  4. Test Adapter EnOcean v0.8.x
    6.5k
enocean
255 Beiträge 25 Kommentatoren 66.0k Aufrufe 26 Beobachtet
  • B Black-Raven
    @jey-cee Erstmal Danke für die schnelle Antwort und die Mühe um den Adapter. So jetzt hab ich die beiden Gateways mal gegenübergestellt und jeweils den gleichen Aktor eingelernt.
    FGW14:
      "nodeVersion": "v16.18.1",
      "serialDevices": [
        "/dev/ttyUSB0",
        "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH05TOEX-if00-port0"
      "instance": {
        "native": {
          "serialport": "/dev/ttyUSB0",
          "ser2net": false,
          "ser2net-ip": "",
          "ser2net-port": "",
          "esp2Switch": false,
          "gateway": "fgw14-usb",
          "device-id": "",
          "device-name": ""
        "version": "0.8.4",
        "installedFrom": "Jey-Cee/ioBroker.enocean#dd123fbf39b837136258b79d10117c49e4befb03"
      "devices": [
          "_id": "enocean.0.gateway",
          "native": {
            "BaseID": "00010000",
            "Frequency": "868.3 Mhz",
            "Protocol": "ESP2",
            "AppVersion": "1.0.0.0",
            "ApiVersion": "1.0.0.0",
            "ChipID": "00000001",
            "ChipVersion": "00000001",
            "AppDescription": "Eltako RS485 Bus Gateway",
            "senderIDs": {
              "10001": "ffaf7291",
              "10002": "",
              "10003": "",
              "10004": "",
              "10005": "",
              "10006": "",
              "10007": "",
              "10008": "",
              "10009": "",
              "10010": "",
              "10011": "",
              "10012": "",
              "10013": "",
              "10014": "",
              "10015": "",
              "10016": "",
              "10017": "",
              "10018": "",
              "10019": "",
              "10020": "",
              "10021": "",
              "10022": "",
              "10023": "",
              "10024": "",
              "10025": "",
              "10026": "",
              "10027": "",
              "10028": "",
              "10029": "",
              "10030": "",
              "10031": "",
              "10032": "",
              "10033": "",
              "10034": "",
              "10035": "",
              "10036": "",
              "10037": "",
              "10038": "",
              "10039": "",
              "10040": "",
              "10041": "",
              "10042": "",
              "10043": "",
              "10044": "",
              "10045": "",
              "10046": "",
              "10047": "",
              "10048": "",
              "10049": "",
              "10050": "",
              "10051": "",
              "10052": "",
              "10053": "",
              "10054": "",
              "10055": "",
              "10056": "",
              "10057": "",
              "10058": "",
              "10059": "",
              "10060": "",
              "10061": "",
              "10062": "",
              "10063": "",
              "10064": "",
              "10065": "",
              "10066": "",
              "10067": "",
              "10068": "",
              "10069": "",
              "10070": "",
              "10071": "",
              "10072": "",
              "10073": "",
              "10074": "",
              "10075": "",
              "10076": "",
              "10077": "",
              "10078": "",
              "10079": "",
              "1000a": "",
              "1000b": "",
              "1000c": "",
              "1000d": "",
              "1000e": "",
              "1000f": "",
              "1001a": "",
              "1001b": "",
              "1001c": "",
              "1001d": "",
              "1001e": "",
              "1001f": "",
              "1002a": "",
              "1002b": "",
              "1002c": "",
              "1002d": "",
              "1002e": "",
              "1002f": "",
              "1003a": "",
              "1003b": "",
              "1003c": "",
              "1003d": "",
              "1003e": "",
              "1003f": "",
              "1004a": "",
              "1004b": "",
              "1004c": "",
              "1004d": "",
              "1004e": "",
              "1004f": "",
              "1005a": "",
              "1005b": "",
              "1005c": "",
              "1005d": "",
              "1005e": "",
              "1005f": "",
              "1006a": "",
              "1006b": "",
              "1006c": "",
              "1006d": "",
              "1006e": "",
              "1006f": "",
              "1007a": "",
              "1007b": "",
              "1007c": "",
              "1007d": "",
              "1007e": ""
            "BaseID_offset": 0
          "native": {
            "id": "ffaf7291",
            "eep": [
              "TF-14-01",
              "TF-14-02"
            "manufacturer": "ELTAKO",
            "Sender_ID": "10001"
