  4. IO-Broker stater nicht - Kann jemand helfen (Thomas?)
    5.6k
27 Beiträge 4 Kommentatoren 1.1k Aufrufe 3 Beobachtet
  • W WolfgangFB
    pi@raspberrypi202:/opt/iobroker $ iobroker status
    node:internal/modules/cjs/loader:959
      throw err;
    Error: Cannot find module 'semver'
    Require stack:
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js
    - /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
    - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
        at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
        at Function.Module._load (node:internal/modules/cjs/loader:804:27)
        at Module.require (node:internal/modules/cjs/loader:1028:19)
        at require (node:internal/modules/cjs/helpers:102:18)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:5:19)
        at Module._compile (node:internal/modules/cjs/loader:1126:14)
        at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
        at Module.load (node:internal/modules/cjs/loader:1004:32)
        at Function.Module._load (node:internal/modules/cjs/loader:839:12)
        at Module.require (node:internal/modules/cjs/loader:1028:19) {
      code: 'MODULE_NOT_FOUND',
      requireStack: [
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
        '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
    @wolfgangfb
    dmesg -T | grep -i ext4
    sagt?
    W 1 Antwort Letzte Antwort
      @wolfgangfb
      sagt?
      W Offline
      W Offline
      WolfgangFB
      pi@raspberrypi202:/opt/iobroker $ dmesg -T | grep -i ext4
      [So Dez 11 18:57:57 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=1a87f003-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
      [So Dez 11 18:58:00 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
      [So Dez 11 18:58:00 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [So Dez 11 18:58:04 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
      • W WolfgangFB
        @wolfgangfb
        iob stop
        for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
        cd /opt/iobroker
        sudo -H -u iobroker npm install iobroker.js-controller
        iobroker restart
          @wolfgangfb
          iob stop
          cd /opt/iobroker
          iobroker restart
          W Offline
          W Offline
          WolfgangFB
          pi@raspberrypi202:/opt/iobroker $ iob stop
          pi@raspberrypi202:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
          pi@raspberrypi202:/opt/iobroker $ cd /opt/iobroker
          pi@raspberrypi202:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
          up to date in 37s
          54 packages are looking for funding
            run `npm fund` for details
          pi@raspberrypi202:/opt/iobroker $ iobroker restart
          Objects type: jsonl
          States  type: jsonl
          • W WolfgangFB
            up to date in 37s
            Objects type: jsonl
            States  type: jsonl
            @wolfgangfb sagte in IO-Broker stater nicht - Kann jemand helfen (Thomas?):
            Objects type: jsonl
            States type: jsonl
            Hast du jetzt aktiv umgestellt oder ist das durch die frische Installation passiert?
              Objects type: jsonl
              States type: jsonl
              W Offline
              W Offline
              WolfgangFB
              @thomas-braun sagte in IO-Broker stater nicht - Kann jemand helfen (Thomas?):
              Objects type: jsonl
              States type: jsonl
              Ich habe nur das gemacht, was Du mir geschrieben hast, sprich es muss durch die frische Installation geschehen sein. (Ich wüsste auch gar nicht, wie ich das aktiv umstellen könnte)
              Was mache ich mit dem Hinweis:
              npm fund liefert
              pi@raspberrypi202:~ $ npm fund
              pi
              Sehr viele "details" kann ich dem nicht entnehmen.
              • W WolfgangFB
                Objects type: jsonl
                States type: jsonl
                npm fund liefert
                pi
                Nichts. Das sind Pakete, deren Maintainer um (finanzielle) Unterstützung bitten. Für die Installation von ioBroker nicht erforderlich.
                • W WolfgangFB
                  Objects type: jsonl
                  States type: jsonl
                  npm fund liefert
                  pi
                  npm-Befehle müssen immer im entsprechenden Verzeichnis ausgeführt werden. In deinem home liegt nicht drin.
                    W Offline
                    W Offline
                    WolfgangFB
                    Danke,
                    ich sehe gerade das nächste Problem :-(
                    Der Raspberry bleibt kurz nach dem Start stehen (ping geht noch, aber sonst ist tote Hose).
                    Wenn ich sofort nach dem Start ein
                    top
                    ausführe sehe ich:
                    pi@raspberrypi202:~ $ top
                    top - 11:57:51 up 3 min,  2 users,  load average: 9,05, 3,84, 1,47
                    Tasks: 195 total,   1 running, 194 sleeping,   0 stopped,   0 zombie
                    %CPU(s): 56,8 us, 20,2 sy,  0,0 ni,  2,8 id, 16,6 wa,  0,0 hi,  3,5 si,  0,0 st
                    MiB Spch:    922,5 total,     30,9 free,    845,8 used,     45,8 buff/cache
                    MiB Swap:      0,0 total,      0,0 free,      0,0 used.     27,2 avail Spch
                      PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
                     1369 iobroker  20   0  212584  73548   7776 D  74,1   7,8   0:39.78 npm install hom
                     1885 iobroker  20   0   91820  62944   3764 D  38,8   6,7   0:09.33 cc1plus
                      601 iobroker  20   0  271344 130736   6972 S  30,7  13,8   1:12.78 iobroker.js-con
                     1833 iobroker  20   0   34004  20160   2304 D  30,5   2,1   0:11.21 pip
                     1926 iobroker  20   0   72140  43348   3504 D  27,9   4,6   0:05.38 cc1plus
                    Ich vermute, dass da npm install hom Schuld ist, wie kann ich verhindern, dass das auomatisch nach dem Start ausgeführt wird?
