  3. Einsteigerfragen
  4. Installation
  5. Orange Pi 5 | Installation IOBroker schlägt fehl
18 Beiträge 3 Kommentatoren 2.2k Aufrufe 2 Beobachtet
  • L LaplaceII
    @thomas-braun Die manuelle Installation von nodejs entlang der Anleitung funktioniert auch nicht. Oder muss ich hier warten bis das apt update funktioniert bzw. gibt es ggf. eine Möglichkeit das zu umgehen?
    orangepi@orangepi5:~$ cd /opt/iobroker
    orangepi@orangepi5:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash
    [sudo] password for orangepi:
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    Get:1 https://deb.nodesource.com/node_16.x bullseye InRelease [4,586 B]
    Err:1 https://deb.nodesource.com/node_16.x bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    Hit:2 https://repo.huaweicloud.com/debian bullseye InRelease
    Hit:3 https://repo.huaweicloud.com/debian bullseye-updates InRelease
    Hit:4 https://repo.huaweicloud.com/debian bullseye-backports InRelease
    Hit:5 https://repo.huaweicloud.com/debian-security bullseye-security InRelease
    Get:6 https://repo.huaweicloud.com/docker-ce/linux/debian bullseye InRelease [43.3 kB]
    Get:7 https://repo.huaweicloud.com/docker-ce/linux/debian bullseye/stable arm64 Packages [16.6 kB]
    Get:8 https://repo.huaweicloud.com/docker-ce/linux/debian bullseye/stable arm64 Contents (deb) [1,375 B]
    Err:8 https://repo.huaweicloud.com/docker-ce/linux/debian bullseye/stable arm64 Contents (deb)
      Hash Sum mismatch
      Hashes of expected file:
       - Filesize:1375 [weak]
       - SHA512:cb21325e11979c44e4dcf4d9932dd86bcdc87711ea58081e46dd0482875f5816f9ab411f156a6786ae2ad53d39d3126d2bdfd00c95ce5ecffcd6063bed886700
       - SHA256:e28e16fb2a8521f8de3d1085cb35bc456b4286ccf8b516c7485347fbf2f5895f
       - SHA1:a038fc45299b05fa2b7d15fbc5d1fe5f80811627 [weak]
       - MD5Sum:086018c06f94126b2293ea617923ccd4 [weak]
      Hashes of received file:
       - SHA512:8ed8b58b0663e1fb87640077060bce0e5c2d247da20e02f4ff3e37649fae7aecd6df367a42f0be03e0453cc0a28b20918a2a58ad6df32ae862b540d93fa804da
       - SHA256:2d57ca917e5f742aa894464e7eff23652c2ed93740e90148a34f543c09a13828
       - SHA1:82c78b8a6a4c9deecf6ae1523b2e31cf8cfeffb1 [weak]
       - MD5Sum:d43060e29468dfa49485ae2671fb2439 [weak]
      Last modification reported: Fri, 25 Nov 2022 10:12:41 +0000
      Release file created at: Mon, 19 Dec 2022 12:12:36 +0000
    Reading package lists... Done
    W: GPG error: https://deb.nodesource.com/node_16.x bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280
    E: The repository 'https://deb.nodesource.com/node_16.x bullseye InRelease' is not signed.
    N: Updating from such a repository can't be done securely, and is therefore disabled by default.
    N: See apt-secure(8) manpage for repository creation and user configuration details.
    Error executing command, exiting
    orangepi@orangepi5:/opt/iobroker$ sudo apt install nodejs
    nodejs is already the newest version (12.22.12~dfsg-1~deb11u1).
    0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
    orangepi@orangepi5:/opt/iobroker$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    @laplaceii
    1. Frage: Wozu brauchst du den Docker überhaupt?
    Nicht benötigte Software schleppt man auch nicht durch.
    L 1 Antwort Letzte Antwort
      @laplaceii
      LaplaceII
      @thomas-braun ich brauchs nicht. Das steckt in der apt update routine drin....kann ich das los werden?
      • L LaplaceII
        @laplaceii
        Dann lösch die entsprechende .list-Datei. Dürfte sich in /etc/apt/sources.list.d/ finden. Wie die heißt weiß ich allerdings nicht.
        ls -lA /etc/apt/sources.list.d/
        sagt?
          @laplaceii
          sagt?
          LaplaceII
          @thomas-braun perfekt das war die Ursache. Ich habe die docker.list gelöscht und danach ist alles durch gelaufen. Also issue solved! Vielen Dank und happy xmas
          • L LaplaceII
            @laplaceii
            Gut. Was sagt jetzt
            uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            • L LaplaceII
              @laplaceii sagte in Orange Pi 5 | Installation IOBroker schlägt fehl:
              hä?
              https://repo.huaweicloud.com/docker-ce/linux/debian/dists/bullseye/s
              Huaweicloud?
              wo kommt die denn her?
