  2. Nederlands
  3. Visualisatie
  4. jarvis
    1.0k
jarvis
Geplant Angeheftet Gesperrt Verschoben Visualisatie
15 Beiträge 2 Kommentatoren 8.1k Aufrufe 2 Beobachtet
    MCU
    @chris-nij You have to create a datapoint in ioBroker -> exp.: 0_userdata.0.jarvis.camera1.image
    And then you fill this DP with the data from your camera. (script)
    Ronny did this like he shown in the script:
    So every second it will generate a new data for the DP.
    // create DP
    createStateAsync('0_userdata.0.jarvis.camera1.image', {read: true, write: true, name: "Camera1 Image", type: "string", role: "text", def: "" });
    //Instar Kamera 9008
    let cameraLiveStream = 'http://192.168.178.49:8085/tmpfs/auto.jpg?usr=xxx&pwd=xxx';
    let cameraInterval = setInterval(function() {
        setState('0_userdata.0.jarvis.camera1.image', cameraLiveStream + '&_=' + Math.floor(Math.random() * 10000), true);
    }, 1000);
    Add device for this new DP (0_userdata.0.jarvis.camera1.image)
    Then you change in jarvis the parameter in displayImage from directly by http to DP.
    I hope this are enough information for you, otherwise ask again.
    Have a nice day.
    C 1 Antwort Letzte Antwort
    • M MCU
      // create DP
      }, 1000);
      Have a nice day.
      chris nij
      @mcu Hello,
      I've been working on it, I've found out how I make a data point in user data. But when I open it, I don't know what to do. there is already something in, but what next. when I put something in it, I can't save it.
      I am not familiar with scripting.
      Greetings,
      chris
      • C chris nij
        @mcu Hello,
        Greetings,
        chris
        MCU
        @chris-nij You don't have to it, it would automatically done by script.
        I show how to initialize the script.
        Do you have installed "javascript"? Do you see this in your speech? scripts?
        If not, you must install javascript.
        Then you go to "adapter" on left side. Click on it and then search javascript.
        Click on "+" to install the javascript-adapter.
        Do you have it or not?
        • M MCU
          chris nij
          @mcu Hello,
          I installed scripts, and added the script. adjusted the stream to my instar camera. but it doesn't work in jarvis unfortunately. what am i doing wrong.
          Greetings
          chris
          • C chris nij
            @mcu Hello,
            Greetings
            chris
            MCU
            @chris-nij Show me the configuration of the displayImage-modul in layout.
            Use this configuration
            Not the user at first.
            • M MCU
              chris nij
              I don't know exactly what you mean by configuration of the displayimage module. but I think one of the pictures is the right one.
              chris
              • C chris nij
                chris
                MCU
                @chris-nij You could change the Refresh Method?
                Do you get a Picture with cameraLiveStream-Link in a normal Browser Window?
                And its works
                Which Link did you used at this time before?
                • M MCU
                  And its works
                  chris nij
                  @mcu
                  with my link in the browser, works.
                  with the link you gave me. I get a logon, but when I enter users and password it says that this is not correct. but i know that this is good.
                  C M 2 Antworten Letzte Antwort
                  • C chris nij
                    @mcu
                    chris nij
                    @chris-nij said in jarvis:
                    @mcu
                    • C chris nij
                      @mcu
                      MCU
                      @chris-nij I don't have a Camera. So I only can say what I read in the forum.
                      Perhaps @lines or @Ronny-Gerndt can help you in a better way?
                      So use your Link (And it works) and change the refresh Method to add numbers.
                      • M MCU
                        chris nij
                        @mcu
                        Okay,
                        thank you for helping. I learned something in iobroker (scripts).
                        Greetings,
                        chris
                        • C chris nij
                          @mcu
                          Okay,
                          Greetings,
                          chris
                          chris nij
                          @chris-nij
                          Yes its works.😀
                          I used the administration account. apparently the instar camera doesn't like this. I have now created a user account in the camera and added it in jarvis. now everything works great.
                          chris