          "_id": "enocean.0.ffaf7291"
    FAM USB 515:
      "serialDevices": [
        "/dev/ttyUSB0",
        "/dev/serial/by-id/usb-BSC_Computer_GmbH_FAM-USB-515_AB7BBEG7-if00-port0"
      "instance": {
        "native": {
          "ser2net": false,
          "ser2net-ip": "",
          "ser2net-port": "",
          "gateway": "usb300",
          "device-id": "",
          "device-name": ""
        "version": "0.8.4",
      "devices": [
          "native": {
            "BaseID": "ffa6b180",
            "Protocol": "ERP1",
            "AppVersion": "1.6.1.0",
            "ApiVersion": "1.5.1.231",
            "ChipID": "04224d63",
            "ChipVersion": "454f0103",
            "AppDescription": "TCM515",
            "senderIDs": {
              "ffa6b181": "ffaf7291",
              "ffa6b182": "",
              "ffa6b183": "",
              "ffa6b184": "",
              "ffa6b185": "",
              "ffa6b186": "",
              "ffa6b187": "",
              "ffa6b188": "",
              "ffa6b189": "",
              "ffa6b18a": "",
              "ffa6b18b": "",
              "ffa6b18c": "",
              "ffa6b18d": "",
              "ffa6b18e": "",
              "ffa6b18f": "",
              "ffa6b190": "",
              "ffa6b191": "",
              "ffa6b192": "",
              "ffa6b193": "",
              "ffa6b194": "",
              "ffa6b195": "",
              "ffa6b196": "",
              "ffa6b197": "",
              "ffa6b198": "",
              "ffa6b199": "",
              "ffa6b19a": "",
              "ffa6b19b": "",
              "ffa6b19c": "",
              "ffa6b19d": "",
              "ffa6b19e": "",
              "ffa6b19f": "",
              "ffa6b1a0": "",
              "ffa6b1a1": "",
              "ffa6b1a2": "",
              "ffa6b1a3": "",
              "ffa6b1a4": "",
              "ffa6b1a5": "",
              "ffa6b1a6": "",
              "ffa6b1a7": "",
              "ffa6b1a8": "",
              "ffa6b1a9": "",
              "ffa6b1aa": "",
              "ffa6b1ab": "",
              "ffa6b1ac": "",
              "ffa6b1ad": "",
              "ffa6b1ae": "",
              "ffa6b1af": "",
              "ffa6b1b0": "",
              "ffa6b1b1": "",
              "ffa6b1b2": "",
              "ffa6b1b3": "",
              "ffa6b1b4": "",
              "ffa6b1b5": "",
              "ffa6b1b6": "",
              "ffa6b1b7": "",
              "ffa6b1b8": "",
              "ffa6b1b9": "",
              "ffa6b1ba": "",
              "ffa6b1bb": "",
              "ffa6b1bc": "",
              "ffa6b1bd": "",
              "ffa6b1be": "",
              "ffa6b1bf": "",
              "ffa6b1c0": "",
              "ffa6b1c1": "",
              "ffa6b1c2": "",
              "ffa6b1c3": "",
              "ffa6b1c4": "",
              "ffa6b1c5": "",
              "ffa6b1c6": "",
              "ffa6b1c7": "",
              "ffa6b1c8": "",
              "ffa6b1c9": "",
              "ffa6b1ca": "",
              "ffa6b1cb": "",
              "ffa6b1cc": "",
              "ffa6b1cd": "",
              "ffa6b1ce": "",
              "ffa6b1cf": "",
              "ffa6b1d0": "",
              "ffa6b1d1": "",
              "ffa6b1d2": "",
              "ffa6b1d3": "",
              "ffa6b1d4": "",
              "ffa6b1d5": "",
              "ffa6b1d6": "",
              "ffa6b1d7": "",
              "ffa6b1d8": "",
              "ffa6b1d9": "",
              "ffa6b1da": "",
              "ffa6b1db": "",
              "ffa6b1dc": "",
              "ffa6b1dd": "",
              "ffa6b1de": "",
              "ffa6b1df": "",
              "ffa6b1e0": "",
              "ffa6b1e1": "",
              "ffa6b1e2": "",
              "ffa6b1e3": "",
              "ffa6b1e4": "",
              "ffa6b1e5": "",
              "ffa6b1e6": "",
              "ffa6b1e7": "",
              "ffa6b1e8": "",
              "ffa6b1e9": "",
              "ffa6b1ea": "",
              "ffa6b1eb": "",
              "ffa6b1ec": "",
              "ffa6b1ed": "",
              "ffa6b1ee": "",
              "ffa6b1ef": "",
              "ffa6b1f0": "",
              "ffa6b1f1": "",
              "ffa6b1f2": "",
              "ffa6b1f3": "",
              "ffa6b1f4": "",
              "ffa6b1f5": "",
              "ffa6b1f6": "",
              "ffa6b1f7": "",
              "ffa6b1f8": "",
              "ffa6b1f9": "",
              "ffa6b1fa": "",
              "ffa6b1fb": "",
              "ffa6b1fc": "",
              "ffa6b1fd": "",
              "ffa6b1fe": ""
            "BaseID_offset": 0
          "native": {
            "id": "ffaf7291",
            "eep": [
              "TF-14-01",
              "TF-14-02"
            "Sender_ID": "ffa6b181"
    Gruß Martin
    Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    #91
    @black-raven ich Zitieren mich mal selbst:
    Die Bus Geräte melden sich mit ihrer Bus Adresse, das heist es fängt bei 00 00 00 01 an.
