  4. Node Red startet in IO Broker nicht "Verbindung verweigert"
    5.6k
32 Beiträge 5 Kommentatoren 3.9k Aufrufe 4 Beobachtet
    @heinloth das kann nicht sein!
    hast du was herausgeschnitten?
    Heinloth
    @homoran ```
    pi@iobroker-pi:~ $ iobroker list instances
    • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
    • system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled
    • system.adapter.backitup.0 : backitup : iobroker-pi - enabled
      system.adapter.discovery.0 : discovery : iobroker-pi - disabled
      system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker-pi - disabled
      system.adapter.fronius.0 : fronius : iobroker-pi - disabled
      system.adapter.iot.0 : iot : iobroker-pi - disabled
      system.adapter.javascript.0 : javascript : iobroker-pi - disabled
      system.adapter.lgtv.1 : lgtv : iobroker-pi - disabled
    • system.adapter.loxone.0 : loxone : iobroker-pi - enabled, port: 80
    • system.adapter.node-red.5 : node-red : iobroker-pi - enabled, port: 1880, bind: 0.0.0.0
    • system.adapter.sonos.0 : sonos : iobroker-pi - enabled
    • system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
    • instance is alive
    Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
    • H Heinloth
      @thomas-braun ```
      node-red.1
      2022-12-02 20:03:29.385 error 2 Dec 20:03:29 - [error] Error: listen EADDRINUSE: address already in use 192.168.178.38:8081 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at doListen (node:net:1660:7) at processTicksAndRejections (node:internal/process/task_queues:84:21)
      node-red.1
      2022-12-02 20:03:29.382 error 2 Dec 20:03:29 - [error] Nicht abgefangene Ausnahmebedingung:
      node-red.1
      2022-12-02 20:03:13.803 error 2 Dec 20:03:13 - [error] Error: listen EADDRINUSE: address already in use 192.168.178.38:8081 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at doListen (node:net:1660:7) at processTicksAndRejections (node:internal/process/task_queues:84:21)
      node-red.1
      2022-12-02 20:03:13.801 error 2 Dec 20:03:13 - [error] Nicht abgefangene Ausnahmebedingung:
      @heinloth sagte in Node Red startet in IO Broker nicht "Verbindung verweigert":
      node-red.1
      wo ist das?
      H 1 Antwort Letzte Antwort
      • H Heinloth
        @homoran ```
        • instance is alive
        node-red.5
        Was machst du da?
        Und bitte die CodeTags in einer neuen Zeile setzen, dann funktioniert es auch richtig.
        • H Heinloth
          @homoran ```
          • instance is alive
          DJMarc75D Offline
          DJMarc75D Offline
          DJMarc75
          wird schwierig mit den Resourcen vom System 😁
          Lehrling seit 1975 !!!
            node-red.1
            wo ist das?
            Heinloth
            @homoran die nummer kann man doch frei wählen
            ich habe einfach verschiedenes probiert die 1 wurde wieder gelöscht genauso wie die 0
            H HomoranH 2 Antworten Letzte Antwort
            • H Heinloth
              Heinloth
              jetzt läuft nodered 5 auf einmal, seither ging es nicht
              Wenn ich jetzt wieder damit arbeite und es nach 5 Tage wieder drei grätsche macht verzweifle ich.
              • H Heinloth
                wie sollen wir dir helfen, wenn du die Rahmenbedingungen änderst?
                wieso zeigst du uns ein (altes) Log mit .1 wenn du jetzt .5 hast?
                gibt es da den Fehler nicht mehr?
                • H Heinloth
                  @heinloth
                  sieh mal hier:
                  da steht u.a.
                  In der Zwischenzeit keine eigenen Aktionen durchführen, die man aus der Nachfrage glaubt erfüllen zu sollen.
                    @heinloth
                    sieh mal hier:
                    da steht u.a.
                    Heinloth
                    @homoran Sorry, ich bin kein IT ler. Ja, ich habe den 1er gelöscht und 5er installiert in der zwischenzeit. Merke ich mir fürs nächste mal. Nichts verändern.
                    Woran kann das aber jetzt gelegen haben?
                    • H Heinloth
                      das können wir dir nicht mehr sagen, weil wir die Situation zum Zeitpunkt des Problems nicht gekannt haben.
                        Heinloth
                        @homoran Herzlichen Dank für Eure Hilfe. Ohne euch Spezialisten wäre ich als leihe komplett aufgeschmissen. Danke
