    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • ArmilarA Armilar
    @markus-s
    Leg mal das komplette Tasmota-Log (ab Neustart und FlashNextion...) vom in Code-Tags fb0975df-5309-49c2-990b-8c27f66e891d-image.png . Nur der Screenshot hilft hier nicht viel...
    Markus S.M Offline
    Markus S.M Offline
    Markus S.
    #913
    @armilar
    00:00:00.003 HDW: ESP32-D0WD-V3
    00:00:00.106 UFS: FlashFS mounted with 280 kB free
    00:00:00.189 CFG: Loaded from File, Count 27
    00:00:00.205 QPC: Count 1
    00:00:00.473 BRY: Berry initialized, RAM used=4041 bytes
    00:00:00.504 Project tasmota - Tasmota Version 12.2.0(nspanel)-2_0_5(2022-10-17T08:40:00)
    00:00:00.016 NXP: Initializing Driver
    00:00:00.023 BRY: Successfully loaded 'autoexec.be'
    00:00:01.616 WIF: Connecting to AP1 DeepSpaceNine Channel 1 BSSId B4:FB:E4:11:92:60 in mode 11n as tasmota-D3CE24-3620...
    00:00:06.332 WIF: Connected
    00:00:06.594 HTP: Web server active on tasmota-D3CE24-3620 with IP address 10.1.1.185
    16:51:52.585 RSL: INFO1 = {"Info1":{"Module":"NSPanel","Version":"12.2.0(nspanel)","FallbackTopic":"cmnd/DVES_D3CE24_fb/","GroupTopic":"cmnd/tasmotas/"}}
    16:51:52.600 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D3CE24-3620","IPAddress":"10.1.1.185"}}
    16:51:52.604 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":10}}
    16:51:52.618 RSL: RESULT = {"POWER1":"OFF"}
    16:51:52.620 RSL: POWER1 = OFF
    16:51:52.623 RSL: RESULT = {"POWER2":"OFF"}
    16:51:52.625 RSL: POWER2 = OFF
    16:51:52.769 QPC: Reset
    16:51:56.765 RSL: STATE = {"Time":"2022-11-28T16:51:56","Uptime":"0T00:00:12","UptimeSec":12,"Heap":137,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":313,"MqttCount":0,"Berry":{"HeapUsed":14,"Objects":223},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"DeepSpaceNine","BSSId":"B4:FB:E4:11:92:60","Channel":1,"Mode":"11n","RSSI":82,"Signal":-59,"LinkCount":1,"Downtime":"0T00:00:06"}}
    16:51:56.806 RSL: SENSOR = {"Time":"2022-11-28T16:51:56","ANALOG":{"Temperature1":29.2},"TempUnit":"C"}
    16:53:00.551 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft
    16:53:00.562 RSL: RESULT = {"FlashNextion":"Done"}
    16:53:00.603 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v3.6.0.tft
    • Markus S.M Markus S.
      @armilar
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      #914
      @markus-s
      bist du sicher, dass das Subnetz 10.1.1. in das Internet darf oder kommt?
      Markus S.M 1 Antwort Letzte Antwort
      • ArmilarA Armilar
        @markus-s
        Markus S.M Offline
        Markus S.M Offline
        Markus S.
        #915
        @armilar
        Ja - sehr sicher!
        ArmilarA J 2 Antworten Letzte Antwort
          @armilar
          Ja - sehr sicher!
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #916
          @markus-s
          Lass uns auf @joBr99 warten. Bei den Unwegsamkeiten beim Flashen kennt er sich besser aus. Ich transportiere nur die Daten zum Tasmota.
          Ist aber dennoch, merkwürdig, dass nicht einmal das Flashen startet. Geht bei korrekter Installation des Berry-Driver eigentlich sehr schnell und kann auch wiederholt werden. Auch wenn es nervt, es ist "keine" Komponente im Router an, die der IP 10.1.1.185 untersagt, sich mit der Außenwelt zu verbinden?
            @armilar
            Ja - sehr sicher!
            joBr99
            #917
            @markus-s
            Mit weblog 3 in der tasmota konsole kannst du etwas mehr log output bekommen.
