  3. Einsteigerfragen
  4. Installation
  5. Installtion von ioBroker auf RaspberryPi 4
19 Beiträge 4 Kommentatoren 1.6k Aufrufe 3 Beobachtet
  • H Offline
    Hoffmakl1961
    auf meinen RaspberryPi 4 läuft bereits Mosquitto, Node-RED v2.1.0, Influxdb und Grafana v9.3.1.
    Zusätzlich habe ich auf dem RaspberryPi ein ioBroker versucht zu installieren, mit
    curl -sLf https://iobroker.net/install.sh | bash -
    Ich habe gelesen und gesucht, leider bekomme ich es nicht zum Laufen.
    js-controller neu installiert, da bekomme ich einen error.
    npm install iobroker.js-controller
    npm WARN ancient lockfile
    npm WARN ancient lockfile The package-lock.json file was created with an old version of npm,
    npm WARN ancient lockfile so supplemental metadata must be fetched from the registry.
    npm WARN ancient lockfile This is a one-time fix-up, please be patient...
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm ERR! code 22
    npm ERR! path /home/pi/node_modules/iobroker.js-controller
    npm ERR! command failed
    npm ERR! command sh -c -- node iobroker.js setup first
    npm ERR! Could not connect to objects database at 127.0.0.1:9001 (invalid protocol). Please make sure the configured IP and port points to a host running JS-Controller >= 2.0. and that the port is not occupied by other software!
    Was läuft auf welchem Port?
    sudo ss -tulpn | grep LISTEN
    tcp    LISTEN  0       511                 0.0.0.0:80             0.0.0.0:*      users:(("nginx",pid=628,fd=6),("nginx",pid=627,fd=6),("nginx",pid=626,fd=6),("nginx",pid=625,fd=6),("nginx",pid=624,fd=6))
    tcp    LISTEN  0       9                   0.0.0.0:21             0.0.0.0:*      users:(("pure-ftpd",pid=597,fd=4))
    tcp    LISTEN  0       128                 0.0.0.0:22             0.0.0.0:*      users:(("sshd",pid=581,fd=3))
    tcp    LISTEN  0       5                 127.0.0.1:631            0.0.0.0:*      users:(("cupsd",pid=31684,fd=7))
    tcp    LISTEN  0       511                 0.0.0.0:1880           0.0.0.0:*      users:(("node-red",pid=10519,fd=19))
    tcp    LISTEN  0       4096              127.0.0.1:8088           0.0.0.0:*      users:(("influxd",pid=882,fd=3))
    tcp    LISTEN  0       100                 0.0.0.0:1883           0.0.0.0:*      users:(("mosquitto",pid=875,fd=9))
    tcp    LISTEN  0       128                 0.0.0.0:9001           0.0.0.0:*      users:(("mosquitto",pid=875,fd=8))
    tcp    LISTEN  0       511                    [::]:80                [::]:*      users:(("nginx",pid=628,fd=7),("nginx",pid=627,fd=7),("nginx",pid=626,fd=7),("nginx",pid=625,fd=7),("nginx",pid=624,fd=7))
    tcp    LISTEN  0       9                      [::]:21                [::]:*      users:(("pure-ftpd",pid=597,fd=5))
    tcp    LISTEN  0       4096                      *:8086                 *:*      users:(("influxd",pid=882,fd=59))
    tcp    LISTEN  0       128                    [::]:22                [::]:*      users:(("sshd",pid=581,fd=4))
    tcp    LISTEN  0       2        [::ffff:127.0.0.1]:3350                 *:*      users:(("xrdp-sesman",pid=570,fd=7))
    tcp    LISTEN  0       4096                      *:8888                 *:*      users:(("chronograf",pid=871,fd=8))
    tcp    LISTEN  0       4096                      *:3000                 *:*      users:(("grafana-server",pid=868,fd=14))
    tcp    LISTEN  0       100                    [::]:1883              [::]:*      users:(("mosquitto",pid=875,fd=10))
    tcp    LISTEN  0       2                         *:3389                 *:*      users:(("xrdp",pid=602,fd=11))
    tcp    LISTEN  0       128                       *:9090                 *:*      users:(("systemd",pid=1,fd=90))
    Mosquitto scheint das Problem zu sein (Port 9001), oder?
    Wie kann ich weiter vorgehen?
    (Meine Linux Erfahrungen sind minimal.)
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    pi@rasp-Pi-4:~ $ node -v
    v16.18.1
    pi@rasp-Pi-4:~ $ npm -v
    8.19.2
    • H Hoffmakl1961
      npm ERR! code 22
      VERSION_ID="10"
      ID=raspbian
      ID_LIKE=debian
      v16.18.1
      8.19.2
      @hoffmakl1961
      Bieg den Port auf was anderes und schalte den Desktop inkl. Remote Desktop aus.
      Und beerdige Buster und installier 'Bullseye'.
      H 1 Antwort Letzte Antwort
        @hoffmakl1961
        Hoffmakl1961
        Thomas, Danke für die schneller Antwort.
        Ich werde demnächst das System neu aufsetzen und Bullseye ohne remote Desktop installieren.