    Für den Anlernprozess bedeutet dass, das man einfach nur die Bus Adresse angibt. Sonst ist soweit alles gleich wie bisher auch.
    Du verwendest hier beim FGW14 jedoch die ID die der FAM14 benutzt für das Gerät.
    Mich Überrascht das du das Gerät so Steuern kannst, aber vielleicht interpretiert der FAM14 das richtig und gibt das an den Aktor weiter.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
    • Jey CeeJ Jey Cee
      Black-Raven
      #92
      @jey-cee Habs jetzt mal mit der Busadresse in dezimal und hexadezimal ausprobiert, das Ergebnis bleibt jedoch das gleiche. Was mir aufgefallen ist, der Datenpunkt enocean.0.gateway.lastID zeigt wenn ich über das FAM USB 515 fahre schön brav an wenn sich einer der Aktoren zu Wort meldet. Über das FGW14 bleibt dieser Datenpunkt dauerhaft auf "(null)".
      • B Black-Raven
        Jey CeeJ Offline
        Jey CeeJ Offline
        Jey Cee
        #93
        @black-raven hat jetzt etwas gedauert den Fehler zu beheben, da gab es zwei Problemstellen. Bitte installiere mal von Github neu und gib mir Rückmeldung.
        • Jey CeeJ Jey Cee
          Black-Raven
          #94
          @jey-cee Jetzt siehts besser aus. Heute morgen hab ichs mal ausprobiert und siehe da die FTS14EM haben auf einmal wieder eine Reaktion gezeigt und liesen sich einlernen. Mit den F4SR14-LED hatte ich noch eine Kampf auszufechten aber nachdem ich das FAM14 richtig eingestellt habe gings. Ich hatte am Wochenende noch mal verschiedene Einstellungen des FAM14 ausprobiert und dann wohl irgendwie auch den Überblick verloren 😩 . Als ich dann gerade noch mal alles zurückgestzt habe und einen erneuten Versuch durchgeführt hab kamen auch gleich die LastID Daten am entsprechenden Datenpunkt an. So wie es gerade aussieht hab ich morgen Früh Sturmfrei dann werd ich mal versuchen das ganze System einzulernen.
          • B Black-Raven
            Jey CeeJ Offline
            Jey CeeJ Offline
            Jey Cee
            #95
            @black-raven sehr gut, danke fürs Feedback.
              mustang
              #96
              @Jey-Cee
              Hallo Jey-Cee, bis Adapter Version 0.8.3 haben meine Eltako Rollladenaktoren noch einwandfrei funktioniert. Seit Version 0.8.4 werden die Datenpunkte TT und TTT beschrieben, sobald der Rollladen vor erreichen der Endposition ein Stopkommando per Adapter erhält. Die Werte bleiben dann unveränderlich bestehen und der jeweilige Rollladen fährt dann nicht mehr bis zur Endposition, wenn ein Auf- oder Ab-Kommando gesendet wird.
              Erst nach manuellem überschreiben der Werte mit null in den Objekten ist wieder eine komplette Auf- bzw. Abfahrt möglich.
              Soll das so sein? Wenn ja muß ich meine Scripte anpassen.
