem Start des ioBrokers?
