  4. Test Adapter vis 2.0 (Alpha)
    6.6k
780 Beiträge 108 Kommentatoren 350.7k Aufrufe 140 Beobachtet
  • ChaotC Chaot
    Die Widgets von vis-inventwo funktionieren gar nicht. Eine Seite die vile dieser Widgets enthält produziert beim Öffnen im Editor eine weiße Seite.
    Links hört der Scrollbalken auf obwohl da noch zwei Gruppen kommen sollten:
    Zusätzlich diese Fehlermeldungen:
    ws.0
    2022-11-26 23:26:49.029	error	10 - at Function.renderTo (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
    ws.0
    2022-11-26 23:26:49.028	error	9 - at r (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
    ws.0
    2022-11-26 23:26:49.026	error	8 - at Function.frag (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
    ws.0
    2022-11-26 23:26:49.025	error	7 - at Function.hookup (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
    ws.0
    2022-11-26 23:26:49.024	error	6 - at a.each (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:343:211)
    ws.0
    2022-11-26 23:26:49.022	error	5 - at HTMLSpanElement.<anonymous> (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
    ws.0
    2022-11-26 23:26:49.021	error	4 - at Object.eval (i-vis-multi.js:22:87)
    ws.0
    2022-11-26 23:26:49.019	error	3 - at Object.universalButton2 (http://192.168.8.50:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
    ws.0
    2022-11-26 23:26:49.018	error	2 - at createWidget (http://192.168.8.50:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
    ws.0
    2022-11-26 23:26:49.012	error	1 - at Object.getImgColorFilter (http://192.168.8.50:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5757:17)
    ws.0
    2022-11-26 23:26:49.011	error	0 - TypeError: Cannot read properties of undefined (reading 'toLowerCase')TypeError: Cannot read properties of undefined (reading 'toLowerCase')
    ws.0
    2022-11-26 23:26:49.010	error	can't render i-vis-multi w000036 on "DemoView":
    ws.0
    2022-11-26 23:26:49.009	error	10 - at Object.eval (tplFilterDropdown.js:42:10)
    ws.0
    2022-11-26 23:26:49.007	error	9 - at Function.txt (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
    ws.0
    2022-11-26 23:26:49.002	error	8 - at p.bind (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
    ws.0
    2022-11-26 23:26:49.000	error	7 - at i.bindAndSetup [as bind] (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:595:151)
    ws.0
    2022-11-26 23:26:48.996	error	6 - at t.Compute._bindsetup (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:853:22)
    ws.0
    2022-11-26 23:26:48.988	error	5 - at t.Compute.<anonymous> (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
    ws.0
    2022-11-26 23:26:48.985	error	4 - at t.Compute._on (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
    ws.0
    2022-11-26 23:26:48.980	error	3 - at t.getValueAndBind (http://192.168.8.50:8082/vis-2-beta/lib/js/can.custom.js:773:167)
    ws.0
    2022-11-26 23:26:48.976	error	2 - at Object.eval (tplFilterDropdown.js:47:21)
    ws.0
    2022-11-26 23:26:48.972	error	1 - at _ (http://192.168.8.50:8082/adapter/info/lib/js/commons.js:45:16)
    ws.0
    2022-11-26 23:26:48.970	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
    sigi234S Online
    sigi234S Online
    @chaot sagte in Test Adapter vis 2.0 (Alpha):
    Dito
    • sigi234S sigi234
      @apollon77 sagte in Test Adapter vis 2.0 (Alpha):
      Die neuen Widget-Pakete bzw. aktualisierte Widgets für Wetter installiert man bei Bedarf über:
      Die neuen Widgets tauchen bei mir nicht auf (bei Palette). Wurden installiert, update gemacht unter Adapter sind sie aber da.
      Unter Instanzen haben sie aber ein Zeit Icon?