              Gruß mustang
              -1
              • M mustang
                @Jey-Cee
                Gruß mustang
                Jey CeeJ Offline
                Jey CeeJ Offline
                Jey Cee
                #97
                @mustang sagte in Test Adapter EnOcean v0.8.x:
                Soll das so sein?
                Nein das ist so nicht richtig und wurde mir bisher auch von keinem anderen so geschildert.
                Gib mir bitte mal den Inhalt aus dem "Support information" Tab.
                • Jey CeeJ Jey Cee
                  Soll das so sein?
                  mustang
                  #98
                  @jey-cee
                  ..komplett - oder nur für einen Eltako?
                  • M mustang
                    @jey-cee
                    Jey CeeJ Offline
                    Jey CeeJ Offline
                    Jey Cee
                    #99
                    @mustang komplett bitte
                    • Jey CeeJ Jey Cee
                      mustang
                      #100
                      @jey-cee
                      bitte sehr..
                       "nodeVersion": "v16.14.0",
                       "serialDevices": [
                         "/dev/ttyUSB0",
                         "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH079CVM-if00-port0"
                       "instance": {
                         "native": {
                           "serialport": "/dev/serial/by-id/usb-FTDI_FT232R_USB_UART_AH079CVM-if00-port0",
                           "device-id": "",
                           "device-name": "",
                           "ser2net": false,
                           "ser2net-ip": "",
                           "ser2net-port": "",
                           "gateway": "usb300"
                         "version": "0.8.4",
                       "devices": [
                           "native": {
                             "BaseID": "ffea0e00",
                             "Protocol": "ERP1",
                             "AppVersion": "2.15.0.0",
                             "ApiVersion": "2.6.9.0",
                             "ChipID": "058cd41c",
                             "AppDescription": "GATEWAYCTRL",
                             "BaseID_offset": 46,
                             "senderIDs": {
                               "ffea0e01": "0420cd17",
                               "ffea0e02": "051b86c2",
                               "ffea0e03": "0584ab89",
                               "ffea0e04": "0516a045",
                               "ffea0e05": "05937c4f",
                               "ffea0e06": "0591eada",
                               "ffea0e07": "0420ccc2",
                               "ffea0e08": "05937ce2",
                               "ffea0e09": "059b9041",
                               "ffea0e0a": "",
                               "ffea0e0b": "0514ac95",
                               "ffea0e0c": "051487ea",
                               "ffea0e0d": "",
                               "ffea0e0e": "0411420b",
                               "ffea0e0f": "0410ea29",
                               "ffea0e10": "0410fb3a",
                               "ffea0e11": "",
                               "ffea0e12": "",
                               "ffea0e13": "",
                               "ffea0e14": "",
                               "ffea0e15": "",
                               "ffea0e16": "05969f95",
                               "ffea0e17": "05975390",
                               "ffea0e18": "058dee4b",
                               "ffea0e19": "058c1120",
                               "ffea0e1a": "",
                               "ffea0e1b": "",
                               "ffea0e1c": "",
                               "ffea0e1d": "",
                               "ffea0e1e": "",
                               "ffea0e1f": "",
                               "ffea0e20": "",
                               "ffea0e21": "",
                               "ffea0e22": "",
                               "ffea0e23": "",
                               "ffea0e24": "",
                               "ffea0e25": "",
                               "ffea0e26": "",
                               "ffea0e27": "",
                               "ffea0e28": "",
                               "ffea0e29": "",
                               "ffea0e2a": "",
                               "ffea0e2b": "",
                               "ffea0e2c": "",
                               "ffea0e2d": "",
                               "ffea0e2e": "",
                               "ffea0e2f": "",
                               "ffea0e30": "",
                               "ffea0e31": "",
                               "ffea0e32": "",
                               "ffea0e33": "",
                               "ffea0e34": "",
                               "ffea0e35": "",
                               "ffea0e36": "",
                               "ffea0e37": "",
                               "ffea0e38": "",
                               "ffea0e39": "",
                               "ffea0e3a": "",
                               "ffea0e3b": "",
                               "ffea0e3c": "",
                               "ffea0e3d": "",
                               "ffea0e3e": "",
                               "ffea0e3f": "",
                               "ffea0e40": "",
                               "ffea0e41": "",
                               "ffea0e42": "",
                               "ffea0e43": "",
                               "ffea0e44": "",
                               "ffea0e45": "",
                               "ffea0e46": "",
                               "ffea0e47": "",
                               "ffea0e48": "",
                               "ffea0e49": "",
                               "ffea0e4a": "",
                               "ffea0e4b": "",
                               "ffea0e4c": "",
                               "ffea0e4d": "",
                               "ffea0e4e": "",
                               "ffea0e4f": "",
                               "ffea0e50": "",
                               "ffea0e51": "",
                               "ffea0e52": "",
                               "ffea0e53": "",
                               "ffea0e54": "",
                               "ffea0e55": "",
                               "ffea0e56": "",
                               "ffea0e57": "",
