<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[IO-Broker stater nicht - Kann jemand helfen (Thomas?)]]></title><description><![CDATA[<p dir="auto">Nach versehentlichem "Stecker weg" kommt jetzt:</p>
<pre><code>pi@raspberrypi202:~ $ iobroker status
node:internal/modules/cjs/loader:959
  throw err;
Error: Cannot find module 'semver'
Require stack:
- /opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js
- /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js
- /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
    at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15)
    at Function.Module._load (node:internal/modules/cjs/loader:804:27)
    at Module.require (node:internal/modules/cjs/loader:1028:19)
    at require (node:internal/modules/cjs/helpers:102:18)
    at Object.&lt;anonymous&gt; (/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js:5:19)
    at Module._compile (node:internal/modules/cjs/loader:1126:14)
    at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10)
    at Module.load (node:internal/modules/cjs/loader:1004:32)
    at Function.Module._load (node:internal/modules/cjs/loader:839:12)
    at Module.require (node:internal/modules/cjs/loader:1028:19) {
  code: 'MODULE_NOT_FOUND',
  requireStack: [
    '/opt/iobroker/node_modules/iobroker.js-controller/lib/tools.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js',
    '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
</code></pre>
<p dir="auto">Was bedeutet das und wie behee ich es?</p>
]]></description><link>https://forum.iobroker.net/topic/60943/io-broker-stater-nicht-kann-jemand-helfen-thomas</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 17:57:21 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/60943.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Dec 2022 18:03:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sat, 17 Dec 2022 18:43:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/911640">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/911637">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Welche Zeile vermisst Du?</p>
</blockquote>
<p dir="auto">eine Legende!<br />
in etwa + is active</p>
</blockquote>
<p dir="auto">Na ja, da der IO-Broker nicht läuft ist auch nichts active.</p>
<p dir="auto">Auf meinem zweiten Raspberry (mit laufendem IO-Broker) kommt</p>
<pre><code>pi@raspberrypi:~ $ iobroker list instances
 Connection is closed.
Uncaught Rejection: Error: Objects DB is not allowed to start in the current Multihost environment
    at Redis.&lt;anonymous&gt; (/opt/iobroker/node_modules/@iobroker/db-objects-redis/lib/objects/objectsInRedisClient.js:632:23)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
 Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
 Unable to subscribe to meta namespace "meta." changes: Connection is closed.
pi@raspberrypi:~ $
</code></pre>
<p dir="auto">Was auch nicht unbedingt gut aussieht (ich habe gar kein Multihost System) :-(</p>
]]></description><link>https://forum.iobroker.net/post/911643</link><guid isPermaLink="true">https://forum.iobroker.net/post/911643</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 17 Dec 2022 18:43:54 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sat, 17 Dec 2022 18:37:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/911637">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/911640</link><guid isPermaLink="true">https://forum.iobroker.net/post/911640</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 17 Dec 2022 18:37:07 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sat, 17 Dec 2022 18:34:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/911606">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> ist das vollständig?<br />
ich vermisse da z.B. die letzte Zeile</p>
</blockquote>
<p dir="auto">Welche Zeile vermisst Du? Ich habe den IO-Broker gestoppt weil sonst ja das System nach kürzester Zeit einfriert.</p>
<pre><code>pi@raspberrypi202:~ $ iobroker list instances
  system.adapter.admin.0                  : admin                 : raspberrypi202                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
  system.adapter.backitup.0               : backitup              : raspberrypi202                           -  enabled
  system.adapter.discovery.0              : discovery             : raspberrypi202                           - disabled
  system.adapter.esphome.0                : esphome               : raspberrypi202                           -  enabled
  system.adapter.ham.0                    : ham                   : raspberrypi202                           -  enabled
  system.adapter.ham.1                    : ham                   : raspberrypi202                           - disabled
  system.adapter.history.0                : history               : raspberrypi202                           - disabled
  system.adapter.info.0                   : info                  : raspberrypi202                           -  enabled
  system.adapter.javascript.0             : javascript            : raspberrypi202                           -  enabled
  system.adapter.modbus.0                 : modbus                : raspberrypi202                           - disabled
  system.adapter.mqtt.0                   : mqtt                  : raspberrypi202                           -  enabled, port: 1883, bind: 0.0.0.0
  system.adapter.onkyo.0                  : onkyo                 : raspberrypi202                           -  enabled
  system.adapter.openweathermap.0         : openweathermap        : raspberrypi202                           -  enabled
  system.adapter.ping.0                   : ping                  : raspberrypi202                           - disabled
  system.adapter.shelly.0                 : shelly                : raspberrypi202                           - disabled, port: 1882, bind: 0.0.0.0
  system.adapter.vis.0                    : vis                   : raspberrypi202                           -  enabled
  system.adapter.web.0                    : web                   : raspberrypi202                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
  system.adapter.zigbee.0                 : zigbee                : raspberrypi202                           - disabled, port: /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0014DA3E1C-if00
+ instance is alive
iobroker is not running on this host.