            17:53:33.461 CMD: weblog 3
            17:53:33.472 MQT: stat/tasmota_nspwohn/RESULT = {"WebLog":3}
            17:53:49.603 CMD: FlashNextion http://nspanel.pky.eu/lui.tft
            17:53:49.606 SRC: WebConsole from 192.168.62.152
            17:53:49.609 CMD: Grp 0, Cmd 'FLASHNEXTION', Idx 1, Len 29, Pld -99, Data 'http://nspanel.pky.eu/lui.tft'
            17:53:49.623 MQT: stat/tasmota_nspwohn/RESULT = {"FlashNextion":"Done"}
            17:53:49.670 FLH: host: nspanel.pky.eu, port: 80, get: /lui.tft
            17:53:49.732 FLH: Connected:true
            17:53:49.840 FLH: Retry 2
            17:53:50.871 FLH: HTTP Respose is 200 OK or 206 Partial Content
            17:53:50.882 FLH: Flash file size: 7957460
            17:53:50.887 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
            17:53:50.892 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
            17:53:50.897 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
            17:53:50.904 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
            17:53:50.917 NXP: Received Raw = bytes('23FFFFFF636F6D6F6B20322C33303631342D302C4E5834383332463033355F30...')
            17:53:50.924 FLH: Send (High Speed) flash start
            17:53:50.932 NXP: Nextion command sent = bytes('77686D692D7772697320373935373436302C3932313630302C72657330FFFFFF')
            17:53:51.318 NXP: Received Raw = bytes('05')
            17:53:51.323 FLH: Read block
            17:53:51.326 FLH: Buff size 4990
            17:53:51.333 FLH: Writing 4096
            17:53:51.344 MQT: tele/tasmota_nspwohn/RESULT = {"Flashing":{"complete": 0, "time_elapsed": 0}}
            17:53:51.457 FLH: Total 4096
            17:53:51.614 NXP: Received Raw = bytes('08')
            17:53:51.618 FLH: Waiting offset...
            17:53:54.916 NXP: Received Raw = bytes('00000000')
            17:53:54.920 FLH: Flash offset marker 0
            17:53:54.924 FLH: Read block
            17:53:54.957 FLH: Buff size 6638
            17:53:54.964 FLH: Writing 4096
            17:53:55.074 FLH: Total 8192
            17:53:55.096 NXP: Received Raw = bytes('05')
            17:53:55.101 FLH: Read block
            17:53:55.121 FLH: Buff size 8286
            17:53:55.130 FLH: Writing 4096
            17:53:55.240 FLH: Total 12288
            • J joBr99
              @markus-s
              Markus S.M Offline
              Markus S.M Offline
              Markus S.
              schrieb am zuletzt editiert von Markus S.
              #918
              @jobr99
              Bei mir hört der da einfach auf...
              00:00:00.002 HDW: ESP32-D0WD-V3
              00:00:00.003 HDW: FoundPSRAM=0 CanUsePSRAM=0
              00:00:00.137 UFS: FlashFS mounted with 280 kB free
              00:00:00.248 CFG: Loaded from File, Count 42
              00:00:00.263 QPC: Count 1
              00:00:00.265 CFG: CR 427/699, Busy 0
              00:00:00.275 CFG: CR 427/699, Busy 0
              00:00:00.278 ROT: Mode 1
              00:00:00.597 CFG: No '*.autoconf' file found
              00:00:00.604 BRY: Berry initialized, RAM used=4041 bytes
              00:00:00.628 BRY: No 'preinit.be'
              00:00:00.633 SRC: Restart
              00:00:00.640 Project tasmota - NSPanel Version 12.2.0(nspanel)-2_0_5(2022-10-17T08:40:00)
              00:00:00.641 ETH: No ETH MDC and/or ETH MDIO GPIO defined
              00:00:01.051 NXP: Initializing Driver
              00:00:01.059 BRY: Successfully loaded 'autoexec.be'
              00:00:01.447 WIF: Attempting connection...
              00:00:01.943 WIF: Connecting to AP1 DeepSpaceNine Channel 1 BSSId F0:9F:C2:F1:5F:C2 in mode 11n as tasmota-D3CE24-3620...
