  4. [gelöst] Synology Adapter baut keine Verbindung auf
52 Beiträge 8 Kommentatoren 6.5k Aufrufe 6 Beobachtet
  • G GiB64
    Bei der Geschwindigkeit wie die Fehler reinkommen ist das nach ein paar Sec. schon sehr groß:
    2022-12-03 20:41:33.264  - debug: synology.0 (243206) Redis Objects: Use Redis connection: 127.0.0.1:9001
    2022-12-03 20:41:34.348  - debug: synology.0 (243206) Objects client ready ... initialize now
    2022-12-03 20:41:34.430  - debug: synology.0 (243206) Objects create System PubSub Client
    2022-12-03 20:41:34.433  - debug: synology.0 (243206) Objects create User PubSub Client
    2022-12-03 20:41:35.196  - debug: synology.0 (243206) Objects client initialize lua scripts
    2022-12-03 20:41:35.209  - debug: influxdb.0 (98223) Write Point: hm-rpc.1.0001D3C99C4699.6.POWER values:{"value":0.89,"time":"2022-12-03T19:41:35.194Z","from":"system.adapter.hm-rpc.1","q":0,"ack":true} options: null
    2022-12-03 20:41:35.220  - debug: influxdb.0 (98223) Point written to iobroker
    2022-12-03 20:41:35.226  - debug: synology.0 (243206) Objects connected to redis: 127.0.0.1:9001
    2022-12-03 20:41:35.278  - debug: synology.0 (243206) Redis States: Use Redis connection: 127.0.0.1:9000
    2022-12-03 20:41:35.316  - debug: synology.0 (243206) States create System PubSub Client
    2022-12-03 20:41:35.318  - debug: synology.0 (243206) States create User PubSub Client
    2022-12-03 20:41:35.412  - debug: synology.0 (243206) States connected to redis: 127.0.0.1:9000
    2022-12-03 20:41:35.597  - debug: synology.0 (243206) Plugin sentry Initialize Plugin (enabled=true)
    2022-12-03 20:41:35.603  - info: synology.0 (243206) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
    2022-12-03 20:41:36.094  - info: synology.0 (243206) starting. Version 2.1.13 in /opt/iobroker/node_modules/iobroker.synology, node: v16.18.1, js-controller: 4.0.23
    2022-12-03 20:41:36.135  - debug: synology.0 (243206) working directory is /opt/iobroker/iobroker-data/synology_0/
    2022-12-03 20:41:36.138  - info: synology.0 (243206) Connecting to Synology 192.168.1.13:5000
    2022-12-03 20:41:38.775  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.776  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.778  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.885  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.887  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.888  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.889  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.890  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.905  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.905  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.906  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.906  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.907  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.920  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.921  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.922  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.922  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.923  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.936  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.936  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.937  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.938  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.939  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.949  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.949  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.950  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.950  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.951  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.961  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.962  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.963  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.963  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.964  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.973  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.973  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.974  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    2022-12-03 20:41:38.974  - debug: synology.0 (243206) * sendPolling. namePolling = firstPoll | iteration = 0 | typeof poll = object | poll = {"api":"dsm","method":"getPollingData","params":{}}
    2022-12-03 20:41:38.975  - debug: synology.0 (243206) * Get info from (firstPoll) api: DSM method: getPollingData params: {}
    2022-12-03 20:41:38.983  - debug: synology.0 (243206) * No response, read next.
    2022-12-03 20:41:38.984  - debug: synology.0 (243206) *** ERROR : src: *sendPolling syno[dsm][getPollingData] code: EPROTO message: write EPROTO 547786682432:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../deps/openssl/openssl/ssl/record/ssl3_record.c:332:
    2022-12-03 20:41:38.984  - debug: synology.0 (243206) -----------------------------------------------------------------------------------------------------
    @gib64
    Da dürfte einer der beteiligten die falsche SSL-Sprache sprechen. Ich vermute die Synolololology.
    G GlasfaserG 2 Antworten Letzte Antwort
      @gib64
      GiB64
      @thomas-braun Ok, die DSM ist auf Vers. 6.2.4 und im Synology Adapter kann ich nur 6..2.3 auswählen, aber waass? Kann ich da was machen, außer auf Updates hoffen?
        @gib64 sagte in Synology Adapter baut keine Verbindung auf:
        DSM ist noch auf 6.2.4, der Rest ist aktuell:
        dann ist es nicht das selbe
        Meine Fehlermeldung ist aber die selbe wie die vom Ersteller.
        und die wäre?
        bitte als code in code-tags posten!
        nicht den selben Mist mit Screenshot
        GiB64
        @homoran said in Synology Adapter baut keine Verbindung auf:
        Sieht für mich aber ziemlich ähnlich aus...
        • G GiB64
          @gib64
          DSM7 fahren?
          G 1 Antwort Letzte Antwort
          • GlasfaserG Offline
            GlasfaserG Offline
            Der Threadstart User hat port 5000 und HTTPS angehakt das ist falsch !!