Objects type: jsonl
States  type: jsonl
</code></pre>
]]></description><link>https://forum.iobroker.net/post/911637</link><guid isPermaLink="true">https://forum.iobroker.net/post/911637</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 17 Dec 2022 18:34:14 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sat, 17 Dec 2022 17:42:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> ist das vollständig?<br />
]]></description><link>https://forum.iobroker.net/post/911606</link><guid isPermaLink="true">https://forum.iobroker.net/post/911606</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Sat, 17 Dec 2022 17:42:22 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sat, 17 Dec 2022 16:04:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/homoran" aria-label="Profile: homoran">@<bdi>homoran</bdi></a> sagte in <a href="/post/908648">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">was sagt denn <code>iobroker list instances</code>?</p>
</blockquote>
+ instance is alive
</code></pre>
<p dir="auto">Bleibt die Frage wie ich die ham Instanz loswerde, die immer versucht etwas zu installieren und dann abstürzt.</p>
]]></description><link>https://forum.iobroker.net/post/911564</link><guid isPermaLink="true">https://forum.iobroker.net/post/911564</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sat, 17 Dec 2022 16:04:26 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 13:20:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908569">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Der Raspberry lief eigentlich eine gefühlte Ewigkeit mit 1GB.</p>
</blockquote>
<p dir="auto">und irgendwann kommt das letzte Bit, das den RAM zum überlaufen bringt.</p>
]]></description><link>https://forum.iobroker.net/post/908648</link><guid isPermaLink="true">https://forum.iobroker.net/post/908648</guid><dc:creator><![CDATA[Homoran]]></dc:creator><pubDate>Mon, 12 Dec 2022 13:20:14 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 12:24:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908569">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">PS. Der Raspberry lief eigentlich eine gefühlte Ewigkeit mit 1GB.</p>
</blockquote>
<p dir="auto">Und plötzlich nicht mehr. Geht mir mit der Kaffeemaschine/dem Auto/dem Fernseher usw auch schon mal so.</p>
<p dir="auto">Unter 2 GB ist der ioBroker jedenfalls nur ganz eingeschränkt verwendbar.</p>
]]></description><link>https://forum.iobroker.net/post/908593</link><guid isPermaLink="true">https://forum.iobroker.net/post/908593</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 12 Dec 2022 12:24:28 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 12:22:06 GMT]]></title><description><![CDATA[<p dir="auto">@dp20eic</p>
<p dir="auto">Das sind Kompiler bzw. Python Paket Manager.</p>
<p dir="auto">Die laufen bei Installationen/Kompilierungen natürlich.<br />
Ohne RAM halt entsprechend langsam.</p>
]]></description><link>https://forum.iobroker.net/post/908591</link><guid isPermaLink="true">https://forum.iobroker.net/post/908591</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 12 Dec 2022 12:22:06 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 11:39:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a></p>
<p dir="auto">Keine Lösung, aber eine Frage, bin mit den RasPi Images nicht so vertraut.</p>
<p dir="auto">In Deinen <code>top</code> sehe ich <code>cc1plus</code> und <code>pip</code> sind das nötige Pakete oder nur Platzverschwendung?<br />
In meinen zwei <strong>ioBroker</strong> installation unter <strong>Debian</strong> und auch unter <strong>Arch-Linux</strong> habe ich die nicht mit installiert?</p>
<p dir="auto">VG<br />
Bernd</p>
]]></description><link>https://forum.iobroker.net/post/908576</link><guid isPermaLink="true">https://forum.iobroker.net/post/908576</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Mon, 12 Dec 2022 11:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 11:15:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/908564">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Mit 1GB Arbeitsspeicher kannst du halt nicht viel reißen. Insbesondere nicht, wenn auch der Swap abgeschaltet wurde. Warum?</p>
</blockquote>
<p dir="auto"><a href="https://forum.iobroker.net/topic/53197/raspberryos-iobroker-sd-karten-killer">https://forum.iobroker.net/topic/53197/raspberryos-iobroker-sd-karten-killer</a></p>
<p dir="auto">Bleibt die Frage: Wie bekomme ich das Gerät wieder in einen Zustand, in dem ich zumindest etwas einstellen kann.<br />