      web.0
      2022-11-27 08:29:26.626	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.626	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.625	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.625	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.626	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.625	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.624	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.624	error	can't render i-vis-universal w00005_Home on "Home":
      web.0
      2022-11-27 08:29:26.625	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.625	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.624	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.623	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.623	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.624	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.624	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.623	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.622	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.622	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.623	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.623	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.622	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.621	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.621	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.621	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.622	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.622	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.620	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.620	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.621	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.621	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.621	error	can't render i-vis-universal w01089_Home on "Home":
      web.0
      2022-11-27 08:29:26.620	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.619	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.619	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.620	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.618	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.618	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.618	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.619	error	can't render i-vis-universal w01704_Home on "Home":
      web.0
      2022-11-27 08:29:26.619	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.617	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.617	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.617	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.618	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.618	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.616	error	can't render i-vis-universal w00007_Home on "Home":
      web.0
      2022-11-27 08:29:26.616	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.617	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.617	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.616	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.615	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.615	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.616	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.614	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.614	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.615	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.615	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.613	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.613	error	10 - at tt.componentDidMount (http://localhost:8082/vis-2-beta/static/js/184.cd8fa31f.chunk.js:16:50255)
      web.0
      2022-11-27 08:29:26.614	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.612	error	9 - at tt.renderWidget (http://localhost:8082/vis-2-beta/static/js/184.cd8fa31f.chunk.js:16:66606)
      web.0
      2022-11-27 08:29:26.612	error	7 - at Function.renderAs (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1465:39)
      web.0
      2022-11-27 08:29:26.612	error	5 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:29)
      web.0
      2022-11-27 08:29:26.613	error	can't render i-vis-universal w01085_Home on "Home":
      web.0
      2022-11-27 08:29:26.611	error	4 - at t.template.fn (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:2223:26)
      web.0
      2022-11-27 08:29:26.611	error	2 - at Object.eval (tplTwSimpleDate.js:3:28)
      web.0
      2022-11-27 08:29:26.612	error	6 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.612	error	8 - at e.view.e.template (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1401:47)
      web.0
      2022-11-27 08:29:26.610	error	1 - at Object.startDate (<anonymous>:289:21)
      web.0
      2022-11-27 08:29:26.610	error	can't render tplTwSimpleDate w00193_Home on "Home":
      web.0
      2022-11-27 08:29:26.611	error	3 - at n.render (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:2229:46)
      web.0
      2022-11-27 08:29:26.609	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.610	error	0 - ReferenceError: _setTimeout is not definedReferenceError: _setTimeout is not defined
      web.0
      2022-11-27 08:29:26.609	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.608	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.608	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.607	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.608	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.606	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.607	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.606	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4661:31)
      web.0
      2022-11-27 08:29:26.604	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.604	error	can't render i-vis-universal w01091_Home on "Home":
      web.0
      2022-11-27 08:29:26.604	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.603	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.604	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.603	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.602	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.602	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.603	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.601	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.601	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.602	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.602	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.600	error	can't render i-vis-universal w02247 on "Home":
      web.0
      2022-11-27 08:29:26.601	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.599	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.598	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.598	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.597	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.597	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.596	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.597	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.596	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.596	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.595	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.594	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.594	error	can't render i-vis-universal w00281 on "Home":
      web.0
      2022-11-27 08:29:26.592	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.591	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.592	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.590	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.590	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.589	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.588	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.589	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.588	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.587	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.586	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.586	error	can't render i-vis-universal w01561 on "Home":
      web.0
      2022-11-27 08:29:26.584	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.583	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.584	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.582	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.582	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.581	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.580	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.581	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.579	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.578	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.578	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.577	error	can't render i-vis-universal w00020 on "Home":
      web.0
      2022-11-27 08:29:26.576	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.575	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.574	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.575	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.573	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.573	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.572	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.571	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.570	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.571	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.570	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.569	error	can't render i-vis-universal w01349 on "Home":
      web.0
      2022-11-27 08:29:26.568	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.567	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.567	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      web.0
      2022-11-27 08:29:26.566	error	7 - at Function.hookup (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1418:19)
      web.0
      2022-11-27 08:29:26.565	error	6 - at a.each (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:343:211)
      web.0
      2022-11-27 08:29:26.564	error	5 - at HTMLSpanElement.<anonymous> (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1419:98)
      web.0
      2022-11-27 08:29:26.563	error	4 - at Object.eval (i-vis-universal.js:22:87)
      web.0
      2022-11-27 08:29:26.562	error	3 - at Object.universalButton2 (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4258:3)
      web.0
      2022-11-27 08:29:26.562	error	2 - at createWidget (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:4739:30)
      web.0
      2022-11-27 08:29:26.561	error	1 - at Object.getImgColorFilter (http://localhost:8082/vis-2-beta/widgets/vis-inventwo/js/vis-inventwo.js:5761:21)
      web.0
      2022-11-27 08:29:26.560	error	0 - TypeError: Cannot read properties of undefined (reading 'emit')TypeError: Cannot read properties of undefined (reading 'emit')
      web.0
      2022-11-27 08:29:26.560	error	can't render i-vis-universal w00788 on "Home":
      web.0
      2022-11-27 08:29:26.555	error	10 - at Function.renderTo (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
      web.0
      2022-11-27 08:29:26.555	error	9 - at r (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1370:22)
      web.0
      2022-11-27 08:29:26.554	error	8 - at Function.frag (http://localhost:8082/vis-2-beta/lib/js/can.custom.js:1405:22)
      Version 2.0.6
      @sigi234 für das zeit icon brauchen die noch ein github issue ;-). Hat aber keine Auswirkung. Versuch nochmal ein Vis-2-Beta restart bitte. Sonst muss bluefox schauen.
