  4. Node Red startet in IO Broker nicht "Verbindung verweigert"
    5.6k
32 Beiträge 5 Kommentatoren 3.9k Aufrufe 4 Beobachtet
  • H Heinloth
    pi@iobroker-pi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    pi@iobroker-pi:~ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    armv7l
    Kein Docker
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v16.18.1
    v16.18.1
    8.19.2
    4.0.23
    pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    tty
    /home/pi
    OK:1 http://archive.raspberrypi.org/debian buster InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
    OK:3 https://deb.nodesource.com/node_16.x buster InRelease
    Alle Pakete sind aktuell.
    nodejs:
      Installiert:           16.18.1-deb-1nodesource1
      Installationskandidat: 16.18.1-deb-1nodesource1
      Versionstabelle:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    pi@iobroker-pi:~ $
    pi@iobroker-pi:~ $ iobroker uodate
    iobroker [command]
    Commands:
      iobroker setup                                               Setup ioBroker
      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
      iobroker info                                                Shows the host info
      iobroker logs [<adapter>]                                    Monitor log
      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
      iobroker rebuild [<module>]                                  Rebuild all native modules or path
      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
      iobroker update [<repositoryUrl>]                            Update repository and list adapters
      iobroker upgrade                                             Upgrade management
      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
      iobroker object                                              Object management  [aliases: o]
      iobroker state                                               State management  [aliases: s]
      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
      iobroker list <type> [<filter>]                              List all entries, like objects
      iobroker chmod <mode> <file>                                 Change file rights
      iobroker chown <user> <group> <file>                         Change file ownership
      iobroker touch <file>                                        Touch file
      iobroker rm <file>                                           Remove file
      iobroker file                                                File management
      iobroker user                                                User commands
      iobroker group                                               group management
      iobroker host <hostname>                                     Set host to given hostname
      iobroker set <adapter>.<instance>                            Change settings of adapter config
      iobroker license <license.file or license.text>              Update license by given file
      iobroker cert                                                Certificate management
      iobroker clean <yes>                                         Clears all objects and states
      iobroker backup                                              Create backup
      iobroker restore <backup name or path>                       Restore a specified backup
      iobroker validate <backup name or path>                      Validate a specified backup
      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
      iobroker repo [<name>]                                       Show repo information
      iobroker uuid                                                Show uuid of the installation  [aliases: id]
      iobroker unsetup                                             Reset license, installation secret and language
      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
      iobroker multihost                                           Multihost management
      iobroker compact                                             compact group management
      iobroker plugin                                              Plugin management
      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
    Options:
      --help  Show help  [boolean]
    @heinloth streiche o setze p
    H 1 Antwort Letzte Antwort
      @heinloth
      iobroker update
      Dein Betriebssystem möchte in Gänze auf eine aktuelle Version aktualisiert werden. Buster hat das Ende of Life im September erreicht.
      Heinloth
      @thomas-braun alle aktualisiert
      läuft trotzdem noch nicht
        Heinloth
        @homoran wo
        • H Heinloth
          @homoran wo
          @heinloth sagte in Node Red startet in IO Broker nicht "Verbindung verweigert":
          @homoran wo
          bei uodate
          alle aktualisiert
          was und warum?
            @heinloth
            iobroker update
            Heinloth
            pi@iobroker-pi:~ $ iobroker update
            Used repository: stable
            Adapter    "admin"        : 6.2.23   , installed 6.2.23
            Adapter    "alexa2"       : 3.21.0   , installed 3.21.0
            Adapter    "backitup"     : 2.5.4    , installed 2.5.4
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "fronius"      : 1.1.3    , installed 1.1.3
            Adapter    "fronius-solarweb": 0.0.3 , installed 0.0.3
            Adapter    "iot"          : 1.11.9   , installed 1.11.9
            Adapter    "javascript"   : 6.0.3    , installed 6.0.3
            Controller "js-controller": 4.0.23   , installed 4.0.23
            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
            Adapter    "loxone"       : 3.0.0    , installed 3.0.0
            Adapter    "mihome-plug"  : 0.2.1    , installed 0.2.1
            Adapter    "node-red"     : 4.0.0    , installed 4.0.0
            Adapter    "simple-api"   : 2.7.0    , installed 2.7.2
            Adapter    "sonos"        : 2.2.3    , installed 2.2.3
            • H Heinloth
              @Heinloth
              Und im LogFile steht was?