]]></description><link>https://forum.iobroker.net/post/908569</link><guid isPermaLink="true">https://forum.iobroker.net/post/908569</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Mon, 12 Dec 2022 11:15:08 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 11:07:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a></p>
]]></description><link>https://forum.iobroker.net/post/908564</link><guid isPermaLink="true">https://forum.iobroker.net/post/908564</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 12 Dec 2022 11:07:44 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 11:02:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Danke,<br />
ich sehe gerade das nächste Problem :-(</p>
<p dir="auto">Der Raspberry bleibt kurz nach dem Start stehen (ping geht noch, aber sonst ist tote Hose).<br />
Wenn ich sofort nach dem Start ein</p>
<pre><code>top
</code></pre>
<p dir="auto">ausführe sehe ich:</p>
<pre><code>pi@raspberrypi202:~ $ top
top - 11:57:51 up 3 min,  2 users,  load average: 9,05, 3,84, 1,47
Tasks: 195 total,   1 running, 194 sleeping,   0 stopped,   0 zombie
%CPU(s): 56,8 us, 20,2 sy,  0,0 ni,  2,8 id, 16,6 wa,  0,0 hi,  3,5 si,  0,0 st
MiB Spch:    922,5 total,     30,9 free,    845,8 used,     45,8 buff/cache
MiB Swap:      0,0 total,      0,0 free,      0,0 used.     27,2 avail Spch
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     ZEIT+ BEFEHL
 1369 iobroker  20   0  212584  73548   7776 D  74,1   7,8   0:39.78 npm install hom
 1885 iobroker  20   0   91820  62944   3764 D  38,8   6,7   0:09.33 cc1plus
  601 iobroker  20   0  271344 130736   6972 S  30,7  13,8   1:12.78 iobroker.js-con
 1833 iobroker  20   0   34004  20160   2304 D  30,5   2,1   0:11.21 pip
 1926 iobroker  20   0   72140  43348   3504 D  27,9   4,6   0:05.38 cc1plus
</code></pre>
<p dir="auto">Ich vermute, dass da npm install hom Schuld ist, wie kann ich verhindern, dass das auomatisch nach dem Start ausgeführt wird?</p>
]]></description><link>https://forum.iobroker.net/post/908560</link><guid isPermaLink="true">https://forum.iobroker.net/post/908560</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Mon, 12 Dec 2022 11:02:05 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 10:46:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908545">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Sehr viele "details" kann ich dem nicht entnehmen.</p>
</blockquote>
<p dir="auto">npm-Befehle müssen immer im entsprechenden Verzeichnis ausgeführt werden. In deinem home liegt nicht drin.</p>
]]></description><link>https://forum.iobroker.net/post/908549</link><guid isPermaLink="true">https://forum.iobroker.net/post/908549</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 12 Dec 2022 10:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 10:45:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908545">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Was mache ich mit dem Hinweis:</p>
</blockquote>
<p dir="auto">Nichts. Das sind Pakete, deren Maintainer um (finanzielle) Unterstützung bitten. Für die Installation von ioBroker nicht erforderlich.</p>
]]></description><link>https://forum.iobroker.net/post/908548</link><guid isPermaLink="true">https://forum.iobroker.net/post/908548</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 12 Dec 2022 10:45:08 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Mon, 12 Dec 2022 10:41:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a> sagte in <a href="/post/908391">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908389">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">Objects type: jsonl<br />
States  type: jsonl</p>
</blockquote>
<p dir="auto">Hast du jetzt aktiv umgestellt oder ist das durch die frische Installation passiert?</p>
</blockquote>
<p dir="auto">Ich habe nur das gemacht, was Du mir geschrieben hast, sprich es muss durch die frische Installation geschehen sein. (Ich wüsste auch gar nicht, wie ich das aktiv umstellen könnte)</p>
<pre><code>54 packages are looking for funding
  run `npm fund` for details
</code></pre>
<p dir="auto">npm fund liefert</p>
<pre><code>pi@raspberrypi202:~ $ npm fund
pi
</code></pre>
]]></description><link>https://forum.iobroker.net/post/908545</link><guid isPermaLink="true">https://forum.iobroker.net/post/908545</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Mon, 12 Dec 2022 10:41:55 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 21:03:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908389">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.iobroker.net/post/908391</link><guid isPermaLink="true">https://forum.iobroker.net/post/908391</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 11 Dec 2022 21:03:08 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 20:57:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@raspberrypi202:/opt/iobroker $ iob stop