                               "ffea0e58": "",
                               "ffea0e59": "",
                               "ffea0e5a": "",
                               "ffea0e5b": "",
                               "ffea0e5c": "",
                               "ffea0e5d": "",
                               "ffea0e5e": "",
                               "ffea0e5f": "",
                               "ffea0e60": "",
                               "ffea0e61": "",
                               "ffea0e62": "",
                               "ffea0e63": "",
                               "ffea0e64": "",
                               "ffea0e65": "",
                               "ffea0e66": "",
                               "ffea0e67": "",
                               "ffea0e68": "",
                               "ffea0e69": "",
                               "ffea0e6a": "",
                               "ffea0e6b": "",
                               "ffea0e6c": "",
                               "ffea0e6d": "",
                               "ffea0e6e": "",
                               "ffea0e6f": "",
                               "ffea0e70": "",
                               "ffea0e71": "",
                               "ffea0e72": "",
                               "ffea0e73": "",
                               "ffea0e74": "",
                               "ffea0e75": "",
                               "ffea0e76": "",
                               "ffea0e77": "",
                               "ffea0e78": "",
                               "ffea0e79": "",
                               "ffea0e7a": "",
                               "ffea0e7b": "",
                               "ffea0e7c": "",
                               "ffea0e7d": "",
                               "ffea0e7e": ""
                           "native": {
                             "id": "051b86c2",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e02",
                             "baseIDoffset": 2
                           "_id": "enocean.0.051b86c2"
                           "native": {
                             "id": "0584ab89",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e03",
                             "baseIDoffset": 3
                           "_id": "enocean.0.0584ab89"
                           "native": {
                             "id": "0516a045",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e04",
                             "baseIDoffset": 4
                           "_id": "enocean.0.0516a045"
                           "native": {
                             "id": "05937c4f",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e05",
                             "baseIDoffset": 5
                           "_id": "enocean.0.05937c4f"
                           "native": {
                             "id": "0591eada",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e06",
                             "baseIDoffset": 6
                           "_id": "enocean.0.0591eada"
                           "native": {
                             "id": "05937ce2",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e08",
                             "baseIDoffset": 8
                           "_id": "enocean.0.05937ce2"
                           "native": {
                             "id": "0514ac95",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e0b",
                             "baseIDoffset": 11
                           "_id": "enocean.0.0514ac95"
                           "native": {
                             "id": "051487ea",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e0c",
                             "baseIDoffset": 12
                           "_id": "enocean.0.051487ea"
                           "native": {
                             "id": "0411420b",
                             "eep": [
                               "TF-13-11",
                               "TF-14-02"
                             "Sender_ID": "ffea0e0e",
                             "baseIDoffset": 14
                           "_id": "enocean.0.0411420b"
                           "native": {
                             "id": "0410ea29",
                             "eep": [
                               "TF-13-11",
                               "TF-14-02"
                             "Sender_ID": "ffea0e0f",
                             "baseIDoffset": 15
                           "_id": "enocean.0.0410ea29"
                           "native": {
                             "id": "0410fb3a",
                             "eep": [
                               "TF-13-11",
                               "TF-14-02"
                             "Sender_ID": "ffea0e10",
                             "baseIDoffset": 16
                           "_id": "enocean.0.0410fb3a"
                           "native": {
                             "id": "fef6e05f",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef6e05f"
                           "native": {
                             "id": "fef6dfe6",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef6dfe6"
                           "native": {
                             "id": "fef17646",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef17646"
                           "native": {
                             "id": "fef05d03",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef05d03"
                           "native": {
                             "id": "fef05cfa",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef05cfa"
                           "native": {
                             "id": "fef05d1d",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef05d1d"
                           "native": {
                             "id": "fef05d39",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fef05d39"
                           "native": {
                             "id": "0593d240",
                             "eep": [
                               "A5-04-02"
                           "_id": "enocean.0.0593d240"
                           "native": {
                             "id": "05969f95",
                             "eep": [
                               "TF-01-02",
                               "TF-14-02"
                             "Sender_ID": "ffea0e16",
                             "baseIDoffset": 22
                           "_id": "enocean.0.05969f95"