      sigi234S D 4 Antworten Letzte Antwort
      • apollon77A apollon77
        sigi234S Online
        sigi234S Online
        Erledigt.
        https://github.com/ioBroker/ioBroker.vis/issues/566
          sigi234S Online
          sigi234S Online
          Leider nein.
            @marty56 echarts dabei und up to date? Flot? Was steht im Browser log?
            Marty56
            Ich benutze eCharts überhaupt nicht mehr und habe den Adapter deinstalliert. Vermutlich ist in der alten VIS DB noch irgendeine Datenleiche, die durch die Migration zum Leben erweckt wird.
            Im Browser Log steht nur eine Zeile.
            HW:NUC (16 GB Ram)
            OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
            • liv-in-skyL liv-in-sky
              @amg_666 Klick mal auf das + neben dem Namen deines ersten views der angezeigt wird - oder auf „Seiten verwalten“. Dann bekommst du alle views angezeigt.
              Warum zumachen anstatt schließen? Weil irgendwie die Übersetzung blöd ist ;-) ich glaub gibts schon als github issue das zu ändern.
              da passiert bei mir leider nix ! weder seite verwalten - noch das plus zeigt irgendwelche reaktionen
              amg_666A Offline
              amg_666A Offline
              amg_666
              @liv-in-sky sagte in Test Adapter vis 2.0 (Alpha):
              Bei mir genauso, nix passiert :-(
              -1
                denjo
                @apollon77 bei mir klappt das importieren immer noch nicht und dann schwarzer bildschirm
                web.0
                2022-11-27 12:58:40.000	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
                web.0
                2022-11-27 12:58:39.998	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
                web.0
                2022-11-27 12:58:39.997	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
                web.0
                2022-11-27 12:58:39.995	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
                web.0
                2022-11-27 12:58:39.982	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
                web.0
                2022-11-27 12:58:39.981	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
                web.0
                2022-11-27 12:58:39.979	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
                web.0
                2022-11-27 12:58:39.978	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
                web.0
                2022-11-27 12:58:39.976	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
                web.0
                2022-11-27 12:58:39.975	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
                web.0
                2022-11-27 12:58:39.974	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
                web.0
                2022-11-27 12:58:39.972	error	can't render tplMfdShutterDialog w00022 on "Tabs":
                web.0
                2022-11-27 12:58:39.961	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
                web.0
                2022-11-27 12:58:39.960	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
                web.0
                2022-11-27 12:58:39.959	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
                web.0
                2022-11-27 12:58:39.958	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
                web.0
                2022-11-27 12:58:39.957	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
                web.0
                2022-11-27 12:58:39.955	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
                web.0
                2022-11-27 12:58:39.953	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
                web.0
                2022-11-27 12:58:39.950	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
                web.0
                2022-11-27 12:58:39.949	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
                web.0
                2022-11-27 12:58:39.947	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
                web.0
                2022-11-27 12:58:39.945	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
                web.0
                2022-11-27 12:58:39.944	error	can't render tplMfdShutterDialog w00020 on "Tabs":
                web.0
                2022-11-27 12:58:39.940	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
                web.0
                2022-11-27 12:58:39.939	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
                web.0
                2022-11-27 12:58:39.938	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
                web.0
                2022-11-27 12:58:39.936	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
                web.0
                2022-11-27 12:58:39.934	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
                web.0
                2022-11-27 12:58:39.933	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
                web.0
                2022-11-27 12:58:39.932	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
                web.0
                2022-11-27 12:58:39.931	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
                web.0
                2022-11-27 12:58:39.929	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
                web.0
                2022-11-27 12:58:39.928	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
                web.0
                2022-11-27 12:58:39.927	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