              00:00:01.974 WIF: Attempting connection...
              00:00:03.638 WIF: Connected
              00:00:04.240 HTP: Web server active on tasmota-D3CE24-3620 with IP address 10.1.1.185
              00:00:04.921 RTC: UTC 2022-11-28T16:59:26, DST 2022-03-27T02:00:00, STD 2022-10-30T03:00:00
              17:59:26.000 RTC: Synced by NTP
              17:59:27.227 RSL: INFO1 = {"Info1":{"Module":"NSPanel","Version":"12.2.0(nspanel)","FallbackTopic":"cmnd/DVES_D3CE24_fb/","GroupTopic":"cmnd/tasmotas/"}}
              17:59:27.243 RSL: INFO2 = {"Info2":{"WebServerMode":"Admin","Hostname":"tasmota-D3CE24-3620","IPAddress":"10.1.1.185"}}
              17:59:27.247 RSL: INFO3 = {"Info3":{"RestartReason":"Software reset CPU","BootCount":15}}
              17:59:27.261 RSL: RESULT = {"POWER1":"OFF"}
              17:59:27.263 RSL: POWER1 = OFF
              17:59:27.265 RSL: RESULT = {"POWER2":"OFF"}
              17:59:27.268 RSL: POWER2 = OFF
              17:59:27.280 TFS: File 'autoexec.bat' not found
              17:59:29.711 QPC: Reset
              17:59:30.286 HTP: Main Menu
              17:59:31.703 APP: Boot Count 15
              17:59:31.711 RSL: STATE = {"Time":"2022-11-28T17:59:31","Uptime":"0T00:00:10","UptimeSec":10,"Heap":136,"SleepMode":"Dynamic","Sleep":0,"LoadAvg":210,"MqttCount":0,"Berry":{"HeapUsed":14,"Objects":223},"POWER1":"OFF","POWER2":"OFF","Wifi":{"AP":1,"SSId":"DeepSpaceNine","BSSId":"F0:9F:C2:F1:5F:C2","Channel":1,"Mode":"11n","RSSI":58,"Signal":-71,"LinkCount":1,"Downtime":"0T00:00:04"}}
              17:59:31.753 RSL: SENSOR = {"Time":"2022-11-28T17:59:31","ANALOG":{"Temperature1":28.5},"TempUnit":"C"}
              17:59:32.021 CFG: Saved, Count 43, Bytes 4096
              17:59:32.211 HTP: Consoles
              17:59:34.107 HTP: Console
              18:00:31.329 CMD: FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft
              18:00:31.332 SRC: WebConsole from 10.1.1.101
              18:00:31.334 CMD: Grp 0, Cmd 'FLASHNEXTION', Idx 1, Len 59, Pld -99, Data 'http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.6.0.tft'
              18:00:31.345 RSL: RESULT = {"FlashNextion":"Done"}
              18:00:31.396 FLH: host: nspanel.pky.eu, port: 80, get: /lovelace-ui/github/nspanel-v3.6.0.tft
              18:00:31.482 FLH: Connected:true
              18:00:31.591 FLH: Retry 2
              18:00:31.792 FLH: Retry 3
              18:00:32.819 FLH: HTTP Respose is 200 OK or 206 Partial Content
              18:00:32.830 FLH: Flash file size: 7925436
              18:00:32.835 NXP: Nextion command sent = bytes('4452414B4A485355594447424E434A48474A4B534842444EFFFFFF')
              18:00:32.839 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
              18:00:32.843 NXP: Nextion command sent = bytes('7265636D6F643D30FFFFFF')
              18:00:32.847 NXP: Nextion command sent = bytes('636F6E6E656374FFFFFF')
              • ArmilarA Offline
                ArmilarA Offline
                Armilar
                #919
                @markus-s
                @joBr99 was ist denn das für eine Datei? Von der habe ich bislang in der NSPanel-Welt noch nichts gehört?
                von einer
                auch noch nicht
                  Matze_HH
                  #920
                  @Armilar
                  Sorry das ich nochmal hier rein schreibe :)
                  Da du ja jetzt die Hintergrundfarben implementiert hast, wollte ich gleich ans Werk gehen, aber das updaten der .ts...