                           "native": {
                             "id": "05975390",
                             "eep": [
                               "TF-01-02",
                               "TF-14-02"
                             "Sender_ID": "ffea0e17",
                             "baseIDoffset": 23
                           "_id": "enocean.0.05975390"
                           "native": {
                             "id": "feea0917",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.feea0917"
                           "native": {
                             "id": "fee7ba4b",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fee7ba4b"
                           "native": {
                             "id": "058dee4b",
                             "eep": [
                               "TF-01-01",
                               "TF-13-04"
                             "Sender_ID": "ffea0e18",
                             "baseIDoffset": 24
                           "_id": "enocean.0.058dee4b"
                           "native": {
                             "id": "058c1120",
                             "eep": [
                               "TF-01-01",
                               "F6-02-02"
                             "Sender_ID": "ffea0e19",
                             "baseIDoffset": 25
                           "_id": "enocean.0.058c1120"
                           "native": {
                             "id": "058dda99",
                             "eep": [
                               "TF-13-01"
                           "_id": "enocean.0.058dda99"
                           "native": {
                             "id": "fef39372",
                             "eep": [
                               "F6-02-02"
                             "manufacturer": "Enocean GmbH"
                           "_id": "enocean.0.fef39372"
                           "native": {
                             "id": "fef75184",
                             "eep": [
                               "F6-02-02"
                           "_id": "enocean.0.fef75184"
                           "native": {
                             "id": "fee78d21",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fee78d21"
                           "native": {
                             "id": "01972373",
                             "eep": [
                               "TF-13-12"
                           "_id": "enocean.0.01972373"
                           "native": {
                             "id": "000321f5",
                             "eep": [
                               "TF-13-23"
                           "_id": "enocean.0.000321f5"
                           "native": {
                             "id": "0420cd17",
                             "eep": [
                               "TF-13-03",
                               "TF-13-04"
                             "Sender_ID": "ffea0e01",
                             "baseIDoffset": 46
                           "_id": "enocean.0.0420cd17"
                           "native": {
                             "id": "0420ccc2",
                             "eep": [
                               "TF-13-03",
                               "TF-13-04"
                             "Sender_ID": "ffea0e07",
                             "baseIDoffset": 27
                           "_id": "enocean.0.0420ccc2"
                           "native": {
                             "id": "fee55fe6",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fee55fe6"
                           "native": {
                             "id": "fee5c000",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fee5c000"
                           "native": {
                             "id": "fef3935d",
                             "eep": [
                               "F6-02-02"
                           "_id": "enocean.0.fef3935d"
                           "native": {
                             "id": "fedca659",
                             "eep": [
                               "TF-13-02"
                           "_id": "enocean.0.fedca659"
                      • M mustang
                        @jey-cee
                        bitte sehr..
                         "serialDevices": [
                           "/dev/ttyUSB0",
                         "instance": {
                           "native": {
                             "device-id": "",
                             "device-name": "",
                             "ser2net": false,
                             "ser2net-ip": "",
                             "ser2net-port": "",
                             "gateway": "usb300"
                           "version": "0.8.4",
                         "devices": [
                             "native": {
                               "Protocol": "ERP1",
                               "senderIDs": {
                                 "ffea0e0a": "",
                                 "ffea0e0d": "",
                                 "ffea0e11": "",
                                 "ffea0e12": "",
                                 "ffea0e13": "",
                                 "ffea0e14": "",
                                 "ffea0e15": "",
                                 "ffea0e1a": "",
                                 "ffea0e1b": "",
                                 "ffea0e1c": "",
                                 "ffea0e1d": "",
                                 "ffea0e1e": "",
                                 "ffea0e1f": "",
                                 "ffea0e20": "",
                                 "ffea0e21": "",
                                 "ffea0e22": "",
                                 "ffea0e23": "",
                                 "ffea0e24": "",
                                 "ffea0e25": "",
                                 "ffea0e26": "",
                                 "ffea0e27": "",
                                 "ffea0e28": "",
                                 "ffea0e29": "",
                                 "ffea0e2a": "",
                                 "ffea0e2b": "",
                                 "ffea0e2c": "",
                                 "ffea0e2d": "",
                                 "ffea0e2e": "",
                                 "ffea0e2f": "",
                                 "ffea0e30": "",
                                 "ffea0e31": "",
                                 "ffea0e32": "",
                                 "ffea0e33": "",