            5000 ist nur HTTP
              @gib64
              GlasfaserG Offline
              GlasfaserG Offline
              @thomas-braun sagte in Synology Adapter baut keine Verbindung auf:
                @gib64
                DSM7 fahren?
                GiB64
                schrieb am zuletzt editiert von GiB64
                @thomas-braun geht leider nicht da ich unter DSM 7 kein Java zum laufen bekomme...
                @Glasfaser Das war es! Danke! Habe https rausgenommen und dann lief es sauber. (Genau wie beim Ersteller 😀 )
                Danke an alle!!
                • G GiB64
                  Danke an alle!!
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Danke an alle!!
                  Kein Thema ;)
                  • G GiB64
                    Danke an alle!!
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Müßte hiermit ... mit einem Umweg gehen ..
                    https://community.synology.com/enu/forum/1/post/144667?page=2&sort=oldest
                    • GlasfaserG Glasfaser
                      GiB64
                      @glasfaser Danke aber da warte ich lieber noch mal. Das ist mir noch zu windig denn einen Weg zurück gibt es nicht.
                      • M mibr85
                        Hallo zusammen
                        DS1019+
                        DSM DSM 7.0.1-42218 Update 3
                        Adapter version: v2.1.13
                        JS-Controller version: v4.0.15
                        Node version: v14.19.0
                        Operating system: Debian
                        bekomme leider beim Verbindungsaufbau mit meinem Synology NAS über den Adapter folgende Fehlermeldung im milisekunden Takt im Log, kann damit jemand was anfangen? Verbindung kann keine aufgebaut werden.
                        Zum anderen stellt sich mir die Frage wenn ich die 2FA nutzen will, wo bekomme ich den 2FA Key in meinem Synology angezeigt?
                        Danke für eure Hilfe
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @mibr85 sagte in Synology Adapter baut keine Verbindung auf:
                        In der Beschreibung auf Github ... ganz unten ist es erklärt !
                        https://github.com/iobroker-community-adapters/ioBroker.synology/blob/master/docs/en/template.md
                        • G GiB64
                          GlasfaserG Offline
                          GlasfaserG Offline
                          Bei DSM 7 gibt es den noch . reicht der nicht .
                            GiB64
                            @glasfaser Das war mir entgangen. Dann gehe ich das mal die Tage an....
                              mibr85
                              Vielen Dank für den Tip mit der 2FA, das hatte ich übersehen.
                              hab nochmal alles auf den neusten Stand gebracht, funktioniert aber leider immer noch nicht:
                              DS1019+
                              Node version: v16.18.1
                              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                              • M mibr85
                                DS1019+
                                Ist nicht der aktuelle Stand.
                                Die Fehlermeldung (die ich nicht kopieren kann, weil sinnfreier Screenshot von Text) hatten wir die Tage aber schonmal im Zusammenhang mit einer Synology.
                                • M mibr85
                                  DS1019+
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  Ja .... du hast es noch nicht geändert !
                                  Habe hier was zu geschrieben ...
                                  @glasfaser sagte in Synology Adapter baut keine Verbindung auf:
                                  5000 ist nur HTTP
                                    SpM
                                    ich habe leider das gleiche oder ein ähnliches Problem mit der Verbindung des Adapters zu meiner Synology NAS.
                                    Aktuell habe ich folgende Konstellation:
                                    Synology DS 920+ mit DSM 7.1.1-42962 Update1
                                    IoBroker im Docker als Bridge
                                    Folgendes habe ich bereits geprüft bzw. eingestellt:
                                    Im Adapter:
                                    Im NAS:
                                    LOG File des Adapters:
                                    IOBroker_LOG.txt
                                    Ich hoffe Ihr könnt mir helfen.
                                    Gruß Marco
                                    • S SpM
                                      Im Adapter:
                                      Im NAS:
                                      IOBroker_LOG.txt
                                      Gruß Marco
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      @spm anscheinend hast Du das Https-Häkchen-Thema hier im Beitrag "überlesen"
                                      Lehrling seit 1975 !!!
                                      • DJMarc75D DJMarc75
                                        SpM
                                        @djmarc75
                                        Meinst du ich soll auf Port 5000 und den Hacken bei https entfernen?
                                        Gruß Marco
                                        • S SpM
                                          @djmarc75
                                          Gruß Marco
                                          GlasfaserG Offline
                                          GlasfaserG Offline
                                          @spm sagte in Synology Adapter baut keine Verbindung auf:
                                          Wenn du deine Syn mit 5001 / Https eingerichtet hast bzw. auch erreichst , dann wird der Adapter genauso eingestellt .
                                          Aber dein DEBUG Log sieht sehr kurz aus , da fehlt sehr viel !!
                                          Der neue User muß Administratorrechte haben , sonnst funktioniert das nicht .
                                          Und warum einen extra User nimm den Administator User dafür