                  Gibt es eine Anleitung fürs Updaten? Habe in der Wiki nichts gefunden...
                  • ArmilarA Offline
                    ArmilarA Offline
                    Armilar
                    #921
                    @matze_hh
                    In diesem Fall ist es leicht...
                    Den unteren Teil ab
                    // _________________________________ Ab hier keine Konfiguration mehr ____________
                    einfach ersetzten und die 3 Farbkonstanten (nachfolgend Zeile 3 - 5) hinzufügen.
                    //Screensaver Default Theme Colors
                    const scbackground:     RGB = { red:   0, green:    0, blue:   0};
                    const scbackgroundInd1: RGB = { red: 255, green:   0,  blue:   0};
                    const scbackgroundInd2: RGB = { red: 121, green: 222,  blue: 121};
                    const scbackgroundInd3: RGB = { red: 255, green: 255,  blue:   0};
                    Den Rest macht das TS-Script mit dem ersten Start selbst.
                    Ach ja und
                    in der Tasmota-Console ausführen.
                    Das wäre dann schon alles...
                    ArmilarA M M 3 Antworten Letzte Antwort
                    • ArmilarA Armilar
                      @matze_hh
                      Den unteren Teil ab
                      Ach ja und
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #922
                      Link vom TS-Script 3.6.0.1 vergessen. Aber die meisten hätten es auch so gefunden:
                      https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker
                        ich bin neu in dem Thema und habe bereits gesucht, aber nichts gefunden.
                        Ich habe am Wochenende die Installation durchgeführt.
                        Tasmota für das NSPanel 12.2 drauf, das Berry Script autoexec.be drauf.
                        Dann das FlashNextion durchgeführt - das Display wird blau und zeigt "Write 0% 4096".
                        Blieb doirt hängen und nach knapp 2 Minuten machte das Display ein Reboot.
                        Nun zeigt das Display "System Data ERROR!"
                        Ich versuche es erneut mit Flashen - die Anzeige in der Console ist:
                        15:48:26.855 CMD: FlashNextion http://nspanel.pky.eu/lui-release.tft
                        15:48:26.865 RSL: RESULT = {"FlashNextion":"Done"}
                        15:48:26.899 FLH: host: nspanel.pky.eu, port: 80, get: /lui-release.tft
                        Danach kommt nichts mehr - der Bildschirm auf dem Display wird auch nicht mehr "blau". Der Tasmota Teil läuft weiter - sieht man, denn das Log zeigt weitere Nachrichten an, z.B. wenn man schaltet, oder die Temperatur an dem Teil ändert sich.
                        Sollte ich was übersehen habe - ich bin für jeden Tipp dankbar! Ich hoffe ich habe nun keinen Schalter mit schwarzem Display.
                        Vielen, vielen Dank,
                        Markus
                        W Offline
                        W Offline
                        Wuschl
                        schrieb am zuletzt editiert von Wuschl
                        #923
                        @markus-s said in SONOFF NSPanel mit Lovelace UI:
                        Probier mal das
                        Ich hatte letztens auch ein Panel das sich nicht flashen lies, funktionierte aber dann mit nem anderen Link. Weiß nur nicht ob es dieser war. Den hatte @Armilar in seiner Anleitung stehen. Ich finde Ihn aber leider nicht mehr.
