  3. Entwicklung
  4. (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?
    6.5k
herdsmanzigbee
129 Beiträge 13 Kommentatoren 31.7k Aufrufe 12 Beobachtet
  • D Diamand2k22
    @patrick-kenzler
    kopiere das file nach
    /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/
    und mach den Eintrag bei externe Adapter raus.
    Dann Zigbee Adapter neu starten.
    Patrick Kenzler
    @diamand2k22 habs probiert er schmeißt immernoch Fehler :-/ hast du noch eine Idee?
    2022-11-22 23:28:11.087	error	instance system.adapter.zigbee.2 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2022-11-22 23:28:11.087	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1105:14)
    2022-11-22 23:28:11.087	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman-converters/index.js:118:30)
    2022-11-22 23:28:11.086	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:102:18)
    2022-11-22 23:28:11.086	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1005:19)
    2022-11-22 23:28:11.086	error	Caught by controller[0]: at Function.Module._load (node:internal/modules/cjs/loader:822:12)
    2022-11-22 23:28:11.085	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:981:32)
    2022-11-22 23:28:11.085	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1159:10)
    2022-11-22 23:28:11.084	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1069:27)
    2022-11-22 23:28:11.084	error	Caught by controller[0]: at wrapSafe (node:internal/modules/cjs/loader:1033:15)
    2022-11-22 23:28:11.083	error	Caught by controller[0]: at Object.compileFunction (node:vm:352:18)
    2022-11-22 23:28:11.083	error	Caught by controller[0]: SyntaxError: Unexpected identifier
    2022-11-22 23:28:11.083	error	Caught by controller[0]: ^^^^^^^^
    2022-11-22 23:28:11.083	error	Caught by controller[0]: konstantes Ergebnis = {};
    2022-11-22 23:28:11.082	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman-converters/devices/06b9e9de-716c-4a03-95a1-94f34a45ccf6-avatto_me167.js:36
    P 1 Antwort Letzte Antwort
    • P Patrick Kenzler
      Patrick Kenzler
      #66
      Habs in den Griff bekommen, neu installiert, Konverter in den Pfad verschoben - Adapter läuft aber erkennt jetzt das Thermostat nicht -.-
      2022-11-23 07:58:07.595 – Fehler : zigbee.2 (1887) Gerät 0x84ba20fffee088ee „TS0601“ nicht beschrieben in statesMapping.
      • P Patrick Kenzler
        #67
        Ich hab übrigens gesehen, dass in der aktuellen Alpha-Version vom GitHub die herdsman-Module angepackt wurden.
        P M 2 Antworten Letzte Antwort
          Patrick Kenzler
          #68
          @thomas-braun okay dann spart es wahrscheinlich einfach Zeit und Nerven wenn ich abwarte und hoffe das das Thermostat aufgenommen wird? :-D
            mucke1985
            #69
            Hallo hab auch das selbe Problem das der Converter nicht richtig funktioniert ich verwende den converter von hier ->https://github.com/twhittock/avatto_me167 und hab diesen über die externen converter eingetragen, ansteuern kann ich die Thermostate aber die reinkommenden Datenpunkte werden nicht in die Objektdaten geschriben bin schon mehrere Tage auf der suche nach einer Lösung leider hab ich keine ahnung an was es liegen könnte.
            Kannst du mir ev. bei der fehlersuch helfen
            mfg Michael
            • Thomas BraunT Online
              #70
              @mucke1985 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
              Ich nicht.
                Ich nicht.
                mucke1985
                #71
                Ok
                • M mucke1985
                  Ok
                  Diamand2k22
                  #72
                  @mucke1985
                  ac9923ff-88a8-40b2-80a8-fdb4741ba2f0-avatto_me167.js
                  Hab's angepasst für dein ME167 Thermostat.
                  M P 2 Antworten Letzte Antwort
                  • D Diamand2k22
                    @mucke1985
                    mucke1985
                    schrieb am zuletzt editiert von mucke1985
                    #73
                    @diamand2k22
                    Hallo danke für deine Antwort das hab ich gemacht, hab mit nano unter devices eine datei erstellt (me167.js) und den verlinkten Inhalt rein kopiert.
                    Super Danke jetzt hats funktioniert !!!!!!!!!!!!!!!!!!!!!!!!