                @Heinloth
                Heinloth
                @thomas-braun ```
                node-red.1
                2022-12-02 20:03:29.385 error 2 Dec 20:03:29 - [error] Error: listen EADDRINUSE: address already in use 192.168.178.38:8081 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at doListen (node:net:1660:7) at processTicksAndRejections (node:internal/process/task_queues:84:21)
                node-red.1
                2022-12-02 20:03:29.382 error 2 Dec 20:03:29 - [error] Nicht abgefangene Ausnahmebedingung:
                node-red.1
                2022-12-02 20:03:13.803 error 2 Dec 20:03:13 - [error] Error: listen EADDRINUSE: address already in use 192.168.178.38:8081 at Server.setupListenHandle [as _listen2] (node:net:1463:16) at listenInCluster (node:net:1511:12) at doListen (node:net:1660:7) at processTicksAndRejections (node:internal/process/task_queues:84:21)
                node-red.1
                2022-12-02 20:03:13.801 error 2 Dec 20:03:13 - [error] Nicht abgefangene Ausnahmebedingung:
                • H Heinloth
                  @thomas-braun ```
                  node-red.1
                  node-red.1
                  node-red.1
                  node-red.1
                  @heinloth
                  Da läuft schon was anderes. Vermutlich die Instanz node-red.0
                  Warum hantierst du mit zwei Instanzen?
                  iobroker list instances
                  sagt?
                  • H Offline
                    Heinloth
                    @thomas-braun ```
                    pi@iobroker-pi:~ $ iobroker list instances
                    • system.adapter.admin.0 : admin : iobroker-pi - enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    • system.adapter.alexa2.0 : alexa2 : iobroker-pi - enabled
                    • system.adapter.backitup.0 : backitup : iobroker-pi - enabled
                      system.adapter.discovery.0 : discovery : iobroker-pi - disabled
                      system.adapter.fronius-solarweb.0 : fronius-solarweb : iobroker-pi - disabled
                      system.adapter.fronius.0 : fronius : iobroker-pi - disabled
                      system.adapter.iot.0 : iot : iobroker-pi - disabled
                      system.adapter.javascript.0 : javascript : iobroker-pi - disabled
                      system.adapter.lgtv.1 : lgtv : iobroker-pi - disabled
                    • system.adapter.loxone.0 : loxone : iobroker-pi - enabled, port: 80
                    • system.adapter.node-red.5 : node-red : iobroker-pi - enabled, port: 1880, bind: 0.0.0.0
                    • system.adapter.sonos.0 : sonos : iobroker-pi - enabled
                    • system.adapter.web.0 : web : iobroker-pi - enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    • instance is alive
                      pi@iobroker-pi:~ $
                    • H Heinloth
                      @thomas-braun ```
                      • instance is alive
                        pi@iobroker-pi:~ $
                      @heinloth das kann nicht sein!
                      hast du was herausgeschnitten?
                        @heinloth
                        sagt?
                        Heinloth
                        @thomas-braun habe ein paar mal gelöscht und neu gestartet
                        • ? Offline
                          Es nur eine Randnotiz. Bei mir Läuft NodeRed 4.x auch nicht. Alle Nodes sind deaktiviert.
                          Vieleicht die Version 3.x Probieren.
                            Heinloth
                            @homoran ```
                            • instance is alive
                            Thomas BraunT DJMarc75D 2 Antworten Letzte Antwort
                            • H Heinloth
                              @thomas-braun ```
                              node-red.1
                              node-red.1
                              node-red.1
                              node-red.1
                              node-red.1
                              wo ist das?
                              • H Heinloth
                                @homoran ```
                                • instance is alive
                                node-red.5
                                Was machst du da?
                                Und bitte die CodeTags in einer neuen Zeile setzen, dann funktioniert es auch richtig.
                                • H Heinloth
                                  @homoran ```
                                  • instance is alive
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  wird schwierig mit den Resourcen vom System 😁
                                  Lehrling seit 1975 !!!
                                    node-red.1
                                    wo ist das?
                                    Heinloth
                                    @homoran die nummer kann man doch frei wählen
                                    ich habe einfach verschiedenes probiert die 1 wurde wieder gelöscht genauso wie die 0
                                    H HomoranH 2 Antworten Letzte Antwort
                                    • H Heinloth
                                      Heinloth
                                      jetzt läuft nodered 5 auf einmal, seither ging es nicht
                                      Wenn ich jetzt wieder damit arbeite und es nach 5 Tage wieder drei grätsche macht verzweifle ich.
                                      • H Heinloth
                                        wie sollen wir dir helfen, wenn du die Rahmenbedingungen änderst?
                                        wieso zeigst du uns ein (altes) Log mit .1 wenn du jetzt .5 hast?
                                        gibt es da den Fehler nicht mehr?
                                        • H Heinloth
                                          @heinloth
                                          sieh mal hier:
                                          da steht u.a.
                                          In der Zwischenzeit keine eigenen Aktionen durchführen, die man aus der Nachfrage glaubt erfüllen zu sollen.