        "Bieg den Port auf was anderes"
        Ich habe die Datei /opt/iobroker/iobroker-data/iobroker.json angepasst:
        Port: 9001 auf 8001
         "objects": {
            "type": "jsonl",
            "// type": "Possible values: 'file' - [port 8001], 'jsonl' - [port 8001], 'redis' - [port 6379 or 26379 for sentinel].",
            "host": "127.0.0.1",
            "port": 8001,
        danach ein reboot durchgeführt.
        Wo muss ich noch Anpassen?
        Bekomme immer noch die gleiche Fehlermeldung
        wenn ich
        ausführe.
        • H Hoffmakl1961
          Port: 9001 auf 8001
           "objects": {
              "type": "jsonl",
              "port": 8001,
          wenn ich
          ausführe.
          @hoffmakl1961 sagte in Installtion von ioBroker auf RaspberryPi 4:
          Ja, dann mach das. Solange bin ich raus.
            Hoffmakl1961
            Ich verstehe, dass du nichts mit veralteten Systemen zu tun haben willst, dazu noch mit Leuten ohne Linuxerfahrung.
            Trotzdem, Danke.
            Im Moment benötige ich noch meine Node-Red, InluxDB und Grafana Umgebung.
            Mein Ziel war, zusätzlich den ioBroker aufzusetzen, um zu spielen.
            HomoranH Thomas BraunT H 3 Antworten Letzte Antwort
            • H Hoffmakl1961
              Trotzdem, Danke.
              @hoffmakl1961 was soll denn das jetzt?
              genau für diese sind wir da!
              dann verstehst du es wohl doch nicht so ganz.
              Die Fehlersuche ist sehr aufwändig. Eine Reparatur bei einem abgekündigten System nicht mehr hilfreich, ggf. auch nicht mehr möglich.
              Sobald du das OS upgradest wird eh alles neu gebaut (wenn nötig)
              • H Hoffmakl1961
                Trotzdem, Danke.
                Es gibt bei neuen Debian-Releases einen Zeitraum von ungefähr einem Jahr, wo stable und oldstable parallel gepflegt werden, eben damit man genug Zeit hat seinen Kram umzuziehen. Das Jahr 'Übergangszeit' war für Buster im September 2022 vorbei.
                • H Hoffmakl1961
                  Trotzdem, Danke.
                  Hoffmakl1961
                  Sorry, genau das habe ich auch gesagt.
                  Wenn ein System abgekündigt ist, gibts kein Support! Was denn sonst.
                  ... dazu noch mit Leuten ohne Linuxerfahrung, ...
                  soll bedeuten, noch mehr Aufwand als einer mit Erafhrung.
                  • H Hoffmakl1961
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    Brauchst Du jetzt noch Hilfe oder zitierst Du nur Beiträge?
                    Mach halt erstmal was @Thomas-Braun schon geschrieben hat...
                    https://forum.iobroker.net/post/907218
                    Lehrling seit 1975 !!!
                    • DJMarc75D DJMarc75
                      Hoffmakl1961
                      @djmarc75 said in Installtion von ioBroker auf RaspberryPi 4:
                      Ich kann's nicht nachvollziehen, was mir heute alles unterstellt wird.
                      Können wir uns wieder auf's Technische beschränken.
                      • H Hoffmakl1961
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        gerne: was ist nun Dein neues Problem ?
                        oder:
                        noch das Problem?
                        Wenn ja dann:
                        https://forum.iobroker.net/topic/60887/installtion-von-iobroker-auf-raspberrypi-4/2?_=1670676084359
                        wenn nein dann bin ich da auch raus - aus Gründen 😶
                          oder:
                          noch das Problem?
                          Wenn ja dann:
                          Hoffmakl1961
                          @djmarc75
                          Ja, das Problem existiert noch.
                          Ich habe den port:9001 auf 8001 geändert
                          in der /opt/iobroker/iobroker-data/iobroker.json
                          wie von mir oben beschrieben,
                          https://forum.iobroker.net/topic/60887/installtion-von-iobroker-auf-raspberrypi-4/3?_=1670681895489
                          bekomme aber immer noch die gleiche Fehlermeldung.
                          Was muss ich noch anpassen? Oder was habe ich falsch gemacht?
                          • H Hoffmakl1961
                            @djmarc75
                            wessen Port?
                              Hoffmakl1961
                              wenn man ein neues System mit ioBroker installiert, ist deine Empfehlung im Forum:
                              "Wichtig ist LITE, ohne Desktop!" - oder reicht es auch, den Desktop einfach auszuschalten, wie oben von dir vorgeschlagen?
                              • H Hoffmakl1961
                                @hoffmakl1961
                                Da du eh neu installieren musst:
                                Nimm direkt die Lite 64bit Version.
                                  wessen Port?
                                  Hoffmakl1961
                                  Das ist der Port im
                                  "objects": {
                                  "type": "jsonl", ....
                                  siehe meine Beschreibung:
                                    @hoffmakl1961
                                    Hoffmakl1961
                                    ok, schönes Wochenende.
                                    • H Hoffmakl1961
                                      Das ist der Port im
                                      "objects": {
                                      Das ist der Port im
                                      ist das der mosquitto?
                                      oder versuchst du gerade in ioBroker alles zu verstellen?
                                        Das ist der Port im
                                        Hoffmakl1961
                                        schau dir bitte meine Beschreibung an, was ich gemacht habe.