                                 "ffea0e34": "",
                                 "ffea0e35": "",
                                 "ffea0e36": "",
                                 "ffea0e37": "",
                                 "ffea0e38": "",
                                 "ffea0e39": "",
                                 "ffea0e3a": "",
                                 "ffea0e3b": "",
                                 "ffea0e3c": "",
                                 "ffea0e3d": "",
                                 "ffea0e3e": "",
                                 "ffea0e3f": "",
                                 "ffea0e40": "",
                                 "ffea0e41": "",
                                 "ffea0e42": "",
                                 "ffea0e43": "",
                                 "ffea0e44": "",
                                 "ffea0e45": "",
                                 "ffea0e46": "",
                                 "ffea0e47": "",
                                 "ffea0e48": "",
                                 "ffea0e49": "",
                                 "ffea0e4a": "",
                                 "ffea0e4b": "",
                                 "ffea0e4c": "",
                                 "ffea0e4d": "",
                                 "ffea0e4e": "",
                                 "ffea0e4f": "",
                                 "ffea0e50": "",
                                 "ffea0e51": "",
                                 "ffea0e52": "",
                                 "ffea0e53": "",
                                 "ffea0e54": "",
                                 "ffea0e55": "",
                                 "ffea0e56": "",
                                 "ffea0e57": "",
                                 "ffea0e58": "",
                                 "ffea0e59": "",
                                 "ffea0e5a": "",
                                 "ffea0e5b": "",
                                 "ffea0e5c": "",
                                 "ffea0e5d": "",
                                 "ffea0e5e": "",
                                 "ffea0e5f": "",
                                 "ffea0e60": "",
                                 "ffea0e61": "",
                                 "ffea0e62": "",
                                 "ffea0e63": "",
                                 "ffea0e64": "",
                                 "ffea0e65": "",
                                 "ffea0e66": "",
                                 "ffea0e67": "",
                                 "ffea0e68": "",
                                 "ffea0e69": "",
                                 "ffea0e6a": "",
                                 "ffea0e6b": "",
                                 "ffea0e6c": "",
                                 "ffea0e6d": "",
                                 "ffea0e6e": "",
                                 "ffea0e6f": "",
                                 "ffea0e70": "",
                                 "ffea0e71": "",
                                 "ffea0e72": "",
                                 "ffea0e73": "",
                                 "ffea0e74": "",
                                 "ffea0e75": "",
                                 "ffea0e76": "",
                                 "ffea0e77": "",
                                 "ffea0e78": "",
                                 "ffea0e79": "",
                                 "ffea0e7a": "",
                                 "ffea0e7b": "",
                                 "ffea0e7c": "",
                                 "ffea0e7d": "",
                                 "ffea0e7e": ""
                             "native": {
                               "id": "051b86c2",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 2
                             "native": {
                               "id": "0584ab89",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 3
                             "native": {
                               "id": "0516a045",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 4
                             "native": {
                               "id": "05937c4f",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 5
                             "native": {
                               "id": "0591eada",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 6
                             "native": {
                               "id": "05937ce2",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 8
                             "native": {
                               "id": "0514ac95",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 11
                             "native": {
                               "id": "051487ea",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 12
                             "native": {
                               "id": "0411420b",
                               "eep": [
                                 "TF-13-11",
                                 "TF-14-02"
                               "baseIDoffset": 14
                             "native": {
                               "id": "0410ea29",
                               "eep": [
                                 "TF-13-11",
                                 "TF-14-02"
                               "baseIDoffset": 15
                             "native": {
                               "id": "0410fb3a",
                               "eep": [
                                 "TF-13-11",
                                 "TF-14-02"
                               "baseIDoffset": 16
                             "native": {
                               "id": "fef6e05f",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef6dfe6",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef17646",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef05d03",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef05cfa",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef05d1d",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef05d39",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "0593d240",
                               "eep": [
                                 "A5-04-02"
                             "native": {
                               "id": "05969f95",
                               "eep": [
                                 "TF-01-02",
                                 "TF-14-02"
                               "baseIDoffset": 22
                             "native": {
