  4. [gelöst] Cloud Adapter "terminated" seit 2 Tagen ohne erkennbaren Grund
9 Beiträge 3 Kommentatoren 1.2k Aufrufe
    tempestas
    Moin,
    seit vorgestern Nacht bekomme ich keine Verbindung mehr für den Cloud Adapter, log sieht (unendlich lang) so aus
    ` > host.raspberrypi 2017-08-11 07:55:02.717 info object change system.adapter.cloud.0
    host.raspberrypi 2017-08-11 07:55:02.558 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:55:02.557 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:55:01.933 info instance system.adapter.cloud.0 started with pid 9296
    host.raspberrypi 2017-08-11 07:55:00.910 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:55:00.909 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:55:00.547 info instance system.adapter.tankerkoenig.0 started with pid 9290
    host.raspberrypi 2017-08-11 07:55:00.274 info instance system.adapter.cloud.0 started with pid 9284
    host.raspberrypi 2017-08-11 07:54:59.238 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:54:59.237 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:54:58.635 info instance system.adapter.cloud.0 started with pid 9278
    host.raspberrypi 2017-08-11 07:54:55.441 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:54:55.440 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:54:54.715 info instance system.adapter.cloud.0 started with pid 9272
    host.raspberrypi 2017-08-11 07:54:53.691 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:54:53.691 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:54:53.165 info instance system.adapter.cloud.0 started with pid 9266
    host.raspberrypi 2017-08-11 07:54:52.128 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:54:52.127 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:54:51.532 info instance system.adapter.cloud.0 started with pid 9260
    host.raspberrypi 2017-08-11 07:54:50.498 info Restart adapter system.adapter.cloud.0 because enabled
    host.raspberrypi 2017-08-11 07:54:50.497 error instance system.adapter.cloud.0 terminated with code 1 ()
    host.raspberrypi 2017-08-11 07:54:49.937 info instance system.adapter.cloud.0 started with pid 9254 `
    Ein Neustart des Pi hat kurzfristig geholfen, aber wenig später sieht es dann wieder aus wie oben.
    Alles andere läuft völlig normal und ohne Probleme.
    Was kann ich tun?
    <size="85">ioBroker | 21 Adapter | Ubuntu Server | intel NUC | Homematic CCU2 | Hue | Osram Lightify| Sonos | 2x Instar Cam | Samsung Tab A 2016 im Holzrahmen| 3x Echo dot | 1x Echo | Neato Botvac D5</size>
    • eric2905E Offline
      eric2905E Offline
      eric2905
      Moin,
      @tempestas:
      Was kann ich tun? `
      erst mal posten, welche Versionen Du installiert hast ;)
      • js-controller
      • admin
      • cloud
      Melde Dich mal unter https://iobroker.net an. Evtl. musst Du dort die Lizenzbestimmungen bestätigen.
      Gruß,
      Eric
      Von unterwegs getippert
        tempestas
        Hi Eric,
        danke für die Hinweise, hier die Antworten:
        zum Thema Lizenz: ich glaube, ich gehörte mit zu den ersten, die das getan haben :)
        wenn ich auf https://iobroker.net gehe und mich anmelde kommt, dass ich noch nicht verbunden bin… mehr passert nicht. Ist ja irgendwie auch logisch, wenn der cloud Adapter net mehr will.
        Im Profil sehe ich keine Auffälligkeiten. Es wird auch keine Bestätigung von irgendwas verlangt.
        installiert ist:
        cloud: 1.0.7
        admin: 1.7.6
        js: da bin ich zu blöd, wo finde ich das?
        • eric2905E Offline
          eric2905E Offline
          eric2905
          Reiter „Host“ im Admin.
          BTW: Mal den API-Key überprüft (nur zur Sicherheit)?
          Gruß,
          Eric
            tempestas
            kanns ja mal aktualisieren.
            API Key prüfe ich, aber wieso sollte der sich über Nacht wenn ich schlafe verstellen.
            Plus, nachdem ich den Raspi komplett reboote, ging der Cloud Adapter ja eine Weile
              tempestas
              Aktualisiert auf 1.0.3 (es gibt doch schon 1.1.12?).
              Mehr wollte er mir aber beim upgrade nicht zugestehen. Na ja.
              Jetzt ist es erstmal wieder verbunden, die spannende Frage ist: wie lange. Denn ich habe ioBroker ja neugestartet.
              Ich melde mich wenn es entweder wieder Probleme gibt, oder in ein paar Stunden, falls es weiter läuft
              • eric2905E Offline
                eric2905E Offline
                eric2905
                @tempestas:
                Mehr wollte er mir aber beim upgrade nicht zugestehen. Na ja. `
                Welches Repository / Verwahrungsort verwendest Du?
                „Latest“ beinhaltet auch „instabile“ Versionen, „Stable“ halt die stabilen, die keine gemeldeten Fehler mehr haben.
                Gruß,
                Eric
                  Liesmich:
                  http://forum.iobroker.net/viewtopic.php … positories
                    tempestas
                    Ach Jungs / Männer: auf eure Hilfe ist verlass, danke!
