  4. flot gibt Werte abweichend wieder
43 Beiträge 4 Kommentatoren 3.9k Aufrufe 2 Beobachtet
    @mipl sagte in flot gibt Werte abweichend wieder:
    Ich könnte einen Screenshot bereitstellen, weiß aber nicht, wie es in diesem Forum geht.
    1. icon von rechts
    MiPl
    • M MiPl
      @mipl und die Konfiguration des charts?
      was ist das für eine Darstellung?
      so sieht flot bei mir nicht aus
        MiPl
        schrieb am zuletzt editiert von MiPl
        hier die Einstellung in Flot für die Tagesansicht
        http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1440&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
        und hier für die Monatsansicht:
        http://192.168.1.50:8083/flot/index.html?l%5B0%5D%5Bid%5D=modbus.0.holdingRegisters.226.789_PV_power&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23fff300&l%5B0%5D%5Bmin%5D=0&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=W&l%5B0%5D%5Bname%5D=Solarleistung+W&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5BignoreNull%5D=false&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5Bsmoothing%5D=20&l%5B0%5D%5Binstance%5D=sql.0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B1%5D%5Bid%5D=modbus.0.holdingRegisters.100.843_Battery_State_of_Charge_(System)&l%5B1%5D%5Binstance%5D=sql.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%230600ff&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bthickness%5D=3&l%5B1%5D%5Bshadowsize%5D=3&l%5B1%5D%5Bunit%5D=%25&l%5B1%5D%5Bname%5D=Batterieladezustand+SOC&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5BafterComma%5D=1&l%5B1%5D%5Bdashes%5D=false&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5Bsmoothing%5D=20&l%5B1%5D%5Byaxe%5D=left&l%5B1%5D%5Bxaxe%5D=off&timeType=relative&relativeEnd=now&range=1m&aggregateType=count&aggregateSpan=300&title=Solareinstrahlung+Tag&titlePos=top%3A35%3Bleft%3A50&titleColor=%23ffffff&titleSize=10&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=300&legend=sw&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m.&noBorder=noborder&x_labels_color=%23ffffff&y_labels_color=%23ffffff&border_color=%23ffffff
        Du hast Recht, dass die Darstellung aus VIS kommt.
        HomoranH bahnuhrB 2 Antworten Letzte Antwort
        • M MiPl
          also weiter Einflüsse durch Browsercache, Rendering usw! :-(
          bitte immer alle relevanten Informationen von Anfang an mitliefern.
          diesmal wäre ein Screenshot besser. da wühl ich mich am Handy nicht durch den Bandwurm-URL
          also zwei verschiedene Einstellungen/flots?
          nicht nur das Zeitintervall geändert?
            MiPl
            hier zwei Screenshots aus Flot
            Tagesansicht und Monatsansicht. Ich habe nur die Zeit geändert und die Voransicht aktualisiert. Die Y-Achse (hier leider in weiß nur schwer zu sehen) ist unterschiedlich.
            Randnotiz: Die höhe der Kurven ändert sich auch, wenn man bei Aggregation die Werte ändert. Das habe ich jetzt aber nicht gemacht.
            • M MiPl
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              @mipl
              Dann leg doch, wie oben schon geschrieben einen Max wert fest. dann ist y immer gleich.
              Und so wird auch die im Verhältnis gleich aussehen.
              Danke.
              • bahnuhrB bahnuhr
                @mipl
                MiPl
                @bahnuhr
                klar, könnte ich machen. Aber im Wiki steht ja, dass die Anzeige dynamisch ist, wenn man keinen Wert eingibt. Und gerade bei unterschiedlichen Umgebungsbedingungen ist dies gerade gewünscht, damit man mit den Graphen noch was anfangen kann.
                • M MiPl
                  das ist genau das was ich meinte mit
                  @homoran sagte in flot gibt Werte abweichend wieder:
                  @bahnuhr sagte in flot gibt Werte abweichend wieder:
                  Das hört sich alles richtig an.
                  eher nicht, aber... wenn....
                  ich gehe mal davon aus, dass...
                  die Zeitspanne auf 1 Monat
                  auch die
                  Zeitspanne 1 Tag
                  enthält.
                  aber,....
                  und,.....
                  kann man erst was zu sagen wenn man alles weiß
                  das ist die Ursache, mit anderer Aggregation wird anders geglättet
                  M 2 Antworten Letzte Antwort
                    auch die
                    Zeitspanne 1 Tag
                    enthält.
                    aber,....
                    und,.....
                    MiPl
                    wie ich schrieb habe ich die Werte nicht geändert bei den beiden übermittelten Darstellungen. Sieht man ja auch auf den Screenshots.
                      auch die
                      Zeitspanne 1 Tag
                      enthält.
                      aber,....
                      und,.....
                      MiPl
                      geglättet kann ich ja verstehen, aber Maximum von ca. 150 W auf ca. 40 W verändert!?
                      • M MiPl
                        bahnuhrB Online
                        bahnuhrB Online
                        bahnuhr
                        @mipl
                        Ich hör jetzt hier auf; habe solche Probleme nicht.
                        Und ehrlich gesagt, ich versteh das Problem auch nicht.
                        Bei mir wird flot immer so angezeigt wie ich es gerne hätte.
                        Danke.
                        • M MiPl
                          ja, wenn nur kurze Peaks auf eine große Zeit geglättet werden fallen die hohen Werte weg.
                          beim Zoomen kommen sie wieder.
                          Also vorsichtig mit den Aggregationseinstellungen
                            MiPl
                            ich möchte ja nicht nerven, aber sieh mal hier:
                            Verändert sich irgendwie. Habe nichts gemacht, außer gewartet.
                            • M MiPl
                              klar, die Werte pro Zeiteinheit (Integral) ändern sich im Laufcder Kurvenerstellung und damit auch die der Aggregation zugrunde Liegende Datenbasis.
                              Jetzt ist der Peak vollständig und beteits eine längere Zeit "fertig"
                                MiPl
                                die Werte an der y-achse und auch die Kurven selbst ändern sich:
                                zuerst:
                                nach einer Wartezeit:
                                Ist das vielleicht Berechnungszeit, die benötigt wird?
                                • M MiPl
                                  zuerst:
                                  ich kann das sehr schlecht sehen. ostfriesische Kriegsflagge mit weißem Adler auf weißem Grund ist besser zu erkennen
                                    MiPl
                                    ok, hier nochmal mit schwarzer Schrift:
                                    Monatsansicht direkt nach Aktualisierung der Ansicht in Flot:
                                    und hier nochmal nach Wartezeit:
                                    Aber es handelt sich ja um die Monatsansicht = mehr Daten = längere Berechnung? Bei Tagesansicht geht daher vielleicht schneller? Ich werde es mal mit einem noch längeren Zeitraumm testen und die Zeit messen.
                                    • M MiPl
                                      eher nicht. Muss mit der Aggregation zu tun haben.
                                      du hast nur 300 Datenpunkte, stell die mal höher.
                                      oder nur schwaches Frontend? schlechte Datenübertragung?
                                        MiPl
                                        hier mit Anzahl = 1000
                                        mit Anzahl = 2000
                                        Die Ausschläge steigen, sind aber nicht bei dem eigentlichen Wert.
                                        Und mit Wartezeit:
                                        Was meinst Du mit schwachem Frontend? Der Pi3?
                                        • M MiPl
                                          mit Anzahl = 2000
                                          Und mit Wartezeit:
                                          der sollte nur das Backend sein (hoffentlich)
                                          Das Tablet auf dem du es darstellst muss das rechnen.