                        Oder dieser
                        FlashNextion http://nspanel.pky.eu/lovelace-ui/github/nspanel-v3.1.0.tft
                        • ArmilarA Armilar
                          @matze_hh
                          Den unteren Teil ab
                          Ach ja und
                          Matze_HH
                          #924
                          @armilar said in SONOFF NSPanel mit Lovelace UI:
                          Ok dann mache ich es schon richtig, bekomme aber einen riesen Haufen Fehler :(
                          javascript.0 (689) script.js.NSPanel.Panel_1_3_5: TypeScript compilation failed: "yAxis": "Gas [kWh]", ^ ERROR: Type '{ type: "cardChart"; heading: string; useColor: true; subPage: false; parent: undefined; yAxis: string; yAxisTicks: number[]; items: PageItem[]; }' is not assignable to type 'PageChart'. Object literal may only specify known properties, and '"yAxis"' does not exist in type 'PageChart'. await createAliasAsync(config.weatherEntity + '.ICON', 'accuweather.0.Current.WeatherIcon', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ICON' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP', 'accuweather.0.Current.Temperature', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature', name: 'TEMP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MIN', 'accuweather.0.Daily.Day1.Temperature.Minimum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.forecast.0', name: 'TEMP_MIN' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MAX', 'accuweather.0.Daily.Day1.Temperature.Maximum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.max.forecast.0', name: 'TEMP_MAX' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.SET', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.SET', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.ACTUAL', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.SET', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'ipAddress.ACTUAL', NSPanel_Path + 'NSPanel_ipAddress', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.BerryDriver.ACTUAL', NSPanel_Path + 'Berry_Driver.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Uptime.ACTUAL', NSPanel_Path + 'Tasmota.Uptime', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Version.ACTUAL', NSPanel_Path + 'Tasmota.Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Hardware.ACTUAL', NSPanel_Path + 'Tasmota.Hardware', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.AP.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.AP', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.SSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.SSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.BSSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.BSSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Channel.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Channel', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Mode.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Mode', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.RSSI.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.RSSI', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Signal.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Signal', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.TFTVersion.ACTUAL', NSPanel_Path + 'Display_Firmware.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.Model.ACTUAL', NSPanel_Path + 'NSPanel_Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.Player.currentAlbum', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.Player.currentArtist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.Player.currentTitle', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.Player.controlNext', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.Player.controlPrevious', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.Player.controlPlay', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.Player.controlPause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.Commands.deviceStop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.Player.currentState', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + 'player.album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + 'player.artistName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + 'player.trackName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + 'player.contextDescription', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + 'player.skipPlus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + 'player.skipMinus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + 'player.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + 'player.isPlaying', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.current_album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.current_artist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.current_title', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + '.current_station', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.next', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.prev', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.stop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.state_simple', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. scrSvrBGCol = rgb_dec565(scbackgroundInd1); ^ ERROR: Cannot find name 'scbackgroundInd1'. scrSvrBGCol = rgb_dec565(scbackgroundInd2); ^ ERROR: Cannot find name 'scbackgroundInd2'. scrSvrBGCol = rgb_dec565(scbackgroundInd3); ^ ERROR: Cannot find name 'scbackgroundInd3'. await createAliasAsync(AliasPath + 'Sensor.ANALOG.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ANALOG.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ESP32.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ESP32.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'.
                          • M Matze_HH
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #925
                            @matze_hh
                            Ja perfekt. Das Beispiel ist zwar schon drin, aber die cardChart ist noch nicht in der TFT-Firmware. Daher mit der cardChart noch ein wenig warten. Das TS-Script kann das schon, aber das NSPanel ist noch nicht so weit.
                            Mit anderen Worten. Die cardChart darf aktuell noch nicht in den Seiten aufgerufen werden.
                            • ArmilarA Armilar
                              @matze_hh
                              Matze_HH
                              #926
                              @armilar ah, ok. Es läuft aber so erstmal?! :)
                              ArmilarA 2 Antworten Letzte Antwort
                              • M Matze_HH
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #927
                                @matze_hh
                                Ja, sollte alles wie gewohnt, auch erst abwärtskompatibel laufen.
                                Alle anderen beschriebenen Funktionen kannst du natürlich einbauen oder testen. Nur halt die Charts noch nicht.
                                In der HMI-DEV ist die schon drin, aber in dem aktuellen TFT-Release noch nicht...
                                Kann aber nicht mehr lang dauern.
                                • M Matze_HH
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #928
                                  @matze_hh
                                  Hast du es auch genauso gemacht?
                                  Den unteren Teil ausgetauscht und nur oben die 3 Screensaver Konstanten hinzugefügt?
                                  Es dürfte am rechten Rand nichts rot sein.