                web.0
                2022-11-27 12:58:39.926	error	can't render tplMfdShutterDialog w00018 on "Tabs":
                web.0
                2022-11-27 12:58:39.924	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
                web.0
                2022-11-27 12:58:39.923	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
                web.0
                2022-11-27 12:58:39.921	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
                web.0
                2022-11-27 12:58:39.920	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
                web.0
                2022-11-27 12:58:39.919	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:850:27)
                web.0
                2022-11-27 12:58:39.917	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
                web.0
                2022-11-27 12:58:39.912	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
                web.0
                2022-11-27 12:58:39.894	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
                web.0
                2022-11-27 12:58:39.893	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
                web.0
                2022-11-27 12:58:39.891	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
                web.0
                2022-11-27 12:58:39.889	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
                web.0
                2022-11-27 12:58:39.888	error	can't render tplMfdShutterDialog w00017 on "Tabs":
                web.0
                2022-11-27 12:58:39.884	error	10 - at Object.eval (tplMfdShutterDialog.js:286:10)
                web.0
                2022-11-27 12:58:39.858	error	9 - at Function.txt (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2194:47)
                web.0
                2022-11-27 12:58:39.857	error	8 - at p.bind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1350:19)
                web.0
                2022-11-27 12:58:39.854	error	7 - at i.bindAndSetup [as bind] (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:595:151)
                web.0
                2022-11-27 12:58:39.852	error	6 - at t.Compute._bindsetup (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:853:22)
                web.0
                2022-11-27 12:58:39.851	error	5 - at t.Compute.<anonymous> (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1285:35)
                web.0
                2022-11-27 12:58:39.847	error	4 - at t.Compute._on (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1315:19)
                web.0
                2022-11-27 12:58:39.834	error	3 - at t.getValueAndBind (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:773:167)
                web.0
                2022-11-27 12:58:39.833	error	2 - at Object.eval (tplMfdShutterDialog.js:291:21)
                web.0
                2022-11-27 12:58:39.831	error	1 - at _ (http://192.168.178.98:8082/adapter/info/lib/js/commons.js:45:16)
                web.0
                2022-11-27 12:58:39.829	error	0 - ReferenceError: translateWord is not definedReferenceError: translateWord is not defined
                web.0
                2022-11-27 12:58:39.827	error	can't render tplMfdShutterDialog w00015 on "Tabs":
                web.0
                2022-11-27 12:58:39.823	error	10 - at Qe.componentDidMount (http://192.168.178.98:8082/vis-2-beta/static/js/363.1c471ab3.chunk.js:16:51349)
                web.0
                2022-11-27 12:58:39.821	error	9 - at Qe.renderWidget (http://192.168.178.98:8082/vis-2-beta/static/js/363.1c471ab3.chunk.js:16:67700)
                web.0
                2022-11-27 12:58:39.818	error	8 - at e.view.e.template (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1401:47)
                web.0
                2022-11-27 12:58:39.816	error	7 - at Function.renderAs (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1465:39)
                web.0
                2022-11-27 12:58:39.813	error	6 - at Function.renderTo (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1449:63)
                web.0
                2022-11-27 12:58:39.812	error	5 - at r (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:1370:29)
                web.0
                2022-11-27 12:58:39.810	error	4 - at t.template.fn (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2223:26)
                web.0
                2022-11-27 12:58:39.808	error	3 - at n.render (http://192.168.178.98:8082/vis-2-beta/lib/js/can.custom.js:2229:46)
                web.0
                2022-11-27 12:58:39.806	error	2 - at Object.eval (tplTwSimpleClock.js:3:34)
                web.0
                2022-11-27 12:58:39.805	error	1 - at Object.startTime (<anonymous>:170:17)
                web.0
                2022-11-27 12:58:39.803	error	0 - ReferenceError: _setTimeout is not definedReferenceError: _setTimeout is not defined
                web.0
                2022-11-27 12:58:39.801	error	can't render tplTwSimpleClock w00009 on "Tabs":
                web.0
                2022-11-27 12:58:35.045	error	Cannot find search "chart" in "system"
                web.0
                2022-11-27 12:58:27.525	error	Cannot find search "chart" in "system"
                web.0
                2022-11-27 12:57:44.959	error	Cannot find search "chart" in "system"
                • amg_666A amg_666
                  FeuersturmF Offline
                  FeuersturmF Offline
                  Feuersturm
                  @amg_666 ist ja auch erst in der 2.0.8 gefixt die noch nicht auf npm liegt.