                               "id": "05975390",
                               "eep": [
                                 "TF-01-02",
                                 "TF-14-02"
                               "baseIDoffset": 23
                             "native": {
                               "id": "feea0917",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fee7ba4b",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "058dee4b",
                               "eep": [
                                 "TF-01-01",
                                 "TF-13-04"
                               "baseIDoffset": 24
                             "native": {
                               "id": "058c1120",
                               "eep": [
                                 "TF-01-01",
                                 "F6-02-02"
                               "baseIDoffset": 25
                             "native": {
                               "id": "058dda99",
                               "eep": [
                                 "TF-13-01"
                             "native": {
                               "id": "fef39372",
                               "eep": [
                                 "F6-02-02"
                             "native": {
                               "id": "fef75184",
                               "eep": [
                                 "F6-02-02"
                             "native": {
                               "id": "fee78d21",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "01972373",
                               "eep": [
                                 "TF-13-12"
                             "native": {
                               "id": "000321f5",
                               "eep": [
                                 "TF-13-23"
                             "native": {
                               "id": "0420cd17",
                               "eep": [
                                 "TF-13-03",
                                 "TF-13-04"
                               "baseIDoffset": 46
                             "native": {
                               "id": "0420ccc2",
                               "eep": [
                                 "TF-13-03",
                                 "TF-13-04"
                               "baseIDoffset": 27
                             "native": {
                               "id": "fee55fe6",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fee5c000",
                               "eep": [
                                 "TF-13-02"
                             "native": {
                               "id": "fef3935d",
                               "eep": [
                                 "F6-02-02"
                             "native": {
                               "id": "fedca659",
                               "eep": [
                                 "TF-13-02"
                        Jey CeeJ Offline
                        Jey CeeJ Offline
                        Jey Cee
                        #101
                        Ok ich seh du hast von Github am 21. November installiert, dort ist nicht die Änderung drin bei der ich so einen Fehler erwartet hätte. Bitte installiere mal von Github drüber.
                        Dann Prüfen wie die Situation ist und mir Rückmeldung geben.
                        • Jey CeeJ Jey Cee
                          mustang
                          #102
                          @jey-cee
                          drüberinstalliert - gleiches Verhalten wie zuvor.
                          • M mustang
                            @jey-cee
                            Jey CeeJ Offline
                            Jey CeeJ Offline
                            Jey Cee
                            #103
                            @mustang OK bitte nochmal installieren von Github, ich hab gerade einen Fix hochgeladen.
                            M A 2 Antworten Letzte Antwort
                            • Jey CeeJ Jey Cee
                              mustang
                              #104
                              @jey-cee
                              Vielen Dank, jetzt sieht es gut aus. Es wird nur noch der Wert TT bei vorzeitigem Stop-Befehl gesetzt und der Rollladen fährt wieder wie erwartet.
                              • Jey CeeJ Jey Cee
                                ares44
                                #105
                                @jey-cee Mal eine Frage zur Programmierung. Meine FJ62 scheinen jetzt korrekt angelernt zu sein. Direktes Setzen von CMD am Objekt fährt rauf oder runter. Wenn ich den Wert per Skript mit setState setze, dann passiert nichts, bzw. der Zustand des Objektes ändert sich, aber die Rolladen fahren nicht. Was fehlt da noch?
                                • A ares44
                                  Jey CeeJ Offline
                                  Jey CeeJ Offline
                                  Jey Cee
                                  #106
                                  @ares44 ich vermute mal das du ACK auf true setzt mit dem Skript, dann klappt das nicht.
                                  • Jey CeeJ Jey Cee
                                    ares44
                                    #107
                                    @jey-cee Nicht bewusst. Ich setze nur CMD auf UP/DOWN.
                                    • A ares44
                                      Jey CeeJ Offline
                                      Jey CeeJ Offline
                                      Jey Cee
                                      #108
                                      @ares44 dann zeig mal das Skript
                                      • Jey CeeJ Jey Cee
                                        ares44
                                        #109
                                        @jey-cee recht übersichtlich:
                                        console.log(getState("enocean.0.041105bb.CMD"));
                                        setState("enocean.0.041105bb.CMD", 'UP');
                                        • A ares44
                                          Jey CeeJ Offline
                                          Jey CeeJ Offline
                                          Jey Cee
                                          #110
                                          @ares44 alles klar, der Befehl ist ein Zahl, der Text ist nur eine Hilfe. Die Zahl steht immer hinter dem Text in Klammern.