                                  Deine alten Variablen und Config bleiben so wie sie sind. Ist dann höchstens 5 Minuten Umstellung auf die neue Version...
                                  • ArmilarA Armilar
                                    SONOFF NSPanel Touch Display Switch
                                    mit Lovelace UI und TASMOTA Firmware
                                    Das Thema https://forum.iobroker.net/topic/50888/sonoff-nspanel/1542 wird hier jetzt fortgesetzt...
                                    An alle begeisterten NSPanel'er
                                    Dieser Thread soll sich jetzt ausschließlich mit den Fragen und Themen rund um das SONOFF NSPanel mit Lovelace UI beschäftigen.
                                    Wie alles begann:
                                    • 22.10.2021
                                      Blakadder's Dokumentation der Dekodierung des NSPanel-Kommunikationsprotokolls und Einrichtung der Steuerung des Nextion-Bildschirms mit benutzerdefinierter Firmware.
                                      https://blakadder.com/nspanel-hacking/
                                    • 01.01.2022
                                      Erste Gehversuche mit Blockly-Scripts auf der Original-Firmware nach einer ersten coolen Anleitung für den ioBroker von @haus-automatisierung.
                                      Funkstille auf allen Kanälen, da das Panel in der Originalsoftware einfach zu wenig Funktionalität hat. Ein Vergleich mit "Jugend forscht" wäre maßlos übertrieben...
                                    • 15.01.2022
                                      @jobr99 Erstes POC von Lovelace Konzept mit ESPhome Komponente, da Nextion Upload Protcol unter tasmota nicht umsetzbar ist (berry tcpclient crashed ESP, HTTP Libary ist auf viel zu kleine Dateien limitiert)
                                    • 17.01.2022
                                      peepshow-21 Erste implementierung von Nextion Upload Protocol 1.1 mit Workaround für HTTP Libary über Java Converter um tft files für tasmota vorzubereiten
                                    • 20.01.2022
                                      s-hadinger fixt bug in berry tcpclient
                                    • 31.01.2022
                                      Erste Version für HomeAssistant mit Nodered und Tasmota
                                    • 08.02.2022
                                      @joBr99 Erste Implementierung von Nextion Upload Protokoll 1.2 in Berry basiertend auf HTTP Range Header Requests und lokalem Buffer (funktioniert nur mit -nspanel tasmota build uns PSRAM Support)
                                    • 12.02.2022
                                      peepshow-21 Implementierung von Nextion Upload Protocol 1.2 mit vollständigem Download und "streaming" zum Nextion Screen während dem Download
                                    • 05.03.2022
                                      @joBr99 Portierung von Node-Red Flow zu AppDaemon, da AppDaemon sich besser eignet zur Implementierung vom Backend
                                    • 13.03.2022
                                      @joBr99 Erste Version von Lovelace Berry Driver basierend auf Upload Protocol Implementierung von peepshow-21, da diese etwas stabiler läuft mit zusätzlichem Error Handling
                                    • 30.03.2022
                                      @joBr99 kommt mit der Info um die Ecke, dass es ein erstes Script v1.9.0 für den ioBroker von @Britzelpuf gibt. Zu diesem Zeitpunkt gab es bereits den Screensaver die Seitennavigation und die Möglichkeit eine Lampe, einen Dimmer eine Taste und eine Info, sowie die popUps für Licht (Brightness) und Shutter (Position) und einen Thermostaten zur Steuerung einzubinden.
                                    • 10.04.2022
                                      @joBr99 Firmware got bigger and bigger with >15 Minutes Flashing Time for the tft file
                                      Increased Flashing Speed of Berry Driver from 115200 to 921600 and added skipping to the End with HTTP Range Headers, resulted in faster display flashing
                                    • 11.04.2022
                                      @Armilar macht seine ersten Änderungen auf github und hört seit dem nicht mehr auf, weitere Funktionen in das TSScript hinzuzufügen... ;-)
                                      @joBr99 entwickelt die HMI und neue Funktionen für Home Assistant schneller als der Wind - und macht das Panel zur echten Bereicherung für jedes Smart Home 😊 👏
                                    heute
                                    • Eine der besten Community's die ich jemals erlebt habe. Hilfsbereit und kompetent wird jeder mit Hilfestellungen und Problemlösungen in kürzester Zeit versorgt.