                  • FeuersturmF Offline
                    FeuersturmF Offline
                    Feuersturm
                    @sigi234 sagte in Test Adapter vis 2.0 (Alpha):
                    Ist bei mir mit vis-2-beta v2.0.7 auch so. Legst du ein issue an?
                    • G Offline
                      GiB64
                      schrieb am zuletzt editiert von GiB64
                      ich habe beim installieren irgendwas von Info: www not found gesehen, da es Info war, ignoriert. Wenn ich Vis starte kann ich irgendwie keine Widgets und Co aufrufen. Irgenwie scheinen Icons zu fehlen und nach klicken passiert auch nichts...
                      VG GiB
                      edit: es sieht irgendwie komisch aus und mit den Icons ist auch nicht viel nazufangen. Sehen alle 3 auch gleich aus in den Eigenschaften... Wie kann ich die Installation am besten wiederholen bzw. reparieren?
                        denjo
                        @apollon77 so ich habe den fehler gefunden warum ich immer ein schwarzen bildschirm bekomme wenn ich es importiere.
                        ich habe mehrere widgets gruppiert, zu einem.
                        wenn ich die gruppierung aufhebe klappt auch alles, man darf es nicht gruppiert exportieren und dann importieren.
                        ChaotC apollon77A joergeliJ 3 Antworten Letzte Antwort
                        • D denjo
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          @denjo Autsch! Dann wird das bei mir auch so sein. Ich habe fast überall mit Gruppen gearbeitet.
                          • ChaotC Chaot
                            denjo
                            @chaot ja ich auch viel, und guck gerade was ich alles gruppiert habe aber finde nicht alles :D
                              FeuersturmF Offline
                              Feuersturm
                              Hmm, ich habe bei mir auch einige Elemente gruppiert und keine Probleme beim Import gehabt. Ergänze aber mal deine Infos beim issue das bluefox sich das noch einmal näher ansehen kann.
                              • FeuersturmF Feuersturm
                                denjo
                                @feuersturm ja hab ich schon gemacht. ich habe es bei mir mehrfach ausprobiert und es klappt nicht wenn es gruppiert ist
                                • D denjo
                                  ChaotC Offline
                                  ChaotC Offline
                                  Chaot
                                  @denjo Ich habe auch sehr viel mit den vis-inventwo Widgets gearbeitet. Dort werden die Widgets allesamt fehlerhaft übernommen. Alle eingebauten Bindings sind weg usw.
                                  Sieht in dem Fall nach einem kompletten Neubau aus.
                                  @apollon77 Wie im Eröffnungstread beschrieben soll VIS2 einfacher und leichter werden. Den Eindruck habe ich ehrlich gesagt nicht so. Es wirkt eher komplizierter und überladener. Mal schauen wie das wirkt wenn ich mal versuchen werde eine komplette View neu zu erstellen.
                                  Was ich allerdings jetzt schon vermisse ist ein deutlich sichtbarer Knopf zum zwischenspeichern.
                                  Ich habe auch das Konzept noch nicht so ganz verstanden. Meine Projekte sind jeweils Views mit einer Navigationsstruktur. Hier scheinen die Projekte immer die Einzelseiten zu sein oder verstehe ich das falsch?
                                  In dem Fall kann bei mir der Import kaum klappen. Ich habe innerhalb der Projekte alle einzelnen Views mit dem gleichen Namen angelegt. Also die Startseite heißt immer "Info", hat aber unterschiedliche Inhalte, je nach Gerät.
                                  D apollon77A 2 Antworten Letzte Antwort
                                  • ChaotC Chaot
                                    denjo
                                    @chaot ja sehe ich fast genau so wie du.
                                    ich finde es bis jetzt auch komplizierter aber wollen wir mal abwarten.
                                    für mich kommt ein ganz neuer aufbau nicht wirklich in frage.
                                    seid dem ich iobroker habe baue ich meine vis immer hin und her und das war nun mal jahre lange arbeit.
                                    entweder der import klappt reibungsfrei oder dann eben nicht.
                                    aber wie gesagt mal abwarten.
                                    • G GiB64
                                      VG GiB
                                      @gib64 www nor found wäre ok
                                      • D denjo
                                        @denjo bitte auf github melden als issue
                                          denjo
                                          @apollon77 hab ich in mein issus hinzugefügt