              Was machst du da überhaupt?
                @laplaceii
                Gut. Was sagt jetzt
                LaplaceII
                @thomas-braun Hier das Ergebnis der Befehle:
                orangepi@orangepi5:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                orangepi@orangepi5:~$ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                aarch64
                Kein Docker
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.19.0
                v16.19.0
                8.19.3
                4.0.23
                orangepi
                orangepi tty disk dialout sudo audio video plugdev games users systemd-journal input netdev ssh docker iobroker
                tty
                /home/orangepi
                Hit:1 https://deb.nodesource.com/node_16.x bullseye InRelease
                All packages are up to date.
                nodejs:
                  Installed: 16.19.0-deb-1nodesource1
                  Candidate: 16.19.0-deb-1nodesource1
                  Version table:
                 *** 16.19.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u1 500
                        500 https://repo.huaweicloud.com/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 https://repo.huaweicloud.com/debian bullseye/main arm64 Packages
                • L LaplaceII
                  aarch64
                  Kein Docker
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.19.0
                  v16.19.0
                  8.19.3
                  4.0.23
                  orangepi
                  tty
                  /home/orangepi
                  nodejs:
                    Version table:
                  @laplaceii
                  Passt. Der huawei-Mirror irritiert mich immer noch. Sehr ungewöhnlich.
                    hä?
                    Huaweicloud?
                    LaplaceII
                    @homoran Die Verbindung zur Huaweicloud kommt aus der Debian Installation für den OrangePi5, welche ich von der Internetseite für den OrangePi5 heruntergeladen habe. Folgende Verbindungen werden dort aufgebaut:
                    +deb https://repo.huaweicloud.com/debian bullseye main contrib non-free
                    #deb-src https://repo.huaweicloud.com/debian bullseye main contrib non-free
                    deb https://repo.huaweicloud.com/debian bullseye-updates main contrib non-free
                    #deb-src https://repo.huaweicloud.com/debian bullseye-updates main contrib non-free
                    deb https://repo.huaweicloud.com/debian bullseye-backports main contrib non-free
                    #deb-src https://repo.huaweicloud.com/debian bullseye-backports main contrib non-free
                    deb https://repo.huaweicloud.com/debian-security bullseye-security main contrib non-free
                    #deb-src https://repo.huaweicloud.com/debian-security bullseye-security main contrib non-free
                    Die Huaweicloud ist auch bei Debian als offizieller mirror geführt https://www.debian.org/mirror/list.de.html
                    Kann ich den Mirror einfach wechseln, indem ich repo.huaweicloud.com durch z.B. ftp-stud.hs-esslingen.de austausche? Bzw. welchen Mirror würdet Ihr empfehlen?
                      @laplaceii
                      LaplaceII
                      @thomas-braun mich auch...
                      • L LaplaceII
                        @laplaceii
                        apt sucht sich eigentlich von alleine den besten Mirror.
                        Jedenfalls wenn nicht ein fixer Mirror in die .list-Files hart eingetragen wurde.
                        Kann sein das für deinen Standort der Server der nächste ist. Häufiger sieht man halt Esslingen, Halifax oder Uni Graz usw.
                          @laplaceii
                          LaplaceII
                          @thomas-braun Wohne am Bodensee. Esslingen sollte näher sein ;-)
                          In der sources.list sind die Huawaiserver eingetragen...Kann man das einfach rausnehmen oder besser ersetzen?
                          • L LaplaceII
                            @laplaceii
                            Last login: Wed Dec 21 17:27:28 2022 from 100.75.198.95
                            echad@chet:~ $ cat /etc/apt/sources.list
                            deb http://deb.debian.org/debian bullseye main contrib non-free
                            deb http://security.debian.org/debian-security bullseye-security main contrib non-free
                            deb http://deb.debian.org/debian bullseye-updates main contrib non-free
                            deb http://deb.debian.org/debian bullseye-backports main contrib non-free
                            # Uncomment deb-src lines below then 'apt-get update' to enable 'apt-get source'
                            #deb-src http://deb.debian.org/debian bullseye main contrib non-free
                            #deb-src http://security.debian.org/debian-security bullseye-security main contrib non-free
                            #deb-src http://deb.debian.org/debian bullseye-updates main contrib non-free
                            #deb-src http://deb.debian.org/debian bullseye-backports main contrib non-free
                            echad@chet:~ $
                            deb.debian.org wird dann entsprechend an den besten Mirror umgeleitet.