                                    Es macht großen Spaß zusammen mit euch...
                                    Armilar
                                    Beispiele:
                                    Features:
                                    • cardEntities für die Unterstützung diverser Steuerelemente (siehe Beispiele)
                                    • cardGrid (3x2-Raster) für die Unterstützung diverser Steuerelemente (siehe Beispiele)
                                    • cardGrid2 (4x2) für die Unterstützung diverser Steuerelemente (siehe Beispiele)
                                    • cardGrid3 (2x2) für die Unterstützung diverser Steuerelemente (siehe Beispiele)
                                    • cardPower zur Visualisierung der Energieverteilung
                                    • cardAlarm als Seite für Alarmanlagen
                                    • cardMedia - der Media-Player (Diverse Adapter)
                                    • cardThermo - Seite für Thermostat oder Klimaanlage
                                    • cardQR - Seite mit QRCode zur Anzeige von WLAN-Informationen
                                    • cardChart - Balkendiagramme
                                    • Detailseiten für Leuchtmittel (Helligkeit, Temperatur und Farbe)
                                    • Detailseite für Jalousien/Rollos (Position und Tilt)
                                    • Detailseite für Ventilatoren
                                    • Detailseite für Timer
                                    • Auswahl Detailseite für Werteliste
                                    • Bildschirmschonerseite mit Uhrzeit, Datum und Wetterinformationen oder/und Infos
                                    • Multilingual (unterstützt über 40 Sprachen)
                                    • Unbegrenzte Anzahl an Seiten und Unterseiten
                                    • Abfallkalender
                                    • Favoritenseiten
                                    • etc.
                                      ich glaube da ist eine verbesserte "cardMedia" in der Entwicklung - sieht cool aus...
                                    NsPanel Lovelace UI ist eine Firmware für den Nextion-Bildschirm innerhalb des NSPanel.
                                    Die allgemeine Idee ist, dass das Nextion-Display einen Seitenzähler durchläuft und der ESP32 dem Display sagt, was zu tun ist. Alles ist dynamisch durch Alias-Erstellung konfigurierbar, es ist nicht erforderlich, Nextion Editor zu programmieren. Neben der Seiten-Definition sind im ioBroker keine Programmierkenntnisse erforderlich. Es ist im ioBroker ebenfalls kein Lovelace-Adapter erforderlich.
                                    Das Panel arbeitet mit Tasmota und MQTT. Um das Panel zu steuern und mit Inhalten von ioBroker zu aktualisieren, gibt es ein vordefiniertes TypeScript (TS) für den JavaScript-Adapter.
                                    Aktuelle Wiki (Anleitung) für den ioBroker
                                    https://github.com/joBr99/nspanel-lovelace-ui/wiki by @Kuckuckmann
                                    NsPanelTs.ts (TypeScript) für ioBroker v4.9.3.X
                                    zur Steuerung des SONOFF NSPanel mit dem ioBroker by @Armilar und @TT-Tom
                                    abgestimmt auf:
                                    • TFT 58 / v4.9.3 ( by @joBr99 / Armilar > 4.4.0)
                                    • BerryDriver 9 ( by peepshow-21 (based on code by blakadder and s-hadinger))
                                    • Tasmota 15.1.0 ( by Theo Arends ) --> Theo-Arends-Sonoff-MQTT-OTA
                                    Projekt:
                                    by @joBr99
                                    • main (Home Assistant - Version und Nextion HMI): https://github.com/joBr99/nspanel-lovelace-ui by @joBr99
                                    • ioBroker: https://github.com/joBr99/nspanel-lovelace-ui/tree/main/ioBroker by @Armilar (HA - Adaption)
                                    Icon-Mapper:
                                    • icon_mapping.ts:
                                      https://github.com/joBr99/nspanel-lovelace-ui/blob/main/ioBroker/icon_mapping.ts
                                      (TypeScript muss in global liegen)
                                    Icons:
                                    unter: https://docs.nspanel.pky.eu/icon-cheatsheet.html
                                    Video-Tutorial:
                                    https://www.youtube.com/watch?v=ZPLJk2ZLo_8 by @haus-automatisierung
                                    berlinchris81B Offline
                                    berlinchris81
                                    #929
                                    Hi Leute gute Arbeit die Ihr macht - Respect. Ich hab jetzt alle Einstellungen 3 mal gemacht - aber es funktiert nicht - ich hab folgens im log kann aber damit nichts anfangen - icon mapping habe ich eingebunden es wird auch nicht rot unterschrichen. zum einen habe ich ein "Waiting for content" sceen und ich bekommen folgendes im log angezeigt - ich verzweifle langsam
                                    LG Chris! Ich nutze den IOBroker.2022-11-28 22_39_07-logs - iobroker-iobroker1.png MeineConfig.txt
                                    K ArmilarA 2 Antworten Letzte Antwort
                                    • berlinchris81B berlinchris81
                                      Kuckuckmann
                                      #930
                                      @berlinchris81
                                      Hallo und willkommen hier im Forum :-)
                                      Du hast in deiner Config eine cardEntities die keinen Inhalt hat, insofern kann auch nichts angezeigt werden.