                    • W WolfgangFB
                      Danke,
                      top
                      ausführe sehe ich:
                      @wolfgangfb
                      Mit 1GB Arbeitsspeicher kannst du halt nicht viel reißen. Insbesondere nicht, wenn auch der Swap abgeschaltet wurde. Warum?
                      • W Offline
                        W Offline
                        WolfgangFB
                        @wolfgangfb
                        https://forum.iobroker.net/topic/53197/raspberryos-iobroker-sd-karten-killer
                        Bleibt die Frage: Wie bekomme ich das Gerät wieder in einen Zustand, in dem ich zumindest etwas einstellen kann.
                        PS. Der Raspberry lief eigentlich eine gefühlte Ewigkeit mit 1GB.
                        ? Thomas BraunT HomoranH 3 Antworten Letzte Antwort
                        • W WolfgangFB
                          @wolfgangfb
                          @wolfgangfb
                          Keine Lösung, aber eine Frage, bin mit den RasPi Images nicht so vertraut.
                          In Deinen top sehe ich cc1plus und pip sind das nötige Pakete oder nur Platzverschwendung?
                          In meinen zwei ioBroker installation unter Debian und auch unter Arch-Linux habe ich die nicht mit installiert?
                          Bernd
                            @wolfgangfb
                            Bernd
                            @dp20eic
                            Das sind Kompiler bzw. Python Paket Manager.
                            Die laufen bei Installationen/Kompilierungen natürlich.
                            Ohne RAM halt entsprechend langsam.
                            • W WolfgangFB
                              @wolfgangfb
                              Und plötzlich nicht mehr. Geht mir mit der Kaffeemaschine/dem Auto/dem Fernseher usw auch schon mal so.
                              Unter 2 GB ist der ioBroker jedenfalls nur ganz eingeschränkt verwendbar.
                              • W WolfgangFB
                                @wolfgangfb
                                und irgendwann kommt das letzte Bit, das den RAM zum überlaufen bringt.
                                was sagt denn iobroker list instances?
                                  W Offline
                                  W Offline
                                  WolfgangFB
                                  @homoran sagte in IO-Broker stater nicht - Kann jemand helfen (Thomas?):
                                  pi@raspberrypi202:~ $ iobroker list instances
                                    system.adapter.admin.0                  : admin                 : raspberrypi202                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    system.adapter.backitup.0               : backitup              : raspberrypi202                           -  enabled
                                    system.adapter.discovery.0              : discovery             : raspberrypi202                           - disabled
                                    system.adapter.esphome.0                : esphome               : raspberrypi202                           -  enabled
                                    system.adapter.ham.0                    : ham                   : raspberrypi202                           -  enabled
                                    system.adapter.ham.1                    : ham                   : raspberrypi202                           - disabled
                                    system.adapter.history.0                : history               : raspberrypi202                           - disabled
                                    system.adapter.info.0                   : info                  : raspberrypi202                           -  enabled
                                    system.adapter.javascript.0             : javascript            : raspberrypi202                           -  enabled
                                    system.adapter.modbus.0                 : modbus                : raspberrypi202                           - disabled
                                    system.adapter.mqtt.0                   : mqtt                  : raspberrypi202                           -  enabled, port: 1883, bind: 0.0.0.0
                                    system.adapter.onkyo.0                  : onkyo                 : raspberrypi202                           -  enabled
                                    system.adapter.openweathermap.0         : openweathermap        : raspberrypi202                           -  enabled
                                    system.adapter.ping.0                   : ping                  : raspberrypi202                           - disabled
                                    system.adapter.shelly.0                 : shelly                : raspberrypi202                           - disabled, port: 1882, bind: 0.0.0.0
                                    system.adapter.vis.0                    : vis                   : raspberrypi202                           -  enabled
                                    system.adapter.web.0                    : web                   : raspberrypi202                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    system.adapter.zigbee.0                 : zigbee                : raspberrypi202                           - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014DA3E1C-if00
                                  + instance is alive
                                  Bleibt die Frage wie ich die ham Instanz loswerde, die immer versucht etwas zu installieren und dann abstürzt.
                                  • W WolfgangFB
                                    + instance is alive
                                    @wolfgangfb ist das vollständig?
                                    ich vermisse da z.B. die letzte Zeile
                                      W Offline
                                      W Offline
                                      WolfgangFB
                                      Welche Zeile vermisst Du? Ich habe den IO-Broker gestoppt weil sonst ja das System nach kürzester Zeit einfriert.
                                      + instance is alive
                                      pi@raspberrypi202:~ $ iobroker status
                                      iobroker is not running on this host.
                                      Objects type: jsonl
                                      States  type: jsonl
                                      • W WolfgangFB
                                        + instance is alive
                                        Objects type: jsonl
                                        States  type: jsonl
                                        eine Legende!
                                        in etwa + is active
                                        • W Offline
                                          W Offline
                                          WolfgangFB
                                          eine Legende!
                                          in etwa + is active
                                          Na ja, da der IO-Broker nicht läuft ist auch nichts active.
                                          Auf meinem zweiten Raspberry (mit laufendem IO-Broker) kommt
                                          pi@raspberrypi:~ $ iobroker list instances
                                           Connection is closed.
                                          Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
                                              at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:632:23)
                                              at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                           Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                           Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                          pi@raspberrypi:~ $
                                          Was auch nicht unbedingt gut aussieht (ich habe gar kein Multihost System) :-(