pi@raspberrypi202:/opt/iobroker $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
pi@raspberrypi202:/opt/iobroker $ cd /opt/iobroker
pi@raspberrypi202:/opt/iobroker $ sudo -H -u iobroker npm install iobroker.js-controller
up to date in 37s
pi@raspberrypi202:/opt/iobroker $ iobroker restart
pi@raspberrypi202:/opt/iobroker $ iobroker status
Objects type: jsonl
States  type: jsonl
</code></pre>
]]></description><link>https://forum.iobroker.net/post/908389</link><guid isPermaLink="true">https://forum.iobroker.net/post/908389</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sun, 11 Dec 2022 20:57:28 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 20:19:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a></p>
<pre><code>iob stop
cd /opt/iobroker
iobroker restart
</code></pre>
]]></description><link>https://forum.iobroker.net/post/908376</link><guid isPermaLink="true">https://forum.iobroker.net/post/908376</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 11 Dec 2022 20:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 20:16:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@raspberrypi202:/opt/iobroker $ dmesg -T | grep -i ext4
[So Dez 11 18:57:57 2022] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=720 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=1a87f003-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[So Dez 11 18:58:00 2022] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[So Dez 11 18:58:00 2022] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[So Dez 11 18:58:04 2022] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
</code></pre>
]]></description><link>https://forum.iobroker.net/post/908373</link><guid isPermaLink="true">https://forum.iobroker.net/post/908373</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sun, 11 Dec 2022 20:16:47 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 20:07:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a></p>
<pre><code>dmesg -T | grep -i ext4
</code></pre>
<p dir="auto">sagt?</p>
]]></description><link>https://forum.iobroker.net/post/908370</link><guid isPermaLink="true">https://forum.iobroker.net/post/908370</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 11 Dec 2022 20:07:25 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 19:51:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<pre><code>pi@raspberrypi202:/opt/iobroker $ iobroker status
  throw err;
Require stack:
  requireStack: [
</code></pre>
]]></description><link>https://forum.iobroker.net/post/908356</link><guid isPermaLink="true">https://forum.iobroker.net/post/908356</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sun, 11 Dec 2022 19:51:19 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 19:48:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a> sagte in <a href="/post/908346">IO-Broker stater nicht - Kann jemand helfen (Thomas?)</a>:</p>
<blockquote>
<p dir="auto">nach dem Neustart kommt genau der gleiche Fehler nochmal</p>
</blockquote>
<p dir="auto">Meldung posten. Ich vermute die Meldung ist nicht gleich.</p>
]]></description><link>https://forum.iobroker.net/post/908349</link><guid isPermaLink="true">https://forum.iobroker.net/post/908349</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 11 Dec 2022 19:48:06 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 19:44:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: thomas-braun">@<bdi>thomas-braun</bdi></a></p>
<p dir="auto">Hmm, nach 15 Minuten kam der Fehler wieder, diemal lässt er sich so nicht beheben. (nach dem Neustart kommt genau der gleiche Fehler nochmal)</p>
]]></description><link>https://forum.iobroker.net/post/908346</link><guid isPermaLink="true">https://forum.iobroker.net/post/908346</guid><dc:creator><![CDATA[WolfgangFB]]></dc:creator><pubDate>Sun, 11 Dec 2022 19:44:21 GMT</pubDate></item><item><title><![CDATA[Reply to IO-Broker stater nicht - Kann jemand helfen (Thomas?) on Sun, 11 Dec 2022 18:35:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wolfgangfb" aria-label="Profile: wolfgangfb">@<bdi>wolfgangfb</bdi></a></p>
<p dir="auto">Zum Fehler:</p>
<p dir="auto"><a href="https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8">https://forum.iobroker.net/topic/57337/fehler-25-oder-217-bei-adapter-install-update-mit-npm8</a></p>
<p dir="auto">Die  Datenbanken würde ich auf jsonl/jsonl umstellen.</p>
]]></description><link>https://forum.iobroker.net/post/908291</link><guid isPermaLink="true">https://forum.iobroker.net/post/908291</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Sun, 11 Dec 2022 18:35:46 GMT</pubDate></item></channel></rss>