                                      Da auch dadurch keine Icons definiert sind, kommt es zu Fehlermeldungen. Heißt aber auch im Umkehrschluss, Du hast schon ganz viel richtig gemacht, von Flashen bis hin zu MQTT und so.
                                      Schau dir doch mal im Wiki an, wie man so eine Seite mit einem Alias und Icons, etc. bestückt.
                                      Wenn Du nicht weiter kommt, gerne nochmal melden.
                                      LG
                                      NSPanel Dokumentation im GitHub Wiki:
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #931
                                        @berlinchris81
                                        Irgendwie wird das global-Script des IconsSelector nicht geladen. Das wird auch der Grund sein, warum du aus dem "Waiting for Content" nicht raus kommst. Das TypeScript kompiliert nicht.
                                        Mache jetzt Schluss für heute. Ab wann bist du morgen wieder verfügbar? Dann gehen wir es mal zusammen durch und bringen es zum Laufen...
                                        Wenn du aus dem Log postest, dann kannst du die Code-Tags 7f6d0fc8-6d7b-4a38-8068-13f5dfecef64-image.png oben in der Menüleiste benutzen. Wird dann für uns einfacher es zu lesen.
                                        Wäre noch Interessant zu wissen, welche node.js-Version und welche JS-Adapter-Version du aktuell nutzt.
                                        Nach welcher Anleitung bist du vorgegangen?
                                        Falls die:
                                        https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---Basisinstallation
                                        dann hast du die richtige.
                                        Ab Punkt 8 wird das IconScript beschrieben. Es muss im "global"-Verzeichnis liegen. Unter github liegen zwei. Ein IconScript für TypeScript (muss als TypeScript angelegt sein) oder alternativ ein IconScript für JS (muss dann als JavaScript angelegt sein, es wurde für eine fehlerbehaftete Version des JS-Adapters abgelegt). Könntest sonst mal beide Varianten versuchen.
                                        Auf der anderen Seite, möchte der Kompiler eine Version aus dem Speicher benutzen. Sagt mir an erster Stelle mal, dass es schon mal funktioniert hat. Stimmt das?
                                        berlinchris81B 1 Antwort Letzte Antwort
                                        • ArmilarA Armilar
                                          @berlinchris81
                                          Falls die:
                                          berlinchris81
                                          schrieb am zuletzt editiert von berlinchris81
                                          #932
                                          @armilar
                                          Der Tipp mit der icons Datei hat funktioniert - er ist aus dem scenn raus. Danke schön. Jetzt kann ich weiter probieren. Toll. Aller Dings nur mit der Notlösung ... JS Script und ich habe jetzt neue Warnungen drin, die sind zwar "nur" Warungen aber vielleicht interessierts euch.
                                          JS Adapter: v6.14
                                          Node JS weiß ich nicht läuft in nem Docker container.
                                          Ich muss jetzt erstmal Arbeiten - melde mich dann.
