  4. flot gibt Werte abweichend wieder
43 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    @mipl und die Konfiguration des charts?
    was ist das für eine Darstellung?
    so sieht flot bei mir nicht aus
    MiPl
    schrieb am zuletzt editiert von MiPl
    hier die Einstellung in Flot für die Tagesansicht
    http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1440&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
    und hier für die Monatsansicht:
    http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1m&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
    Du hast Recht, dass die Darstellung aus VIS kommt.
    HomoranH bahnuhrB 2 Antworten Letzte Antwort
    • M MiPl
      @mipl sagte in flot gibt Werte abweichend wieder:
      also weiter Einflüsse durch Browsercache, Rendering usw! :-(
      bitte immer alle relevanten Informationen von Anfang an mitliefern.
      diesmal wäre ein Screenshot besser. da wühl ich mich am Handy nicht durch den Bandwurm-URL
      also zwei verschiedene Einstellungen/flots?
      nicht nur das Zeitintervall geändert?
        MiPl
        hier zwei Screenshots aus Flot
        Tagesansicht und Monatsansicht. Ich habe nur die Zeit geändert und die Voransicht aktualisiert. Die Y-Achse (hier leider in weiß nur schwer zu sehen) ist unterschiedlich.
        Randnotiz: Die höhe der Kurven ändert sich auch, wenn man bei Aggregation die Werte ändert. Das habe ich jetzt aber nicht gemacht.
        • M MiPl
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          @mipl
          Dann leg doch, wie oben schon geschrieben einen Max wert fest. dann ist y immer gleich.
          Und so wird auch die im Verhältnis gleich aussehen.
          Danke.
          • bahnuhrB bahnuhr
            @mipl
            MiPl
            @bahnuhr
            klar, könnte ich machen. Aber im Wiki steht ja, dass die Anzeige dynamisch ist, wenn man keinen Wert eingibt. Und gerade bei unterschiedlichen Umgebungsbedingungen ist dies gerade gewünscht, damit man mit den Graphen noch was anfangen kann.
            • M MiPl
              das ist genau das was ich meinte mit
              @homoran sagte in flot gibt Werte abweichend wieder:
              @bahnuhr sagte in flot gibt Werte abweichend wieder:
              Das hört sich alles richtig an.
              eher nicht, aber... wenn....
              ich gehe mal davon aus, dass...
              die Zeitspanne auf 1 Monat
              auch die
              Zeitspanne 1 Tag
              enthält.
              aber,....
              und,.....
              kann man erst was zu sagen wenn man alles weiß
              das ist die Ursache, mit anderer Aggregation wird anders geglättet
              M 2 Antworten Letzte Antwort
                auch die
                Zeitspanne 1 Tag
                enthält.
                aber,....
                und,.....
                MiPl
                wie ich schrieb habe ich die Werte nicht geändert bei den beiden übermittelten Darstellungen. Sieht man ja auch auf den Screenshots.
                  auch die
                  Zeitspanne 1 Tag
                  enthält.
                  aber,....
                  und,.....
                  MiPl
                  geglättet kann ich ja verstehen, aber Maximum von ca. 150 W auf ca. 40 W verändert!?
                  • M MiPl
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @mipl
                    Ich hör jetzt hier auf; habe solche Probleme nicht.
                    Und ehrlich gesagt, ich versteh das Problem auch nicht.
                    Bei mir wird flot immer so angezeigt wie ich es gerne hätte.
                    Danke.
                    • M MiPl
                      ja, wenn nur kurze Peaks auf eine große Zeit geglättet werden fallen die hohen Werte weg.
                      beim Zoomen kommen sie wieder.
                      Also vorsichtig mit den Aggregationseinstellungen
                        MiPl
                        ich möchte ja nicht nerven, aber sieh mal hier:
                        Verändert sich irgendwie. Habe nichts gemacht, außer gewartet.
                        • M MiPl
                          klar, die Werte pro Zeiteinheit (Integral) ändern sich im Laufcder Kurvenerstellung und damit auch die der Aggregation zugrunde Liegende Datenbasis.
                          Jetzt ist der Peak vollständig und beteits eine längere Zeit "fertig"
                            MiPl
                            die Werte an der y-achse und auch die Kurven selbst ändern sich:
                            zuerst:
                            nach einer Wartezeit:
                            Ist das vielleicht Berechnungszeit, die benötigt wird?
                            • M MiPl
                              zuerst:
                              ich kann das sehr schlecht sehen. ostfriesische Kriegsflagge mit weißem Adler auf weißem Grund ist besser zu erkennen
                                MiPl
                                ok, hier nochmal mit schwarzer Schrift:
                                Monatsansicht direkt nach Aktualisierung der Ansicht in Flot:
                                und hier nochmal nach Wartezeit:
                                Aber es handelt sich ja um die Monatsansicht = mehr Daten = längere Berechnung? Bei Tagesansicht geht daher vielleicht schneller? Ich werde es mal mit einem noch längeren Zeitraumm testen und die Zeit messen.
                                • M MiPl
                                  eher nicht. Muss mit der Aggregation zu tun haben.
                                  du hast nur 300 Datenpunkte, stell die mal höher.
                                  oder nur schwaches Frontend? schlechte Datenübertragung?
                                    MiPl
                                    hier mit Anzahl = 1000
                                    mit Anzahl = 2000
                                    Die Ausschläge steigen, sind aber nicht bei dem eigentlichen Wert.
                                    Und mit Wartezeit:
                                    Was meinst Du mit schwachem Frontend? Der Pi3?
                                    • M MiPl
                                      mit Anzahl = 2000
                                      Und mit Wartezeit:
                                      der sollte nur das Backend sein (hoffentlich)
                                      Das Tablet auf dem du es darstellst muss das rechnen.
                                        MiPl
                                        Das ist ein
                                        • M MiPl
                                          Das ist ein
                                          @mipl der sollte das schaffen.
                                          was hast du denn bei der Datenreihe ein gegeben?
                                          minmax? bei Änderung?