                    Würde gerne verstehen was jetzt anders ist das es funktioniert, liegts an dem umgang mit externenConvertern in IoBroker
                    oder wo lag das Problem an der me167.js datei die ich verwendet habe.
                    Wo muss ich die img/ME167.png reinkopieren.
                    Danke nochmal
                    • D Diamand2k22
                      @mucke1985
                      Patrick Kenzler
                      schrieb am zuletzt editiert von Patrick Kenzler
                      #74
                      @diamand2k22 jetzt funktioniert es, vielen Dank! Ich habe nen Node.js Update gemacht und anschließend das Thermostat nochmal neu angelernt :-)
                        Diamand2k22
                        #75
                        @Thomas-Braun
                        Hallo Thomas, ich bin's mal wieder :-D wieso bekomm ich jetzt den Fehler wenn ich den zigbee herdsmann adapter aus dem Github aktualisieren will?
                        Brauch das update aufgrund neuer device.js updates.
                        $ iobroker url ioBroker/ioBroker.zigbee --host pi4b --debug
                        install ioBroker/ioBroker.zigbee
                        NPM version: 8.19.2Installing ioBroker/ioBroker.zigbee... (System call)
                        npm ERR! code ENOTEMPTY
                        npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2022-11-24T21_59_38_118Z-debug-0.log
                        host.pi4b Cannot install ioBroker/ioBroker.zigbee: 217
                        ERROR: Process exited with code 25
                        • D Diamand2k22
                          @Thomas-Braun
                          #76
                          @diamand2k22
                          https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                            @diamand2k22
                            Diamand2k22
                            #77
                            danke, hat funktioniert, hab ich vorhin auch gerade zufällig gesehen!
                            for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                            R 1 Antwort Letzte Antwort
                            • D Diamand2k22
                              ReverZ
                              #78
                              Einen Datenpunkt für den Batteriestand für den Avatto me167 gibt ´s momentan nicht, oder?
                              Und muss man lediglich die ME167.png in die entsprechenden Ordner kopieren oder sind weitere Schritte nötig, um das passende Bild zu dem Gerät angezeigt zu bekommen?
                              • R ReverZ
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #79
                                @reverz ???????????????????????
                                  Diamand2k22
                                  #80
                                  @diamand2k22 said in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                  kann sein Thomas, hab ich aber wieder hingebogen bekommen.
                                  @Asgothian
                                  hab mir jetzt ne eigene ketotek.js für mein Heizkörperthermostat gebastelt.
                                  Jetzt funktioniert es wunderbar und ich hab keine Unrecognized DP's mehr und kann es steuern und empfange Temperaturen.
                                  Was mich nur interessieren würde, wie bekomme ich da ein vernünftiges Bild rein?
                                  Kannst du das Thermostat aufnehmen?
                                  @arteck
                                  Könnt ihr das Heizkörperthermostat bei zigbee2mqtt mit aufnehmen.
                                  Es handelt sich um Heizkörperthermostat der Firma Kenotek.
                                  • arteckA Offline
                                    arteckA Offline
                                    arteck
                                    #81
                                    @diamand2k22 sagte in (GELÖST) zigbee-herdsmann-converters / wie manuell updaten?:
                                    zigbee2mqtt
                                    dann musst du den issue auch da einstellen.. das macht iobroker nicht..anderes Projekt
                                    • arteckA arteck
                                      zigbee2mqtt
                                      Diamand2k22
                                      #82
                                      @Thomas-Braun
                                      Hallo Thomas,
                                      wie kann ich auf eine bestimmte zigbee-herdmann-converters Version zurück?
                                      z.B. wenn ich die Version zigbee-herdsman-converters@14.0.670 installiert habe und will auf z.b. die Version zigbee-herdsman-converters@14.0.667 zurück.
                                      Wenn ich über die Weltkugel gehe, installiert er logischerweise immer die aktuellste Version.
                                      • D Diamand2k22
                                        @Thomas-Braun
                                        Hallo Thomas,
                                        #83
                                        @diamand2k22
                                        Am besten garnicht. Das zerfleddert dir ggf. die Dependencies.
                                          @diamand2k22
                                          Diamand2k22
                                          #84
                                          dann hab ich mir jetzt wohl was weggeballert. zumindest komm jetzt nach dem update diese "not descriped in statesMapping"
                                          das hat allerdings schon mal funktioniert :-/
